4th Revision - The new revised Clutch TSB 10-3-8
395 replies to this topic
#61 OFFLINE   billf65
billf65
  • 45 posts
  • Joined 21-June 06
Posted 01 March 2010 - 07:12 PM
I think I figured out what and why they are having the PCM reprogramed to a newer update.
It has to do with this other TSB that came out 2 weeks before this new clutch TSB.
Any idea why the IDS versions are different in the two TSB's? What is IDS?
Are IDS versions and configuration file versions one in the same? I am assuming they are not and this explains the difference.
Bill
Edited by billf65, 01 March 2010 - 07:31 PM.
#62 OFFLINE   Grabber
  • 35,392 posts
Posted 01 March 2010 - 07:13 PM
What ? Posted Image
#63 OFFLINE   billf65
billf65
  • 45 posts
  • Joined 21-June 06
Posted 01 March 2010 - 07:55 PM
What ? Posted Image
IDS releases under the PCM reprogram in TSB 10-2-3 vs TSB 10-3-8.
#64 OFFLINE   palacekeeper
palacekeeper
    palacekeeper
  • 233 posts
  • Joined 07-April 08
  • Interests:occasional drag racing, mods - just enjoy cruising around
Posted 03 March 2010 - 07:47 PM
can someone clarify what the warranty period is for this TSB? no one ever answers this question when it is posted. is it 60k/5 yrs or what?
#65 OFFLINE   Grabber
  • 35,392 posts
Posted 03 March 2010 - 08:13 PM
I have been told 3 years / 36,000 miles.
#66 OFFLINE   mblgjr
mblgjr
  • 54 posts
  • Joined 06-November 06
Posted 04 March 2010 - 03:48 PM
FYI, I checked the Motorcraft PCM update codes.
If you have the catch code (white sticker on top of PCM) of "PZP1"; then the new PCM flash won't do anything for you. I checked two mid/late run '09's; both had the PZP1 stickers.
It seems if your car is very early '09 or prior (def. '08) that it will simply update you to the '09 production programming.
IDS Numbers are irrelevant to the end-user consumer and have no bearing to the vehicle at all. That info pertains to Ford's IDS diagnostic software and VCM module; this the the software/hardware that your tech uses to diagnose/fix/program the vehicle. The different IDS numbers are ever-changing as Ford makes new vehicles and revisions to the software. So no worries about that.
Edited by mblgjr, 04 March 2010 - 03:51 PM.
#67 OFFLINE   jnf
jnf
  • Mountain Region
  • 1,030 posts
Posted 05 March 2010 - 05:49 PM
Was at the dealer this week.
Was told drive train warranty is 5 yrs or 60,000 miles. Bumper to bumper is 3 yrs or 36,000 miles.
Here's the biggie, the clutch is only covered for 1 year due to different driving habits that people have. The tech I was talking to said they have had people come back in for clutch replacement under warranty where they have completely beaten the piss out of the car. Yes, he was talking about GT 500's sadly.
Said they even had one woman driving while riding the clutch pedal, partially released. Burned the clutch after 3000 miles and insisted on a new one.
They learned this when she drove the tech on a test drive.
Not sure what the other dealers are doing, but this particular dealer does all of the warranty for Shelby.
07 GT 500 Coupe
White w/ Vista Blue stripes
SLP Loud mouth exhaust
Ford Racing Short Throw with Shelby Ball
Custom CS 69 Special Edition 20" wheels
BMR Upper and lower control arms and brackets
BMR panhard bar, brace and relocation bracket
Eibach Pro lowering springs struts and shocks with front and rear sway bars
Shelby adjustable front end links
VMP 2.59 pulley and tune
JLT Big Air carbon fiber CAI
McLeod RXT twin disc clutch
#68 OFFLINE   cobra_joe
cobra_joe
  • 12 posts
  • Joined 07-March 08
Posted 16 March 2010 - 11:22 AM
Mine was built 4/2008. Started experiencing clutch slipping when getting on the super charger about a month ago, now it does it in every gear.
19k miles.
Edited by cobra_joe, 16 March 2010 - 11:51 AM.
#69 OFFLINE   cobra_joe
cobra_joe
  • 12 posts
Posted 16 March 2010 - 11:43 AM
This morning I brought my '08 GT500 into the service shop with my TSB 10-3-8 in hand and 25 printed out forum examples of other 07-09 Shelby owners getting their Clutch systems replaced under warranty in respects to this flywheel issue. My clutch is toast, car has 19k miles. I went directly to the service manager told him about my research on the issue, met the assigned advisor (who specializes in transmissions) and took him for a ride in the parking lot; reproduced the issue within seconds. He was interested in forum examples read through them while we were in the car.
I've already spec'd out a quote for a 2011 GT500 with this dealership (before I had this clutch problem). Will have to see how they handle this situation, if they honor this TSB and properly correct the problem they will keep me as a customer.
#70 OFFLINE   cobra_joe
cobra_joe
  • 12 posts
Posted 17 March 2010 - 11:56 AM
Shop is honoring the replacement, over $3000 worth. I asked about the replacement clutch, flywheel, and those are all 2010 parts.
#71 OFFLINE   Red Snake
Red Snake
  • 265 posts
  • Joined 26-March 08
Posted 17 March 2010 - 12:20 PM
Interesting, so your saying/they told you they are going to put the "2010" GT500 clutch system in as a replacement on your 08?
Edited by Red Snake, 17 March 2010 - 12:22 PM.
GT500+
#72 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
  • Joined 26-March 06
Posted 17 March 2010 - 02:39 PM
wow, are you sure, this is huge
Ford Shelby GT500- Modified
#73 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
Posted 17 March 2010 - 03:06 PM
Could someone let me know if the proper slave cylinder was put in my car the other day when it was replaced with the clutch?
I have 4R3Z-7A508-AA
If it is not, does anyone know how tough it is to change to the new revised one?
Does anyone know what changes were made to warrant the change?
Thank you kindly
#74 OFFLINE   Grabber
  • 35,392 posts
Posted 17 March 2010 - 07:12 PM
Thank you kindly
That's the same part number that they put in my car. It is the correct one.
#75 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
Posted 18 March 2010 - 06:05 AM
Thanks Grabber, I think the slight difference in part number is just that the A up front instead of the 4 signifies it is part of the TSB.
#76 OFFLINE   Light66
Light66
  • 489 posts
  • Joined 17-September 06
Posted 18 March 2010 - 07:07 AM
Rob,
How important is it to replace the CSC? The applicable TSB for my 08 did not have that option.
#77 OFFLINE   Grabber
  • 35,392 posts
Posted 18 March 2010 - 06:16 PM
Rob,
Well...it's either working or not and if it's not, then the tranny has to come back out. The part is dirt cheap compared to pulling the tranny. The part costs about $60 bucks and has 2 bolts and a hydro line connection. It takes 3 minutes to put it on...so Ford is now including it in the TSB.
#78 OFFLINE   brisk_tea
brisk_tea
    better than you
  • 120 posts
  • Joined 06-January 09
Posted 19 March 2010 - 08:21 AM
OK, I thought i had no problems, but i think i might have started experiencing early warning signs... maybe... I read all I could on this subject, not sure if this is it or not.
car in neutral, clutch not depressed - sounds like worn throwout bearing rattle, etc. Push clutch in, sound goes away.
in 2nd gear - sounds like gears aren't meshing correctly. In 1st, 3-6 absolutely quiet.
Sound like this issue?
thanks,
'68 buick riviera
2 '87 notches
'92 MR2
'94 Mustang GT
'05 ACR SRT-4
'08 GT500 - alloy/silver 302 of 314
#79 OFFLINE   10random
10random
  • 194 posts
  • Joined 19-June 09
Posted 20 March 2010 - 01:02 PM
I am cuurently doing a spec clutch install and here is what I have learned. The slave cylinder was added because the TSB is now using the 2010 clutch setup. The clutch and flywheel are also new part numbers and the TSB references the 2010 WSM for install. Do not use this slave cylinder if you're going aftermarket. It is half the length of the 4RZ part number and I can't find a clear answer on how this new slave could work in a 2007-2009 Setup. If anyone has any information that can clarify these changes and what I've determined so far feel free to correct.
Edited by 10random, 20 March 2010 - 01:05 PM.
2010 GT500 Kona Blue w/ White Stripes - Stock
#80 OFFLINE   MadManMoon
MadManMoon
  • 489 posts
  • Joined 20-August 07
Posted 21 March 2010 - 09:21 PM
So what about those of us who had the TSB performed under the initial (first) revision? We get to keep the chattering old clutch and flywheel? Hopefully it'll stand up to long-term use. :banghead:
IF THE SHOE FITS: "The GT500...[is] about as stable and behaved as a crack-smoking monkey...irresponsible and outrageous, and seems intended for people with social disorders....If you want a high-strung, nine-testicled pet, get a GT500." - Eddie Alterman, Motive Magazine
FUNNIEST QUOTE EVER: "This car is like a pet midget. I don't anticipate buying one, but if someone gave one to me, I'd have as much fun as I could before the police came and took it away." - RamblinReck89@Jalopnik
#81 OFFLINE   skiph
skiph
  • 918 posts
Posted 22 March 2010 - 04:06 PM
thanks,
That rattle when you are in neutral I had too, and from all the input I received, is "normal". IE. LOTS of people reported it as something they experienced. However, interestingly enough, after I had the clutch and flywheel version of the TSB, it completely went away. Would not hurt to take it in.
Not sure about the 2nd gear symptom you describe. Is there a grinding, or just a funny sound when shifting into 2nd? Just curious, as would not hurt to take that one in too.
2008 GT500 Coupe. ~~~~~~~~~~~~~~~~~~~~~~~~~~~ Manufactured 1/22/2008
Came as Black w/White Stripes. ~~~~~~~~~~~~~~~~~~ Nav, HID, Sirius Sat Radio
Full post-sale Red Appearance Package conversion ~~~~ So 1? of 0 2008 Coupes w/red app pkg
SPP Center Gauge Cluster ~~~~~~~~~~~~~~~~~~~~~~ BangaStang Radiator Cover
Vehicle #3936 of 6513 2008 coupes ~~~~~~~~~~~~~~~~ VMP C&L CAI, 2.65" Pulley & Tune
Cobra caps under the hood for all liquids. ~~~~~~~~~~~~ Premium Trim Package
Tinted windows, 20% back & 30% on front. ~~~~~~~~~~ "KR" Exhaust
Carroll Shelby Signed Dash Plaque ~~~~~~~~~~~~~~~~ SHELBY GT500 portion of door sill plates painted red
RedlineTuning hood lifts ~~~~~~~~~~~~~~~~~~~~~~~~ Sequential Tail lights
Oh have I mentioned.. I love this car!
#82 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
Posted 22 March 2010 - 05:19 PM
So is it true that the 2010 clutch/flywheel/slave is now being used for this TSB?
complete and utter bullshit to those of us that had it done prior to this if true
#83 OFFLINE   10random
10random
  • 194 posts
  • Joined 19-June 09
Posted 22 March 2010 - 07:07 PM
2010 Clutch is a Yes for the latest TSB.
Ford finally figured it out :) Either way I'm happy with my Spec and won't miss either clutch.
#84 OFFLINE   m81mclaren
m81mclaren
  • 260 posts
  • Joined 04-April 06
Posted 22 March 2010 - 09:51 PM
[quote name='10random' date='22 March 2010 - 07:07 PM' timestamp='1269313653' post='932625']
Grabber, is this true? I have a hard time believing this. Does the new TSB list 2010 parts for replacement?
#85 OFFLINE   sandro
sandro
  • 88 posts
  • Joined 16-April 06
Posted 23 March 2010 - 03:03 AM
[quote name='m81mclaren' date='23 March 2010 - 01:51 AM' timestamp='1269323498' post='932676']
[/quote]
yes, its true. Just performed TSB last week with 2010 parts. what a difference.
#86 OFFLINE   brisk_tea
brisk_tea
    better than you
  • 120 posts
Posted 23 March 2010 - 10:29 AM
no problems going into 2nd, you just hear "gear noise" when in 2nd. Kind of like improperly installed rear gears. tranny is completely silent in 1,3-6
yeah, i need to go in and see what they say. i don't want to get stuck paying down the road. almost 2 years down, and a little over a year left for problem to show up for free
'68 buick riviera
2 '87 notches
'92 MR2
'94 Mustang GT
'05 ACR SRT-4
#87 OFFLINE   cobra_joe
cobra_joe
  • 12 posts
Posted 23 March 2010 - 12:24 PM
Absolutely. I even had them print out all of the part numbers, and according to Ford they matched the 2010 parts. The clutch feel is completely different, and no "hissing" noises either. I've put about 30 miles on the new clutch so far. It's a major improvement.
$3800 worth of parts and labor were covered, took them 4 days.
They said based on the TSB I brought it, they put in the 2010 parts.
#88 OFFLINE   shelby001
  • 19,800 posts
Posted 23 March 2010 - 12:48 PM
Why did it take 4 days to change the clutch?
#89 OFFLINE   shelby001
  • 19,800 posts
#90 OFFLINE   chuckstang
chuckstang
  • 3,445 posts
Posted 23 March 2010 - 03:54 PM
Well, I am going to contact my lawyer tomorrow.
Ford royally screwed me for the last time.
I SAID MONTHS AGO that a new TSB would be released where they would replace all clutch components with the 2010 parts and no body believed me. Ford told me this first hand way back then and told me they would get back to me when it was released.
Before I paid $3k for parts and labor on my Spec, I called my dealer and Ford and asked about if the new TSB they spoke of long ago that replaces parts with the 2010 gear is avaialable yet and they said no, the new tsb 10-3-08 was not it and I should keep waiting.
Well, I stopped waiting and put in my own clutch last week as many know. This was way after the new TSB 10-3-08 was released.
I have been betrayed by the company I loved my whole life.
F you ford
:angry22: :censored:
I think its time to move on from this BS, Im going to start looking at other cars from now on.
