I see the unit goes for $1,329. I assume you guys had the CSC and pilot bearing replaced when you had the job done and the tranny splines lubed with the Ford blue lube as well.
http://www.evoperfor...products_id=708
Spec SS-Trim Twin Disc Clutch Kit and Flywheel
$1,329.00
SS-Trim Torque Capacity is Rated at 900 ftlbs
Super Twins are 10inch upgrades vs. the factory 8.5inch diameter.
All Twin Disk Clutch Kits Include a SPEC Aluminum Flywheel
SPEC Clutches and Flywheels introduces the Super Twin for street and track use in cars with extreme horsepower and torque.
Until now, there has been a drivability, maintenance and longevity trade-off with clutches built to handle 700-1500 ft lbs tq. The revolutionary new SPEC Super Twin has set a new standard offering near-stock drivability, tremendous life expectancy, a no shimming/setup bolt-in installation and maintenance free operation.
With all billet construction, these units are smooth and quiet. The super twin is constructed with aircraft grade aluminum and high carbon billet steel milled to an industry leading .001 inch for perfect balance and actuation.
Friction is provided by dampened, full-faced carbon graphite discs. Organic or full metallic options are available.
Flywheel and track-spec hardware are included in each kit. All units include flywheel, high strength bolts and bearings. Installation is bolt-in with no shimming or setup required.
The Super Twin is for street and track use in cars with extreme horsepower and torque (700-1500 ft lbs tq). The Super Twin offers near-stock drivability, tremendous life expectancy, a no shimming/setup bolt-in installation and maintenance free operation. With all billet construction, these units are smooth and quiet. The units are rebuild-able by SPEC or the end user and replacement components or rebuild services are always available. The super twin is constructed with aircraft grade aluminum and high carbon billet steel milled to an industry leading .001 inch for perfect balance and actuation. Friction is provided by dampened, full-faced carbon graphite discs. Organic, fiber and full metallic options are available. Flywheel and track-spec hardware are included in each kit. Types of driving: street, drag, drift, road racing, time attack, pulling and rallye.
Edited by Grabber, 18 September 2011 - 03:55 PM.
Posted 18 September 2011 - 03:52 PM
View Garage
