1-2 Shift problems
204 replies to this topic
#1 OFFLINE   georgefrye
georgefrye
  • 33 posts
  • Joined 05-October 10
  • Interests:Cars/Guns
Posted 01 March 2012 - 08:00 PM
Hi all,  Has anyone heard if Ford is doing anything on correcting the 1-2 shift problems on the 2012 Shelby GT500?  Everytime I try to speed shift from 1 to 2 I get a grinding of gears. All the other gears speed shift just fine I have been back to my dealer several times they tell me they can't find a problem.
George
#2 OFFLINE   Torched10
Torched10
  • 2,291 posts
  • Joined 19-February 09
  • Interests:GTOs,Vettes,Mustangs
Posted 02 March 2012 - 05:59 AM
do a search on this forum--there are lots of suggestions, including what parts are needed for your dealer to fix it
formerly known as bobstripower
2010 Torch Red  Shelby vert 540hp ordered 2/15,VIN--3/15,  window sticker 4/24,Est build 5/19,actual 6/3,shipped 6/11,at dealer(MM) 6/17,picked up 6/18 1of24 red with silver verts 1 of 8 w/o GPS
2007 Burgundy Vette vert  400hp
2011 Caddy Escalade EXT 405hp white, 2008 Cadillac STS-V 469hp,black/black 1 of 400 made
1965GTO vert,4spd,tripower Reef Turquoise,white top,white interior 360hp,frame-off resto,all original parts
Atlanta,Ga
you have to grow old,but you can stay immature forever
#3 OFFLINE   zimm17
zimm17
  • 86 posts
  • Joined 12-May 11
Posted 02 March 2012 - 08:29 AM
http://www.allfordmu...-2nd-ideas.html
In short- PM deysha with VIN and your location to get the ball rolling.  Had mine rebuilt at 600 miles.  Fixed.
#4 OFFLINE   Amigo GT500
Amigo GT500
  • 1,332 posts
  • Joined 05-July 11
  • Interests:Harley Davidson Motorcycles
Posted 02 March 2012 - 08:40 AM
Other option.....go with MGW!! it's worth!!
2012 Shelby GT500 Super Snake - CSM 12SS0214 - Performance White, Black Stripes, Black Wheels
2007 Shelby GT - CSM 07SGT0874 - White, Silver Stripes, Grey Interior, Auto Transmission (1 of 48)
1989 Shelby Dakota #180 - Engine Serial Number KN652001809 - White, Black & Silver Stripes (1 of 500)
2003 Shelby Pagsta Mini Motorcycle - VIN 1J9RR11573C273523 (1 of 25) - Blue, Silver Tribal. Signed by Carroll Shelby
2011 Shelby Felt Bicycle - #SF134 (1 of 500) - White, Blue Stripes
"If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower."
#5 OFFLINE   zimm17
zimm17
  • 86 posts
  • Joined 12-May 11
Posted 02 March 2012 - 08:41 AM
MGW won't fix a faulty 1-2 gears and synchronizers...... and could void the warranty before ford fixes it.
Edited by zimm17, 02 March 2012 - 08:42 AM.
#6 OFFLINE   Boidster
Boidster
    Shelby Amateur
  • 252 posts
  • Joined 19-December 11
Posted 02 March 2012 - 10:09 AM
The few times I've tried a fast 1-2 shift above 4K RPM I've gotten a grinding rejected shift. If I wait just a fraction of a second after the pedal hits the floor, the shift is OK. Eventually I will get it into the dealer and ask Deysha to escalate right away. I'm not going to go 3 rounds with the dealer; I'd rather have someone from Ford call the dealer proactively, saying they know about my VIN and its shift problems.
- 2012 GT500 in Performance White, stripe delete, SVTPP, nav
- 1967 289 Vinyl-Top Coupe in Sauterne Gold, 50K miles, factory exterior, light performance upgrades
- Trust me you don't care about my other cars, past or present
#7 OFFLINE   georgefrye
georgefrye
  • 33 posts
Posted 03 March 2012 - 05:52 AM
Thanks zimm, how do I go about sending deysha my informatio?
George
#8 OFFLINE   2010KonaBlueGT
  • 5,959 posts
Posted 03 March 2012 - 11:50 AM
You click on the link, scroll down to Deysha's post, click on her name, click on the "Personal Message" (PM) button and send her the information she requests in her post (VIN, mileage, dealer name, etc.).
#9 OFFLINE   georgefrye
georgefrye
  • 33 posts
Posted 03 March 2012 - 12:40 PM
  Thanks zimm I appreciate the help.
George
#10 OFFLINE   2010KonaBlueGT
  • 5,959 posts
Posted 03 March 2012 - 12:50 PM
George
Anytime john.
#11 OFFLINE   zimm17
zimm17
  • 86 posts
  • Joined 12-May 11
Posted 04 March 2012 - 01:43 PM
Good luck!  Report back your results.
#12 OFFLINE   georgefrye
georgefrye
  • 33 posts
Posted 05 March 2012 - 07:37 AM
Will do,thanks
George
#13 OFFLINE   jeredh
jeredh
  • 37 posts
  • Joined 19-November 11
Posted 13 March 2012 - 06:57 AM
i'm finding myself following this topic...my '12 GT500 has grinded 1-2 on two occasions...two more occasions than I wish to admit.  I'm not speed shifting, but certainly am trying to get from 1st to 2nd as quickly as possible.  I called my dealer and he looked on Ford's technical bulletin, and to date there is no technical services bulletin posted about this problem on my VIN number.   So I'm on high alert.
I did send Deysha a PM at allfordmustang as well.
Thanks All
#14 OFFLINE   Radical08
Radical08
  • 374 posts
  • Joined 19-December 07
Posted 16 March 2012 - 02:23 AM
Look up my post in here and you will find all sorts of info.  The only cure is to get the transmission rebuilt with the listed parts under warranty.  Once it grinds it will always grind and get worse.  After that I did the below things to ensure no more issues.  Also key is get a good size dealer that has a tech with years of experience in these type of transmissions.
1.  I installed an MGW shifter to replace the sloppy stock shifter
2.  I replaced the tramsmission fluid with Amsoil full synthetic
3.  I installed a brace that connects the transmission to the car frame so no more twisting.  This is important because no matter what shifter is on there one ond of the shifter rails mount on the transmission and the rear end to the car upper tunnel.  So when there is torque and twisting that will have an impact on the shifter because of how it's mounted
My car with VMP mods is putting down right at 600rwhp and I have no issues anymore.  I also don't speed shift because no need to anyway with  this much power and fast revving the engine does.
BELOW ARE THE PARTS THAT WERE REPLACED
-7R3Z 7124A SYNCHRO -SPROCKET
-AR3Z 7102A GEAR MAIN SHAFT
-AR3Z 7100AB GEAR MAIN SHAFT
-7R3Z 7107A RING 1ST SPROCKET
-7R3Z 7A082A KIT TRANS CO0SPROCKET
-7R3Z 7124A SYNCHRO ASSY
-7R3Z 7107A RING-TR 1ST SYNCHRO
-7R3Z 7A082A KIT TRANS CONTROL
-AR3Z 7100AB GEAR MAIN SHAFT 1ST
-AR3Z 7102A GEAR MAIN SHAFT 2ND
Could be 1-2 more but this is what I recall.  One was a blocking ring.
Edited by Radical08, 16 March 2012 - 02:26 AM.
#15 OFFLINE   71sixpack
71sixpack
  • 51 posts
  • Joined 27-September 11
Posted 16 March 2012 - 05:05 AM
Has anyone had any luck dealing with Tasca Ford in Rhode Island on this issue?  My '12 with less than 1k miles has it as well.  I talked to the mod shop about it and the reply was to install the MGW because Ford was not honoring the claims anymore.
Joe
Current Cars:
2012 GT500 Convertible - Grabber Blue
1969 Mach 1 - Calypso Coral
#16 OFFLINE   Radical08
Radical08
  • 374 posts
Posted 17 March 2012 - 04:02 AM
Once the grind starts the cure is repair the transmission.  MGW will not solve the grind alone.
#17 OFFLINE   SnakeStrike
SnakeStrike
  • 26 posts
  • Joined 28-September 09
Posted 01 April 2012 - 11:55 PM
ford has a fix. Buy a 2013.  Listen from about the 3 minute mark.
Edited by SnakeStrike, 01 April 2012 - 11:56 PM.
2010 GT500 Kona blue White Stripes
Life just got a whole lot more FUN!
#18 OFFLINE   mustangrich
mustangrich
    Newbe
  • Joined 15-January 12
Posted 08 May 2012 - 05:58 PM
Anyone want to buy my 2012, Im thinking about the 2013!
It would be sweet just to change out the tranny for a 2013 one.
Edited by mustangrich, 08 May 2012 - 05:59 PM.
#19 OFFLINE   corepuncher
corepuncher
  • 127 posts
  • Joined 07-June 11
  • Interests:Meteorologist, like chasing and playing drums. Oh...and GT500's!
Posted 08 May 2012 - 10:28 PM
I brought my 2011 by the dealer twice.  He could not get it to grind, so I rapped it up to 6000 rpm and it did NOT grind...both days I was there.    He said that he does not see anything wrong with it.
I have to say, I"m getting better at driving it.  Just a slight hesitation and a hard deliberate shift works. I don't know what it is but I have grinded 2nd gear by shifting very slowly in town, especially around corners.  Not sure if it was a lack of concentration on my part or what, but from what I can tell, the clutch is all the way down.  Now that I have driven the car for a year, it grinds much less.
I think we are SOL unless we get a 2013.
2011 GT500 Shelby Mustang + SVTPP + NAV  Delivered on: July 6th, 2011
Sterling Grey Metallic + Wide Black Matte Stripes
Mods (performance):Ford TVS + 2.59", CJ TB, C&R Heat Exchanger, 170 deg thermostat, Roush Tank, Resonator Eliminator, Airaid Blue Filter
20" Asanti 3-Piece forged rims with Michelin Pilot Super Sport Tires (255 F, 295 R)
Mods (dress up):Carroll Shelby Signature Plate, 20% Tint, Turn signal & Quarter marker light tint,
chrome door bezel, locks, handles, headlight knob, map lights, seat adjustment levers.
Stereo: JL C5-570x front doors, JL C2-570x rear, Jl Cleansweep + DX400 Amp, Memphis 1000D Amp + 12" Diamond Sub
#20 OFFLINE   jeredh
jeredh
  • 37 posts
Posted 14 May 2012 - 07:49 PM
Got mine back from the dealer. I dropped it off at my dealer on a Monday, the transmission dropped Tuesday, and the parts ordered on a Wednesday after my dealer communicated their findings to Ford.  I got the car back Tuesday...8 days after I dropped it off. The "invoice" shows my issue as "there is a grinding noise heard and felt when shifting into second gear at or around 5,000RPMs".  The next line says "Cause: faulty synchrnizer".
Here's the parts listed as having been replaced:
(1) 8R3Z*7230*A  Fork - 1st and 2nd Speed
(1) AR3Z*7102*AB Gear - Mainshaft 2nd speed
(1) AR3Z*7124*AA Synchronizer Asy - 1st and 2nd
(1) 7R3Z-7A082*A Kit - Transm Contyrol Selector
(1) AR3Z*7107*A Ring - Synchronizer
Jury is still out on the results, but initial test drive did not result in a 1-2 grind. I will admit it's not the smooth shift you'd expect out of this vehicle either.  I have to put on many more miles before I am convinced it's fixed.  My first priority is going to be to drive a new model and compare the two.
