Battery Drain
#1 OFFLINE
Posted 22 January 2008 - 12:15 PM
#2 OFFLINE
Posted 22 January 2008 - 12:20 PM
1yountfan, on Jan 22 2008, 04:15 PM, said:
#3 OFFLINE
Posted 22 January 2008 - 12:23 PM
SHELBY1, on Jan 22 2008, 03:20 PM, said:
I'm getting one of those, but still......this is a nearly a brand new car (12,000 miles). This shouldn't even be an issue. Heck, I have a 1965 Mustang that doesn;t have this issue. I guess I'm more annoyed at it more than anything.
#4 OFFLINE
Posted 22 January 2008 - 12:26 PM
I have the same problem with my GT-H. I think the battery tender is the way to go unless there is some way to stop the constant trickle of juice needed to keep the radio and other electronics semi-active. My 1968 Mustang sits OUTSIDE the garage and starts after a few pumps of the pedal, no matter how long it's been sitting! Oh well, trade-offs are worth it.
I'm going to try turning off the radio before shutting down to see if that does anything.
Mike
Edited by Benzito, 22 January 2008 - 12:27 PM.
1968 Ford Mustang
1965 AC / Shelby Cobra 427SC (SPF replica)
Some others . . .
#5 OFFLINE
Posted 22 January 2008 - 12:55 PM
#6 OFFLINE
Posted 22 January 2008 - 12:56 PM
Mike
I'm going to try the radio thing too....after I charge my dead battery up. Let me know if it works for you.
#7 OFFLINE
Posted 22 January 2008 - 01:56 PM
I have left mine in the garage for 3 weeks and no problem.
Battery tender is the way to go also if it is cold outside than that will also have a effect on you're battery.
Art
#8 OFFLINE
Posted 22 January 2008 - 05:57 PM
First of all, my car sets for a month or more at a time sometimes and has never had a dead battery. Ford and everyone can make excuses all they want to, but to me it's all crap. Total crap. Did I mention I think it's crap?
I have a friend that just traded his 06 GT back in because it wouldn't maintain a charge. It also went throug two rear ends. The car had less than 4000 miles on it and never exceeded the speed limit. He has now become committed to avoid Ford products (Mustangs anyway).
For ford to say that you need a battery tender is a cop out. You can't tell me since there are plenty of Shelbys out there (like mine) that don't lose charge, that this isn't an issue that Ford could figure out.
My wife's 05 Ford 500 had a dead battery back in October. A cell went completely dead. The dealership told me that they have had some issue with substandard batteries.
My official stance is accept no excuses.........make the dealership/Ford figure it out. It's a new car.
Okay, now I'm done.
CB
2007 Shelby GT 500
Vista Blue (the fastest color) with Tungsten Stripes
SLP Loudmouth's
Custom Dead Pedal
Custom Power Plug Cover
Bone Stock Otherwise
Blue Ovals Until The Day I Die........
All hail the Carroll Shelby legacy
Stangs United Member
Central Mo Mustang and Ford Club Member
Co Author of "Wild Horses..A Portrait of America's Favorite Muscle Car"
1967 C Code Fastback Project
2001 V6 Coupe (son's)
2002 V6 Coupe (daughter's)
#9 OFFLINE
Posted 22 January 2008 - 07:16 PM
1yountfan, on Jan 22 2008, 03:15 PM, said:
If that does not work, I agree with Cobra Boy... have the dealership correct it...
Edited by SHELBYGTH, 22 January 2008 - 07:32 PM.
#10 OFFLINE
Posted 22 January 2008 - 07:30 PM
I'm missing over 1500 posts and I want them back dammit!!
#11 ONLINE
Posted 22 January 2008 - 07:36 PM
http://forum.teamshe...showtopic=15005
2007 GRABBER ORANGE GT500 Coupe ordered 10/13/06. Sub to plant 12/14/06. Scheduled 1/16/07. Bucked 1/17/07. Released From Plant 1/19/07. Plant Quality Hold 1/19/07. Off Plant Quality Hold 2/21/07. Shipped 2/22/07. Delivered 3/8/07. New 2008 2nd Gen. Tranny & Nickle Hub Clutch & Flywheel & Lube & CSC bearing 1/16/2008. New 2009 2nd Gen. Flywheel & another new Nickel Hub Clutch & Pilot Bearing 8/8/08. New 2010 Clutch and flywheel and slave cylinder & pilot bearing and clutch line 8/2/12
#12 OFFLINE
Posted 22 January 2008 - 08:00 PM
Okay, now I'm done.
CB
To those of you having issues, are you locking the car? I'm wondering if since it's locked the anti-theft system uses more juice? I don't know...just a guess.
Dave
#13 ONLINE
Posted 22 January 2008 - 08:28 PM
FYI-You have to actually drive the car to get the alt. to charge the battery.The batteries in the new Mustangs will last about 3 weeks while parked.The electrical systems on these cars are what we call on the network.While these cars are parked and turned off the network actually powers 7 modules,anti theft switches and the amps in the stereo.After 30 minutes the network goes into sleep mode but still powers all items mentioned.If you pop the trunk or open the door the network wakes up and stays awake for 30 minutes as long as nothing else is used in the car then goes back into sleep mode.The reason you hear sometimes to turn your radio off before you turn the car off is the ACM or audio module draws 4 amps and usually the most likely module to go bad.If the ACM goes bad it never goes into sleep mode and draws 4 continuous amps till the battery is dead,which doesn't take long.Hope this helps.
#14 OFFLINE
Posted 23 January 2008 - 10:52 AM
Okay, now I'm done.
CB
I couldn't agree with you more Cobra Boy!!!!! I have a 2002 Caddy and a 65 Mustang that can sit for months and have no issues with the battery!
A nearly brand new car shouldn't need a battery tender! And I shouldn't have to go out and buy one or charge my battery up every few weeks. Sounds like it's not a one-off problem just in my car......sounds that many that are having the same issue. You think someone could have found a solution by now. But I'm 100% with you Cobra Boy!
#15 OFFLINE
Posted 23 January 2008 - 11:43 AM
#16 OFFLINE
Posted 23 January 2008 - 12:34 PM
Dave
#17 OFFLINE
Posted 23 January 2008 - 01:00 PM
I certainly think I would take it to the dealer for a dead battery or discharge problem.
Just adding my experiences to the discussion.
1965 Mustang Coupe. Dad bought it new. I still have it!
1968 Mustang Coupe
Ford blue in my veins
#18 OFFLINE
Posted 23 January 2008 - 01:14 PM
shelby001, on Jan 23 2008, 03:34 PM, said:
Mine is going right back to the dealer! It should make no difference if I lock it, keep the radio on when I turn off the car, or leave it for more than a couple weeks without driving it. The battery should not be drained!
#19 OFFLINE
Posted 23 January 2008 - 01:27 PM
#20 OFFLINE
Posted 23 January 2008 - 01:55 PM
