Spec SS-Trim Twin Disc Clutch Kit and Flywheel
76 replies to this topic
#31 OFFLINE   jacks1071
jacks1071
  • World-Wide Region
  • 80 posts
  • Joined 22-September 10
  • Region:Australia
Posted 28 August 2012 - 05:37 AM
We've got the Spec SuperTwin P-trim in our two super snakes, they are noisey as hell. You get drive-line noises and serious vibrations through the entire car at lower rpm in higher gears and they rattle/chatter sometimes when you are trying to slip the cluch in tight places like car parks. Getting the car moving off the lights without dumping the clutch or chirping the wheels isn't easy especially on a hill.
They do hold the power, there is no doubt about that. The loss of drivability though almost ruins an otherwise fantastic vehicle. Anyone who tells you "they drive like stock" is full of crap, I presume the S model maybe more user friendly but the P-trim is the one that was recommended for our 800hp super snakes. These came highly recommended and are very disappointing.
Having driven a super snake last weekend with the stock clutch I'm thinking about pulling the spec out. Changing the stock clutch every 10,000 miles doesn't seem so bad.
On the stock clutch I could drive in 6th gear at 60km/ph without any noise. If I run 6th even at 100km/ph with the Spec clutch the drive-line sounds like its going to explode.
Spec support was hopeless as these apparantly are "normal" traits.
Edited by jacks1071, 28 August 2012 - 05:44 AM.
#32 OFFLINE   B Shelby
B Shelby
  • Great Lakes Region
  • 897 posts
  • Joined 19-May 07
  • Interests:Guitars, cars, racing and fishing
Posted 28 August 2012 - 06:36 AM
I have the P trim in my car and not having near the problems you are. I don't slip the clutch , does shutter if trying slip it to much. Drives good at 60 in sixth gear but I down shift to 5th for hills. not much noise, happy with mine
Performance white/black
800 hp polished KB
Super Snake completed March 17 2009
#33 OFFLINE   gtt500
gtt500
  • 275 posts
  • Joined 28-February 07
  • Interests:fast cars,family,dogs
Posted 28 August 2012 - 06:51 AM
I also have the Spec P-trim,not the best in traffic or on hills but no noises or vibrations.
2007 Shelby GT500 white w/blue
3.6 LC Kenne Bell/Evolution Competition Supercharger kit.Thanks Van
80 lb.injectors
Custom cams by L&M
Spec P-trim clutch and flywheel.Thanks Van
Tuned by Jon Lund
Evolution Performance fuel rails
Kooks LTs
Revan/Shelby HE.Thanks Van
Shelby Super Snake Hood
19" CCW Wheels
Bangastang radiator cover
Custom interior upgrade
Narrowed diff w/ 4:10's
Dynotech aluminum D/S
Thank you Van for all your help!!!!
Many,many more mods.....
#34 OFFLINE   Grabber
  • 35,392 posts
Posted 28 August 2012 - 02:32 PM
I went with the 2010 stock set up. It is such a pleasure to drive. It makes driving the car 10 times better. See link for cost:
http://www.teamshelb...-to-pay-for-it/
#35 OFFLINE   E.Marquez
E.Marquez
    GearHead
  • 165 posts
  • Joined 10-February 12
Posted 28 August 2012 - 02:49 PM
I run the S Trim and have zero issues like reported above.
Not a Super Snake power level, just a healthy 634 or so at the wheels...... BUt I for one am very happy with the clutch.
Edited by E.Marquez, 29 August 2012 - 02:31 AM.
Lateral G-forces make me smile.
#36 OFFLINE   redwingone
redwingone
  • 130 posts
  • Joined 13-July 07
Posted 29 August 2012 - 02:04 AM
For those that are eligible for the most current TSB that uses the 2010+ system, it is more than adequate for stock or mildly modified applications with less pedal effort and no noise. If you modify your car past 550 RWHP, you will destroy it sooner than later....been there done that. I deal with street cars, road race cars, and drag cars every day and have many that have complained that the 2010 clutch has held up worse than the Pre TSB clutch and the Post TSB clutch. My own 2010 clutch lasted less than 100 miles when I upgraded to the Kenne Bell 3.6LC. The clutch was slipping and I couldn't even tell, the Dyno did. I went from 666 RWHP to 763 RWHP with just the addition of the SPEC Twin SS. 7K miles later, no issues. I have people with over 30K miles with this Twin SS system with no issues. Remember everyone,. there are positives and negatives to each and every clutch system out there and there are many dealers that will try and talk you into the clutch they make the most money off. SPEC has a pretty poor dealer program, so many dealers don't push them. There is a very little profit margin on a very good clutch system, so many dealers do not push them. Another thing is that there are dealers that sell SPEC clutches that have been sitting on a shelf for a long time...the early versions are not as good smoothness wise as the ones made from November of last year. Been there done that too. The ones that sound too good to be true, usually are. ALWAYS replace the CSC with a new FORD unit too...Why?? Because the CSC wears on the front face to the pressure plate. I have people with 300 miles on their car, insisting to use their 300 mile CSC, and I won't do it, the CSC will fail before the clutch because of the wear pattern. ALWAYS use a new Ford CSC!! ALWAYS use the blue input shaft lube!! Do your home work and determine what you want to use your car for and figure out what is best for your own application before spending the money on a clutch system for your car. The right decision will give you years of enjoyment out of your car with out the feeling in the back of your head "what if". Too many people have made the wrong choice, sometimes several times over, and it is not worth the effort time or money wise.
Alex
alex this is the kinda info that is so helpful and informative. thanks for sharing knowledge tha tonly experience can impart..
ken
#37 OFFLINE   cobra567
cobra567
    Survivor
  • 274 posts
  • Joined 05-September 06
  • Interests:.
Posted 01 September 2012 - 06:01 PM
I had the Spec Twin SS installed in June. My car is 642 rwhp so its healthy but not a monster. I have put about 500 miles on the new clutch and I hate it. Drivability is miserable on the street. I am sure it is great on the track but the chatter that occurs upon engagement ruins the experience of driving the car. I was told to drive it and the surfaces would mate. NOT HAPPENING. I am going to opt to dump the Spec and go back to the Ford upgrade unit. I would rather replace the ford clutch every 15,000 miles than shake my car apart at every light. If you are considering a new clutch I highly recommend not considering the Spec unit.
Red Coupe w White Stripes Picked up - August 10, 2006. -VMP 2.3 TVS w Hi Flow elbow & interchangable pulley-FRPP Twin 65 Throttle Body-FRPP 373 Gears-Ford Finned Aluminum Axel Cover-Shelby KR 18 wheels-2012 Recarro Seats-McLeod RSX Clutch-KR Hood (real)-Shelby Shifter-JLT 127 CAI-Tune from VMP-Shelby Baer 6 Piston front brakes & Baer Eradispeed Rear rotors-SAI Brake Cooling ducts-1 Piece Alumn Drv Shft-Chicane Tow Hook-Chicane Brake Booster Brace-Shelby Radiator and Heat Exchanger-Shelby overflow tanks-P321 graphite caps-FRPP KR Axel Back, Shelby KR H Pipe-Steeda LCA,-Shelby Kicker Premium Sound System-CDC Sequencial turn signals-Tint, FRPP Springs-MMS camber plates-Bangastang Radiator Cover-KR Axel reservoir-MMS Adjustable Sway bar end links-JLT Oil Seperator-P321 Billet Coil covers
#38 OFFLINE   Grabber
  • 35,392 posts
Posted 01 September 2012 - 07:25 PM
That sucks. Really sucks. Sorry to hear this.
#39 OFFLINE   GT500FLYBOY
GT500FLYBOY
  • 3,130 posts
  • Joined 16-September 06
Posted 02 September 2012 - 03:56 AM
Good idea.
Proud member of Team 40th - 07XL0078
2007 Shelby GT500. Ordered 7/31/06. Built 2/8/07. Delivered 3/5/07.
40th Anniversary Shelby GT500 CSM07XL0078 completed 3/24/08.
Whipple 2.9L supercharger, 3.25" pulley, lower IW pulley,
Whipple monoblade TB. C&R radiator, dual fan I/C heat exchanger.
730 RWHP, 680 RWTQ. 1/4 11.18 @ 127.
Posted ImagePosted ImagePosted ImagePosted ImagePosted Image
#40 OFFLINE   E.Marquez
E.Marquez
    GearHead
  • 165 posts
Posted 02 September 2012 - 06:42 AM
Horrible to hear, seems to be a complaint we see about most any brand aftermarket clutch installed.
The only clutch consistently reviewed as pleasant to drive is the OEM 2010 clutch.
I have no way of understanding why my SPEC S trim clutch and the other two I installed are working well for us, and others find it a chattering PIA on their car. But there are just too many reports to ignore.
I'd still recommend it, but suggest that it only be installed by a shop that has a proven track record with SPEC.
Life to short to drive an ugly car, or one that even feels ugly.
Best of luck with your 2010 OEM install.
#41 OFFLINE   ingram4868
  • 6,363 posts
  • Interests:Love of God, Family and Great Cars
Posted 26 September 2012 - 06:51 AM
We all frequently refer to the 2010 clutch as a final fix for our 2007-2009 cars. I'm curious if the 2011+ cars have the same clutch kits as the 2010 or does Ford use something different for them?????
David Ingram
Sparks, NV.
Newest addition 1100 mile 2007 GT500
#42 OFFLINE   cobraracing
cobraracing
    10 second Canuck
  • 4,557 posts
  • Joined 14-December 06
  • Interests:Golf, cars, racing Golf, cars, racing Golf, cars, racing Golf, cars, racing
Posted 06 October 2012 - 04:31 AM
I installed the SS Spec clutch last week with great results, this is how the car should have come from the factory
I have had the TSB installed a few years back and both rattled and made noise but always put up with it
When the clutch started to slip on the dyno it was time for an upgrade
The clutch is so smooth, peddle feel is consistent and similar to the stock, and the rattle when the clutch is released at idle in neutral, it also feels so much better up and down shifting
One of the biggest diferences was going from the 8.5"to the 10"clutch but the lightweight flywheel spins up so much faster than stock
Attached File  IMG_2966.jpg   117.76KB   24 downloads
Attached File  IMG_2971.jpg   116.78KB   36 downloads
Attached File  IMG_2979.jpg   92.93KB   27 downloads
Shelby driving logo
2007 Vista Blue coupe, white stripes tinted windows -Shaker 1000 ,Steeda CAI-SH 2.6 pulley Metco tensioner-SCT live wire tune Eibach Pro kit -Polished Steeda LCA's-Steeda UCA and bracket, 3.73 gears,,2008 mods Kooks headers GESI catted X-pipe and Magnaflow stainless exhaust Innovators west Aluminum OD balancer, DSS driveshaft 160mm T-body Cross drilled Slotted rotors Steeda Adj panhard bar, FMS rear end cover , 2008 ET 10.93 @ 126.55 mph and Dyno #'s 625 RWHP 599 RWTQ on ET Streets, 2012 mods, Shelby heat exchanger, Reservoirs, Vortex series 4 pads, Steeda 20x11 /20x10 Spyder rims with Nitto 315/35/20 - 275/45/20, 6 piston brembos with 15"rotors, rear brake upgrade, stainless brake lines
2013 TVS blower, KB Dual Boost-a-pump now making in Sept 2012 - 755 RWHP & 687 RWTQ **************** 2014 upgrades Ford GT cams 11cc Manley Pistons and h beam rods Ported heads 2013 injectors GT rocker covers 2013 clutch 2013 8 liter oil pan ********2015 Mods - Strange 9" , 350 gear, helical posi, 35 spline axles, dynatech driveshaft, 2.9L Whipple, crusher intake and Tbody, 80lb injectors, Fore innovations fuel system, 28x10-17 slicks on race stars and 18" skinnys
#43 OFFLINE   Grabber
  • 35,392 posts
Posted 06 October 2012 - 07:07 AM
The 2010 to 2012 have the same clutch in them. The 13 is different.
#44 OFFLINE   ingram4868
  • 6,363 posts
Posted 06 October 2012 - 07:32 AM
Thanks for the info Rob. I know you suffered through a number of Ford "fixes" over the years and it is sad that Ford can not react more quickly with such an important aspect of the car. It reminds me of the overheating issues with the 1996 SVT Cobra. I am about to order all the clutch parts that you have listed in your threads. I am so appreciative that you have shared your experiences with all of us on the clutch issues.
David Ingram
Sparks, NV.
#45 OFFLINE   Grabber
  • 35,392 posts
Posted 06 October 2012 - 10:26 AM
I must say that my local Ford dealership has made the service work pretty painless. No suffering on that end of things. The experience has allowed me to establish a better relationship with the service writers and the technicians and the parts guys. Plus it has helped me know how to better help other friends of mine in the car club community get service done on there cars. I am very happy with my GT500 and enjoy the car very much. In fact the Washington and Oregon weather is so good that I will be going out for a drive shortly. 72 and sunny still !! We have not had rain since July 4th and the next 10 days is still looking great. :happy feet:
#46 OFFLINE   markham51
markham51
    markham51
  • Ontario Canada Region
  • 1,477 posts
  • Joined 12-March 06
  • Interests:Cars, boats, golf, fishing!
Posted 07 October 2012 - 04:56 AM
I had the Ford "2010 version" installed in my 07 SS this spring and it works very very nicely. I dont race it. I love how easy the pressure is and how smoothly it shifts. Sean Hyland MS installed it flawlessly and it works far better than the original. with my new brakes it feels like it just came off the showroom floor. My 07 convert still has the original clutch which is working fine still but i would have no hesitation in installing the 2010 factory version if/when it craps out.
Everything happens for a reason; sometimes that reason is you are stupid and make bad choices...
Some of my current vehicles:
68 Shelby Mustang GT500KR Convert Acapulco Blue
64 MKIII SP Cobra w Rousch 427R Black
07 Explorer Sport Trac Limited Red
07 Shelby GT500 Convert Torch Red
07 Shelby GT500SS Coupe Tungsten Grey
10 Lincoln MKS Ecoboost AWD
13 SVT Raptor 6.2L White w graphics
16 GT350 Shelby Cobra Mustang Oxford White w blue stripes
Future cars:
17 Ford GT if I can find one under a gazillion dollars
#47 OFFLINE   Grabber
  • 35,392 posts
Posted 07 October 2012 - 07:21 AM
Glad to hear from you Mark. :)
#48 OFFLINE   markham51
markham51
    markham51
  • 1,477 posts
Posted 08 October 2012 - 04:41 PM
Thx man. Been crazy busy lately with not much extra time. Trust you are well..
Regards,
Future cars:
#49 OFFLINE   LuckySnake
LuckySnake
    LuckySnake
  • 3,541 posts
  • Joined 11-May 06
  • Interests:Cars & Planes
Posted 08 October 2012 - 06:18 PM
I would try driving it with the traction control turned off and drive it with the intention of letting the rear tire spin a tad bit on take off, not the clutch. A tiny pain but it isn't a Corolla. Guys with the 2010 clutch will pay the piper in early replacement costs IMO.
#50 OFFLINE   Grabber
  • 35,392 posts
Posted 08 October 2012 - 06:25 PM
The 2010 set up has been out for 3 years now and 99% of the cars are doing great. There are very very few failures reported. IMO that is great news.
#51 OFFLINE   dlfort
dlfort
  • 33 posts
  • Joined 18-February 11
  • Interests:golf,and driving my shelby
Posted 22 October 2012 - 02:27 PM
I HAVE INSTALLED MY SPEC SS CLUTCH NEW CSC PILOT BEARING.I HAVE BLEED IT,NO GRIND GOING INTO GEAR,IT CHATTERS GOING IN REVERSE,ANY INPUT ON THIS,OR IS NORMAL WHAT ELSE CAN I DO.
#52 OFFLINE   E.Marquez
E.Marquez
    GearHead
  • 165 posts
Posted 22 October 2012 - 03:15 PM
I have no chatter, forward gears or reverse.
Did you install this or have a shop do it?
#53 OFFLINE   jacks1071
jacks1071
  • World-Wide Region
  • 80 posts
  • Region:Australia
Posted 19 December 2012 - 04:16 AM
MY expererince with Spec is that they SUCK at customer service..
and their products are not far behind...
I 2nd your opinion. I wasted quite a lot of money having two of the P-Spec ones shipped to Australia and having them installed.
They are absolutely horrible and the only thing keeping them in there is the expense associated with pulling them out.
#54 OFFLINE   marsh2o
marsh2o
  • 228 posts
  • Joined 15-April 06
Posted 20 December 2012 - 04:46 PM
I just had the Spec SS installed today and have had exactly the same experience -- smooth and quiet under all conditions. I too had the TSB done several years ago and it lasted ~7K before it started slipping again. As I am planning some HP increases in the future, I wanted a clutch that was going to be a little more durable. Time will tell, but I couldn't be happier with the Spec's present performance.
#55 OFFLINE   0201212
0201212
  • 658 posts
  • Joined 30-January 10
  • Interests:Running, family,and anything with a motor
Posted 21 December 2012 - 05:44 AM
My ACT twin disc is more of a pleasure to drive then my friends with the 2010 and up clutch. No issues at all pedal effort is down from stock and you can now slip the heck out of it if needed for spirited starts. Very predictable as well and no more noise then stock.
Edited by 0201212, 21 December 2012 - 05:45 AM.
"There's magic in misery"
#56 OFFLINE   jacks1071
jacks1071
  • World-Wide Region
  • 80 posts
  • Region:Australia
Posted 28 December 2012 - 04:08 AM
Mine chatters in foward and reverse so you're doing alright.
#57 OFFLINE   Hooper T
Hooper T
  • 177 posts
  • Joined 13-August 08
  • Interests:My Family, Varsity Football, BMX, Hockey, Motorcycles and Stangs.
Posted 25 May 2013 - 11:53 AM
I have installed over 50 of the Twin SS SPEC clutches in 07-11 GT500's so far, no issues. No hiss, easy pedal effort, and no worry when you drag race and road race that it will go out. The P trim is overkill for most of our cars. 5K miles on my Twin SS with 763 RWHP, drag racing, road racing, etc, no issues. Really the best clutch for these cars in my opinion, and I have tried them all. I became a Spec dealer as I was using so many of them.
Alex
What Flywheel do you recommend?
Is OEM OK?
#58 OFFLINE   SteelSteeds
SteelSteeds
    Enough HP = no $$ left
  • 595 posts
  • Joined 15-December 05
Posted 27 May 2013 - 11:44 AM
The SPEC twin SS trim comes with its own flywheel, included in the package.
Lance
'77 Cobra II - 302, C4
'78 King Cobra - 351W, T-5
'79 Bronco - 429, C6, NP-205
'08 Shelby GT 500 - 2.59" VMP Pulley & 90mm idler - JLT CAI - Kooks long tubes/custom catted H-pipe/Borla Touring Mufflers
SPEC SS clutch/lightweight aluminum flywheel - MGW short throw shifter - KKM pistol grip shift knob - Granatelli Tire Fryer line lock
Evolution Ultimate Suspension Package
#59 OFFLINE   scgallo2
scgallo2
  • 4 posts
  • Joined 16-July 13
  • Interests:Cars
Posted 23 October 2013 - 05:16 PM
I recently had a Spec Twin SS installed by a reputable speed shop and just completed the 500 mile break-in period.  No problems so far.  It has light pedal feel with smooth engagement.  As Grabber recommended, I had them replace the CSC, pilot bearing, upgrade the clutch line, and change out the fluid with Royal Purple.  Though the aluminum flywheel and my one piece aluminum driveshaft shed alot of drivetrain weight, I do not notice any more noise or vibration over the stock configuration.  I am very pleased with my setup.
2008 Shelby GT500 (Vista Blue)- Ford Racing/Whipple 2.9L Supercharger, 65mm Cobra Jet Throttle Body, 123mm Cold Air Intake, Upgraded Fuel Pumps, NGK Iridium Spark Plugs, C&R Heat Exchanger w/ Dual SPAL Fans, PFAB Intercooler Reservoir Tank, JLT Oil Separators, Speed of Sound Dual A-Pillar Gauge Pod w/ Autometer Cobalt Boost and Fuel Pressure Gauges, Spec SS-Trim Twin Disc Clutch, DSS Aluminum Driveshaft, BMR Front Driveshaft Loop, H&R Sport Lowering Springs, Maximum Motorsports Caster/Camber Plates, BMR Level 1 Drag Race Suspension, BMR Adjustable Panhard Rod w/ Relocation Bracket and Upper Support Brace, Ford Racing Low Profile Differential Cover, DBA 4000 Series Slotted Brake Rotors w/ Hawk HPS Pads, 285/40R18 Nitto NT05R Drag Radials
#60 OFFLINE   peter301
peter301
    Peter
  • 127 posts
  • Joined 22-March 12
Posted 23 October 2013 - 09:02 PM
Well my experience is hell!! Just installed the Spec clutch set up, and we were getting a very loud and high pitched slipping noise from the clutch when leaving from a start in 1st and then in 2nd gear.  We were originally told that we did not need to install the additioanl flywheel, since we were not going with a wild set up, just a very mild one since we did not race or trake the car at all. When we called up their customer service, their tech support, they actually told my mechanic to tell me, "to up my radio, so I couldn't hear it!" Well after he picked himself up off the floor, he called back to speak with someone else and they offered no solutions. This went on for about 3 weeks, until we got a hold of someone in their tech department that sounded older than 20 years old, and had some obvious knowledge about there product. He said that we indeed needed the flywheel, and that the person who placed the order should've know this. After we order the flywheel and installed it, the noise did go away, but know the clutch slips in any gear, when you mildly step on the gas. Under very modest acceleration, I go through all 5 gears and max out at just above 75 mph, never going below 5k rpms, when we used to be over 100 mph in 3rd under the same acceleration. When we called up this time, they told us they would not help us, because the clutch was over it's 30 day wty, and considered used, even though it was their own techs for the reason the 30 day wty ended in the first place. So, I would tell anyone that would listen, stay away from this product!!! More for their lack of customer service and focus after you puchase the product, and secondly becuse they will not only stand behind their products,  but there own employees do not even know about their products...
Spec Clutch: $400 + Labor
Spec Flywheel: $400 + Labor
Getting everything fixed for the 3rd time: Still Waiting for that Bill
Spec's Tech's Answer: "turn up the radio, so you customer can't hear the noise" = PRICELESS    PS, I have the Shaker 1000 set up, and I can still hear the noise!!!
