Shelby Extreme (Baer) rear brake install
58 replies to this topic
#31 OFFLINE   Rag Top Day
Rag Top Day
  • 660 posts
  • Joined 13-February 08
Posted 04 May 2010 - 02:42 PM
Hey Patrick, your making me drool! I love the look and I can hardly wait to start. Boy those front cross-over tubes are just barely clearing the weights.
Edited by Rag Top Day, 04 May 2010 - 04:17 PM.
#32 OFFLINE   me32
me32
    BEASTLY SHELBY GT500 TVS
  • 628 posts
  • Joined 13-November 08
Posted 05 May 2010 - 12:55 AM
very nice right up thanks for sharing
2008 Shelby GT500
2921 out of 6513 coupes
132 of 314 Alloy Metallic
Shelby Dash Plaque,FRPP TVS Super power pack ,Drag Pack,SVT handling pack,FRPP Cobra Jet TB/MAF/80lb injectors,J&M UCA,LCA,Adj.PHB,SFC,PH A/D,O/R H, DynoMax 3in,CHE, Shelby Rad/HE,VMP 2.59,KB BAP,L&M plenum,BMR KMEMEBER,AED CUSTOM RETURN STYLE FUEL SYSTEM.
91/E85 tune by SHAUN AT AED
730HP/700TQ ON E85
10.78@129MPH 1.644 60FT
WWW.AEDHP.COM
#33 OFFLINE   DutchGT500
DutchGT500
    Team Shelby member #7
  • 3,442 posts
  • Joined 27-September 05
  • Region:European Union
  • Interests:Ducati
Posted 05 May 2010 - 01:15 AM
Another five for you.
Patrick
Proud organizer of the 2012 Shelby Run Europe
2500 miles, 10 days, 8 countries
07 Shelby GT500, Grabber Orange #3383 of 8152 coupes #127 of 282 Grabber coupes #? of 168 Grabber/White coupes
08 Shelby Terlingua, CSM08TRT0301, first Tasca Terlingua, converted at 1467 miles, delivered April 17, 2009 at the 45th Mustang Anniversary, Barber Motorsports Park and given to my wife for her birthday, signed by Carroll Shelby
09 BMW 530i touring, Platinbronze metallic
13 Ducati 1199 Panigale R, 204hp and 165kg
Current mods to car:
-Shelby autographed dash plaque
-Shelby gauge pod
-Shelby KR brake duct bezels
-Shelby Extreme Baer brakes front
-Shelby Extreme Baer brakes rear
-Ford Racing brake cooling kit
-Ford GT start button
-CDC directional mirrors
-CDC sequential taillights
-CDC dead pedal
-CDC hood struts
-Shelby KR mufflers
-Steeda Tri-Ax shifter modified with Hurst shifter stick and Shelby shifter knob
-Shelby billet engine caps
-Ground Control Koni Sport/Eibach coilover kit
-Steeda swaybars front and rear with billet brackets
-J&M lower control arms billet aluminum
-J&M adjustable upper control arm black
-Griggs racing Watts link
-MM 6 point rollcage in grabber orange
-Shelby extreme duty radiator
-Shelby extreme duty dual fans heat exchanger
-Shelby extreme duty anodized black coolant reservoir tanks
-Shelby transmission cooler scoop
-Shelby KR rear axle overflow reservoir
-Ford Racing performance intercooler
-Whipple 2.9L with 3.00" pulley
-Ford Racing Dual 65mm Cobra Jet Throttle Body
-JLT 127mm Carbon Fiber Intake
-72lb Fuel Injectors
-Fore Innovations fuel rails
-Kenne Bell dual Boost-a-Pump
-Reische Performance 170deg Thermostat
-Dynatech 1-7/8" longtube headers Jet-Hot coated
-L&M NSR camshafts
-2013 Shelby GT500 black/white leather Recaro's
-Ford Racing X-Brace in grabber orange and rear seat delete kit
#34 OFFLINE   Rag Top Day
Rag Top Day
  • 660 posts
Posted 05 May 2010 - 05:33 AM
Stop it your killin me. :hysterical: Great pictures although they bring up the brake cooling kit install portion. Have read that some people had issues with the cooling backing plates with the Bear Extreme front brakes. Did you have to do any thing extra for the backing plate install. Thanks again for posting the pictures.
#35 OFFLINE   DutchGT500
DutchGT500
  • 3,442 posts
  • Interests:Ducati
Posted 05 May 2010 - 10:50 AM
Yes, we had to cut away a section where the bigger calipers are. Also in the front the outer tie rod end is close to it. Bending it a bit there. You can see somewhat less clearance between rotor there in comparison to top. Photo 4 shows it.
Patrick
-Shelby gauge pod
-CDC dead pedal
-CDC hood struts
-Shelby KR mufflers
-L&M NSR camshafts
#36 OFFLINE   Alexandros
  • 3,738 posts
Posted 05 May 2010 - 12:53 PM
Slabo,Thank you very much for the reply ...I will try it.....enjoy and stay safe......Alexandros
Edited by Alexandros, 05 May 2010 - 12:56 PM.
#37 OFFLINE   Slabo
Slabo
  • 1,942 posts
  • Joined 08-August 08
Posted 06 May 2010 - 08:41 AM
Ok, I have the take off Eradispeed's for sale. $475+shipping. Here's the ad. http://www.teamshelb...brake-set-rear/
Proud member of Team 40th - 07XL0381
2007 GT500 Vert purchased 8/12/08, #828 of 859 Ebony, Nav, Sirius, assembled on 6/11/07
Reborn 9/14/09 at SAI Vegas - 40th Anniv. package w/ Interior Upgrade, 605HP TVS, 3.73's, Shelby Shifter, Cooling Package and Extreme Brakes.
Many additional mods.
#38 OFFLINE   Rag Top Day
Rag Top Day
  • 660 posts
Posted 08 May 2010 - 07:36 PM
Ok first and foremost I want to thank everyone for their help and advice. A special thanks to Dutch GT500 and Slabo for their info on this. As requested I will post a few pictures. I will post some different pictures of areas that I did a little different and a few before and after of course.
Of course the stock brakes
The KR cooling shields hit the rotors so I use a little persuasion to reduce the thickness of the shields to clear the rotors
Since the new calipers are larger a small amount needs to be trimmed of the top and bottom edge of the shield so it will fit properly
I did not like the idea of tie straps so I cut the ABS cable holders of the stock lines and installed them on the new lines
Here is the installed fronts
Picture with the wheels on. Tight fit but plenty of clearance
#39 OFFLINE   Rag Top Day
Rag Top Day
  • 660 posts
Posted 08 May 2010 - 08:00 PM
Now for the rears.
Stock rear brakes
Wow what a differance in rotor size
Nice job on the emergency brake setup
New FRPP M-4033-G2 Diff cover. It clears the panard bar fine.
Shot of the back side. Used the old ABS clip from the original hose. Drilled hole in bracket like Slabo suggested.
Completed rears
Fills up those rear wheels alot better!
Edited by Rag Top Day, 08 May 2010 - 08:54 PM.
#40 OFFLINE   Slabo
Slabo
  • 1,942 posts
Posted 08 May 2010 - 10:11 PM
Great job Ragtop! The red calipers look awesome with your car. Now comes the hard part. Taking it easy until you wear through the coating. I guess since you have to drive maybe its the good part. You have to put on 250-300 miles with no hard use first. Here is the excerpt from the pad bedding from Baer:
"If the new rotor surface finish is plated or the rotor is used with a compound other than the SPORT-TOURING ceramic-based pad, increase the commuter type driving with no hard use, to a total of 250-300-miles to accomplish the blending of the pad surface to the rotor surface." Then season them, then bed them.
have fun!
#41 OFFLINE   DutchGT500
DutchGT500
  • 3,442 posts
  • Interests:Ducati
Posted 08 May 2010 - 11:41 PM
That looks great. Nice write up.
Because of the bad weather I still have to do some miles. Just did the 70 miles back from the shop, mostly interstate so less braking.
Patrick
-Shelby gauge pod
-CDC dead pedal
-CDC hood struts
-Shelby KR mufflers
-L&M NSR camshafts
#42 OFFLINE   Slabo
Slabo
  • 1,942 posts
Posted 09 May 2010 - 07:28 AM
Yup that's right Dutch it has to be mostly around town type driving to work the brakes but nothing hard. Took me some time to get that out of the way. I am working on the rears now. Just took a great drive yesterday. Did some country driving and some around town.
#43 OFFLINE   TX STIG
TX STIG
  • 931 posts
  • Joined 20-January 10
Posted 09 May 2010 - 07:34 AM
Can't wait to add those to mine someday.
But I must ask, has your car ever been driven? Damn that's clean!
VMP Tune - 4.10 Gears - BMR Rear LCAs - Griggs Panhard Bar - IW 10% Pulley - Revan Racing Dual Fan HE
Aeroforce Interceptor - Roush Vent Pod - Forgestar F14 Wheels 20x11/9 - Nitto NT05 315/35 & 275/40
FRPP Tower Brace - FRPP Brake Cooling Kit - FRPP Resonator Eliminator - FRPP Blue Valve Covers
Dynatech LT Headers - High Flow Cats - VMP OE-Look IC Reservoir - Baer 2-Piece Rear Rotors
VMP 67mm Throttle Body - VMP 90mm Idler Pulley - Metco 2.6" Pulley - Metco Aux Idler
Magnaflow 4" x 18" Round-Body Resonators with OEM Mufflers - Custom H-Pipe
2010 SHELBY GT500, Navigation Package, HID's
My Pictures
SOLD :-(
WHEEL OFFSET: FRONT +40, REAR +53
#44 OFFLINE   Rag Top Day
Rag Top Day
  • 660 posts
Posted 09 May 2010 - 07:50 AM
She has 7500 miles on her and does get driven. Try not to drive in the rain although when we picked her up out of state we got stuck in a big thunder storm so that shot the never been driven in the rain deal :hysterical: Luckly my wife agreed to our new garage with a lift so as Slabo will probably agree with, it makes cleaning alot eazier! A little OCD might have something to do with it also. thanks TX STIG
#45 OFFLINE   Slabo
Slabo
  • 1,942 posts
Posted 09 May 2010 - 08:38 AM
LOL ain't that the true. My wife came out to the shop and I was cleaning the underside and she just shook her head and laughed. I am still part of the rusty butt club. How about you Rag Top? I think I will let Alex handle that with a RBST (rusty butt spa treatment).
#46 OFFLINE   Rag Top Day
Rag Top Day
  • 660 posts
Posted 09 May 2010 - 10:07 AM
I am a very lucky guy! My wife is a car person and helps clean the car for shows and she helped with the install of the Brakes on the Shelby. We have alot of fun working on the car togeather. No rusty butt here, even cleaned and painted areas when old brakes were taken off.
#47 OFFLINE   vapor08GT500
vapor08GT500
    MMS
  • 3,240 posts
  • Interests:Anything Shelby, Racing, Car Events, People, Building Fast Cars!!
Posted 09 May 2010 - 02:24 PM
LOL...you and Pam can follow me back to Palm Springs after Grabber's, stay for a couple days, have a nice little vacation, get your RBST and anything else you desire done, then head back to WA...will be a fun trip and you can caravan with all the Shelby's heading back to CA. I will even let you say at my house so you don't need to pay for a hotel...Let me know...
Alex
Always Have Several Shelby's, Saleen's, Cobra's and Mustangs For Sale And Will Build To Suit Your Wants/Needs.
Home Of The MMS Mufflers!!!
#48 OFFLINE   Slabo
Slabo
  • 1,942 posts
Posted 10 May 2010 - 07:16 AM
Alex
Thanks for the offer Alex but we are going to have to get back and re-leave grandma from the kids. We will make it down sometime. Lets talk at Grabbers.
-- Bob
#49 OFFLINE   vapor08GT500
vapor08GT500
    MMS
  • 3,240 posts
Posted 10 May 2010 - 01:04 PM
sounds good...
Alex
#50 OFFLINE   NMAv
NMAv
  • 1,037 posts
  • Joined 10-January 11
Posted 29 March 2011 - 06:22 AM
Brakes - nice. Lift - way cool.
~ NMAv
2011 highly modified Shelby GT500 with SVTPP (Kona Blue)
#51 OFFLINE   justindewoody
justindewoody
  • 904 posts
  • Joined 02-July 09
Posted 29 March 2011 - 07:16 PM
Slabo...I'm sooooo pissed off at you. I want your lift! Not fair...
2011 Shelby GT500
Whipple 2.9--L&M 72--Whipple CAI--IW 10% lower--72 lb. Injectors-JL Tune
725 RWHP
#52 OFFLINE   justindewoody
justindewoody
  • 904 posts
  • Joined 02-July 09
Posted 29 March 2011 - 07:17 PM
By the way, I am installing my new Shelby/Baer Extreme Plus Front AND Rear Brakes in a few weeks. I will do a write up and install post on it.
2011 Shelby GT500
725 RWHP
#53 OFFLINE   Slabo
Slabo
  • 1,942 posts
Posted 30 March 2011 - 10:27 AM
LOL yup it sure make it nice to do these kind of mods. :lol: Your car is going to look sweet and brake hard!
#54 OFFLINE   NMAv
NMAv
  • 1,037 posts
Posted 24 May 2011 - 03:17 PM
I've read about a bunch of people doing the Extreme brake installation but haven't ready much about the final results. Is stopping power signficantly better to warrant the cost. I'm looking to do a little road racing and am wondering if this is a necessity or more of a luxury modification?
~ NMAv
#55 OFFLINE   DutchGT500
DutchGT500
  • 3,442 posts
  • Interests:Ducati
Posted 24 May 2011 - 10:17 PM
It is way better then the stock Brembos. For tracking this is the way to go, Baer or AP Racing. When I drove my wifes Terlingua with these brakes I said to her: I want these on my car. What a difference this makes. I am very satisfied.
Patrick
-Shelby gauge pod
-CDC dead pedal
-CDC hood struts
-Shelby KR mufflers
-L&M NSR camshafts
#56 OFFLINE   medihummer
medihummer
  • 22 posts
  • Joined 09-October 11
Posted 18 December 2011 - 11:31 AM
From what i found are the front rotor sizes exactly the same as the OEM rotos only the brembo is 4 pot and the Baer 6 pot
I like the look on 19 inch wheels but on 20 inch like the supersnake wheels i think the brakes are too small they do not fill the wheels. I'm considering the movit brakes which are 396 mm rotors instead of 355 mm from shelby/baer somebody experience with ap racing or movit?
#57 OFFLINE   shelbypt
shelbypt
  • 797 posts
  • Joined 05-October 08
  • Interests:Orthopedic Manual Physical Therapy, Cars, Shelby, Racing, Deacon at my church.
Posted 02 July 2013 - 02:51 PM
I have a few questions for you guys.
1. When you have a stock differential cover, how do you fill the differential back up with fluid? Is there a plug at the top of the differential?
2. When you remove the pinion lock bolt and pin, do you have to be careful that the spider gears don't fall out? I heard any axle rotation could make them drop out.
3. I will also be installing the Shelby Watts link. My current dif cover is the metal one, but I have the KR cover in the box.  It sounds like this cover may not work with the watts link, anyone know for sure?
Thanks guys, I appreciate any info.
[color="#4169e1"]2008 Shelby GT500KR CSM #08KR0301 Silver Metallic with Blue stripes and Navigation.
A Virtuous Man is a Man of Moderation, and has a KR.
#58 OFFLINE   Freak
Freak
  • Great Lakes Region
  • 586 posts
  • Joined 30-April 07
  • Interests:Fast Cars, Firearms, Photography and my puppy dog.
Posted 31 July 2013 - 12:48 PM
1: There's a plug on the drivers side of the differential housing for filling it. I believe it faces forward on the 8.8. It uses a 3/8" rachet drive, no socket needed.
2: The prelaoad spring should hold the spider gears in. They can fall out of open diffs, but honesty in those it's no biggie. They are super easy to put back in.
3: No idea.
Freedom exists because there are men and women willing to do terrible things to those who would threaten it.
It is the Marines, Soldiers, Sailors and Airmen who salute the flag, who serve beneath the flag, and who's coffins are draped by the flag, that allow the protester to burn the flag.
I'm not a Shelby guy, I'm not a Mustang guy, I'm not a Camaro or Chevy guy, and I'm not a Dodge guy. I'm a car guy. I don't care what the fender says, if it looks cool, is fast and fun to drive, It can be called a Poo-master 1000 for all I care. I'll still like it.
http://www.facebook.com/BanTheFordMustang
#59 OFFLINE   Freak
Freak
  • 586 posts
Posted 31 July 2013 - 12:57 PM
Here's a pic I found.
http://www.supermoto...al/dsc09836.jpg
