brakes
#1 OFFLINE   RUFDRAFT
RUFDRAFT
    RUFDRAFT
  • 68,925 posts
  • Joined 04-May 06
  • Interests:Yes.
Posted 06 September 2006 - 06:09 PM
I'm putting in some Hawk ceramic pads on the GT in a couple of weeks.
Hawk gives you their suggested protocol for bedding the pads in, but I thought someone might have learned a better way?
They recommend 6-10 moderate stops from 30-35 mph - then 2-3 hard stops from 40-45.
Thanks -
Like driving with the hammer cocked! 2016 S550 - GT - a few mods - 315 Nittos! 17x10x5 Racestars -- Previous Mustangs - 2007 Mustang GT - 474 RWHP - SAE Corrected - : 1985 Black Hatch GT - 1989 Red LX 5.0 Vert - 1991 Grey LX 5.0 Sedan - 2001 White V6 - 2003 Zinc Yellow Mach 1. -
#2 OFFLINE   kaylan1521
kaylan1521
    RESIDENT CANADIAN
  • 1,992 posts
  • Joined 13-October 05
  • Interests:Going fast
Posted 06 September 2006 - 07:16 PM
Sounds about right. You don't want to heat the pads too much on the first few stops to prevent "glazing"
www.mohawktrackexperience.com
#3 OFFLINE   TAHOE GT
TAHOE GT
    Mr. G
  • 259 posts
  • Joined 16-August 06
Posted 06 September 2006 - 08:17 PM
Ruf,
I've tried any number of bedding proceedures. Here's the one that I've had the most success with on "performance" pads:
Bring the pads up to operating temps buy approx. 5-6 stops from 35-10mph. Moderate pressure, normal stops.
Perform 4-5 stops from 50-25mph. Slightly heavier stops, but still in the moderate range. Cool brakes buy driving on freeway for a couple of miles.
Next, perform 3-6 stops from the highest speed at which you think you will be stopping from, usually 80 +/- mph, with HEAVY pressure. You should perform the stops until you can smell the brakes. Drive the car on the freeway for several miles to cool the brakes, using as little braking as possible. Park the car and allow brakes to return to ambient temps. If you plan on heavier braking, 100+ mph, than frepeat the warm-up and then perform the heavy stops from that speed and follow the cool-down.
WHEN STOPPING FOR THE COOL-DOWN TO AMBIENT, DO NOT SET THE PARKING BRAKE.
This can cause brake pad material transfer that will create a pulsation in the pedal.
You should NOT bed new pads with new rotors using this method.
The heavy/high-speed stops help to boil-off the binders and gasses that cause the pads to float at higher temps. Also, it helps to transfer the layer of friction material to the rotor without glazing the pads.
Good Luck
Next,
Once proud owner of 2007 Shelby GT 500 #189
Now significantly less dejected owner of 2007 Shelby GT 500 paperweight
#4 OFFLINE   carnut
carnut
    The Nut is Back
  • 7,939 posts
  • Joined 14-July 06
Posted 06 September 2006 - 08:20 PM
While waiting for brakes to cool, cook ribs and have long neck. That should allow for proper cooling of the driver :shift:
#5 OFFLINE   JT93
JT93
    07SGT5059
  • Great Lakes Region
  • 583 posts
  • Joined 26-January 10
Posted 30 January 2010 - 05:24 PM
What type of brakes do you guys suggest for max stopping power? I race my daily driver on the weekends so the brakes are obviously worn down. But, I'm having an issue trying to determine what type to buy. I'm looking to buy a kit so I'll have bigger disks and the option to use the front grill to cool them. Any ideas I'll take. I've got a few months until the car will come out again, but I want to have them on ahead of time so as soon as the weather turns I'll be able to hit the track again.
Whatever the competition comes out with, we'll kick the hell out of 'em. - Carroll Shelby
Carroll Shelby Signed Airbag Cover
Great Lakes Region Windshield Banner
Sequential Tail Lights
Boss 302 Rear Seat Delete
Corbeau TRS Seats
Corbeau Racing Harnesses
Shelby Harness Bar
Shelby Harness Pads
SVT Rims for the track
Boss 302 Rims for the street
FRPP Hot Rod Cams
FRPP 62mm Throttle Body
FRPP Intake Manifold
FRPP Black Cam Covers
FRPP 3.73:1 Gearset
FR500S Differential
FRPP Hubs w/ ARP Studs
Brembo Brake Upgrade
FRPP Brake Cooling Kit
Shaftmasters Driveshaft
Dynatech Long Tubes w/ High Flow Cats
MRT Muffler Delete
Tow Hook with Custom Bracket
Tuned by Paul's High Performance
#6 OFFLINE   Matts
Matts
    USN
  • 1,664 posts
  • Joined 09-December 07
  • Interests:Road racing and Auto-crossing
Posted 30 January 2010 - 08:55 PM
Wow this thread is ollllld! :hysterical:
Umm 14 inch 2 piece rotors, mintex pads, SS lines, GT500 take off calipers. I was going to suggest super blue brake fluid but yours is a DD. I would just find some performance brake fluid. Once I get my bills paid I'm going to start updating my brakes, but if I were you I would go with that combo.
Proud United States Sailor.
#7 OFFLINE   JT93
JT93
    07SGT5059
  • 583 posts
Posted 01 February 2010 - 09:12 AM
DD? I'm sorry, but I'm sorta new to the braking system lingo. I'm only keepin the car in third gear red line on the back stretch. I want to find the balance between high performance and around town efficienty. If I buy high performance brakes won't that hinder my everyday stopping ability and vice versa?
Corbeau TRS Seats
Shelby Harness Bar
Shelby Harness Pads
FRPP Hot Rod Cams
FRPP 3.73:1 Gearset
FR500S Differential
MRT Muffler Delete
