Quantities are limited on the first batch so if you haven't pre-ordered one and are looking to purchase one please feel free to order online or by giving us a call.
http://www.lethalper...l-cover-p-28522
Here's some information on the Fore Precision Works IRS Differential Cover.
Engineered, high rigidity design for maximum strength
Billet 6061-T6 material is highly resistant to failure
Axle bearing cap pre-load bolts for maximum differential strength and reliability
Bottom accessible drain plug for simple draining
Higher fluid volume for increased heat capacity
O-ring seal will not leak and does not require silicone for easy and clean installation and removal.
Integrated cooling fins for maximum heat dissipation
Additional feed and return ports for differential cooler
Posted 30 June 2009 - 08:23 PM
