My Transmission & Clutch & Flywheel installation
325 replies to this topic
#301 OFFLINE   msbmustang
msbmustang
    MSB Mustang
  • 300 posts
  • Joined 24-May 07
  • Interests:High End Audio Equipment and Home Theater System design.
    Audio IC Applications Engineer.
    San Jose Sharks Fan...still waiting for a Stanley Cup!
Posted 21 October 2008 - 08:20 AM
Mark,
I'm glad to hear you got your TSB installed. You have a few miles on your car and like you said you needed a clutch anyways. You scored in that matter IMO.
The difference in the shifter is the bends in the iron and the bushings.
I don't have the rattle / buz that shows in the TSB and my car was built after that date...so I'm good.
Rob
good Morning Rob,
I also noticed from your install pics that the rear of the orig shifter has a mounting bar extending out of the sides of the large rubber dampener with mounting holes on both sides. The new one does not have this bar. In the pics of your install (the first removal part) it shows that the bar is connected into the body of the car with a bolt on either side. however I did not see a pic of the final install of the new shifter. I assume that it is not bolted in to the body and floats which would put less noise into the drivers compartment. Are my assumptions correct?
Also I would assume that a shorter throw shifter would be easier on the transmission? I am still upset that the Ford reps would not let my dealer install a Ford Racing product that (according to Ford Racing) does not violate my warranty. From the pics it is hard to see a difference in the bends but the difference at the rear rubber dampener mounting bar clearly shows one it different from the other.
Thanks again for all the info!!! I really appreciate all the time you and everyone on this forum spends educating the rest of us who need quality help from time to time.
Mark
2007 GT500 - SVT #12 of 8152 Coupes
#2 of 384 in Tungsten Grey
Build Date 4/06/2006
150,000 miles thus far - 50K by Ford...the rest by me!
McLeod RXT Street Twin Disc Clutch Kit
Coast Driveline CD6039HD One Piece AL Driveshaft
Pinion Angle & Camber Bolts set up by Richard at Grace Body Shop
Short Throw Shifter M-7210-B - Ford Racing
VMP Higher HP and Better Mileage Tune by Justin Starkey
J&M Rear Upper and Lower Control Arms
H&R Rear Lowering Springs #51655 OEM Version
Koni Yellow Shocks and Struts, Adjustable Rears
#302 OFFLINE   Grabber
  • 35,392 posts
Posted 21 October 2008 - 09:47 AM
Mark,
The rubber bumper on the factory shifter is a installation aide / alignment positioning bumper for the factory robot to position the shifter correctly during assembly. The same robot that builds the GT500 also builds the Mustang GT and V6 car. The trannys in those cars are different so the bumper compensates for the installation because all the cars run down the same line in a mixed fashion.
Rob
#303 OFFLINE   msbmustang
msbmustang
    MSB Mustang
  • 300 posts
  • Joined 24-May 07
Posted 21 October 2008 - 11:41 AM
Mark,
Rob
Rob,
Thanks again. I went back through this thread completely and found the correct pic that shows the mounting bracket going over the rubber bumper which is used on both units. Just called my dealer and explained the differences between the two shifters. He is getting me a quote to do the driveshaft and shifter in another 7K miles.
I did notice a few questions in your postings about the missing square bumper on the small square plate near the center of the new shifter. Did you end up transferring the the one from the orig shifter to the new one? If so did you glue it?
Mark PS - Even though they did not do the shifter and driveshaft the difference in shifting and launch power is very large!!! Feels like a different car...AND I can actually shift into reverse now on the first try!
Well worth spending $1900 for the warranty and $100 for the upgrade. My warranty expires in 7k miles so now I will have to contact Ford to see if I can extend it again. Everyone needs to have this change done!!!
#304 OFFLINE   Grabber
  • 35,392 posts
Posted 21 October 2008 - 12:34 PM
Mark,
I must not of been clear. The rubber bumper is a robot aid during assembly. It's not needed for the shifter to function.
Please re-read my post above.
#305 OFFLINE   Grabber
  • 35,392 posts
Posted 06 November 2008 - 07:17 PM
Bump for jody
#306 OFFLINE   msbmustang
msbmustang
    MSB Mustang
  • 300 posts
  • Joined 24-May 07
Posted 17 November 2008 - 05:14 PM
Mark,
Hi Rob,
Been driving it for 3 weeks now and WOW what an improvement! Really solid launches now but the mileage is down a bit.
Some bad news though...I lost my job of 10 years as a principle applications engineer in the audio group last Wed at National Semiconductor. Now I will have to put the shifter and drive shaft in myself somehow. Also now that I am not commuting 100 miles every day gas is cut in 1/2!!! As is my 401K and my company options also...And they expire now in 4 months while the stock is down by 1/2! I did sell %60 of them though a year and 1/2 ago to buy the GT500 and my wife's Honda Pilot when the stock was at 29. Now it is at 11! Hope the market recovers after the first of the year but with the new president promising to raise taxes I do not have much hope now.
In addition the night I was laid off I was driving home, it was Veterans Day, and someone launched an egg at the passenger side of my car from the side of the road. It shook the car so hard it rolled 10-20 degrees to the left. The impact left a semicircle cut down to the primer where the shells cut through the paint. Why would anyone do that? I filled out a police report in case they did it to anyone else that night.
Anyway now I will not be extending the warranty at 85k miles but without driving it anymore the warranty might last another year! So there is some good news in all of this!
Thanks again for all the help.
Mark / MSB Mustang
#307 OFFLINE   LuckySnake
LuckySnake
    LuckySnake
  • 3,541 posts
  • Joined 11-May 06
  • Interests:Cars & Planes
Posted 17 November 2008 - 05:28 PM
Hi Rob,
Mark / MSB Mustang
The drive shaft and shifter install are easy, you can do it. You will need to drive your car up on some good ramps and jack the rear half up, place some solid jack stands under your differential. You just need to be able to have some room to work and some basic hand tools. When your ready, plenty of people to answer any questions here.
Very sorry to here about your job and hope you find something you like. That sucks about the egg, must have been a BMF. Good thing about that is, what goes around comes around and it will catch him.
Good Luck
#308 OFFLINE   Grabber
  • 35,392 posts
Posted 17 November 2008 - 08:07 PM
Mark,
I hope you land a new job very soon. I know you will bounce back soon. Keep positive and go get yourself a better job. I'm sorry to hear about the jerk and the egg. There are alot of mean people around.
#309 OFFLINE   msbmustang
msbmustang
    MSB Mustang
  • 300 posts
  • Joined 24-May 07
Posted 18 November 2008 - 08:56 PM
Good Luck
Hi LuckySnake,
Thanks for the advice. I think next week when I have sent out all the resumes I can and my thoughts are a little more in control I will will give your suggestions a try.
I have learned over the years not to attempt something this difficult when I am not as focused as I should be. The good thing is a large project like this will cause me enough frustrations and bloody knuckles that it will take my mind off of the bad job situation that I am looking at right now. Glad I bought the parts several months ago while they were doing the TSB to the drive train (I thought I was going to have them put them on almost for free but the Ford factory person supervising the TSB work said NO!) because now I would not spend the money. But since I have the parts and I am not going to extend the warranty now I might as well do it!
Best Regards,
Mark / MSB Mustang
#310 OFFLINE   msbmustang
msbmustang
    MSB Mustang
  • 300 posts
  • Joined 24-May 07
Posted 18 November 2008 - 09:09 PM
Mark,
Thanks Rob,
You are right, as usual. Keeping positive is really important and I do have a lot to be thankful for. My wife is way better today and I also got a phone call for an interview appointment after Thanksgiving with one of the larger US amplifiers companies for a consulting job . May not lead to a job but it is nice to have hope. The whole country seems to be a bit short on hope for new jobs right now. I pray that the new group in Washington does not raise taxes because that will doom any new job growth for sure.
Another positive thing is that it is cheaper now to drive my GT500 what with premium gas at $2.55 a gal in the Bay Area. Hope the government does not make me convert it over to batteries!
Mark
PS - I love the new clutch!
#311 OFFLINE   TRY2WIN
TRY2WIN
    F8L 500
  • 498 posts
  • Joined 15-September 08
Posted 17 July 2009 - 11:52 AM
I was on my way to va from nc, on the interstate going about 70. Went to pass a truck in 6th gear, gave it gas and the clutch slipped. Bought a ford extented warranty and all, even though I don't need it yet! They said my car is not eligible? I've had gears grinding, hisses all the time now and chatters bad. I don't know what to do. Any help would be appreciated since its my only cart and I deploy in a month for a year.
#312 OFFLINE   Afterburner
Afterburner
  • 245 posts
  • Joined 02-March 08
Posted 17 July 2009 - 01:12 PM
Was it the dealer or Ford ESP that said it wasn't covered? If it was the dealer, which one was it if you don't mind me asking? Also, what year is your car and how many miles?
Edited by Afterburner, 17 July 2009 - 01:14 PM.
FRPP CAI & Tune
KR Axle Backs
WebElectric Sequential Taillights
Shelby Dash Plaque
#313 OFFLINE   TRY2WIN
TRY2WIN
    F8L 500
  • 498 posts
Posted 17 July 2009 - 01:25 PM
It was a dealer in newport news( not gonna throw them under the bus yet) and they said they would make some calls monday but not looking good. And it was the dealer that said this. It's an 08 and has 32k on it. I took it in awhile ago about the clutch cause it chattered and the bearing was making a lot of noise. They told me it was normal. Go figure.
#314 OFFLINE   Afterburner
Afterburner
  • 245 posts
Posted 17 July 2009 - 02:13 PM
That's a good amount of mileage on the clutch. If it was Hall Ford, I have a small amount of experience with them that left a bad taste in my mouth. You can read it here: http://www.teamshelb...showtopic=25793
FRPP CAI & Tune
KR Axle Backs
Shelby Dash Plaque
#315 OFFLINE   TRY2WIN
TRY2WIN
    F8L 500
  • 498 posts
Posted 17 July 2009 - 03:07 PM
That's not the dealer. Great story! But that is who I bought mine from. I got mine 2k below sticker though. I took mine in for the free oil change and they had put 5 qts of 5w20 in it! They corrected that but I have never been back.
#316 OFFLINE   Grabber
  • 35,392 posts
Posted 30 January 2010 - 12:05 PM
Still lovin my new Tranny.Posted Image
#317 OFFLINE   dfm
dfm
  • 23 posts
  • Joined 25-October 07
Posted 30 January 2010 - 07:48 PM
#318 OFFLINE   Grabber
  • 35,392 posts
Posted 30 January 2010 - 07:51 PM
#319 OFFLINE   dfm
dfm
  • 23 posts
What the name of the Ford Dealer who did your TSB on your transmision and clutch? I would like to get mine done soon and I live in Washington near Seattle in Port Orchard.
#320 OFFLINE   Grabber
  • 35,392 posts
Posted 30 January 2010 - 07:56 PM
Vancouver Ford in Vancouver, WA.
#321 OFFLINE   cluscher
cluscher
  • 652 posts
  • Joined 24-April 07
Posted 31 January 2010 - 10:33 AM
Bickford Ford in Snohomish did mine and they have a lot of experience with Shelbys.
2007 GT500 Black/Tungsten
#322 OFFLINE   Perimeter
Perimeter
  • 90 posts
  • Joined 07-December 09
Posted 31 January 2010 - 07:31 PM
I was reviewing this whole entire forum cause i have having small problems with my clutch. today when i was sitting in a parking lot with the car on, and i would put it through the gears with the clutch in. Every once in a while it wouldn't let me put it in a gear and i would have to put it in another gear and then put it in. I got the TSB done before Christmas but my part number is 7R3Z 6375 B..... not AA like yours. I'm in a bundle of problems lol. Should i take it back to ford??
2007 GT500 Black/Silver
Eibach Sport Lowering Springs.
More to come...... :'(
#323 OFFLINE   shelby001
  • 19,682 posts
Posted 31 January 2010 - 07:37 PM
Could be a synchro problem , take back to the dealer let them check it out.
#324 OFFLINE   Perimeter
Perimeter
  • 90 posts
Posted 31 January 2010 - 07:41 PM
But i'm not having any problems shifting normally. I did get on it once and went to shift to second and it squealed like crazy. never did it again though.
#325 OFFLINE   Tob
Tob
    Neo Rapscallion
  • 1,198 posts
  • Joined 25-November 08
  • Interests:Organizing my sock drawer.
Posted 28 July 2011 - 08:37 PM
Rob, was the VIN stamped (or on a sticker) somewhere on your original tranny?
Tob
#326 OFFLINE   Grabber
  • 35,392 posts
Posted 29 July 2011 - 05:01 PM
Tob
It is stamped. I still have my original. Here's some photos:
http://www.teamshelb...__fromsearch__1
