R-12 Air conditioning refrigerant
7 replies to this topic
#1 OFFLINE   boss351
boss351
  • 82 posts
  • Joined 10-May 06
Posted 25 May 2006 - 07:35 PM
Well the old 88 5.0 GT needs the air conditioner fixed.  It is not blowing out ice cold air.  What would be the best way to remedy this? :shrug:  :sos:
#2 OFFLINE   Evil95GT
Evil95GT
    Come on, Rob......just ban me already
  • 1,336 posts
  • Joined 24-September 05
Posted 25 May 2006 - 07:42 PM
I could be wrong, but I *thought* R-12 was phased out. I believe the only way to recharge the a/c is to get the R134 retrofit. I know stores like PepBoys and Autozone sell kits to do this yourself, but I've never tried it.
Michelle
1989 Mustang LX
1995 Mustang GT
Jealous of what? I'm ideal, and I don't need a bunch of leghumpers to confirm what I already know. Love it.
Use email.......PMs are NOT private anymore
#3 OFFLINE   ford4v429
ford4v429
    Old Ford Fan
  • 207 posts
  • Joined 28-September 05
Posted 27 May 2006 - 10:46 AM
I put the 134 in my lincoln mark VII and my 85 camaro- worked pretty well, but not as cold as the R12 was...with the cost of no longer produced R12, there really aint much of a choice- its all gonna leak out sooner or later. My Mark had a leak at the compressor, but the 134 'sealing oil' seemed to stop it- have to add a pound every couple years...the R12 cost me 100 bucks the one time I had it serviced(1995?) and I think 134 costs about 5 bucks a pound...the kit with thread adapters/oil costs 25-30...
2006 Vista blue Mustang GT stick (13.78 @ 103 and 25 mpg bone stock)
2007 Vista blue Pony/Auto (wifes)
2009 Vista blue Mustang GT stick(stored with 3 miles on it)
1969 Acapulco blue Fastback
1965 Caspian blue 4dr hdtp Galaxie500 LTD (gift from old friend/neighbor)
#4 OFFLINE   TwinTurboBoss
TwinTurboBoss
  • 708 posts
  • Joined 05-May 06
Posted 01 June 2006 - 12:09 AM
Edited by TwinTurboBoss, 03 July 2006 - 10:11 PM.
#5 OFFLINE   68fastback
68fastback
    Need DOHC alloy big-block!
  • 12,091 posts
  • Joined 04-May 06
Posted 13 June 2006 - 05:22 PM
I had my wife's Taurus ('93) converted last year.  The old 112 was going for $38/lb so would have cost about $90 just for the refrigerant.  The 134 only cost at $15 in total.  But you can't just change the fittings and refill with 134.  The 112 will contaminate it and it will not get/stay cold.  We're in a rural area and I asked around with mechanics and found most don't have the right equipment to properly convert and purge the system after the fittings conversion.  I wound up using a taxi company that has been running Crown Vics for ages and was really on top of making sure the A/Cs work right.  For $100 they installed the conversion kit, purged the system for nearly and hour and 20 minutes (that's how long it took for the automated purge and test equipment to fully evaporate the traces of remaining 112 (down to a minute amount -- .0053 something units??).  Then the correct amount of 134-compatible a/c oil was added, and then the 134 refrigerant goes in -- still all through this automated equipment.  An initial amount was addded and then the automated machine adds more while the a/c is running on max with windows open until the temperature of the system stabilizes at a target operating pressure.  The old-timer mechanic told me that if you put in too much refrigerant, you'll can blow the seals or collapse the system depending on what fails first.  The hoses from the equipment were then removed.  And it has worked great!  Don't know if this place is unique (small town taxi service place) but I think any place that does a lot of a/c conversion and trubleshooting will have the right equipment and know-how to do it right -- if they also take in folks off the street.  I got this place's name from a mechanic friend who told me if I wanted it done right, "go see Tony and tell him Richie sent ya"  ;-)  Good luck!
"There's no magic involved in racing, just science and physics." --Austin Coil, Force Racing head crew-chief
"Any sufficiently advanced technology is indistinguishable from magic." --Arthur C. Clark, noted author and futurist
"Any intelligent fool can make things bigger and more complex. It takes a touch of genius and a lot of courage to move in the opposite direction." --Albert Einstein
"I'm not going to take this defeatist attitude and listen to all this crap any more from all these people who have nothing except doomsday to predict." --Carroll Hall Shelby
"I am looking for a lot of men who have an infinite capacity to not know what can't be done." --Henry Ford
"Your worth consists in what you are and not in what you have." --Thomas Alva Edison
"One man with courage is a majority." --Thomas Jefferson
#6 OFFLINE   KCMO-GT500
KCMO-GT500
    Old Pole from the Ozarks
  • 3,711 posts
  • Joined 19-March 06
Posted 29 July 2006 - 05:50 PM
a 12 oz can of R12 is going for about 21; you need a tech certification to buy it.  If the ac is still blowing a little cold, a single can will make a world of difference.
Some days I'm a badcat, and somedays not.....
Performance White with a Stage 2 & Some Minor Bling
#7 Guest_evilchris_*
Guest_evilchris_*
  • Guests
  • Joined --
Posted 01 August 2006 - 02:23 PM
If you have to "recharge" your A/C then it is leaking.
My 5.0 still blows ice cold and has a full charge.
#8 OFFLINE   KCMO-GT500
KCMO-GT500
  • 3,711 posts
Posted 02 August 2006 - 12:25 PM
...the point being that if it only needs a can every few years, then that is a whole lot cheaper than trying to track down and fix a very small leak that usually ends up being a multitude of very small leaks.  I consider it a pragmatic approach.  EPA rules allow freon to be added to car systems without trying to find a small leak, in spite of what a lot of repair shops say.
If it is a car that you value as a collector's item, then it might be worthwhile to start replacing hoses and fittings.
