Dyno results '12 GT500 stock vs pulley
15 replies to this topic
#1 OFFLINE   xeongt
xeongt
  • 12 posts
  • Joined 23-May 11
Posted 03 June 2011 - 01:58 PM
So I'm very disappointed in the gains from adding a 2.6" pulley + idler + colder plugs + canned tune. On a Mustang dyno went from 500hp / 479lb-ft @ 8.7psi peak, to just 529hp / 519lb-ft @ 13.3psi. The graph didn't pick up the timing values for some reason, but they were laughably low....yeah the canned tune really killed me I think :( Will have pull the trigger on something else like LTs to force myself to get a real custom tune now.
Car: '12 GT500 SVTPP, ~820 miles on the odometer ;)
#2 OFFLINE   TrakRat
TrakRat
  • 370 posts
  • Joined 29-December 10
Posted 03 June 2011 - 02:42 PM
I would definitely do a custom tune regardless. My fiance's Terminator picked up 45 ft/lb TQ on a custom tune vs. a canned pulley tune.
'11 SVTPP Griggs VMP TVS GT500, '67 Coupe, '00 Explorer Limited, '96 Griggs Cobra *sold*
#3 OFFLINE   Eyedea
Eyedea
  • 6 posts
  • Joined 15-May 11
Posted 03 June 2011 - 11:25 PM
ack, which canned tune? I'm on the fence about getting a pulley and tune, not worth it for that minimal of a gain.
#4 OFFLINE   Wicked_SVT
Wicked_SVT
  • 124 posts
  • Joined 21-April 10
Posted 04 June 2011 - 02:51 PM
Which tune did you go with? I had Justin from VMP send me his 2.59 pulley and idler and a 91 Octane tune and my car picked up 61 rwhp and 60 rwtq. Those gains seem very minimal for a pulley and tune. Maybe the tune is too aggressive and the car is pulling timing? Good luck with getting it worked out.
2011 Shelby GT500 Kona Blue SVTPP stripe delete
Flat Black OTT stripes added
#5 OFFLINE   Redline58
Redline58
    Howie
  • 51 posts
  • Joined 29-August 10
  • Interests:Cars,MMA.Firearms
Posted 04 June 2011 - 03:02 PM
I had same results with my 2011 Gt500 with VMP 2.59 and tune.You are correct , car pulled timing due to tune.Dyno graph showed knock sensor kicked timing.
#6 OFFLINE   xeongt
xeongt
  • 12 posts
  • Joined 23-May 11
Posted 05 June 2011 - 05:34 AM
I don't want to call out the vendor just yet as I'm going to give them a datalog and see what they come up with.
Redline58 - how were you able to tell about pulling timing from the dyno graph? Did yours record it on there so you could just visibly see it drop? If that's the case I should be able to see the same thing with a datalog.
#7 OFFLINE   ChrisSD
ChrisSD
  • 993 posts
  • Joined 23-August 09
Posted 05 June 2011 - 03:02 PM
Off topic - do you live in Santee? I see a Kona Blue with wide black stripes driving on Mast a lot....
#8 OFFLINE   Wicked_SVT
Wicked_SVT
  • 124 posts
Posted 05 June 2011 - 03:25 PM
That would be me and yes I live in Santee. Do you live in Santee as well? Small world. Funny thing is a rarely see any GT500's out.
#9 OFFLINE   ChrisSD
ChrisSD
  • 993 posts
Posted 05 June 2011 - 04:00 PM
Sent you a PM
#10 OFFLINE   moody03svt
moody03svt
    SN8KBYTE
  • 134 posts
  • Joined 25-March 11
Posted 06 June 2011 - 04:33 PM
Would like to see what that looks like when the timing is pulled on a dyno graph. And want to find out why this pulley produced low increase in power.
2012 GT500 - Blk/Red Stripes, SVTPP, Electronics, Recaro seats
#11 OFFLINE   OsirisGT500
OsirisGT500
  • 236 posts
  • Joined 21-March 10
Posted 06 June 2011 - 06:26 PM
In San Diego here too... cool
#12 OFFLINE   xeongt
xeongt
  • 12 posts
  • Joined 23-May 11
Posted 07 June 2011 - 12:46 PM
The shop just sent me the datalog from the dyno. However it's from a different run than the previous graph was for, but the numbers are very similar. On this run the timing and such looks good...which makes this even more confusing. There shouldn't be any differences at all from '11, but has anyone else done a pulley swap already on a '12 like me that could chime in with their results?
Edited by xeongt, 07 June 2011 - 12:47 PM.
#13 OFFLINE   FAST FRED
FAST FRED
  • 51 posts
  • Joined 13-April 11
  • Interests:Mustangs
Posted 08 June 2011 - 11:53 AM
Me too,
just off Mission Gorge Rd.
2014 Shelby GT 500
Deep Impact Blue, SVTPP, Track Pack, Electronics Package w/ Nav, Recaros.
#14 OFFLINE   Eyedea
Eyedea
  • 6 posts
  • Joined 15-May 11
Posted 08 June 2011 - 06:53 PM
I'm getting mine done on the 18th, I post up my results then.
#15 OFFLINE   Eyedea
Eyedea
  • 6 posts
  • Joined 15-May 11
Posted 25 June 2011 - 06:37 PM
Finally got the pulley and tune done on my '12 GT500. Stock she put down 467hp 437tq w/ 9.1lbs boost. Pulley and tune upped the numbers to 517hp 492tq w/ 12.1lbs boost on a mustang dyno.
#16 OFFLINE   moody03svt
moody03svt
    SN8KBYTE
  • 134 posts
Posted 26 June 2011 - 06:34 PM
Isn't 500hp on a stock GT500 high? Especially on Mustang dyno!I would think starting off with 476 is probably more accurate. For the original poster any chance the initial dyno was off?
Looks like getting 520-530HP after a 2.59 / 2.6 with around 12 / 13 PSI is normal.
