Crank shaft drag tech
No replies to this topic
#1 OFFLINE   DVS2XS
DVS2XS
  • 516 posts
  • Joined 11-April 06
Posted 08 June 2006 - 10:08 AM
David Vizard has a very interesting article on crankshaft windage in the Aug, 2006 issue of Circle Track Magazine.
In it, a 3.75 stroke 383 SBC is tested to 7500 rpm with crankshafts using stock flat faced throws and aero shaped throws. And then with and without oil-shedding coatings. Bearing coatings are discussed, as are clearances. Lots of neat (no BS) info on wet sump engines and cranks.
Other articles in this issue include dry-sump systems, cam drives, and pushrod length/friction.
If you are into tech and testing, I recommend picking up the issue.
Edited by DVS2XS, 09 June 2006 - 02:58 AM.
Disclaimer: Everything I post is just my .02, and should be take only as opinion. These opinions tend to be notoriously WRONG, and any that are correct, can only be attributed to my being dropped on my head as a small child - repeatedly.
