Check Engine Light
7 replies to this topic
#1 OFFLINE   DDT
DDT
    Dave
  • 5,936 posts
  • Joined 23-August 07
  • Interests:"Don't blame me"......."What did I do"???????
Posted 28 May 2009 - 02:03 PM
Question for the Great Techs here;
I have less than 10K miles on the 05 Mustang GT and the Engine Light was staying on.
No performance complaint so without a scanner I disconnected and reconnected the
battery and no more active light.........
Should this still be a concern?????????
#2 OFFLINE   07-2937
07-2937
    Bill
  • 1,032 posts
  • Joined 21-February 08
  • Interests:Cars
Posted 28 May 2009 - 05:22 PM
yes any CEL is a concern if you dont have a code reader go by checker auto or autozone  or whoever in your part of the world and they will read the code for you for free..  then fix the prob
Former SAI line Manager SGT,KR,50 SSnakes
07SGT2937, White, 5 speed,shkr1000, 2008 HID, GT500  Steering wheel
GT500 Brembo brakes, Metco uca, Whiteline subframe connectors/LCA's
CS hood,STR wheels/ 20"Razors,Gage pod, Secret stuff
http://s18.photobuck...ownhilbil/2937/
Gen 2 Whipple HO
Dyno tuned 512rwhp 471 trq @ 72degrees F @1524 feet alt
#3 OFFLINE   DDT
DDT
    Dave
  • 5,936 posts
Posted 28 May 2009 - 05:25 PM
Will do, thank's for the reply..........
#4 OFFLINE   hotrodric
hotrodric
  • 539 posts
  • Joined 05-November 07
Posted 28 May 2009 - 05:27 PM
Could it be the 130 MPH run from LA to Vegas at CS85 that percipatated the problem?  :hysterical:
2008 GT500 SUPERSNAKE VISTA BLUE / , CSM SS080218
BUILD COMPLETED 6/03/09
725HP; SHELBY/EIBACH; 6S SHELBY/BAER FRONT & REAR; SHELBY COOLING SYSTEM; SHELBY WHITE BALL SHIFTER
Updated Mods; Oliver Rods, Calais Bearings, Calico Coatings, Manley Pistons & Rings, Ferrea Iconol Intake & Exhaust Valves, Nextek Valve Springs, ARP Fasteners
#5 OFFLINE   DDT
DDT
    Dave
  • 5,936 posts
Posted 28 May 2009 - 05:30 PM
Ya that was Fun......... ;)
You really think the "CEL" has that long of a delay??????? :hysterical:
#6 OFFLINE   hotrodric
hotrodric
  • 539 posts
Posted 28 May 2009 - 05:33 PM
Check your gas cap... pretty typical problem if the cap is not tight or the seal has gone bad.  If you check the codes and you get an emmision error, this is most likely the problem.  That is unless you have been runing leaded gas :hysterical:
#7 OFFLINE   DDT
DDT
    Dave
  • 5,936 posts
Posted 28 May 2009 - 05:42 PM
Leaded Gas is still available???????? :doh:
Anyway I did check the cap and the electronic system check on dash is all okay.......
Couple of days ago I forgot I left it Idleing on the driveway for an extended time
which may have something to do with it??????? :shrug:
Edited by DDT, 28 May 2009 - 06:03 PM.
#8 OFFLINE   socalwrench
socalwrench
    The Fixer
  • 1,696 posts
  • Joined 11-April 09
Posted 12 June 2009 - 05:23 PM
Excessive idling should NOT cause a DTC (diagnostic trouble code). Driving the car fast could cause a problem, but is would usually be evident immediately.
Disconnecting and reconnecting the battery, only resets the computer and erases the adaptive strategy.
Leaded fuel is still available, and is used on many aircraft (for several off topic reasons). However, NEVER use leaded fuel in your modern car. Essentially, the lead will clog up the catalytic converters- which causes several other problems.
Next time the light comes on, drive it gently to the nearest place that has a code scanner. Or, your can buy a cheap scanner and use it the next time the light comes on.
Lastly, most Ford cars and trucks have a separate gas cap light that will come on if the cap is accidentally left off. It should go off after two successful key cycles (evaporative system pressure check).
Edited by socalwrench, 12 June 2009 - 05:24 PM.
TS Member
TRT Member
Greg
