Carroll Shelby: 11 January 1923 - 10 May 2012. More.
"I never thought about dying. The day you were born, it was already written down the day you're gonna check out. Now, I'm not gonna throw myself under a truck,
but I'm not gonna worry about when I die. I'm ready to move on when that day comes." Carroll Shelby.
New 2.5" press on pulley
8 replies to this topic
#1 OFFLINE   enormous
  • 441 posts
  • State or Province:On
Posted 07 February 2012 - 11:01 AM
Bangastang recently released this pulley for the stock Eaton.
http://www.bangastan..._5_4_Blower.htm
#2 OFFLINE   mullens
  • 1,093 posts
  • State or Province:nv
Posted 07 February 2012 - 12:06 PM
I thought the snout had to be reconfigured for a 2.5 pulley? I know VMP had to do some modifications for theirs to fit.
2010 GT500, Torch Red/Satin Black
FRPP TVS w/procal tune
Bob's Oil Separator
KR Mufflers w/ H-Pipe
NXT Hood Struts
#3 OFFLINE   mustang loco
  • 212 posts
  • State or Province:QC
Posted 07 February 2012 - 02:22 PM
No, actually these were machined to fit without any mods done to the Eaton's snout!!
Edited by mustang loco, 08 February 2012 - 12:06 AM.
[If you can't hear my whine......................you're behind
MODS:
Pullied TVS
10% I.West
L&M 72/plenum/port match to the blower
3:73 gears and bit of exhaust!...And all kinds of other mods...
#4 OFFLINE   Justin00Stang
  • Authorized Advertiser
  • 1,639 posts
  • State or Province:FL
Posted 10 February 2012 - 09:38 PM
I have not seen that pulley, but I can tell you what my experience was when we designed the VMP spec TVS.
We adhered to eaton minimum specifications and tolerances when designing the VMP TVS to handle a 2.5" pulley. We also noted the maximum possible tolerance stackup and took that into account. There is litterally a specification down to the thousandth for every part of a blower. We had to take an extra 3mm off the snout to safely accomodate a 2.5" pulley. 3mm is 1/8" so its a good amount. I believe steigmeire and metco also state that there is special machining required to use a 2.5" pulley.
I just did some math, and based on the minimum cross sectional area, minimum clearance, and minimum groove depth for the belt, the smallest I would go on a stock diameter snout is 2.58". Certainly you can cheat on groove depth, but then your belt makes flat contact instead of angular contact, that results in less surface area, and now your belt is riding up higher making the effective diameter larger. We all know what happens if you cheat on cross sectional area.
I will also add, I have measured pulleys that had the ribs mis-aligned by as much as 1/16" and totally deviated from the SAE groove profile in terms of section width and angles. If you put the pulley on an optical comparator you can spot it very easily. You know all those belt squeal problems people have? it's from deviating from the SAE groove profile too much. Within a few thousand miles the belt gets a funny wear pattern and squeaks when cold.
I tend to over-analyze everything, and in the process of designing our pulleys I found a myriad of intricacies.
Justin Starkey Justin@VMPTuning.com VMP Tuning- GT500 Specialists
2007 Shelby GT500 Red/Silver
Highest HP with 2.3L TVS816RWHP/779RWTQ
Mods: VMP 2.3L TVS Supercharger, VMP Dyno-Tune, VMP 2.5" Upper, VMP 72MM TB & Elbow, 123MM MAF, IW 10% OD balancer, 80s, Dynatech 1 7/8" LTs, Comp Stage 2 cams.
New VMP 2.3L TVS Supercharger $3,499
07-12 GT500 Custom Tuning starting at $199
2011 Mustang GT 5.0L with Roushcharger 9.79@140, wife's car
2006 Mustang 4.0L with Vortech @ 15psi & 6spd, wife's car
2006 Jeep GC SRT8 6.1L AWD, wife's truck
2006 F250 6.0L PSD 4WD CC
2000 Mustang Twin Turbo
#5 OFFLINE   UnleashedBeast
  • 306 posts
Posted 22 February 2012 - 12:07 PM
For the record, the Bangastang 2.5" pulley made for the stock Eaton M122 supercharger is manufactured by Sylvain "Autoliberte".
Justin....sounds good with all the technical talk, but I assure you, Sylvain's 2.385" pulley on my VMP TVS is rock solid with zero belt slip/squeals/noises. After sending him the 2.5" that was removed, it was determined that a 2.375" is possible. In all fairness, I am using a bolt on 90mm idler to eliminate the possibility.
With that said, I will tell you this.....My car with the standard 2.5" pulley, your (VMP) stock location 90 mm idler replacement pulley (no metco bolt on style 90mm installed), and a thump tensioner did have belt slip above 4,000 rpm. My assumption is the smaller pulley on the Thump tensioner wasn't capable of taking up enough belt slack like the stock tensioner pulley size would. The same stock length belt was used for both configurations discussed in this post.
17-17.5 PSI with stock lower, no cats, and 3" exhaust all the way from the stock exhaust manifolds back.
Edited by UnleashedBeast, 22 February 2012 - 12:30 PM.
#6 OFFLINE   lawdude
  • 1,243 posts
  • State or Province:GA
Posted 22 February 2012 - 05:42 PM
I have a polished TVS SC that was part VMP group buy done right before he came out with the VMP TVS. It has a 2.59" pulley, which Justin says is the smallest that will fit. Do you have an opinion as to whether this 2.5" pulley would work?
Edited by lawdude, 22 February 2012 - 05:45 PM.
The Fastest Lawyer On The Planet
10.912 @ 134.81
___________________________________________________________________________________________________________________________________________________________________________________________________________
2010 Triple Black - Livernois Engine Rebuild FRPP: TVS S/C, Ported Plenum, 2.59 Upper, MAF, Ken B Tune 690whp 669wtq. L&M T/B. 10% Custom Lower, 72# Injectors, B-A-P, Kooks Headers, Magnaflow Magnapacks & Resonators, McLeod RXT Clutch, MGW Shifter, N2MB WOT Box, Steeda: Air Intake, Aluminum Drive Shaft, Lower Control Arms, D/S Loop, Hood Struts, Adjustable Panhard Bar, Adjustable Rear UCA. Revan Heat Exchanger, American Muscle OEM Style 19" Wheels (Black)
10.912 @ 134.81
#7 OFFLINE   mustang loco
  • 212 posts
Posted 23 February 2012 - 07:00 AM
Don't want to try the same as UnleashedBeast,s?
MODS:
Pullied TVS
10% I.West
#8 OFFLINE   Justin00Stang
  • 1,639 posts
Posted 23 February 2012 - 08:27 AM
That is understandable that it would slip with the thump tensioner and smaller pulley it comes with, which is there for extra clearance. it is possible to swap the stock pulley back onto the thump tensioner though, however if you have a metco aux idler bracket its not a big deal.
We can't work that far outside the minimum spec on pulley design, but if someone wants to assume the risk and go thinner than they can certainly do that. Though based on your quoted boost number it doesn't seem that it was much of an improvement, much bigger gains would be seen from a lower.
Mike, emailing you.
#9 OFFLINE   UnleashedBeast
  • 306 posts
Posted 23 February 2012 - 08:50 AM
Your supercharger with the 2.5" pulley, my car with high flow cats on the 3" JBA setup, only made 16 PSI at max boost. When I gutted the cats and added the 2.385" upper pulley, it now peaks at 17.5 PSI. I'd say that's a big improvement with losing the cats. Sure, I would have gained more with a 10 or 15% lower, but this puts me right on the edge of max boost without race gas. That's as much as I want.
The 2.385" will not fit the stock snout on that blower. Sylvain does make a special 2.55" that will fit any FRPP TVS style blower, which is what the polished version is.
Edited by UnleashedBeast, 23 February 2012 - 08:54 AM.
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
