Yes the 2013 will rock, but will it have a functional oil pressure gauge?
4 replies to this topic
#1 OFFLINE   KEYSTONE
KEYSTONE
  • 87 posts
  • Joined 13-June 10
Posted 11 March 2012 - 06:42 PM
I've seen several videos and screen shots of the "track apps" dash display.  I see it has nifty video-based gauges for boost and other engine parameters, but the only time I've seen a screen shot for the oil pressure gauge was when the car was off and it just read "LOW" instead of the numeric value of 0 psi.
I am still pretty pissed that my 2011 has the equivalent of an "idiot light with a needle", in that the oil pressure gauge is either "normal" or "low", with none of the normal variation (due to oil temp and engine RPM) that a real gauge portrays.  From my initial rant on this topic back in 2010, I was told that Ford decided that people did not know how to interpret a true oil pressure gauge.  Apparently folks would freak out if oil pressure at idle in a car at normal operating temp is (correctly) lower than the idle oil pressure when the engine is cold started.  Really Ford?  There are about 300+ "WARNINGS" and "CAUTIONS" in the owners manual.  How about you give me a real oil pressure gauge and just include a "WARNING" that oil pressure decreases as oil temp increases.....
So, can someone tell me if the 2013 has a real sending unit to send true pressure readings to the Track Apps screen, or does it have a 1940's era binary normal/low sending unit?  One of my cost justifications for considering a trade-in of my 2011 for a 2013 is that by going with the 2013 I can offset the cost of adding a gauge pod to the dash of my 2011, similar to the one on the Boss LS.  I'd appreciate it if someone can track down this info for me and/or post a link to a video of the Track Apps display with the engine running and showing a numeric oil pressure reading (example "47 psi") instead of a f#$%^ng "Normal" reading....
Edited by KEYSTONE, 11 March 2012 - 06:43 PM.
Quote of the year, from 6.1hemi:
"I just wanted to type some junk cause I am having some beers and I really like cars."
#2 OFFLINE   KEYSTONE
KEYSTONE
  • 87 posts
  • Joined 13-June 10
Posted 02 April 2012 - 05:35 PM
Bumping this back up to see if anyone has had the chance to observe the oil pressure reading on the '13 dash with the engine running.  I've saved more than one engine from total grenading by observing variations (on the low side) from prior oil pressure readings, so I want the utility of a real gauge....
On a side note, my local dealer has two (2) 2012 Boss cars on the lot, both are non-LS versions.  Their dashes don't even have the make-believe oil pressure gauge found in the Shelby.  So, maybe I should feel lucky with a faux gauge after all....
Edited by KEYSTONE, 02 April 2012 - 05:38 PM.
#3 OFFLINE   cobra2564
cobra2564
  • 115 posts
  • Joined 13-January 08
Posted 06 April 2012 - 06:50 PM
Just plumb in an actual pressure gauge and call it a day.
#4 OFFLINE   KEYSTONE
KEYSTONE
  • 87 posts
  • Joined 13-June 10
Posted 07 April 2012 - 08:18 PM
This just in: Based on a view of a 2013 GT with the engine running, the oil pressure gauge only displays "NORMAL" and does not display a numeric value.  Ford continues to economize on the cost of sending units for a real gauge....
#5 OFFLINE   svt13
svt13
  • Banned
  • 2,687 posts
  • Joined 24-April 12
Posted 25 April 2012 - 02:38 PM
There are a few articles saying how the oil pressure just says "low", "normal", or "high" on GTs. I don't see that being any different for the shelby.
2013 shelby gt500 black w/black stripe SVTPP,Recaros,Electronics Package,Glass roof,car cover.
35% window tint
nav-tv rear view camera
Red line hood struts
Front splitter curb alert system
Super snake carbon fiber splitter
APR Performance carbon fiber mirror assembly
JLT CF resonator delete w/blue airaid Filter
Shelby transmission cooler scoope
BMR UCA with Mount, BMR adjustable panhard bar
Bob's billet LCA and bob's oil separator
FRPP springs
HRE p40 w/Michelin Super sport tires
Future mods going on the car soon: Shelby floor and trunk mat, custom made EPCO shifter knob
Mods undecided about:
Boss x brace, MGW shifter, Boss side exhaust, Corsa black diamond axleback, Lithium battery
