New 2nd Generation Flywheel & Nickel hub clutch
224 replies to this topic
#31 OFFLINE   Grabber
  • 35,392 posts
Posted 08 August 2008 - 06:30 PM
.....It sounded like my drive line was banging on the tunnel.
I was going to yell to the Tech to turn the motor off, but he let it keep running.
I was about ready to have a heart attack. :baby:
#32 OFFLINE   Grabber
  • 35,392 posts
Posted 08 August 2008 - 06:34 PM
Then....from the passenger side of my car a tech stood up and he had a hammer in one hand, and my old flywheel in his other hand.
He was hiding behind my car making that noise trying to freak Grabber out.
Then they all started laughing. :hysterical:
BOY WAS I RELIEVED. :baby:
#33 OFFLINE   Grabber
  • 35,392 posts
Posted 08 August 2008 - 06:42 PM
Bad Tony took some Pic's of my work today too.
Old Clutch & flywheel. Notice the heat checking with only 1000 miles.
The Tube of Blue Teflon Lube.
My new clutch with some Teflon lube in it.
Applying the lube to the shaft.
The Red boxs that hold all the "special tools".
The new flywheel profile.
The back of the new flywheel. Note the conical dome.
My baby on the operating table. :baby:
#34 OFFLINE   Grabber
  • 35,392 posts
Posted 08 August 2008 - 09:52 PM
Here's a couple more good Pic's from Bad Tonys photobucket:
#35 OFFLINE   Grabber
  • 35,392 posts
Posted 08 August 2008 - 11:08 PM
Rob, I noticed the original flywheel is cast nodular iron. I'm wondering if the new one is forged steel which I think will conduct and dissipate heat better. Dunno if it is ...just was wondering if there's some way to tell. :shrug: Seems the old one has cooling vents which the new one apparently does not require -- that's what made me think of that.
All those new parts sure look mighty purdy! ;)
Yes Dan the old Flywheel is Nodular iron, and it did not dissapate the heat very well at all. :angry2: That's why they are warping. Did you notice that Valeo is stamped in that existing flywheel. They make the clutch too.
The new flywheel has "Ford" stamped in it, and the steel content has been changed. :)
I am very happy with how it drove home. :shift:
:happy feet: No more warping. No more clutch chatter. :happy feet:
#36 OFFLINE   LuckySnake
LuckySnake
    LuckySnake
  • 3,541 posts
  • Joined 11-May 06
  • Interests:Cars & Planes
Posted 09 August 2008 - 02:29 AM
Glad to see the new parts installed, looks good!
#37 OFFLINE   mrfarmdog
mrfarmdog
    PNW Regional Director
  • 3,363 posts
  • Joined 24-July 06
  • Interests:Whatever peaks my interest at the time!
Posted 09 August 2008 - 06:56 AM
Thanks for the pics Rob! My kit is an and I will be taking my car in next week. Do you know what the differences are on the input shaft? I know this has been a weak link and was wondering if the replacement shaft is stronger?
#38 OFFLINE   Grabber
  • 35,392 posts
Posted 09 August 2008 - 07:08 AM
I will double check to see if it is stronger, but this is what my Tremec contact has told me.
1. The input shaft is much smoother. Polished is the word he used.
2. The 26 grooves (splines) in the input shaft have now been milled into the shaft a fuzz wider. I'm talking many about micro nano thousandths here. His exact words to me were: " The Pin diameter has been changed to the higher end of the specification".
With these 2 changes in the shaft it makes for a swift clutch disengagement. Combined with the blue teflon lube and the new nickel clutch hub splines makes for smooth shifting.
#39 OFFLINE   Grabber
  • 35,392 posts
Posted 09 August 2008 - 07:28 AM
Click on these pic's to enlarge them to get a much better look at the thicker section on the new flywheel. The conical shape on the 2nd generation flywheel is much different then the 1st generation flywheel. This is where the new 2nd gen. flywheel is getting it's strength to prevent it from warping. It is heavier in weight, but the inertia mass has been engineered in a manner that that there is no change in the inertia rotation compared to the 1st generation flywheel.
#40 OFFLINE   Grabber
  • 35,392 posts
Posted 09 August 2008 - 07:36 AM
Click on this pic to enlarge the view of the side of the flywheel that out clutch pads ride on. Look at the heat checking marks that are on the surface of the area where the clutch pads ride. This is with only 1000 miles of wear.
Edited by Grabber, 09 August 2008 - 07:37 AM.
#41 OFFLINE   1badsho
1badsho
  • 3,217 posts
  • Joined 02-November 06
  • Interests:03/29/2014 .. update .... I am now back at work with a FORD store. Happy to be back with ford and in search for another GT 500. I bought a Boss 302 , a 2013 but erred.04/06/2014 bought my second GT500 red with red inserts shaker 500 .... let the mods begin !!
Posted 09 August 2008 - 07:58 AM
great pictures and as always THANK YOU !!! ..... What i was most impressed with was your rear end ... ( NOT YOUR *SS GRABBER but THE CARS REAR END ! )
I recall when u re painted it and man it really stands out ... great job !
Don
07 GT500 1ZVHT88S275367748 purchased 04/06/2014
SOLD BUT NOT FORGOTTEN
07 RED SHELBY W/WHITE STRIPES VIN # 1ZVHT88S175275241:RELEASED FROM PLANT 11/14/06 : RAILCAR NUMBER 11/30/2006 : ETA DELIVERY DATE TO MY STORE OF 12/08/2006
CURRENT OTHER RIDES:
1999 F-350 CC drw 7.3 diesel ... 08/01/2010 ....144000 miles .... just broke in :)
1990 Taurus SHO rebuilt from the ground up by yours truly
Montana 36' 10th aniversary edition 5th wheel ( my style of roughing it ! )
PAST RIDES:
2015 Taurus SHO
1989 TRACK PREPPED SHO
1991 SUPER CHARGED SHO +
2013 Boss 302
#42 OFFLINE   Grabber
  • 35,392 posts
Posted 09 August 2008 - 08:28 AM
Thanks Don.
I like to keep the under side of my car looking good. I put in up on my ramps last night to inspect it and do a wipedown. Today I will Change my oil while shes up on the ramps.
Edited by Grabber, 09 August 2008 - 08:29 AM.
#43 OFFLINE   HSURB
HSURB
  • 2,866 posts
  • Joined 23-June 06
Posted 09 August 2008 - 08:30 AM
Thanks Don.
Can we get photos of the oil change process?
HSURB
/Users/jbrush/Desktop/2ywzfj9.gif
#44 OFFLINE   Grabber
  • 35,392 posts
Posted 09 August 2008 - 08:33 AM
HSURB
It would seem that I should provide the instructions to some of the dealerships since so many members here seem to get botched oil changes with the wrong oil and over filled by 1/2 of a quart. :banghead:
#45 OFFLINE   Hans
Hans
  • 797 posts
  • Joined 02-April 06
Posted 09 August 2008 - 05:15 PM
Rob
Thanks for all the great pics and explaining to us all the process and the new parts. I am talking to my dealer that installed my last trans fix, working on them to order the new parts for my car as I have about three thousand miles on the second gen trans. I do have chatter when the car is warmed up and in stop and go traffic. Nice to have friends with a sence of humor!
I'm looking at your thread here and thinking, It is time that you car is finally FIXED!!!. :happy feet:
07 GT500 Shelby acquired Nov 21 2006
Exterior mods
Carbon fiber front splitter
Bi-exnon 6,000 Diamond white running and head lights
Mis Decals on car
Third break LED chrome stop light
Chrome rear tail light bezel trim
Satellite shark fin cover
9 inch antenna
MGW Cobra polished billet license anti-theft Cobra frame
Alcoa Shelby 20/10 rims with Shelby Cobra center caps
Steeda lock nuts
Nitto Invo  4   295/30/20
Cobra air caps all four
Roush rear window covers
Trunk LED light super bright
Web electronics sequential rear tail lights harness
LED license plate light
True forge Heat extractors billet hood vents
Carbon fiber KR Rocker panels by true fiber
Bangastang California side scoops
3M clear Bar Hood and roof and Front
Shelby Billet fuel door
Exterior mods cont.
Cobra rear break covers
Billet fender badges
Mustang Brake Duct Bezels
Carbon Fiber mirror covers Shelby
Engine mods
Morso billet brake Fluid cover
Shelby batteries hold down brackets
Ford racing damper
Revan racing over size C&R radiator and Shelby inter cooler dual high speed fan with matching anodized reservoirs coolant and power steering
VMP 2.4 TVS CNC port matched high flow inlet elbow, 2.6 pulley and 90mm idler pulley, colder plugs and thermostat with SCT tuner & two tunes, one 100 octane tune
Bangastang custom radiator cover to match car
Classic Hood strut lifts kit with Champion replacement 90 LB strut
Shock tower caps
C&L cold air tube and filter
JLT oil separator
Engine mods cont.
Shelby Drake Cobra billet engine cap set complete
Fuse box Chrome cover with old style Shelby cobra emblem
LED under hood engine Bay lights
Interior mods
Shelby Headrests
Areoforce CNF interceptor dual gauges and speed of sound gauge pillars
Mustang billet radio knob
GT500KR trunk liner
Trunk release in glove box
Chrome door lock knobs and pins
Billet cup holder trim
 LED Map light with Shelby Billet trims
Carbon fiber trims inside cabin accents
SVT LED door sills
LED foot well lights
Cobra stainless dead foot pedal rest
Shelby signature floor mats and trunk
MGW Billet deluxe power outlet Cobra
Pad for knee driver side
Organizer glove box
Custom Shelby trimmed Console cover by Gary Disney extra padded Cobra
Window tint all around with mole skins in front to protect film
 Carol Shelby signed dash plate
Ford racing short throw shifter
Grabber pony custom shift Handel and ball
Steeda Billet speaker cover
Four dual cone high performance speakers
Damplifier Prosound Interior insulation
Suspension Mods
Koni yellow strut and shocks
DBA Slotted rotes all four corners
Hawk yellow brake pads
Front Brake cooling hose kit with Billet inlets JLT
Steeda stainless braided break lines all four
Steeda Billet lower control arms
Steeda heavy duty upper control arm adjustable
Steeda blue lower springs all four corners
BMR adjustable panhard brace
BMR drive shaft safety loop
One piece aluminum Drive shaft
KR axel back muffler set
#46 OFFLINE   Grabber
  • 35,392 posts
Posted 09 August 2008 - 05:19 PM
Rob
Hans,
This was just another little setback. It's now complete. Today I installed a little mod under the hood in celebration. :happy feet:
http://www.teamshelb...p...ic=32313=
#47 OFFLINE   Grabber
  • 35,392 posts
Posted 10 August 2008 - 07:58 AM
68Fastback,
The difference in weight between the old and new flywheel is negligible -- perhaps 1.5 lb heavier. The inertia is EXACTLY the same.
The flywheel is made out of forged steel (4100 series) which has about 20-30% better heat transfer coefficient as compared to nodular iron.
The input shaft strength is NO different. The "over pin" dimension on the splines has been increased slightly for a better fit with the mating clutch hub. Too small is just as bad as too big. The input shaft is NOT polished. It is broached to 1/10 the average Roughness of the old input shaft.
Hope this helps answer your questions.
#48 OFFLINE   Grabber
  • 35,392 posts
Posted 10 August 2008 - 08:03 AM
I just saw another member post his invoice for what the full TSB would cost if you have to pay for it.
$5,078.82 :fear:
#49 OFFLINE   SCGT500
SCGT500
  • Banned
  • PipPipPipPip
  • 22,831 posts
  • Joined 23-March 06
Posted 10 August 2008 - 08:06 AM
68Fastback,
In this corner we have Dan the Man!!!
And in the corner we have the latest brain wizard GRABBER!!
And their going at it...
Ooh...looks like Grabber just hit Dan w/ an amazing spew of information pulled out of his as..... and Dan is down for the count. :hysterical:
#50 OFFLINE   68fastback
68fastback
    Need DOHC alloy big-block!
  • 12,095 posts
  • Joined 04-May 06
Posted 10 August 2008 - 05:37 PM
:finger: ;-) ...actually I can only take credit for asking if the new one is made of forged steel. Someone else must have asked those other excellent questions ( that I wish I had thought of ;) )
Great info, Rob!!!! ...thanks :happy feet:
"There's no magic involved in racing, just science and physics." --Austin Coil, Force Racing head crew-chief
"Any sufficiently advanced technology is indistinguishable from magic." --Arthur C. Clark, noted author and futurist
"Any intelligent fool can make things bigger and more complex. It takes a touch of genius and a lot of courage to move in the opposite direction." --Albert Einstein
"I'm not going to take this defeatist attitude and listen to all this crap any more from all these people who have nothing except doomsday to predict." --Carroll Hall Shelby
"I am looking for a lot of men who have an infinite capacity to not know what can't be done." --Henry Ford
"Your worth consists in what you are and not in what you have." --Thomas Alva Edison
"One man with courage is a majority." --Thomas Jefferson
#51 OFFLINE   06ragtopGT
06ragtopGT
    I need a new name.....
  • 1,047 posts
  • Joined 16-May 06
Posted 11 August 2008 - 03:27 AM
Nice write up as usual Rob.
Got almost 17K on my car and still cannot convince my dealer anything is wrong. It still shifts pretty good but I get blocked out of reverse and 1st and sometimes grind going into other gears but I cant get it to do it at the dealership. :banghead:
Soooooo I just keep driving and enjoying it. :lurk:
2007 GT500 Tungsten, No stickers (1of21) delivered 11/16/06 545whp/543lbs - 11.45 @ 122mph
#52 OFFLINE   Grabber
  • 35,392 posts
Posted 11 August 2008 - 04:00 AM
:finger:
That info is not pulled out of anyones dung hole. It's spot on.
#53 OFFLINE   Grabber
  • 35,392 posts
Posted 13 August 2008 - 08:45 AM
One other thing that has made the new flywheel stronger is material properties -- Young's Modulus increase (roughly proportional to stiffness) of about 25%. :happy feet:
#54 OFFLINE   68fastback
68fastback
  • 12,095 posts
  • Joined 04-May 06
Posted 13 August 2008 - 09:37 AM
I like Modulus modulars ...oh, nevermind. ;)
Young's Modulus...yikes! ...ok, it's just stronger. :hysterical:
#55 OFFLINE   Joe G
Joe G
    The one in the know
  • 10,102 posts
  • Joined 08-January 06
  • Interests:Speaking the truth
Posted 13 August 2008 - 10:27 AM
So you're saying the new flywheel has a stiffy??
:happy feet:
#56 OFFLINE   Grabber
  • 35,392 posts
Posted 13 August 2008 - 01:47 PM
:happy feet:
I guess you could say that. ;)
Edited by Grabber, 13 August 2008 - 04:38 PM.
#57 OFFLINE   SuperSnake08
SuperSnake08
  • 284 posts
  • Joined 24-September 07
Posted 13 August 2008 - 08:31 PM
Thanks Don.
Hey Grabber- I know how meticulous you are but I have a question. In the northwest I know it rains a lot. Do you drive the car in the rain at all?, and if so have you been able to keep the underside clean? During rainy season in South Florida I don't drive much and it drives me crazy. I have 2 Shelby's and oftentimes can not drive either. Really frustrating.
#58 OFFLINE   68fastback
68fastback
  • 12,095 posts
  • Joined 04-May 06
Posted 13 August 2008 - 08:43 PM
:happy feet:
Posted Image :hysterical:
#59 OFFLINE   Grabber
  • 35,392 posts
Posted 13 August 2008 - 09:38 PM
This car is my nice day driver. If it's raining, I don't take it out. I have been caught in a couple rainstorms, and I did find out that the car does not melt. :)
#60 OFFLINE   Grabber
  • 35,392 posts
Posted 19 August 2008 - 06:52 PM
I have now completed my first 100 miles on my new clutch and flywheel.
Impressions:
Clutch pedal is not loose anywhere, even at the top of the pedal. It's firm, but not stiff at all. It feels just right.
I have done the hiss test several times. No hissing in nuetral with the clutch depressed. This is good.
Starting out in first gear with low RPM's....there is no clutch chatter at all. Starting out in 1st gear with mid RPM's feels great too.
The shifting is very good at all RPM's. There is no bumping of the syncros or crunching feel. I can feel the shift go into the gear with a positive engagement. I am trying to explain what the shift feels like, and the best I can do is say that it feels like a silent click when it goes into gear. Like it was meant to be.
UPDATED IMPRESSIONS:
I have been out of town for a week on vacation, so my car has been sitting all week.
I went out to start it in my shop. Rolled both windows down so I could listen to the motor. Turned the key on and she fired right up. Left her in nuetral and listened. No whine and no hiss. Pushed the clutch pedal in and held it. Listened very carefully. No hissing at all. Did it a second time, and still no hissing.
Results: HISS TEST PASSED.
I then took the car out to a Driving Rally event. The driving was on winding twisty roads with alot of shifting. Many hairpin corners, and lots of 1st, 2nd and 3rd gear shifts. The drive was 2 hours long up in the Oregon country back hills. I put a total of 160 miles on the new clutch and flywheel set up today. The performance was superb. The shifting was all smooth. Never bumped any syncros or missed a beat. The temp was 97 here today, so it was nice and hot.
RESULTS: I now have 260 miles on my TSB work and I could not be happier. :)
