VMP Polished TBs and Polished D port elbows in stock
8 replies to this topic
#1 OFFLINE   Justin00Stang
Justin00Stang
  • 1,672 posts
  • Joined 13-September 06
Posted 28 January 2010 - 09:33 AM
I have polished elbows in stock for the guys that want some major bling (OE powdercoat black also available).
http://www.vmptuning...=358&parent=105
http://www.vmptuning...=350&parent=105
This is our dual 72MM Throttle Body and matching high-flow inlet elbow, designed to make big power on the TVS. Same setup used to make 748RWHP on my car.
The D-port shape flows the most amount of air with the least amount of porting.
The big difference between the standard elbow and the big elbow is the floor. The big elbow has the floor lowered to take advantage of the hollow area inside the TVS blower. The big elbow also has a larger opening on the front to accommodate the VMP 72MM Dual Bore TB.
The standard elbow still has the D-port shape but does not have the floor lowered, so it requires less port matching work, it is designed for stock blower and mild TVS applications. The opening on the front of the standard elbow is stock sized and fits the following TB variants: 66MM, 67MM, and monoblade.
Both elbows re-use the large molded OEM O-rings to assure a perfect seal.
ALL elbows are cross compatible and use the same bolt patterns, which allows you to mix and match parts so you do not have to spend the money twice.
For example, if you are going to buy a TVS in the future you can use our big elbow and 72mm TB on the stock blower, it just requires a little more port matching.
If you already have a monoblade TB or 66MM TB you can use our standard elbow, or take advantage of the lowered floor on our Big elbow.
The only requirement, if you want to use the 72MM TB, you have to use the Big elbow as it has the larger opening on the front to accommodate the large dual bores.
Pic of the 72MM TB, and the the big inlet elbow with shots of the inlet and outlet:
Standard D-Port vs Big D-Port:
To make more power the hole on the blower has to be enlarged, here is a shot of how material needs to be removed for the standard elbow:
Both elbows also have extra material cast in so you can go even farther if you wish. With the D-port design of our elbows, and the revised turn radius, our elbow will flow more than even the best port job on the stock elbow.
Justin Starkey Justin@VMPTuning.com VMP Tuning- GT500 Specialists
2007 Shelby GT500 Red/Silver
Highest HP with 2.3L TVS816RWHP/779RWTQ
Mods: VMP 2.3L TVS Supercharger, VMP Dyno-Tune, VMP 2.5" Upper, VMP 72MM TB & Elbow, 123MM MAF, IW 10% OD balancer, 80s, Dynatech 1 7/8" LTs, Comp Stage 2 cams.
New VMP 2.3L TVS Supercharger $3,499
07-12 GT500 Custom Tuning starting at $199
2011 Mustang GT 5.0L with Roushcharger 9.79@140, wife's car
2006 Mustang 4.0L with Vortech @ 15psi & 6spd, wife's car
2006 Jeep GC SRT8 6.1L AWD, wife's truck
2006 F250 6.0L PSD 4WD CC
2000 Mustang Twin Turbo
#2 OFFLINE   OrthoDude
OrthoDude
  • 59 posts
  • Joined 17-March 08
Posted 28 January 2010 - 10:54 AM
Oh yes, that is what I have been waiting for. Any tips on disassembly of the TVS and porting. I would like to do everything myself. Since I am an orthodontist I could bring it to my office and have one of my assistants hold suction for me while I grind on the TVS in one of my chairs. However, I am sure there is a better way. Thanks Justin for all that you have helped me with so far.
2008 GT500
TVS Supercharger
FRPP CAI
2.65" Upper
66mm TB
Kooks LT Headers w/ catless x
Magnaflow Mufflers
AFCO HE
3.73 Gears
3.5" DSS Aluminum Driveshaft
Steeda LCA's
FRPP Springs
FRPP KR Shifter
VMP 93 Octane
623 RWHP, 610 RWTQ SAE
#3 OFFLINE   SVTpower
SVTpower
  • 3,078 posts
  • Joined 24-February 06
Posted 28 January 2010 - 03:50 PM
Hey Justin, just curious, with all the hype over the last few months on the L&M 66 and how good it is over the monoblade whipple and it's ability to flow huge numbers, why the 72mm now. I am considering the L&M based on the talk off great driveability and throttle response. Is your 66mm not enough for your combo? thanks
2007 Shelby GT500 Coupe Ebony/Tungsten stripes Received Dec 27th, 2006
Evolution TVS Stage 5, Car # 11 - 659 rwhp. Officially tagged Sept 16, 2008
TVS Upgrade
Innovators West 4lb lower
Whipple 160mm TB
Evo Heat Exchanger/180 deg.stat
Mafia Extender
Evo Polished Fuel Rails
Ford GT Polished Coil Covers
Moroso Powdered Coated Black Coolant Tank
BMR Billet LCAs, Adj. UCA, Adj. Panhard Bar & Frame Connectors
JLT Carbon Fibre treats
Ford Racing 5GT's Exh., Lowering Springs, 3:73's, Shift knob/handle, & KR strut brace
MRT Hood Lifts
DynoTech Aluminum Driveshaft
Nexuus Gauges with SOS dual pod
Shelby signed Dashplate
Cobra Outlet Plug
'Shorter' Antenna (HomeMod)
Evo/Asanti 20's with 325's & 255's
#4 OFFLINE   dwight_c
dwight_c
  • 206 posts
  • Joined 25-February 08
Posted 28 January 2010 - 06:13 PM
Hey Paul,
Diassembling the supercharger is not very difficult just make sure you remove and reinstall the rotors with the front of the case facing up to keep from scaring the rotors and case.
I'm attaching some pictures showing how much material you remove along with how it looked after it was ported.
08 Vapor GT500
Polished TVS with VMP 2.65 pulley
VMP Large D port plenum
L&M 66MM TB
Lund Racing tune
IW. 10% lower
80lb FRPP Injectors
JLT intake with Tru flames, JLT carbon fiber radiator & fuse cover with Tru flames
FRPP Lowing springs, Steeda Upper & Lower CA's, Steeda pan hard bar & brace
Dynatech 1-7/8" Long tubes
3" Magnaflow cat back
Canton supercharger & coolant expansion tanks
Revan Racing (C&R) Heat Exchanger & power steering reservior
FRPP 3:73
CS69 LE Wheels 20x9 Nitto 555 255/35/20 & 20x10 Nitto DR 305/35/20
#5 OFFLINE   dwight_c
dwight_c
  • 206 posts
Posted 28 January 2010 - 07:11 PM
It's only allowing me to attach one pic and the rest are to large in size. :banghead:
08 Vapor GT500
L&M 66MM TB
Lund Racing tune
IW. 10% lower
80lb FRPP Injectors
FRPP 3:73
#6 OFFLINE   dwight_c
dwight_c
  • 206 posts
Posted 28 January 2010 - 07:17 PM
Another pic
08 Vapor GT500
L&M 66MM TB
Lund Racing tune
IW. 10% lower
80lb FRPP Injectors
FRPP 3:73
#7 OFFLINE   skiph
skiph
  • 917 posts
  • Joined 26-March 08
Posted 29 January 2010 - 06:55 AM
Very nice!
Would those bolt up nicely to a stock SC and C&L or JLT CAI? Or would that extend the CAIs too far forward?
Oh, and is VMP planning on offereing JLT CAIs any time in the future. Performance wise, as I understand it, the C&L and JLT CAI would have same tune & perform the same. The JLT with the carbon fiber neck and bright red filter available for it just add a bit more "blink", IMHO of course, then the C&L
Edited by skiph, 29 January 2010 - 06:56 AM.
2008 GT500 Coupe. ~~~~~~~~~~~~~~~~~~~~~~~~~~~ Manufactured 1/22/2008
Came as Black w/White Stripes. ~~~~~~~~~~~~~~~~~~ Nav, HID, Sirius Sat Radio
Full post-sale Red Appearance Package conversion ~~~~ So 1? of 0 2008 Coupes w/red app pkg
SPP Center Gauge Cluster ~~~~~~~~~~~~~~~~~~~~~~ BangaStang Radiator Cover
Vehicle #3936 of 6513 2008 coupes ~~~~~~~~~~~~~~~~ VMP C&L CAI, 2.65" Pulley & Tune
Cobra caps under the hood for all liquids. ~~~~~~~~~~~~ Premium Trim Package
Tinted windows, 20% back & 30% on front. ~~~~~~~~~~ "KR" Exhaust
Carroll Shelby Signed Dash Plaque ~~~~~~~~~~~~~~~~ SHELBY GT500 portion of door sill plates painted red
RedlineTuning hood lifts ~~~~~~~~~~~~~~~~~~~~~~~~ Sequential Tail lights
Oh have I mentioned.. I love this car!
#8 OFFLINE   Justin00Stang
Justin00Stang
  • 1,672 posts
Posted 29 January 2010 - 02:59 PM
Hey, I don't know if you remember, but a while back I tested the monoblade and dual 66 on my upper+lower TVS GT500. This was back in the early days of the TVS, and we were not modifying the elbow yet.
There is a clear difference in surface area on the 66 vs the monoblade, as the mono is just like a 66 but with the middle totally opened up.
Both TBs made the exact same power, even though the mono had a lot more surface area for air flow.
This told us the A) the engine did not need more air or B) the restriction lies elsewhere.
With further testing and elbow modifications I found the restriction lie in the factory elbow.
Once I made an elbow that flowed enough air I found the 66mm TB was too small.
Hence the dual 72mm TB was born, it flows a ton of air, has the idle and driveability qualities of a dual bore TB, and still fits on the stock bolt pattern so its compatible with everything. Surface area is nearly as large as a monoblade but with all the benefits of a dual bore design.
#9 OFFLINE   Justin00Stang
Justin00Stang
  • 1,672 posts
Posted 01 February 2010 - 11:01 AM
Very nice!
Of course, the elbow places the TB in the stock location, so any CAI will work fine.
