4th Revision - The new revised Clutch TSB 10-3-8
395 replies to this topic
#1 OFFLINE   Grabber
  • 35,392 posts
Posted 15 February 2010 - 09:27 PM
A friend of mine gave me a copy of the 4th revised Clutch Drag TSB 10-3-8.
This one supersedes TSB 09-19-11 and it removes the production fix date and it updates the service procedure and parts list.
Looks like cars built after 9/1/08 can now get the repair done as well.
The added the replacement of the CSC (Clutch Slave Cylinder) to the parts list too.
They are now saying that the PCM must be reprogrammed after the new clutch is installed with the latest calibration.
The PDF file is too big to load and I do not have a scanner so these photos of the TSB will have to do.
TSB
10-3-8
  • SHELBY GT500 - CLUTCH DRAG
Publication Date: February 12, 2010
FORD:2007-2009 Mustang
This article supersedes TSB 09-19-11 to remove the production fix date, update the Service Procedure and Part List.
ISSUE:
Some 2007-2009 Mustang Shelby GT500 vehicles may exhibit the following clutch/transmission symptoms: hard to disengage or engage 1st and reverse, hard to shift all gears, vehicle creeps with transmission in gear and clutch pedal fully depressed without brake pedal application. These symptoms may be caused by the clutch not disengaging fully when the clutch pedal is fully depressed. This may be due to flywheel distortion caused by excessive heat build-up during unique traffic conditions (example: severe stop/go urban driving, excessive clutch slipping). The clutch system is designed for performance driving conditions.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Located at the end of the procedure are Figures 1, 2 and 3 which show the typical appearance of a flywheel and clutch that has been damaged due to overheating of the clutch. Figures 4, 5 and 6 show the typical appearance of a good flywheel and clutch.
This procedure does not apply to or correct the normal characteristics of the twin-disc cera-metallic clutch used in the Shelby GT500 vehicle or normal wear. The twin disc cera-metallic clutch incorporates racing technology to combine a low inertia assembly with a very durable friction material with high torque capability. Depending on your driving technique, the smoothness of how the clutch reacts to clutch engagements may be different from other vehicles that use a single disc clutch system. Also refer to pages 8 and 9 of the GT500 Owner Guide Supplement for additional information.
Normal Operating Characteristics Of The Twin Disc Cera-metallic Clutch
  • Clutch chatter/shudder when engaging the clutch.
  • Narrow or abrupt engagement point.
  • Hiss upon clutch engagement or disengagement.
  • Transmission gear rollover noise at idle.
  • Gear rattle noise at very low speeds when in 1st or 2nd gear.
  • Normal wear.
Diagnosis And Service Procedure Update
Based on engineering analysis of all of the returned transmission components replaced when performing the prior TSBs, it has been determined that the synchronizer assemblies and transmission input shafts do not exhibit any abnormal wear that would require transmission component replacements.
A diagnostic procedure has been developed to confirm that the transmission synchronizers are operating properly and prevent any unnecessary transmission repairs.
Transmission Synchronizer Diagnosis Procedure
The following procedure is to be used to determine if the synchronizer assemblies in the transmission may have been damaged by attempting to operate the vehicle with a dragging clutch.
  • Set parking brake.
  • Transmission in neutral.
  • Start engine and allow it to idle.
  • Clutch engaged - pedal fully released.
  • Attempt to shift transmission into first gear by firmly pushing shift lever approximately 5-10 lb-ft (22-45 N-m) force for 2-3 seconds.
  • If the synchronizers are okay, the transmission will not make any clash or grinding noise. You will not be able to move the gearshift lever into the selected gear (the synchronizer will block out gear engagement) and the engine RPM will decrease slightly.
  • Repeat the synchronizer test (Step 5 and 6) on all of the other forward gears.
  • If the transmission passes the synchronizer test, the transmission will not require additional service; proceed with clutch/flywheel replacement only. Refer to Clutch Replacement procedure.
  • If clash/grinding noise is found when performing the synchronizer diagnostic, the transmission will need to be repaired along with the replacement of the clutch. Refer to Transmission Repair procedure.
Clutch Replacement
  • Remove the transmission per 2010 Workshop Manual (WSM), Section 308-03C.
  • Remove and replace flywheel per 2010 WSM, Section 303-01C. Discard old bolts and use new bolts.
  • Install new pilot bearing per 2010 WSM, Section 308-01.
  • Install new clutch disc and plate assembly per 2010 WSM, Section 308-01. Using new bolts.
  • Apply a small amount of Motorcraft® PTFE Lubricant to the clutch hub splines per 2010 WSM, Section 308-01.
  • Install new clutch slave cylinder and hydraulic line per 2010 WSM, Section 308-02.
  • Install the transmission per 2010 WSM, Section 308-03C.
  • Refer to Powertrain Control Module (PCM) Reprogramming.
Transmission Repair
  • Remove, drain, disassemble and clean the transmission per 2010 WSM, Section 308-03C.
  • Remove and replace input shaft and all synchronizer assemblies per 2010 WSM, Section 308-03C.
  • Assemble the transmission per 2010 WSM, Section 308-03C.
  • Refer to PCM Reprogramming.
PCM Reprogramming
The PCM must be reprogrammed after the clutch is replaced. Reprogram the PCM to the latest calibration using IDS release 65.07 and higher. This new calibration is not included in the VCM 2010.1 DVD. Calibration files may also be obtained at www.motorcraft.com.
PART NUMBERPART NAMEAR3Z-6375-AFlywheelAR3Z-7B546-AClutch7R3Z-7C391-BTransmission KitXG-8Motorcraft® PTFE LubricantXT-5-QMMotorcraft® MERCON® V Automatic Transmission FluidPM-1-CMotorcraft® High Performance DOT 3 Motor Vehicle Brake FluidXG-1-CMotorcraft® Premium Long-Life GreaseTA-30Motorcraft® Silicone Gasket and SealantTA-25Motorcraft® Threadlock and SealerF6ZZ-7600-APilot Bearing1R3Z-7052-AATransmission Input Shaft Oil SealAR3Z-7A508-AClutch Slave CylinderAR3Z-7A512-AClutch Slave TubeN808969-S100Clutch Bolt (6 required)F6ZZ-6379-AAFlywheel Bolt (8 required)
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATIONDESCRIPTIONTIME100308A2007-2009 Mustang GT500: Replace The Clutch Disc And Plate Assembly; Pilot Bearing, Slave Cylinder And Flywheel. Includes Time To Remove And Install Transmission, Perform The Synchronizer Diagnosis, And Reprogram The PCM (Do Not Use With Any Other Labor Operations)4.2 Hrs.100308B2007-2009 Mustang GT500: Replace The Input Shaft; Synchronizer Assemblies, Clutch Disc And Plate Assembly; Pilot Bearing, Slave Cylinder And Flywheel. Includes Time To Remove And Install Transmission, Perform The Synchronizer Diagnosis, And Reprogram The PCM (Do Not Use With Any Other Labor Operations)
Click to enlarge:
The attached thread has Pic's of the 2010 Clutch and flywheel.
http://www.teamshelb...ost__p__1300288
Costs for the new parts (7/21/12) :
Item Description Fulfillment Price Per Item Quantity Subtotal SLEEVE
Part #: F6ZZ7600A
Pack Qty: 1 Shippable $13.20
Remove $13.20 CYLINDER ASY - CLUTCH SLAVE
Part #: AR3Z7A508A
Pack Qty: 1 Shippable $221.81
Remove $221.81 BOLT
Part #: N808969S100
Pack Qty: 6 Shippable $22.00
Remove $22.00 FLYWHEEL ASY
Part #: AR3Z6375A
Pack Qty: 1 Shippable $253.60
Remove $253.60 CLUTCH ASY
Part #: CR3Z7B546A
Pack Qty: 1 Shippable $601.20
Remove $601.20 LUBRICANT - TEFLON
Part #: XG8
Pack Qty: 1 Shippable $7.92
Remove $7.92 TUBE
Part #: AR3Z7A512A
Pack Qty: 1 Shippable $76.81
Remove $76.81 FLUID - BRAKE
Part #: PM1C
Pack Qty: 1 Shippable $4.78
Remove $4.78 BOLT - HEX.HEAD
Part #: F6ZZ6379AA
Pack Qty: 3 Shippable $11.17
Remove $33.51
Parts Subtotal: $1,234.83 Total: $1,234.83
Edited by Grabber, 21 July 2012 - 08:10 PM.
added link to 2010 clutch photos
#2 OFFLINE   SicShelby
SicShelby
    The NTT Night Shift.
  • 10,004 posts
  • Joined 31-July 08
  • Interests:A nice pair of slacks.
Posted 15 February 2010 - 09:43 PM
Does this have any application for those that had the TSB done already? and is it something that I should look at (the CSC) because that wasn't replaced when I had mine done, or just leave it alone? Figured this question might come up anyhow...
And 'round and 'round it goes! :headspin:
Will be revived...
#3 OFFLINE   Grabber
  • 35,392 posts
Posted 15 February 2010 - 09:54 PM
IMO you should be OK. If it's not broke... don't fix it.
When it does break.....go aftermarket.
#4 OFFLINE   SicShelby
SicShelby
  • 10,004 posts
  • Joined 31-July 08
Check. :salute:
Will be revived...
#5 OFFLINE   Grabber
  • 35,392 posts
Posted 15 February 2010 - 09:56 PM
Check. Posted Image
If your still under warranty...let ford fix it.
When the warranty runs out...go aftermarket.
Mines running fine, but I'm going to ask my Mech about the PCM change.
#6 OFFLINE   SicShelby
SicShelby
  • 10,004 posts
  • Joined 31-July 08
Posted 15 February 2010 - 10:06 PM
It would be easier if I could just hit up the dealership in Ohio where I had the actual TSB done. I might run it by the local dealership here in Modesto and see what they say, but I might have to rehash the process again, and depending (hit or miss) either get an okay, or hit a wall with the dealership - you know how that can go.
And refresh my memory if you will... what are they warrantied up to again? I'm just shy of 25k miles I think. :headscratch:
Will be revived...
#7 OFFLINE   DDT
DDT
    Dave
  • 5,936 posts
  • Joined 23-August 07
  • Interests:"Don't blame me"......."What did I do"???????
Posted 16 February 2010 - 02:12 AM
Thank's for the Update Rob;
I was going to have this done before Christmas but decided to wait for the
Summer just before my 3 yr. Warranty runs out just for this reason to get
the latest update for the procedure.......................
#8 OFFLINE   mach 1 1970
mach 1 1970
  • 1,631 posts
  • Joined 26-July 07
  • Interests:gas , oil & Coke collector --college baseball Ga Tech ,antiques , Motorhome traveling& vintage racing, RETIRED and travel to the AMALFI coast in Italy
Posted 16 February 2010 - 06:00 AM
What if you have a KR i bet they can't reprogram the PCM ?
Current cars.
2014 GT500 ....performance / track / electronic package and Recaros.
Past Fords over 33 years.
2005 FORD GT. ( dream come true car )
2008 Shelby GT 500 KR
1970 Mach1 (3)
1970 Boss 302 ( 3 )
1970 GT500
1969 GT350
1966 GT350
2003 Cobra SVT 10th annv.
2007 SGT
1971 Boss 351
2001 Cobra SVT
1996 Cobra SVT
2006 Shelby GT-H
2008 Shelby GT conv
2013 Boss 302
2011 Shelby GT 500
2016 Shelby GT 350
#9 OFFLINE   KR158
KR158
  • 450 posts
  • Joined 02-October 09
Posted 16 February 2010 - 06:38 AM
I was thinking the same thing with the KR? I am going to be going in this week at some point. I will see if they can leave pcm alone. Anywhere we can print the forms above to have?
#10 OFFLINE   ItalianStallion
ItalianStallion
  • 542 posts
  • Joined 15-July 07
  • Interests:Mustangs and Boating
Posted 16 February 2010 - 08:51 AM
Thanks Rob, Your attention to details and posted new developments on this has helped
numerous people and me too.
You da man !!
IS
2007 Shelby GT500 Coupe Ebony Clearcoat with Red Stripe Appearance Package
-"Red Package" unit #150 of 297 Produced, it is 87 of 169 vehicles finished in Ebony
-Build Date 06/05/2007
-Side Scoops
-Custom Laser Cut Cobra Dead Pedal
-Shelby GT500 Polished Fuse Box Cover
-Sequential Tail Lights
-Shelby Signed Dash Plaque
-Shelby [color="#FF0000"]RED
Door Sill Plates
-Shelby GT500KR Short Throw Shifter
-Centered SHELBY Trunk Lettering
-Corsa Sport Axle Back Exhaust
-Redline Hood Struts
-20" Shelby Alcoas
#11 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
  • Joined 26-March 06
Posted 16 February 2010 - 04:04 PM
Hi Rob, any ideas how this would affect my situation?
Also, I am not understanding why a PCM update or how that would change anything?
Do you know if this applies to people like me that have already had a previous TSB done?
This is crucial for me because if I cant get Ford to rightfully fix my car, I am selling it.
Thank you so much once again
Ford Shelby GT500- Modified
#12 OFFLINE   mullens
mullens
  • 1,307 posts
  • Joined 11-July 08
  • Interests:Fast cars and smart women
Posted 16 February 2010 - 04:18 PM
I'm also at a loss to see what the PCM has to do with the clutch :headscratch:
At least those with custom tunes know to put it back to stock before bringing it in for this procedure. Flashing over the tune would create a REAL headache.
Chuck I thought you were getting a 2011 anyway??
Edited by mullens, 16 February 2010 - 04:20 PM.
2013 GT500 DIB/White
FRPP Resonator Delete
JLT Oil Separator
Redline Hood Struts
#13 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
Posted 16 February 2010 - 04:23 PM
I'm sorry but I have to add in my 2 cents about this whole situation
WTF is Ford thinking. How many freaking revisions do they think they can toss our way?
Why don't they just replace all damaged trannys with new ones and replace all defective clutch kits with the 2010 which has proven to work flawlessly with none of the issues the 07-09 cars have.
I can't believe I am considering buying another GT500 quite frankly after the way Ford has treated its halo car customers.
My gut says tell them to F off and buy the 2010 AMG down the street from me
rant off
#14 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
Posted 16 February 2010 - 04:25 PM
I am but only if the dealer will go to bat for me and give me a good price, which you know how that goes.
I have been optimistic about that, but I will know soon, as they just received their first allocation and I am going in this Sat to talk numbers.
I love my 2007 so much but it has been nothing but headaches since day one, right from when Ford delivered it to the wrong dealer 8 hours away
Edited by chuckstang, 16 February 2010 - 04:25 PM.
#15 OFFLINE   Grabber
  • 35,392 posts
Posted 16 February 2010 - 04:47 PM
Here's the full new TSB:
TSB
10-3-8
ISSUE:
ACTION:
SERVICE PROCEDURE
  • Normal wear.
Clutch Replacement
Transmission Repair
PCM Reprogramming
WARRANTY STATUS:
#16 OFFLINE   Grabber
  • 35,392 posts
Posted 16 February 2010 - 05:49 PM
The new items on this revised TSB are the following in Red:
#17 OFFLINE   QuickSilverShelby
QuickSilverShelby
  • 1,318 posts
  • Joined 21-May 08
  • Interests:The wife, the kids and Shelby's
Posted 16 February 2010 - 08:38 PM
So,........I am a little confused on all this (after 3 years). Would it be safe to say that ALL 2007 to 2009 Clutch's are needing a little TLC at some point in time? Even the ones built after 08/2008?
I am not the sharpest pencil in the box, so please, can you cast a ray of sunshine my way and tell me WTF this all means :confused: , in short, small, simple, words.
QSS
"I wanna go where the beer flows like wine"
07 GT-H 5sp Vert
68 GT 500 Vert
#18 OFFLINE   DDT
DDT
    Dave
  • 5,936 posts
Posted 16 February 2010 - 10:45 PM
What are they trying to accomplish with the
"Program Update"????????
Hope their not trying to save the clutches by
Reducing HP Output??????????? :hysterical:
#19 OFFLINE   LuckySnake
LuckySnake
    LuckySnake
  • 3,541 posts
  • Joined 11-May 06
  • Interests:Cars & Planes
Posted 17 February 2010 - 03:18 AM
Hello Rob, have you heard why Ford wants to recalibrate the PCM ? What does it change/add or remove?
Thank you
#20 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
Posted 17 February 2010 - 06:49 AM
So are they now using the 2010 clutch/flywheel kit for these replacements?
I noticed it mentioned 2010 in many places when refering to parts?
I'd say its safe to say Ford hasnt a clue on how to treat their customers.
Simple as this, replace all damaged units that are still under warranty with the new and working 2010 clutch kit.
But what else do you expect from Ford
Hopefully someone from Ford looks at this site and has some sympathy on their core customers
#21 OFFLINE   jcthorne
jcthorne
    Member Terlingua Racing Team
  • 1,914 posts
  • Joined 10-January 06
Posted 17 February 2010 - 07:39 AM
The reason Ford is not going to replace all the clutches and trannies is because the vast majority of them make it well beyond warranty period without failure. Why should they replace a perfeclty working clutch and transmission?
We are all sorry your dealer messed up yours but really, that is NOT Ford's fault. They paid to have a replacement installed for you. Your dealer needs to fix the shoddy install if its not right. The parts Ford supplies DO work when installed correctly.
I do feel for those having trouble getting the TSB done when needed but many have asked for it and even gotten it when nothing was broken.
The 07 clutch was not an untested and unproven item when it went to production. In most cases it holds up fine.
As grabber said, when the clutch fails after warranty, go aftermarket. Its a wear item.
Gone: GT500 Coupe #3228 Tungsten stripes on Vista Blue
Up next: 2006 Ford GT, Midnight Blue with white stripes.....one day.....
#22 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
Posted 17 February 2010 - 11:56 AM
So no one really cares what this PCM recalibration is?
I talked to a Toyota tech, buddy of mine, and he thinks the only thing possible to alter would be hp/tq and something to the effect of what Nissan did with the GTR.
Lets get beyond my particular scenario for a second although there are many out there with post TSB stuff and still issues but why isint anyone concerned that Ford keeps revising a very old TSB?
So does this mean that if you had your tsb done after the 1st revision, you should go back and have it redone? It does not appear that way but this seems to screw majority of the 07 owners that have already had the TSB completed long ago, not to mention Ford is releasing this when most 07 owners are out of warranty anyway.
IF I HAD A GUARENTEE THAT MY TRANNY IS PERFECTLY FINE, I WOULD HAVE NO ISSUES PUTTING IN AN AFTERMARKET CLUTCH BUT FORD WILL NOT WARRANTY THE DRIVETRAIN WITH AN AFTERMARKET CLUTCH AND THE AFTERMARKET WILL NOT WARANTY THEIR OWN CLUTCH.
So you see this puts people like myself with bad luck with quite a decision...risk losing another $2k for an aftermarket clutch or just dump the car and buy something else.
It just is really pathetic that there will always be an * next the greatness of the 07-09 GT500.
A great drivetrain on some cars but shit to others, that is not what you would expect from your halo car
IMO
#23 OFFLINE   mullens
mullens
  • 1,307 posts
  • Joined 11-July 08
Posted 17 February 2010 - 12:17 PM
I'd be tempted with that AMG if I were you too. It's a SWEET ride. Hang in there..
JLT Oil Separator
Redline Hood Struts
#24 OFFLINE   KR158
KR158
  • 450 posts
Posted 17 February 2010 - 01:33 PM
Funny I went from a tuned sl65 amg into the KR and I love the kr way more then the amg.
#25 OFFLINE   Grabber
  • 35,392 posts
Posted 17 February 2010 - 06:09 PM
Thank you
Dunno....yet. I'm working on it.
I may know Friday.
#26 OFFLINE   skiph
skiph
  • 917 posts
  • Joined 26-March 08
Posted 17 February 2010 - 06:18 PM
Wow. I JUST got the Clutch and Flywheel portion of the 09-19-11 TSB done! Receipt even references that specific TSB. :shrug:
So any thoughts on if I mssed out on something that would now be done under the new TSB or no-problemo Rob? :headscratch:
2008 GT500 Coupe. ~~~~~~~~~~~~~~~~~~~~~~~~~~~ Manufactured 1/22/2008
Came as Black w/White Stripes. ~~~~~~~~~~~~~~~~~~ Nav, HID, Sirius Sat Radio
Full post-sale Red Appearance Package conversion ~~~~ So 1? of 0 2008 Coupes w/red app pkg
SPP Center Gauge Cluster ~~~~~~~~~~~~~~~~~~~~~~ BangaStang Radiator Cover
Vehicle #3936 of 6513 2008 coupes ~~~~~~~~~~~~~~~~ VMP C&L CAI, 2.65" Pulley & Tune
Cobra caps under the hood for all liquids. ~~~~~~~~~~~~ Premium Trim Package
Tinted windows, 20% back & 30% on front. ~~~~~~~~~~ "KR" Exhaust
Carroll Shelby Signed Dash Plaque ~~~~~~~~~~~~~~~~ SHELBY GT500 portion of door sill plates painted red
RedlineTuning hood lifts ~~~~~~~~~~~~~~~~~~~~~~~~ Sequential Tail lights
Oh have I mentioned.. I love this car!
#27 OFFLINE   Light66
Light66
  • 489 posts
  • Joined 17-September 06
Posted 17 February 2010 - 06:28 PM
I may know Friday.
Rob, thanks. Yes there are many of us that want / need to know. Keep up the good work.
#28 OFFLINE   Grabber
  • 35,392 posts
Posted 17 February 2010 - 06:36 PM
Wow. I JUST got the Clutch and Flywheel portion of the 09-19-11 TSB done! Receipt even references that specific TSB. Posted Image
So any thoughts on if I mssed out on something that would now be done under the new TSB or no-problemo Rob? Posted Image
All you missed is the CSC and the PCM update / re calibration.
Here is what the CSC looks like.
#29 OFFLINE   Grabber
  • 35,392 posts
Posted 17 February 2010 - 06:38 PM
I'm as interested as you guys. We will find out soon.
#30 OFFLINE   ingram4868
  • 6,363 posts
  • Interests:Love of God, Family and Great Cars
Posted 17 February 2010 - 08:15 PM
Perhaps the PCM update is to adjust the RPM to allow a smoother release. The problem with that part is that we will all have to reinstall the factory airbox before having the PCM updated.
David Ingram
Sparks, NV.
Newest addition 1100 mile 2007 GT500
