Shift linkage
#1 OFFLINE
Posted 25 August 2010 - 07:31 PM
Shift linkage let go today shifting from 1 -2. Had to get towed home. I'll start taking things apart tomorrow. This sucks because my daily driver is an hour away!
1987 GLHS #0075: Black, Numbers Matching
1987 Shelby Lancer #176: Faded Red, Working DEX (if I hadn't accidently changed the code and locked it out)
www.wc-tm.com
Northern Mopars
Team Shelby
SDAC National Member
#2 OFFLINE
Posted 26 August 2010 - 05:30 AM
#3 OFFLINE
Posted 26 August 2010 - 04:34 PM
www.wc-tm.com
Northern Mopars
Team Shelby
#4 OFFLINE
Posted 26 August 2010 - 04:57 PM
Gaoler1973, on 26 August 2010 - 04:34 PM, said:
Good luck on that
__________________________________________________
Register your Shelby at: Shelby American Registry
Order your SAI Registry Certificate at: Shelby Store
PM's turned OFF. Email me at: StevenT@ShelbyAmerican.com
#5 OFFLINE
#6 OFFLINE
#7 OFFLINE
Posted 24 October 2011 - 12:58 PM
bruces, on 22 October 2011 - 02:46 PM, said:
Dodge still has the part. I'll get you the p/n.
2008 GMC Acadia AWD
1999 ROUSH Mustang Stage II
1989 SHELBY Dakota 0160
1987 SHELBY Charger GLHS 0136
1986 Dodge Shelby Charger TII; 4-Wheel Disc; Koni Coil Overs
#8 OFFLINE
Posted 24 October 2011 - 06:44 PM
GLHS0136, on 24 October 2011 - 12:58 PM, said:
Part number 4348401 Ball Joint List $50.50
This is the socket assy that connect to the main rod from the shifter. It mates to a metal ball on a metal pivot piece.
Robert
2008 GMC Acadia AWD
#9 OFFLINE
Posted 24 October 2011 - 06:59 PM
There is a guy selling heim joint kits for the L body cars over on the Dodge boards.
#10 OFFLINE
Posted 25 October 2011 - 05:56 AM
Thanks for sharing the part # Robert, I had that info handy when my linkage let go last year, but couldn't find it now! I dug out my service manual with the hopes of getting part' numbers for Bruce, but surprisingly it has very little detail on the L-body linkage!
www.wc-tm.com
Northern Mopars
Team Shelby
#11 OFFLINE
Posted 08 November 2011 - 06:06 PM
http://www.pnw-sdac....-1/DSCN0016.jpg
http://www.pnw-sdac....-1/DSCN0017.jpg
there is some photo's, Stephan on pnw-sdac.org was making these, another guy on turbododge.com makes them now. Stephan can get you the list, then you use a die on your linkage to make threads and make them your self too. Or remove the POS 525 and install a 523 or 568. They can use the stock Momo shift knob btw
#12 OFFLINE
Posted 09 November 2011 - 04:01 AM
#13 OFFLINE
Posted 09 November 2011 - 06:44 PM
thought I had a URL on it and I did. This guy makes new hiem joint linkage sets.
If you buy the Mopar shift kit your still using the plastic ends. Until you get past that your still going to have a head ache.
BTW at the end of the main rod, the one from the shifter. If you drill a new hole and move that point an inch towards the fulcrum you get a fast ratio shifter!
I can blow up a 525 in a couple blocks, they shatter like glass, so I can't back telling anyone to keep it. But if your going to stay stone stock this linkage, the chromoly 3rd gear plate and the MP spider gears with girdle should be considered a must. I added just a stage 2 Shelby computer to a 87 GLHS and couldn't pull it out of 3rd after pushing it. So even if the diff survives the 3rd gear will push out of the case. With Girdle, MP spiders and the plate I've seen high 12s with a 525. The owner was the GM for the Seattle BMW so he could afford to fix it lol.
#14 OFFLINE
Posted 12 June 2012 - 04:26 PM
View Garage
