Why to use a Shelby Dual Fan Heat Exchanger
34 replies to this topic
#31 OFFLINE   RogerS
  • 5,173 posts
  • Interests:Shelby GT350
Posted 26 December 2010 - 02:13 PM
One of the first units to be installed was a proto-type unit we installed on the car I am currently driving. We began with the unit designed for the 5.4L engine. First the brackets for the radiator needed to be moved approx. 1" lower for the expansion tanks to fit and locate properly under the hood. This is specific to the 4.6L engine and the Whipple SC. With the KB there is a reverse location on the cold air intake and the bracket for the power steering does not require relocation.
At the time we also were including the power steering reservoir as part of the tank kit. Early design had a couple of engineering flaws and this needed to be relocated on the driver fender well with a custom bracket. All were corrected. I do not recall if we are still including this piece in the kits or not. This you would need to check with SPP Representatives.
On installation and potential interference, the car was originally equipped with first generation brake cooling ducts. These were manufactured in the speed shop and custom fitted to each vehicle. We found that with the brake duct or driving lights and not the combination of both there were few obstacles in fitting the Heat Exchanger for the Supercharger. It will not fit with both, driving lights and brake duct combination kits, installed without major modification.
Hope this provides a little background into the initial development of the product.
Roger
2013 Ford Focus ST Black
#32 OFFLINE   speedyburd33
speedyburd33
    Veritas Aequitas
  • 840 posts
  • Joined 16-January 07
Posted 14 September 2012 - 06:54 PM
I guess i'm bringing back an old one here...
I just got my GT/SC conversion and i had the upgraded FRPP radiator installed. What would be the next best mod (or combination of parts) to combat the heat soak? Heat exchanger? Upgraded tanks? I'm not sure which way i want to go from here.
07SGT0890
Team Shelby Member #2553
286.8 RWHP/305.5 RWTQ Stock
Steeda Carbon Fiber Inlet Elbow
Brenspeed Custom Tune
Ford Racing 3.73 Gears
Kooks Long Tube Headers w/high flow cats
Corsa Extreme Exhaust
315.7 RWHP/327.5 RWTQ Stage 1 Mods
Shelby GT/SC Upgrade w/Polished Whipple 550 Completed at Tasca on 9/10/12
1 Piece Driveshaft
Ford Racing Radiator
502.4 RWHP/463.5 RWTQ Stage 2 Mods
1000 Series Forged Internals
ARP Head Studs
Custom Comp Cams
Upgraded Valve Springs
Stage 2 Ported Heads
McLeod RXT Twin Disc Clutch, 8 bolt flywheel
Ford Racing Polished Throttle Body
Whipple Polished 10 Rib Kit
Injector Dynamics 725cc Injectors
MAF Sensor
Updated Tune
???.? RWHP/???.? RWTQ Stage 3 Mods (Completion Estimated 6/27/13 at Tasca)
#33 OFFLINE   Jer
  • 5,310 posts
  • Interests:Former Shelby American Vice President. I love my wife, my dogs, my cat, cars, and music. NHRA addict.
Posted 17 September 2012 - 07:37 AM
I have the Shelby/C&R radiator and HE on my GT/SC, and have NEVER had a heat soak issue, even after flogging the car on-track at the recent Shelby Vegas Bash, AND driving the car pretty hard in the desert this past (hot) summer. Very impressed. I also have upgraded tanks, which I'm sure don't hurt!
2007 SGT/SC # 446 - White, 5spd, Whipple 550 HO with Shelby/C&R radiator and heat exchanger upgrade, factory painted stripes (rockers and Le Mans), painted lower fascia (a tribute to Whitey), Shelby Mid Draw (2 3/8") Hood with custom GT350 mesh inserts, Shelby brake duct/driving light bezels with PIAA 510XT lights, Shelby custom underbody front brake duct inlets and fabricated brake cooling plates, Terlingua billet hood pin plates and door sill plates, Shelby tensioner support brace, Shelby race-fabricated valve covers, Dark Charcoal Gray Interior and dash (signed by Carroll), IUP, Active Anti-Theft, Pioneer AVIC-Z130BT with XM Radio, NAV, HD Radio, DVD video touchscreen, Bluetooth, rearview camera, etc... Infinity Reference speakers, Shelby Kicker door subwoofers, trunk sub, and 4.1 amp, Chrome 20X9 Shelby-logoed Razors (ET24) with Nitto 555s (255 front, 275 rear), Shelby/Baer Extreme+ 6 piston brakes front and rear, A'te Super Blue brake fluid, Goodridge s/s brakelines, Corsa Sport exhaust, Aeroforce Terminator gauge, Shelby angled gauge pod, CS Supercharged faux gas cap logo, billet lower grille, updated 2008-style front grille mount, grille, and pony emblem, Shelby floormats and trunk mat, Shelby white shifter ball, Shelby Harness Bar, CG-Lock seatbelts, Shelby GT engine cap set and period-correct "Shelby Automobiles" license plate frames, Shelby race-fabricated aluminum engine and supercharger coolant and power steering fluid tanks, brake fluid reservoir, and fusebox cover, Shelby "CS" Oil Separator, shorty antenna, Shelby billet fuel fill door, 3/4 window louvers, Shelby upper control arm and mount and lower control arms, CHE K-member brace w/ torque limiters, sequential taillights, Shelby billet Watts link, Ford Racing 3.73:1 gearset, Shelby GT500KR diff cover, de-rusted and painted rear axle housing, Eaton True Trac limited-slip differential, Moser axles, Strange Engineering axle studs, Shelby GT500KR Axle Reservoir, full of Mobil 1 with Ford Racing filter. H3R HalGuard fire extinguisher with Shelby and Brey-Krause mounting, Shelby Helmet and Driving Jacket. Of course I have lots and lots of Shelby doodads, knicknacks, merch, apparel, bling, and bric-a-brac. Many Shelby certificates and Monroney sticker shiny and intact. Fender SGT guitar. Tolerant wife.
Shelby Vegas Bash 2011, 2012, and 2015 Show Winner.
UPDATE: Left Guitar Center and joined SA as Vice President, Shelby Performance Parts, August 2012-May 2014.
#34 OFFLINE   speedyburd33
speedyburd33
    Veritas Aequitas
  • 840 posts
Posted 17 September 2012 - 08:04 AM
I'll have to see how it does after some prolonged hard driving and go from there. Maybe i'll start with the HE and then do the tanks. It seems like the tanks wouldn't work well since they are metal and the tanks themselves could get hot easily.
07SGT0890
1 Piece Driveshaft
ARP Head Studs
Custom Comp Cams
MAF Sensor
Updated Tune
#35 OFFLINE   csm198
csm198
    CSM198
  • 601 posts
  • Interests:shelby gt's
Posted 06 October 2012 - 08:09 PM
1. Does the heat exchanger conflict with any other items or accessories, for example, brake cooling duct installations?
2. How long should it take the shadetree mechanic to install?
3. What does the finish install look like, i.e., do the SHELBY letters show up at the lower grille area or where?
I just had SA install my Revan heat exchanger in Las Vegas. Prior to my car going to SA, I checked locally with a couple of speed shops and was quoted from $150 to $200 for the install. Since my car was going back to SA, I had the install done there. The install instructions are pretty straight forward, and a "shade tree mechanic" should not have any problems installing it.
The heat exchanger does interfere with the front brake ducts, if you have them installed, but from what I know, the ducts can be modified to make them work. ( I do not have the front brake ducts.)
The Revan exchanger is very well made and is paint-stamped "SHELBY" across the front which is visible through the lower grill opening.
I did not install the larger radiator or tanks on my car.
Hope this info helps.
Well I am out on the heat exchanger. I do have the original ducts . I am glad I found out about this before I started tearing into this project. No matter what simple strait forward project I do, It always ends up being a royal pain int he assphalt.
Oh by the way I have a new in the box heat exchanger never even opened with the shelby logo for sale.
/Users/Jonathan/Pictures/iPhoto Library/Originals/2010/Dec 11, 2010_25/mmfp_0906_03_z+cobra_jet_mustang+front_view.jpg
MY MODS
Performance White
Charcoal Interior
SGT # 198
1st Supercharged SGT from SAI (Paxton - S/C # 14)
GT/SC Delete on side stripe
3:73 gear ratio
CS grill assembly
Shelby Plus Pro Brake System
Shelby 4 wheel brake ducts
Shelby gauge cluster
Shelby stut bar
Sequential tail lights
Quarter window aluminum covers billet hood pins
Engine billet caps
Razors (gun metal)
Various interior pieces upgraded
Billet fuel door
CS/SC trunk lock emblem
Former Cars
1956 T-Bird (Coral)
1965 Mustang Notchback 6 cyl.
1965 Daytona Coupe F5 (Guardsman Blue)
1969 Fairlane Cobra FB 428CJ w/ ram air (Indian Fire)
1967 Shelby GT500 (Dark Moss Green)
http://s229.photobuc...Coupe Factory5/ Visit My Website
