What to tell the dealer about your clutch problem ?
59 replies to this topic
#1 OFFLINE   Grabber
  • 34,337 posts
Posted 24 November 2008 - 06:02 PM
Several people have asked me  "what should I say to the dealer when I go in and talk to them about my clutch problem?".
This is what I would do.
Go in and be polite, and if the service advisor does not know about the problem, you will have to school him up. (Have the TSB in your back pocket too)
Tell him that you know for a fact that:
1. The first 11 months of GT500 production cars did not get any Teflon lube on the input shaft and clutch hub.
2. Tell him that you know your clutch hub and input shaft have a bunch of surface rust and corrosion on them because the lube never was applied.
3. Tell him that you know that the rusty shaft and clutch hub cause the clutch to not release on time and drag.
4. Tell him that you know that clutch drag causes your syncros to remain loaded with engine torque and that is why your gears grind inbetween shifts.
5. Tell him that you know the transmission  input shaft splines have been revised to be a little wider and broached smoother so it will release on time from the clutch hub.
6. Tell him that you know the clutch hub has been revised to be made out of nickle  to prevent the clutch hub from rusting.
7. Tell him that you know your flywheel is made out of nodular iron and it does not dissapate the heat very well so it has warped on you and is toasting your clutch and causing your car to have clutch chatter.
8. Tell him that you know the new flywheel is made out of 4100 series steel and is much thicker to take care of the heat dissapation and warpage problem.
If that does not work.....go to a different dealer. :banghead:
Edited by Grabber, 14 March 2009 - 10:01 PM.
#2 OFFLINE   Craigo
Craigo
  • 416 posts
  • Joined 20-September 08
Posted 24 November 2008 - 06:08 PM
5. Tell him that you know the transmission  input shaft splines have been revised to be a little wider so it will release on time from the clutch hub.
8. Tell him that you know the new flywheel is made out of 3100 series steel and is much thicker to take care of the heat dissapation and warpage problem.
Perfect...Thanks Grabber
'08 Black Vert GT-500 Super Snake 08SS0313
#964 Of 2070 2008 Convertibles #278 Of 682 Ebony Built 12/10/2007
Engine built by Tim Parrot and Paul Dougherty
2.6 Tasca Racing pulley
90MM Idler Bracket and Pulley
Ported TVS Supercharger
Ported Stock Throttle Body
AFCO Heat Exchanger
Tasca Racing Fuel System
Techco Watts Link
Shelby Shift Lever and Knob
6 Piston Rear Caliper upgrade
#3 OFFLINE   DDT
DDT
    Dave
  • 5,936 posts
  • Joined 23-August 07
  • Interests:"Don't blame me"......."What did I do"???????
Posted 24 November 2008 - 06:19 PM
And it has worked only if they perform the TSB correctly??????????????? :doh:
#4 OFFLINE   Grabber
  • 34,337 posts
Posted 24 November 2008 - 06:28 PM
Very True fact.
So you need to then ask them if they have a Tranny technician and tell them that the 14 special tools needed to rebuild the transmission are listed on the front page of each section of the WSM (Work Service Manual). The WSM manuals are available to the tecnicians via the on line dealer access OASIS system. Ask them if the tranny Tech has all those tools.
#5 OFFLINE   DDT
DDT
    Dave
  • 5,936 posts
Posted 24 November 2008 - 06:39 PM
Thank's for all your great advice Grabber.........
No problem with mine yet with low mileage but I definately expect symptoms
to arise before the warranty expires.........In fact I will make sure of it.............. :peelout:
#6 OFFLINE   Grabber
  • 34,337 posts
Posted 26 November 2008 - 03:32 PM
Good luck with your car.
#7 OFFLINE   DDT
DDT
    Dave
  • 5,936 posts
Posted 26 November 2008 - 03:36 PM
Thank's Grabber;
Still happy I baught this beast.........Worth every dollar I paid and then some........
#8 OFFLINE   Grabber
  • 34,337 posts
Posted 26 November 2008 - 03:40 PM
View PostDDT, on Nov 26 2008, 03:36 PM, said:
Thank's Grabber;
I agree 100%. There have been some problems to work thru, and they all get behind us sooner or later, then the enjoyment shines thru.
My Shelby still puts a huge smile on my face when ever I get in it. Now that it's fixed and paid for.....the smile is even bigger. :)
#9 OFFLINE   me32
me32
    BEASTLY SHELBY GT500 TVS
  • 555 posts
  • Joined 13-November 08
Posted 26 November 2008 - 04:03 PM
thanks for posting this, great info
2008 Shelby GT500
2921 out of 6513 coupes
132 of 314 Alloy Metallic
Shelby Dash Plaque,FRPP TVS Super power pack ,Drag Pack,SVT handling pack,FRPP Cobra Jet TB/MAF/80lb injectors,J&M UCA,LCA,Adj.PHB,SFC,PH A/D,O/R H, DynoMax 3in,CHE, Shelby Rad/HE,VMP 2.59,KB BAP,L&M plenum,BMR KMEMEBER,AED CUSTOM RETURN STYLE FUEL SYSTEM.
91/E85 tune by SHAUN AT AED
730HP/700TQ ON E85
10.78@129MPH 1.644 60FT
WWW.AEDHP.COM
#10 OFFLINE   shelbypowered
shelbypowered
  • 491 posts
  • Joined 03-November 07
Posted 02 December 2008 - 03:13 PM
:censored:
View PostGrabber, on Nov 24 2008, 10:28 PM, said:
Very True fact.
So what do you tell them when the clutch is grabby after the tsb? Warming them up to the fact that it should not be grabby however they believe it is a characteristic of the ceramic clutch and is normal- I say what is normal-  This is a dealer that that stepped up to the plate and did not squabble so it is kind of thin ice- All the other portions of the tsb were fine- shifting and no problem on moderate takeoffs just the gentle normal move from stop- sometimes ok and sometimes not so good. You have to drive it like the little old lady from pasedena- I really do not believe everthing was planned that well regarding the tsb issue and the fact others are having problems aferword does not mean because symptons are back the mechanic did something wrong. Correct part numbers used per oasis- so whats the scoop- we may never know. The good dealers are well aware of the tsb and reacting positive so it may be an expensive learning experience on both sides of the coin- those of use who paid the big bucks for the cars and the engineers that did not design the car to have problems. Seems all I can do is let them know I am not happy and hope for the best.
#11 OFFLINE   txlaw
txlaw
  • 104 posts
  • Joined 24-September 06
Posted 06 December 2008 - 03:43 PM
I have not been reading the forum for quite some time. My 07 was built on10/26/2006.  I dont' have many miles, less than 4000 I'm embarassed to say.  With my build date am I vulnerable to this clutch problem?  If so, I am in the Houston area anyone had it done at a Houston dealer successfully?
My own 1500 Club:
Viper GTS
SRT-10 Ram Quad Cab
Shelby GT500
#12 OFFLINE   Grabber
  • 34,337 posts
Posted 06 December 2008 - 06:27 PM
Yes.
#13 OFFLINE   txlaw
txlaw
  • 104 posts
Posted 06 December 2008 - 07:24 PM
View PostGrabber, on Dec 6 2008, 08:27 PM, said:
Yes.
So what should I do?
My own 1500 Club:
Viper GTS
SRT-10 Ram Quad Cab
Shelby GT500
#14 OFFLINE   Grabber
  • 34,337 posts
Posted 06 December 2008 - 07:33 PM
Do you have any of the symptoms listed in the TSB ? Study it and know it well.
Attached File  GT500_Clutch_drag_TSB_08_16_04.pdf   50.67K   494 downloads
School yourself up on the new parts shown in my install thread:
http://www.teamshelb...p...ic=32271=
Do some testing like I did. Here's my clutch test thread:
http://www.teamshelb...p...ic=11629=
Make sure you read post #54 too:
http://www.teamshelb...p...st&p=522571
Edited by Grabber, 06 December 2008 - 07:35 PM.
#15 OFFLINE   markham51
markham51
  • 1,121 posts
  • Joined 12-March 06
  • Interests:Cars, boats, golf, fishing!
Posted 21 December 2008 - 06:01 AM
Great advice.  Thanks Grabber.  Anything else I should emphasize with the full failure I have had on my SS 725?
Regards
Mark
A politician divides mankind into two classes: tools and enemies.
68 Shelby Mustang GT500KR Convert Acapulco Blue
66 Mustang 289 Coupe Emberglo, MCA Gold 2000 (SOLD)
05 Corvette Convert Daytona Sunset Orange
06 Land Rover LR3 HSE
07 Explorer Sport Trac Limited Red
07 Shelby GT500 Convert Torch Red
07 Shelby GT500SS Coupe Tungsten Grey
10 Lincoln MKS Ecoboost AWD
#16 OFFLINE   Grabber
  • 34,337 posts
Posted 21 December 2008 - 09:41 AM
Mark - You have a PM.
#17 OFFLINE   Grabber
  • 34,337 posts
Posted 12 February 2009 - 08:51 PM
Mark,
How did you make out ?
#18 OFFLINE   shelbypowered
shelbypowered
  • 491 posts
Posted 13 February 2009 - 08:23 PM
Thanks for coming back on the clutch issues Grabber your needed and appriciated-
#19 OFFLINE   Grabber
  • 34,337 posts
Posted 13 February 2009 - 08:26 PM
We all need each other once in a while.
#20 OFFLINE   Torch40
Torch40
    Charter Member Team 40th
  • 2,298 posts
  • Joined 18-October 07
Posted 24 April 2009 - 08:56 AM
Should this be a sticky?
2007 Torch Red GT500 40th completed 5/22/08
Griggs Stuff - Rear "GR40 SS" with Watts Link 12/9/09
C&R Racing Cooling Package 12/9/09
For the track - Jongbloed Wheels, Toyo R888's Nitto Invos - street
Deliver 40th to Shelby American Motorsports 4/6/11 for a few more mods...
Picked up 6/14/11 Whipple 2.9L -- 638 RWHP 581 Torque
Stock Clutch
4/06/11 Pick up 2011 GT350 # 50
624 HP Polished Supercharger, Watts Link, Shelby Brakes, Museum Delivery
Proud Member of Team 40th
Posted Image Posted ImagePosted ImagePosted Image
