Fayes 2 Watts link
19 replies to this topic
#1 OFFLINE   09TSpony
09TSpony
  • 74 posts
  • Joined 16-July 07
Posted 28 March 2011 - 03:10 PM
Well, I have a stock suspension and I just bit the bullet and purchased a Fayes 2 Watts link through the Shelby store. I am wanting a little more stability around corners since I do not desire to run 1/4 mile runs. Does anyone have any input on additional parts to compliment the watts link. Do I need a UCA? Do I need relocation brackets and LCA? Any help would be appreciated.
2009 Shelby GT500
Performance White w/ mid-life crisis Blue Stripes
This vehicle is #2033 of a build of 3004 coupes and is #500 of 651
AVIC F90BT Navigation & DVD System
KR cat backs
Dash Plaque and door sill plates
FRPP cai
2.59" pulley w/ 90 mm idler
Custom tune by VMP Tuning
531 rwhp w/ 508 rwtq on a Mustang Dyno
$$ for mods going to Texas A&M for the meantime
#2 OFFLINE   07SGT4578
07SGT4578
    2007-08 Shelby GT Registrar
  • 4,558 posts
  • Joined 29-October 07
  • Interests:nothing to see here........move along.
Posted 28 March 2011 - 03:14 PM
Get a grade 8 bolt to replace the grade 5 bolt used as the propeller bolt!
Chris Carter
Shelby American Registrar --- 07-08 Shelby GT
Oklahoma Director --- Team Shelby Southern Plains Region
Email me
CLICK HERE TO REGISTER YOUR SHELBY
CLICK HERE TO BECOME A MEMBER OF TEAM SHELBY
#3 OFFLINE   09TSpony
09TSpony
  • 74 posts
  • Joined 16-July 07
Posted 28 March 2011 - 03:27 PM
I assume that is a more sturdy bolt than the bolt in the kit. Is the shear strength of the stock bolt an issue? Where would you purchase one?
2009 Shelby GT500
KR cat backs
FRPP cai
#4 OFFLINE   07SGT4578
07SGT4578
  • 4,558 posts
Posted 28 March 2011 - 03:34 PM
I have heard of several and witnessed one propeller bolt breaking. (luckily not mine) You should be able to pick one up at the Home Depot or Lowe's of your choice
The one I witnessed breaking was on a Terlingua, and not on the track when it broke.
Edited by 07SGT4578, 28 March 2011 - 03:35 PM.
Chris Carter
Email me
#5 OFFLINE   09TSpony
09TSpony
  • 74 posts
  • Joined 16-July 07
Posted 28 March 2011 - 03:44 PM
I will upgrade the bolt. Any other mods that you recommend since I have just a stock suspension? Did you notice a difference after installing the watts link?
2009 Shelby GT500
KR cat backs
FRPP cai
#6 OFFLINE   Slabo
Slabo
  • 1,941 posts
  • Joined 08-August 08
Posted 28 March 2011 - 03:55 PM
I would want to get rid of the hop that is inherent with the stock suspension. Easiest way to do this is at least an UCA but most do UCA and LCAs. I would definitely do this at the same time as the Watts. The other suspension pieces (springs, sway bars and shocks/struts) would be the next step after control arms and Watts in this case. Relocation brackets are for when you lower the car.
Proud member of Team 40th - 07XL0381
2007 GT500 Vert purchased 8/12/08, #828 of 859 Ebony, Nav, Sirius, assembled on 6/11/07
Reborn 9/14/09 at SAI Vegas - 40th Anniv. package w/ Interior Upgrade, 605HP TVS, 3.73's, Shelby Shifter, Cooling Package and Extreme Brakes.
Many additional mods.
#7 OFFLINE   09TSpony
09TSpony
  • 74 posts
  • Joined 16-July 07
Posted 30 March 2011 - 04:37 AM
Any recommendations on LCA's and UCA? I was looking at the unmarked steeda brand.
2009 Shelby GT500
KR cat backs
FRPP cai
#8 OFFLINE   NMAv
NMAv
  • 1,037 posts
  • Joined 10-January 11
Posted 30 March 2011 - 10:08 AM
OK, I've never even heard of a Watts link. I've read a little bit about them now and kinda understand the purpose it serves. My impression is this is a true add on and not replacement type thing correct?
Sorry - don't make fun of the new guy .... :happy feet:
~ NMAv
2011 highly modified Shelby GT500 with SVTPP (Kona Blue)
#9 OFFLINE   1badshelby
1badshelby
    Orangaholic
  • 505 posts
  • Joined 30-August 08
  • Interests:Mustangs, Drag Racing, Music.
Posted 30 March 2011 - 10:53 AM
It replaces the panhard rod and brace. I moves the pivot point to the centerline rather than on on edge like the panhard, therefore keeping the rear axle better centered under the car. Also the instant center is adjustable by raising or lowering the pivot point in the center.
Mike
09 GT500 #10 of 68 in Grabber Orange
Grabber Orange Interior Upgrade.
KR Mufflers, Agent 47 mirrors.
CDC sequential tailight kit and hood struts. Shelby Hood Pins.
Hurst Pistol Grip Shifter,Performance Automatic 4R70w with transbrake, Shelby Alcoa SS Wheels. Shelby Extreme Brakes.
Shelby Radiator and Heat exchanger. Super snake gauges, tire fryer line lock.
Fay's II Watts link, Steeda adjustable UCA and Mount. BBR LCA's
Eibach SS Coil Over susp & sway bars. Modified Ford Racing Drive Shaft, Metco DS loop, J&M relo brackets.
Kenne Bell Shelby Super Snake 2.8 stage 3 with 3" pulley. Ford Racing 373 gears. and Ceramic coated headers.
Lethal off road x pipe. 726 RWHP 633 ftlbs torque on pump gas.
10.67 @ 134 in 1/4 mile with 1.59 60ft.
#10 OFFLINE   09TSpony
09TSpony
  • 74 posts
  • Joined 16-July 07
Posted 30 March 2011 - 06:36 PM
I noticed in your sig that you also have a fays2 watts link. Can tell a difference in control and handling?
2009 Shelby GT500
KR cat backs
FRPP cai
#11 OFFLINE   JimFay
JimFay
  • Joined 06-November 07
Posted 03 April 2011 - 06:58 AM
This is one of those times for me to chime in. During initial evaluation of the S197 F2WL, we determined that a grade 5 center pivot bolt would be the correct choice over a grade 8.
See http://www.fays2.net...s_link_12_.html
Particularly:
"We found the main PROPELLER BOLT had been bent approximately 2 degress from straight due to the lateral force exerted on the axle during the sideways slide through grass and dirt at high speed. I believe it is a testament to the strength of the components that a .75" diameter hardened bolt actually bent with no effect whatsoever on any other component. I'm not sure you should replace this bolt with an even higher grade, hardened bolt. This occurred due to very unusual circumstances that would be rarely encountered by the majority of users. Further, it's much less expensive, and easier, to replace a bolt than any other component."
We decided that under extreme situations the bolt is easier to replace than the entire frame. Now having said that, if any of you know a customer I can contact that did in fact break the grade 5 bolt please let me know so we can revisit our decision. I will say that in 6 years of having our setup on the market we have not heard of the center bolt breaking...including cars involved in accidents.
If you do decide to replace the center bolt with a grade 8 make sure you buy a 4.25 or 4.5 inch long bolt and cut it down like we do to insure you have sufficient shoulder length on the bolt for the propeller bearings to ride on.
One more issue. Some of you may have noticed that my return phone calls are taking a little extra time to happen (sometimes even a day later). Here's the reason: Through this May and then again this September through December I am taking some additional metallurgy and engineering classes along with some AutoCad and Catia software upgrades to tweak my product decisions and refinements. In the long run it should benefit all of you so thanks for your patience.
#12 OFFLINE   07SGT4578
07SGT4578
  • 4,558 posts
Posted 03 April 2011 - 07:26 AM
Particularly:
Jim, I meant no disrespect in my post, was just trying to inform a potential customer with my experience. PM sent
Chris Carter
Email me
#13 OFFLINE   dbackg
dbackg
    it's Hammer time
  • 1,185 posts
  • Joined 13-November 07
  • Interests:2008 Super Snake - Black - vert
Posted 03 April 2011 - 08:55 AM
Here is your suspension upgrade shopping list:
1. Shelby Fays2 Watts Link:
BILLET: http://www.shelbysto.../s5m-5649-m.htm
http://www.shelbysto.../s7ma-5649-.htm
http://fays2.net/
2. Shelby/Ford Racing Handling Pack, Front and Rear Sway Bar Kit:
Eibach makes the FRPP Sway bars = identical = different color = blue
F: 35mm, R: 24mm
http://www.shelbysto...s7mk-5490-c.htm
or:
2A. H&R Front & Rear sway bars: = beefiest on the market.
http://www.maximummo...roducts_id=1270
Front: Part # 70655. 36MM
Rear: Part # 71655. 26MM
3. Billet Front Swaybar Mounts: Steeda Part # 555-8113
Only works with the 35mm sway bar, NOT H&R
http://www.steeda.co...rd-mustang.html
4. Front Sway Bar End links:
Shelby/Scott Drake: Part #: 5S3Z-5A486-R
http://www.shelbysto...s3z-5a486-r.htm
5. Steeda Front Swaybar mount brace: Part # 555-5553
Does NOT work with Steeda billet swaybar mounts above.
6. FRPP "KR" SHELBY SVT/GT500 STRUT TOWER BRACE: FRPP Part # M-20201-C
http://www.shelbysto...p/m-20201-c.htm
7. Steeda Rear LCA's: Part # 555-4406
Billet Rear Control Arms - Spherical Bearings
7A. Shelby Rear LCA: Part # Z25-S5MA-5538-A
http://www.shelbysto...s5ma-5538-a.htm
8. Carriage House Engineering (CHE) LCA relocation brackets: Part # CHE1L
http://www.cheperfor...ie/prod-209.htm
9. Carriage House Engineering (CHE)
K-Member Brace with Engine Torque Limiters Part # CHE7LA
http://www.cheperfor...ie/prod-208.htm
10. Steeda (UCA) Street/Competition Rear Upper 3rd Link: part # 555-4109
http://www.steeda.co...ontrol-arm.html
http://www.fordgt500...read.php?t=6873
or
10A. J&M UCA part # 23985 with stock factory mounting bracket
http://www.hotpart.c...uct_detail&p=21
11. UCA 2nd bushing that is mounted above the rear differential:
I ordered the Prothane bushing, from CJ Pony.
http://www.cjponypar...5-2011/p/CAB46/
Prothane Part Number: 6-315 = Axle Side Kit
Ford replacement part # 5A638
12. Maxium Motorsports/Shelby American Caster Camber Plate Kit
http://www.shelbysto...5ma-18183-a.htm
http://www.maximummo...roducts_id=1151
13. Tokico D-Spec complete strut/shock kit: Part # DSP-12
http://www.maximummo...products_id=805
14. Springs: FRPP PART # M-5300-L, lowers approx 1.25"
Shock & Springs:
http://www.teamshelb...792-new-shocks/
FYI: If you lower your GT500, it is highly recommended to trim the rear axle orange rubber bump stops.
See zombeat post #28
http://www.teamshelb...06#entry1155706
Edited by dbackg, 13 May 2012 - 09:37 AM.
SuperSnake. TVS. FRPP CAI. CJ65 TB. VMP *Big TB* Inlet. VMP 2.65 pulley/tune. FORE Billet fuel rails. JLT oil separator. Dynatech exhaust headers. Shelby billet shifter. DYNOTECH 1-piece aluminum drive shaft. 170* thermostat. Shelby Extreme Duty Cooling system. FRPP M-4033-G2 diff girdle cover. 3.73 gears. billet Steeda LCA's & adj UCA. CHE LCA relocations brackets. H&R sway bars. FR3 springs. Tokico D-Specs. Shelby/Fays2 Billet Watts link, Shelby/Baer Big brakes. 20X11.75 rears. Michelin PS2 335/30's.
#14 OFFLINE   09TSpony
09TSpony
  • 74 posts
  • Joined 16-July 07
Posted 10 April 2011 - 07:15 PM
Thx for the info. I am in the process of obtaining the LCA and UCA from Steeda. The springs,struts, and sway bars will have to wait a few months though. Again, thx
2009 Shelby GT500
KR cat backs
FRPP cai
#15 OFFLINE   89Saleen215
89Saleen215
  • Pacific Northwest Region
  • 369 posts
  • Joined 18-March 08
Posted 11 April 2011 - 01:25 PM
Anyone know where I can get the "black" Fays2...there used to be a vendor, but I can't seem to find them anymore.
Also, some like the Roush 3rd link. http://store.roushpe...ail.aspx?ID=772
Sig 3
#16 OFFLINE   enormous
enormous
  • 481 posts
  • Joined 14-February 08
Posted 11 April 2011 - 02:52 PM
Jim Fays just sent me a black Fays 2 for my Shelby.
#17 OFFLINE   dbackg
dbackg
    it's Hammer time
  • 1,185 posts
Posted 11 April 2011 - 06:47 PM
Call Jim Fay
http://www.fays2.net/
I spoke to Jim last week, Thursday.
He said black ones will be ready and available in two weeks, April 24th.
#18 OFFLINE   speedyburd33
speedyburd33
    Veritas Aequitas
  • 840 posts
  • Joined 16-January 07
Posted 13 April 2011 - 04:35 AM
Are you saying that you only need the relocation brackets if you want to lower the car, or when you lower the car? What additional parts/mods does lowering the car require? Right now the suspension on my Dad's GT500 is stock and we're looking to make the rear end more solid and stick to the road better under hard accelerating and cornering. We were originally looking at the Fays2 Watts Link and upper/lower CA's with the relocation brackets for each. Is this the best 1st step in the right direction or do we need to be thinking about more for the rear end?
07SGT0890
Team Shelby Member #2553
286.8 RWHP/305.5 RWTQ Stock
Steeda Carbon Fiber Inlet Elbow
Brenspeed Custom Tune
Ford Racing 3.73 Gears
Kooks Long Tube Headers w/high flow cats
Corsa Extreme Exhaust
315.7 RWHP/327.5 RWTQ Stage 1 Mods
Shelby GT/SC Upgrade w/Polished Whipple 550 Completed at Tasca on 9/10/12
1 Piece Driveshaft
Ford Racing Radiator
502.4 RWHP/463.5 RWTQ Stage 2 Mods
1000 Series Forged Internals
ARP Head Studs
Custom Comp Cams
Upgraded Valve Springs
Stage 2 Ported Heads
McLeod RXT Twin Disc Clutch, 8 bolt flywheel
Ford Racing Polished Throttle Body
Whipple Polished 10 Rib Kit
Injector Dynamics 725cc Injectors
MAF Sensor
Updated Tune
???.? RWHP/???.? RWTQ Stage 3 Mods (Completion Estimated 6/27/13 at Tasca)
#19 OFFLINE   JimFay
JimFay
Posted 02 May 2011 - 05:45 PM
Call Jim Fay
Limited number on the shelf and ready to ship.
#20 OFFLINE   Slabo
Slabo
  • 1,941 posts
Posted 02 May 2011 - 06:17 PM
Yes relocation brackets are used when you lower the car or for drag racing setup's. Lowering the car is done by using different (shorter) springs. Sounds like a great first step.
