High Compression and Supercharging vs. Engine modification
#1 OFFLINE   Shelby2809
Shelby2809
  • 378 posts
  • Joined 24-April 08
Posted 01 February 2010 - 12:24 PM
I feel like I know a lot about cars and how things work... truth is I don't really understand why the new 5.0 engine and its high compression ratio is bad for Supercharging. Maybe someone with a stronger knowledge of this could help explain it to me.
My second question, based on my knowledge of high compression engines is, why not upgrade the cams, intake (including porting and polishing the heads), and exhaust instead of supercharging this engine? It seems like that would be a safer way to get more HP and make this new GT350 very unique in the aftermarket Mustang world.
Thank you in advance, I'm very interested to understand this a bit more.
2008 Shelby GT
Vista Blue, SGT# 0572
Katzkin Custom Leather seats, not installed
SGT# 2809
#2 OFFLINE   DutchGT500
DutchGT500
    Team Shelby member #7
  • 3,442 posts
  • Joined 27-September 05
  • Region:European Union
  • Interests:Ducati
Posted 01 February 2010 - 02:09 PM
Faster way for detonation when there is too much boost. F.e. when people smaller pulley the SC.
Patrick
Proud organizer of the 2012 Shelby Run Europe
2500 miles, 10 days, 8 countries
07 Shelby GT500, Grabber Orange #3383 of 8152 coupes #127 of 282 Grabber coupes #? of 168 Grabber/White coupes
08 Shelby Terlingua, CSM08TRT0301, first Tasca Terlingua, converted at 1467 miles, delivered April 17, 2009 at the 45th Mustang Anniversary, Barber Motorsports Park and given to my wife for her birthday, signed by Carroll Shelby
09 BMW 530i touring, Platinbronze metallic
13 Ducati 1199 Panigale R, 204hp and 165kg
Current mods to car:
-Shelby autographed dash plaque
-Shelby gauge pod
-Shelby KR brake duct bezels
-Shelby Extreme Baer brakes front
-Shelby Extreme Baer brakes rear
-Ford Racing brake cooling kit
-Ford GT start button
-CDC directional mirrors
-CDC sequential taillights
-CDC dead pedal
-CDC hood struts
-Shelby KR mufflers
-Steeda Tri-Ax shifter modified with Hurst shifter stick and Shelby shifter knob
-Shelby billet engine caps
-Ground Control Koni Sport/Eibach coilover kit
-Steeda swaybars front and rear with billet brackets
-J&M lower control arms billet aluminum
-J&M adjustable upper control arm black
-Griggs racing Watts link
-MM 6 point rollcage in grabber orange
-Shelby extreme duty radiator
-Shelby extreme duty dual fans heat exchanger
-Shelby extreme duty anodized black coolant reservoir tanks
-Shelby transmission cooler scoop
-Shelby KR rear axle overflow reservoir
-Ford Racing performance intercooler
-Whipple 2.9L with 3.00" pulley
-Ford Racing Dual 65mm Cobra Jet Throttle Body
-JLT 127mm Carbon Fiber Intake
-72lb Fuel Injectors
-Fore Innovations fuel rails
-Kenne Bell dual Boost-a-Pump
-Reische Performance 170deg Thermostat
-Dynatech 1-7/8" longtube headers Jet-Hot coated
-L&M NSR camshafts
-2013 Shelby GT500 black/white leather Recaro's
-Ford Racing X-Brace in grabber orange and rear seat delete kit
#3 OFFLINE   Son of GT
Son of GT
    "THERE'S NOTHING LIKE A SHELBY... NOTHING.
  • 5,477 posts
  • Joined 18-April 06
  • Interests:Most Motorsports, all types of cars and trucks; especally anything Shelby. My country, family, and friends, and all who have served or are serving in the military defending the U.S.A. Still and video photography; and of course morally casual women!
Posted 01 February 2010 - 04:51 PM
In a nutshell, you generally don't want to force air and fuel under pressure (boost) into a high compression engine because the higher pressure will sooner or later wreck havoc on the valve train, head gaskets, heads, piston rings, connecting rods, rod bearings, and crank bearings. You could also end up bending the crank if it was not hardened. You could stretch the head bolts, and the intake manifold could also lift off the head too.
Additionally, and as Patrick (Dutch) stated, forced induction into a already high compressioned engine also causes detonation to occur, and that would destroy the tops of the pistons among other internal components.
A simplistic, "Mr. Wizard" way of putting it would be to take a balloon and just blow it up with your lungs until it's almost ready to pop. It would probably take you 25 to 40 puffs and about a half a minute to blow up an avarage sized balloon until it popped. Now take another, but smaller balloon and fill it with air from an air compressor. It would probably take you less than 15 seconds to fill it before it popped.
Perhaps that's not the best example I could give you, but I believe that it gives you a broad idea of the differences between a low compression engine and a high compression engine.
The GT350 is being supercharged under the care and guidance of Ford Racing, and essentally the boost pressure on the 5.0 and whipple combo will be quite low, but god help those folks who decide to increase the boost after they get the car home from SA.
It's the same thing with the Dodge Hemi engines too. Mopar says not to supercharge those engines either, but I have seen a few Challengers that have been supercharged with low boost Paxtons and Novi chargers in spite of that warning.
Hope this helps.
Current Stable:
1972 Bronco restomod equipped with an R-spec 5.8, AOD, 4-wheel disc brakes, as well as several other mods.
2003 Mercury Marauder
2007 Performance white SGT S/C CSM #12
2007 Grabber Orange GT500 Convertible VIN #00012; Super Snake CSM #12.
PLEASE BUY AMERICAN MADE PRODUCTS WHENEVER POSSIBLE; NOW MORE THAN EVER BEFORE!
IN MEMORY OF JOE GOSINSKI, 10-23-66 / 12-24-10. RIP JOE, YOU WILL ALWAYS BE MISSED.
"As long as there's America, there will always be a Mustang." - Jay Leno.
"The more time I spend in this place, the more I like dogs". - Me.
Posted Image Posted Image Posted Image Posted Image
Posted Image Posted Image Posted Image Posted Image Posted Image Posted ImagePosted ImagePosted ImagePosted Image Posted Image
Posted Image <--- Current weather at Shelby American, Las Vegas, NV
1987 Mustang LX Convertible, modded. Sold Feb. 2007. Goodbye old friend, you will always be missed.
#4 OFFLINE   Shelby2809
Shelby2809
  • 378 posts
Posted 01 February 2010 - 05:11 PM
Thanks for the replies, that helps to understand why you should apply to much boost to that motor.
What about the second question... if its not good to apply too much boost, why not increase intake and exhaust flow to increase the power in these motors instead? From other posts, I'd venture to say, intake, exhaust and cams would cost about as much as a supercharger (maybe a few hundred $ less)? Wouldn't that be a better way to go? Thanks again,
2008 Shelby GT
SGT# 2809
#5 OFFLINE   Son of GT
Son of GT
  • 5,477 posts
Posted 01 February 2010 - 05:21 PM
That would be a better way to go Jim, but then the car (engine) would not meet 50 state emissions requirements, and SA can't let a car out of their facility unless it meets all federal and state emission and safety requirements.
I, living in California, could not do any of those mods to my car without violating about 15 laws that say I can't.
Current Stable:
#6 OFFLINE   Shelby2809
Shelby2809
  • 378 posts
Posted 01 February 2010 - 07:17 PM
Gotcha, that makes sense. Maybe they'll do an "R" version this way... hint hint.
Thanks again guys... see how my brain goes when I'm on the road for work, all I think about is these cars and what we could do with them.
2008 Shelby GT
SGT# 2809
#7 OFFLINE   DubbsFaris
    Southern Plains Bunny Herder
  • 5,400 posts
  • Interests:Everything with a snake or a bunny!
Posted 01 February 2010 - 08:30 PM
Yeah, SAI is bound by manufacture licensing to not do that kind of engine work....that said....YOU could after you buy it....
I had the high compression explained to me as this...your 5.4 boosted becomes a high compression engine when you add the supercharger. The way the 5.0 is put together already gives you that high compression rate without a supercharger. At some point, every engine has its compression limits....or to put it more accurately, SOME component or components will fail.
2008 GT500 Convertible Red Stripe Appearance Package#14 of 131 **SOLD**2011 GT350 45th Anniversary First GT350 R Tune built and delivered!!! **SOLD** 2014 GT500 Coupe Deep Impact Blue Red Stripes Loaded except Glass roof. 1 of 28 coupes.**SOLD**2008 Shelby Terlingua Coupe Black with Yellow. 1 of 40-ish. CSCF Raffle car! I won it 3 years late!1989 Dodge Shelby Van by Safari.TEAM SHELBY SOUTHERN PLAINS REGIONAL DIRECTORFor Information on regional events and clubs in Arkansas, Louisiana, Oklahoma and Texas, watch the forums!Other Fords:2011 SVT Raptor SCrew, Molten Orange2015 Taurus SHO2015 WW Auto 50th Edition Mustang- 554
2016 Explorer Platinum
1972 Mustang Sprint Sportsroof H code
