nt05r
8 replies to this topic
#1 OFFLINE   softy
softy
  • 190 posts
  • Joined 22-June 07
Posted 28 March 2012 - 03:18 PM
need help on deciding if i should get these or not.   those who have them do you like them?  pros and cons?
i never personaly used a nitto tire before and i always get mixed  thoughts!
#2 OFFLINE   cluscher
cluscher
  • 631 posts
  • Joined 24-April 07
Posted 28 March 2012 - 08:45 PM
They worked great on the drag strip for me.  Stock size and 1.6 short times.  To and fromt the track they drive great, but a bit aggressive for daily street use IMO.  That duty is handled better by the 555r.
2007 GT500 Black/Tungsten
Engine/Performance
FRPP Cold Air Intake; Metco 2/6" S/C Pulley w/Idler; FRPP CJ Throttle Body; L&M s/c plenum; Lund Racing Tune; '08 Lower Pulley; Shelby/Revan Racing Radiator; Shelby/Revan Racing Heat Exchanger; FRPP 3.73 Gears; Full 3 in. JBA catted exhausted; Dynotech 1-piece driveshaft; FRPP SVT Shifter with Shelby cue ball; JLT Brake Duct Kit with Black Bezels; Mintex Xtreme Front Pads; Hawk HPS Rear Pads; Stainless Steel Brake Lines; Reische 170 T-stat; KR Axle Reservoir
Chassis/Suspension
FRPP FR3 Handling Pack (Dampers, Springs, Sway Bars, Strut Tower Brace); Griggs Torque Arm; Griggs Lower Control Arms; Griggs Axle Brackets; Griggs Adj. Panhard Bar
#3 OFFLINE   lonestarrv
lonestarrv
    Maddog-6
  • 24 posts
  • Joined 02-July 08
Posted 03 April 2012 - 10:19 AM
I have a set of them on my GT-500 Super Snake and love them.  Lock up very well, stoped the 2d gear tire spin.  Highly recommend on dry pavement only.  Suck in the rain or wet roads.
2007 GT-500 40th Anniversary, White 07XL0090
2007 GT-500 Super Snake (725HP), White 07SS0092
2007 GT-500 Super Snake (725HP), Black 07SS0089
Thank a VET for your Freedom!
#4 OFFLINE   SVTboy98
SVTboy98
  • 134 posts
  • Joined 10-September 08
Posted 04 April 2012 - 07:18 AM
How do they handle cornering? I know they're a drag radial, but in a 315/35/20, with the short sidewall, I was wondering if they could handle some aggressive corners.
2008 GT500 - 616rwhp 603rwtq
(#364/6513, #79/971 Vapor)
Performance: VMP tune/pulley, C&L intake, TR6 plugs, MGW shifter, Dynomax Ultra-flo, Dynatech headers, Ford Racing 65mm TB, Shelby (Revan) HE, 170 t-stat, McLeod RXT, PST CF driveshaft, Michelin Pilot SS, Steeda - LCAs, comp/street upper, panhard, coil-overs, bumpsteer, X5 ball joints
Appearance: Shelby plaque/sills, Steeda Spyder wheels, Formula 1 ceramic tint, shorty antenna, clear corners, Redline hood struts
#5 OFFLINE   USNavyFlyer
USNavyFlyer
  • 18 posts
  • Joined 22-December 11
  • Interests:Going fast on the ground and in the air.
Posted 04 April 2012 - 10:42 AM
Not looking for daily use, but weekend spirited driving, and trying to decide on the 555r nt05r as well.
There is nothing so likely to produce peace as to be well prepared to meet an enemy.
GEORGE WASHINGTON, Jan. 29, 1780
#6 OFFLINE   NMAv
NMAv
  • 592 posts
  • Joined 10-January 11
Posted 08 April 2012 - 02:36 PM
Just been searching Smmit Racing site for new tires myself. I'm between the Nitto NT05 and the Pilot Sport II
~ NMAv
2011 Shelby GT500 with SVTPP (Kona Blue)
Modifications in order of occurance:  Escort 9500ix * Clearbra * Lund Tune * zPod with Areoforce gauges * Hood Lift Supports * 15% IW * J&M LCA * Shelby Watts link * JLT Oil Seperator * Revan H/E * ARH long tube/high flow cats w/H pipe * billet motor mounts * Evo 3 Point Frame Rail & Torque Box Brace * Boss 302 guage cluster * Boss 302 front brake ducts * OEM look Intercooler Reservoir 3x Capacity * HID Guy fog lights * Bosch 72 lb injectors * Driveshaft Co aluminum driveshaft * BMR LCA relocation brackets * Dynomax bullet mufflers * Kenne Bell 3.6 LC with 3.75 pulley * BMR UCA * Tow hook * Trufiber Black Momba hood * C&R radiator * Thump Racing tensioner - 5" KB high flow air intake *  2013 Upper front grille * 2013 splitter * Shelby transmission cooler scoop * Steeda SS brake lines * Shelby K Member support plates * NavTV reverse camera
Waiting to be installed:  bump stop relocation bracket,3 pod gauge cluster - door, Shelby starter button, rear sway bar relocation bracket.
Currently researching:  1.  Brake modifications - Front - Hawk street/performance pads with DBA 4000/5000 slotted rotors, Goodridge SS brake lines. Rear - Eradispeed 14" rotors (Maybe) and Hawk street/performance pads, Reverse camera by NAV TV.
Currently at 803 rwhp/717 torque with KB 3.6 LC, 3.75 inch upper on juiced gas, 15% IW lower and Jun Lund tune.  Ultimate goal: Surpassed
#7 OFFLINE   cluscher
cluscher
  • 631 posts
Posted 09 April 2012 - 03:37 PM
You don't want to get caught in the rain with the NT05rs.  The 555rs work better for street use, althought not great in rain either, and the NT05r are best suited for the drag strip in my opinion.  As far as handled goes, driving to and from on the NT05rs, it was much better than I expected (I run stock size on stock wheel).........couldn't really tell a difference from the GoodYears in highway driving.  I suspect the 555rs would handle very similarly.
Engine/Performance
Chassis/Suspension
#8 OFFLINE   b17drvr
b17drvr
    Member Number 24
  • 825 posts
  • Joined 05-June 06
  • Interests:Cars, Flying, Home Theatre, and Playing the Tuba.
Posted 09 April 2012 - 05:11 PM
If you want cornering get the NT05 (no "R") or the NT555 R II or the NT01.
2007 Shelby GT-500 40th Anniversary CSM#07XL0124
Red with Silver Stripes. Gunmetal Wheels. Born on July 21, 2006.
BMR UCA, LCAs, Relocation brackets, A arms, Tokico struts/shocks, and H & R Springs.
Steeda Panhard support, adjustable panhard rod, Caster Camber Plates,
and Steeda adjustable endlinks. Steeda 3 point Torque Box Frame Rail Braces.
FRPP 3.73 gears, FRPP girdle, FRPP Shorty Headers, MRT H-Pipe and Axle Back Exhaust.
JLT Intake and Pulley with VMP Tune. 548 RWHP--533 Torque.
#9 OFFLINE   needstires
needstires
  • Joined 15-March 12
  • Interests:racing
Posted 06 June 2012 - 07:43 PM
i just put on a set of nitto 05r and i ran them for the first time i was dissapointed i left at 3500 rpm with trak control off and it went into wheel hop so bad i had to lif and feather it the short times were 2201 thats after a 2nd gear burn out to get them hot . with 20 lbs of tire pressure . then i tried 17 lbs of tire pressure withe a dry hop burn out with the trak control on sport mode the same thing except the trak control cut the throttle and it still had a2001 short time a little better but that still sucks . any suggestions on how to get this pig to launch better . it only has a pulley change and a tune it might be a little over 600 hp at the crank its a 2010 m.y. it ran 116 mph that should be good for an high 11 sec pass.
