Will 11" widened stock wheels fit with Griggs GR40SS and 315 kit?
8 replies to this topic
#1 OFFLINE   cloud9
cloud9
  • 971 posts
  • Joined 12-July 06
Posted 11 November 2009 - 09:14 AM
I have the Griggs GR40SS kit with Watts Link and the "315 kit" installed that moves the rear shocks inward allowing a wider wheel to fit. I was thinking of widening my road track set of stock wheels to 11" and running Hoosier 315/30/18s which are 12.5" wide and recommended for 11"-12" rims.
I currently run the Nitto 305/40/18s on stock rims for the street and they are 12.13" wide and Toyo R888 305/35/18s on the track. I got under the car and measured to see what clearance looked like. It looked like the closest contact point is the bolt head at the top of the shock. I measured just under 2" of clearance to my Nittos and the Nittos sit 1/2" outside the stock 9.5" rims. To me it seems like I've got plenty of room to go 11" rims since the Hoosiers shouldn't sit outside the rim diameter like the Nittos. I wasn't able to measure clearance at the bump stops without getting it on a four wheel lift so I can measure with the suspension loaded.
Anyone know if the 11" will work fine with the Griggs rear setup?
Vista Blue with White Stripes
640 rwhp/625 rwtq
VMP Custom Tune, TVS 2.3L supercharger with Stiegemeier interchangeable hub and 2.6" & 2.9" Metco pulleys, FRPP CAI, Griggs GR40SS with Watts Link and front Koni coilovers, Revan Racing twin fan heat exchanger, Revan Racing radiator, VMP Intercooler Reservior Tank, 2008 GT500 lower pulley, Goodridge Steel Brake Lines, DBA 5000 2-piece Slotted Rotors, Hawk DTC 60/70 Pads, JLT Brake Cooling Kit, FRPP SVT1 Exhaust, FRPP 3.73 Gears, CHE Drive Shaft Safety Loop, Aeroforce Interceptor Gauge, Homelink Rear View Mirror
2012 Boss 302 CO/BK with Recaros/Torsen - Aeroforce Gauge, LS wing, Corsa Extremes, Trans scoop, brake cooling hoses, SS Lines, MM c/c plates, JLT Oil Separator, MM 4pt roll bar, 302S (suspension,hood, grille, splitter radiator, air-to-oil cooler & tow hooks), MGW Shifter, ARP studs
#2 OFFLINE   Revan Racing
Revan Racing
  • 2,380 posts
  • Joined 27-June 07
  • Interests:Road Racing
Posted 11 November 2009 - 09:25 AM
You can go to 11" rims but we've run 10.5 with Toyo 305's on some cars. I don't think you need to go too wide. The biggest thing is the rotational mass of that wheel. Braking and the moment of inertia with a wheel that size are dramatic. When I finally get my 10.5" rims I will likely run 305's or 315's on all four corners.
You'll be fine either way with the 315 kit in place.
Van
2007 Shelby GT500 Alloy Metallic # 357 NASA Time Trial Unlimited Competition Vehicle
WWW.REVANRACING.COM
2007 Shelby GT500 Alloy Metallic Coupe
Purchased October 30, 2006
Shelby Registry Documented as GT500 cooling system development car
Modifications:
Revan Racing/Shelby Original Prototype Radiator, Revan Racing/Shelby Original Prototype Heat Exchanger, Revan Racing/Shelby Reservoir Kit
Griggs Racing Products GR40 ST Suspension with Watts Link and Full Front SLA, Dynotech 1-Piece Aluminum Drive Shaft, dba Slotted Rotors, Hawk DTC 70 Race Pads, Brembo LCF 600 Plus Brake Fluid, Forgeline ZX3R's Matte Black with Titanium Fasteners and Hoosier R6 315's on all 4 corners
Kenne Bell 3.6LC Polished Competition Supercharger with 3.75 Upper, Kenne Bell Competition Boost-A-Pump, 2008 Lower Pulley, HPX MAF Sensor, Jon Lund Tuned and Calibrated (at least 100 times), Borla XR-1 Racing Long Tube Headers, Catless X-Pipe, Borla XR-1 Mufflers, Ford Racing Sparco Race Seat, Shelby Shifter, Silver Horse Racing Side Window Louvers, Agent 47 Retro Mirrors, Proglass Retro Ram Air Hood with Run Cool Hood Louvers, Agent 47 Brake Ducts, Schroth Racing harnesses, AEM Wide Band
Stock Motor Died on track at Daytona International Speedway December 2009 at 190+ MPH
New Motor Born February 2010
Custom Diamond/L&M Race Pistons 9.5:1 Compression, Oliver Rods with ARP 2000 Rod Bolts, Manley Titanium Valve Spring Retainers, Ferrea Super Alloy Exhaust and Intake Valves, AP Rings, Speed Pro Main and Rod Bearings, Ford GT Cams, Canton Road Race Oil Pan, Complete ARP 2000 Bolts throughout
Sponsored by: L&M Engines, www.lmengines.com C&R Racing, www.crracing.com Kenne Bell Superchargers, www.kennebell.net Lund Racing, www.lundracing.com SPEC Clutches, www.specclutch.com Griggs Racing www.grigg ing.com & Borla Racing Exhaust Systems www.borla.com
#3 OFFLINE   KR158
KR158
  • 450 posts
  • Joined 02-October 09
Posted 11 November 2009 - 10:09 AM
Van I want my KR to look like the car on the site and I need the cooling package too. I need a package deal for the entire set up ;)
#4 OFFLINE   jamesb
jamesb
  • 396 posts
  • Joined 01-May 09
Posted 11 November 2009 - 01:43 PM
IIRC the tech who measured my wheels reckoned that I could fit 11". My advice: DONT RUSH THINGS. Get the kit installed, then measure what you have.
Jamie
Black delete 2007 Shelby GT 500 Coupe, FRPP CAI, 3.73's, Griggs ST + Watts, Revan Racing cooling package. VMP Stock look 2.65 pulley, IW 10% OD, tune. All installed by Alex at Encinitas Automotive. HRE 10.5" C80s. Toyo RA1 305/35R18 from Chicane23.
#5 OFFLINE   chicane23
chicane23
  • 34 posts
  • Joined 20-January 08
  • Interests:Open Track events and Team Shelby events
Posted 11 November 2009 - 02:19 PM
The recommendation from both Griggs Racing and us is to use the following:
10.5 wheel
- Toyo 888 305/35-18
- Toyo RA1 305/35-18
- Hoosier R6 315/30-18
We have had great success with these combos both on the street and on the track.
John G.
AI #23 - 2004 & 2005 American Iron series Champion
2004 AIX Cobra - GR40 WC SLA, Griggs 4on4 Brake System, De-cambered hybrid 8.8"/9" Rear End, Jongbloed 305 Aeros 17x10.5, Hoosier R6 315/35-17, Tiger Racing Carbon Fenders, doors, Air Extraction Hood, G-Stream Wing and Splitter - 647 HP/517 TQ
1995 AI GT - GR40 WC SLA, Griggs 4on4 Brake System, De-cambered hybrid 8.8"/9" Rear End, 275/40-17 Toyo RA-1, Tiger Racing Carbon Fenders, Air Extraction Hood, G-Stream Wing and Splitter - (362rwhp/382rwtq) (Detuned for AI 333rwhp/354rwtq)
Chicane 23 Store
Griggs Racing, Maximum Motorsports, Agent 47, G-Stream Wings, Brembo, Baer, Canton, Fuel Safe, Toyo Tires, Koni, Pit Pal, ChaseCam, StopTech, etc.
#6 OFFLINE   cloud9
cloud9
  • 971 posts
  • Joined 12-July 06
Posted 11 November 2009 - 04:52 PM
Van
Good point on the rotational mass and more braking needed :doh:
640 rwhp/625 rwtq
#7 OFFLINE   cloud9
cloud9
  • 971 posts
  • Joined 12-July 06
Posted 11 November 2009 - 04:55 PM
10.5 wheel
Great thanks! I've been running the 305 R888s on the 9.5s but don't like the flex from the tire hanging out so much over the rim. I really want to run the Hoosier R6 315 so I guess 10.5 is the ticket. Hopefully that doesn't add too much weight? I know Van's gonna tell me to pony up for some new (lighter) rims versus widening the stockers :banghead:
Edited by cloud9, 11 November 2009 - 04:55 PM.
640 rwhp/625 rwtq
#8 OFFLINE   kahmann
kahmann
    08SGT1292
  • 7,347 posts
  • Joined 30-May 08
  • Interests:Going fast.
Posted 11 November 2009 - 05:00 PM
305's on a 9.5 rim is not a good idea. The chance of sidewall damage increases greatly with that wide of tread on the stock wheel.
Do you track the car with that setup or just street? The OEM SVT rims are heavy as all hell, but for $225/ea, Weldcraft is a heck of a good deal, IMO. Good luck
Ken
2008 Shelby GT (#1292 of 2214)
LIVERNOIS - WHIPPLE - MANLEY - COMP - GRIGGS RACING - WELDCRAFT - TOYO
#9 OFFLINE   chicane23
chicane23
  • 34 posts
Posted 11 November 2009 - 05:50 PM
Nothing like a great set of lightweight Forgeline or Jongbloed Wheels ;-)
John G.
Chicane 23 Store
