What does "tire pressure sensor fault mean"
14 replies to this topic
#1 OFFLINE   mustangshelbygt500
mustangshelbygt500
  • 121 posts
  • Joined 19-June 09
Posted 24 December 2009 - 12:50 PM
I got this warning on my screen with the tire pressure light flashing, it says "tire pressure sensor fault". I checked all the tires, all of them were 30 psi, everything looked ok. Why am I getting this warning? What does it mean?
#2 OFFLINE   08 Mustang
08 Mustang
  • 908 posts
  • Joined 23-September 09
Posted 24 December 2009 - 02:18 PM
Typically it means the tires are low. I'd start out by putting some more air in the tires and see if that turns the dash warning off and go from there.
2003 SVT Cobra
Kenne Bell Polished 2.2 l Al Papitto-Boss 330 Racing Short Block l Accufab Throttle Body l 3.25 upper - 4lb lower l CCW Classic Rims l Spec Stage 3+ Clutch l Fidanza Flywheel l MAC Ceramic Coated Headers l Lethal Performance X-Pipe w/Magnaflow Highflow Cats l Borla Stinger Catback l Billetflow IRS Brace l Kenny Brown Springs
Tuned By MV Performance
*Dyno Video ~ 008.MOV - YouTube
*Walk Around Video ~ 042.MOV - YouTube
#3 OFFLINE   kahmann
kahmann
    08SGT1292
  • 7,347 posts
  • Joined 30-May 08
  • Interests:Going fast.
Posted 24 December 2009 - 02:26 PM
One of the sensors may have failed inside of the tires. Or one of the bands may have broken and a sensor might be floating around in there. Same thing happened to me a couple months back. Or it could just be a computer error.
Ken
2008 Shelby GT (#1292 of 2214)
LIVERNOIS - WHIPPLE - MANLEY - COMP - GRIGGS RACING - WELDCRAFT - TOYO
#4 OFFLINE   Son of GT
Son of GT
    "THERE'S NOTHING LIKE A SHELBY... NOTHING.
  • 5,477 posts
  • Joined 18-April 06
  • Interests:Most Motorsports, all types of cars and trucks; especally anything Shelby. My country, family, and friends, and all who have served or are serving in the military defending the U.S.A. Still and video photography; and of course morally casual women!
Posted 24 December 2009 - 03:54 PM
When you have low tire pressure in one or more of your tires you will get a message saying "LOW TIRE PRESSURE" and a small amber icon of a flat tire will illuminate in your gage.
"TIRE PRESSURE SENSOR FAULT" is exactly what Ken (Kahmann) says it is. A loss of signal from one or more of the TPS's (tire pressure sensors). As stated, one or more mounting bands may have snapped, one or more of the sensors have failed, or they just need to be reprogrammed. Your dealer or most tire shops have a hand held device that is placed against the sidewall of the tire which uses a RF signal to reprogram each TPS in about five minutes or less. That would be the first thing that I would try, and if that doesn't clear the fault, then I would pursue the other potental causes of the fault code.
Current Stable:
1972 Bronco restomod equipped with an R-spec 5.8, AOD, 4-wheel disc brakes, as well as several other mods.
2003 Mercury Marauder
2007 Performance white SGT S/C CSM #12
2007 Grabber Orange GT500 Convertible VIN #00012; Super Snake CSM #12.
PLEASE BUY AMERICAN MADE PRODUCTS WHENEVER POSSIBLE; NOW MORE THAN EVER BEFORE!
IN MEMORY OF JOE GOSINSKI, 10-23-66 / 12-24-10. RIP JOE, YOU WILL ALWAYS BE MISSED.
"As long as there's America, there will always be a Mustang." - Jay Leno.
"The more time I spend in this place, the more I like dogs". - Me.
Posted Image Posted Image Posted Image Posted Image
Posted Image Posted Image Posted Image Posted Image Posted Image Posted ImagePosted ImagePosted ImagePosted Image Posted Image
Posted Image <--- Current weather at Shelby American, Las Vegas, NV
1987 Mustang LX Convertible, modded. Sold Feb. 2007. Goodbye old friend, you will always be missed.
#5 OFFLINE   Tob
Tob
    Neo Rapscallion
  • 1,198 posts
  • Joined 25-November 08
  • Interests:Organizing my sock drawer.
Posted 25 December 2009 - 06:29 AM
As soon as the outside temperature goes down (I'm twenty minutes from downtown Buffalo, NY) my dash lights up indicating the same thing. If it warms up, the light will go off. My sensors are fine, and I have the programmer that is used to 'retrain' the sensors. After a lengthy discussion with my local Ford dealer, they all said the same thing - the system is a PIA, especially for them. They get a lot of people coming into their shop with brand new vehicles with the same complaint.
Tob
#6 OFFLINE   springer
  • 1,746 posts
Posted 25 December 2009 - 07:37 AM
Don't know if this applies to you, but on my Sequoia, my tire sensor light came on and it was the spare tire that was low on air. I had to take it to the dealer to figure it out. :banghead:
#7 OFFLINE   GT500FLYBOY
GT500FLYBOY
  • 3,116 posts
  • Joined 16-September 06
Posted 25 December 2009 - 08:01 AM
Get yourself a training device - you can find them on ebay for like $15. set your tire pressure to what you want - then retrain all tires. i need to do this everytime i change sets of tires. i have set for the strip - set to 18lbs. everyday driving 35 lbs. road course 40lbs. i have also had tpms sensor problems, but you're going to want to do above anyway. start with that before you start dismounting tires to find a bad tpms. one indication of a bad tpms strap is you'll have tire balancing issues. you won't be able to get a tire properly balanced with the strap and tpms flopping around. if you don't have balancing issues - at least you know there are no broken straps. if you think you do, take a wheel a just roll it by hand - you should hear the strap and tpms flopping.
Proud member of Team 40th - 07XL0078
2007 Shelby GT500. Ordered 7/31/06. Built 2/8/07. Delivered 3/5/07.
40th Anniversary Shelby GT500 CSM07XL0078 completed 3/24/08.
Whipple 2.9L supercharger, 3.25" pulley, lower IW pulley,
Whipple monoblade TB. C&R radiator, dual fan I/C heat exchanger.
730 RWHP, 680 RWTQ. 1/4 11.18 @ 127.
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
#8 OFFLINE   mustangshelbygt500
mustangshelbygt500
  • 121 posts
  • Joined 19-June 09
Posted 25 December 2009 - 10:08 AM
I think when it says "Low tire pressure", it means the tires are low. I did what you said anyway and it worked but after a mile I got the same warning again
Edited by mustangshelbygt500, 25 December 2009 - 10:09 AM.
#9 OFFLINE   mustangshelbygt500
mustangshelbygt500
  • 121 posts
  • Joined 19-June 09
Posted 25 December 2009 - 10:23 AM
Tob
At what temperature does that happen? if it's below 40 degrees then I'm fine, I guess.
Edited by mustangshelbygt500, 14 January 2010 - 10:43 PM.
#10 OFFLINE   mustangshelbygt500
mustangshelbygt500
  • 121 posts
  • Joined 19-June 09
Posted 25 December 2009 - 10:42 AM
Ken
Thank you all for the answers
Edited by mustangshelbygt500, 25 December 2009 - 07:08 PM.
#11 OFFLINE   mustangshelbygt500
mustangshelbygt500
  • 121 posts
  • Joined 19-June 09
Posted 25 December 2009 - 10:49 AM
I wish the problem was that, but GT500s don't come with spare tire
#12 OFFLINE   TexasShelby
TexasShelby
    S197ShelbyOA #139
  • 3,046 posts
  • Joined 28-March 07
Posted 26 December 2009 - 03:50 PM
Made a Deposit in May of '05. Delivered November 1st. 2006.
#13 OFFLINE   ovrpar6
ovrpar6
  • 8 posts
  • Joined 27-September 15
  • Interests:Golf, Detailing my cars, performance upgrades
Posted 14 October 2015 - 03:53 AM
I see this is an old thread but I'm a NEW owner of a 2008 Shelby GT 500 vert. Intermittently I get the "TPS sensor failure" unfortunately it always happens on Sunday and the next time I drive it could be 3 to 5 days and the message is gone. Tire pressure is good. Possibly computer glitch?
How do you turn off the TPS anyway? On my other cars you can thru the iDrive. I just drive for pleasure so the TPS really isn't needed.
#14 OFFLINE   Leroy
Leroy
  • Mountain Region
  • 169 posts
  • Joined 22-September 07
  • Interests:Cruising, Cars
Posted 15 October 2015 - 10:36 AM
One or more of your TPMS sensors is failing. This could be as simple as a Battery or the sensor itself. If you have after market sensors they can be troublesome too. Suggest to re-train the sensors and re-evaluate it's operation. Cant turn off the warning either, Federal law. Do a search to find out how to train your tire pressure sensors for more info.
FRPP CAI
KR Exhaust
H-Pipe
FRPP Short throw shifter
FRPP Chrome shifter and white shifter ball
Updated clutch and flywheel 2nd Generation
Webelectric sequentials
Shorty Antenna
Carroll Shelby Signed dash plaque
KR Trunk Hood Liner
3.73 Ford Bullitt / KR OEM Service Gears
FRPP Axle Girdle
KR Axle Reservior
S H E L B Y trunk letters (JLT)
TVS VMP Supercharger 2.5 pulley 91 octane VMP Tune
Redline front hood Struts black
FRPP Lowering Springs
FRPP Front and Rear Sway Bars
Tokico Adjustables
BMR Adjustable Panhard Bar and Brace
KR Brake Cooling Bezels w/kit and Lower grille
GT-500 Dead pedal
DG Customs Outside Mirror covers
08 Shelby GT Vista Blue Auto
Shorty Antenna
FRPP Blue rocker covers
Redline Hood Struts Black
Shelby GT Dead Pedal
Shelby Store GT 3 piece Floor mat set
Sequential Turn Signals
Carrol Shelby Signed Passenger Visor
Shelby GT Trunk liner
DG Customs Outside Mirror Covers
Shelby Front Brake Duct Bezels and PIAA Fog lights
#15 OFFLINE   rsfdiver
rsfdiver
  • 559 posts
  • Joined 02-February 08
Posted 02 January 2016 - 12:48 PM
My TPS warning was blinking too after I had my battery disconnected for a day. I just hit reset on the dash, did my after spark plug and air filter change beat the car run it never came on again...
Yet...
Where am I going,
and why am I in this hand basket?
