Finally 2013 grilles are installed.....
405 replies to this topic
#391 OFFLINE   patrickshelby
patrickshelby
  • 968 posts
  • Joined 20-October 08
  • Region:European Union
Posted 09 November 2012 - 10:36 AM
You did not want to have the mesh in front of the heat exchanger also?
#392 OFFLINE   jskup1
jskup1
  • 146 posts
  • Joined 04-February 12
Posted 11 November 2012 - 10:57 AM
No, I didn't want to change the "open" look entirely to where it did't look like it matched the upper grille.
#393 OFFLINE   WJinLV
WJinLV
    WJ in Vegas
  • 904 posts
  • Joined 15-June 12
  • Interests:.
Posted 11 November 2012 - 11:16 AM
I am planning on putting that black mesh inside my open grille and the HE. But, I havent figured out how I want it secured in. The website sells a black rubber strip to frame the mesh, kinda like door trim and uses tie-downs, but Im not sure I want that. There has to be a better way. Suggestions?
2013 Shelby GT500. Performance White Sonic Blue Stripes. Airaid SynthaMax filter. JLT dual oil separators. FRPP resonator delete. Redline hood struts. Michelin PSS, 275/40/19, 285/35/20. Smoked markers. Shelby shifter ball. Jaeger brothers stone guards. GT350 style rear window covers. K&N Cabin filter. Lloyd's mats.
#394 OFFLINE   Crushinator
Crushinator
  • 341 posts
  • Joined 01-August 10
Posted 11 November 2012 - 02:07 PM
Has anyone else installed an Afco dual fan heat exchanger that did the '13 grilles? I just did the h/e today, and the only bad part
is that you can see the top of the intercooler pump sticking out. There's no way around it. The pump mounts on the top. When I
was wrapping up the install, I hadn't even thought about it until my wife walked in the garage and said, "won't you see that sticking
up with the open grille on there?". I stepped back and thought I had a big problem. Fortuntaly I got everything back together and
you can see it, but not as bad as I thought. Standing right in front of the car looking down, yes, then you can clearly see the pump.
From straight on, you can just see the top of it. I guess when it's all said and done, it's definitely worth it for the added cooling of the
h/e. I'm surprised I haven't seen anyone with a '13 talking about it that may have done the upgraded h/e. Or maybe, no one has yet.
2012 Grabber Blue SVTPP
'13 2.3 TVS, VMP 2.4" pulley, JLT 127 w/ PowerStack Filter, 170 stat, Ford Racing 65MM T/B
Afco dual fan H/E, tune by Justin at VMP
672 RWHP 656 RWTQ
#395 OFFLINE   jskup1
jskup1
  • 146 posts
Posted 11 November 2012 - 05:33 PM
I bought a bunch of that black rubber trim that I won't use, let me know if you'd like some. I don't think you could secure it to the grille or bumper with ties, but you probably could if you layed the mesh flush with the HE and tied it down to that. Mine won't budge with the rtv holding it in.
#396 OFFLINE   WJinLV
WJinLV
    WJ in Vegas
  • 904 posts
  • Joined 15-June 12
  • Interests:.
Posted 11 November 2012 - 06:13 PM
Thanks. I think flush with the HE defeats the purpose as a stone hitting the mesh will also hit the HE. Mounting on the backside of the grille seems best, but how to do it? Is the open grille easily removable? If so, the mesh could probably be hot glued to the back of it. Got any pics of yours?
#397 OFFLINE   jskup1
jskup1
  • 146 posts
Posted 12 November 2012 - 05:20 AM
I didn't take any pics of the back, but I basically just trimmed the mesh allowing about 1/2" on all sides. then I bent the mesh around the opening and used Black RTV to glue it down. The mesh won't sit flush inside the openings unless you trim the grille down a litle as the bottom and sides protrude in more than the top. This was necessary for me anyway for it to fit with the brake ducts. The grille is pretty easy to remove with the bumper off as there are about 8-10 tabs that need released. When I put the brake duct kit in, I post pics of the back of the grille.
Edited by jskup1, 12 November 2012 - 05:21 AM.
#398 OFFLINE   betiwin
betiwin
  • 7 posts
  • Joined 12-July 11
Posted 18 December 2012 - 06:52 AM
Did most of you guys install the lower brace below the HE that the 2013 comes stock with? Also when you guys talk about trimming is that only if you have a brake duct kit? If not is it just a pop in pop out affair?
#399 OFFLINE   jskup1
jskup1
  • 146 posts
Posted 19 December 2012 - 04:09 AM
I have the brace, but haven't put it on yet. For the lower grille to snap all the way in, the bezel's where the brake ducts attach to the bumper have to be trimmed off or you could do what did and trim some of the grille off. Either way, you need to trim. Many pics in this thread to show you exactly.
Edited by jskup1, 19 December 2012 - 04:10 AM.
#400 OFFLINE   NMAv
NMAv
  • 1,038 posts
  • Joined 10-January 11
Posted 30 December 2012 - 11:36 AM
Installed the upper today. Didn't have to pull the front clip to do so - only discovered this after unbolting everything and starting to pull the clip. Easy modification. Not going to do the lower at this time.
~ NMAv
2011 highly modified Shelby GT500 with SVTPP (Kona Blue)
#401 OFFLINE   SVT1159
SVT1159
  • 15 posts
  • Joined 06-September 12
Posted 17 February 2013 - 08:53 AM
Ok so I took the bumper cover off, installed the 13 grills and as I am putting the cover back on I reconnect the side marker and fog lights. So knowing my luck I decided to make sure they both work before I completely reinstall the cover and low and behold the driving lights dont work. Re checked the connection and both are plugged in. Any ideas???
#402 OFFLINE   SVT1159
SVT1159
  • 15 posts
Posted 17 February 2013 - 08:56 AM
ok forget it. I guess I am a little dumb. I tried starting the car and checking and they work. I never knew they didnt come on when car off.
#403 OFFLINE   Amigo GT500
Amigo GT500
  • 1,410 posts
  • Joined 05-July 11
  • Interests:Harley Davidson Motorcycles
Posted 21 February 2013 - 06:01 AM
:hysterical2:
2012 Shelby GT500 Super Snake - CSM 12SS0214 - Performance White, Black Stripes, Black Wheels, Wide Body
1989 Shelby Dakota #180 - Engine Serial Number KN652001809 - White, Black & Silver Stripes (1 of 500)
2003 Shelby Pagsta Mini Motorcycle - VIN 1J9RR11573C273523 (1 of 25) - Blue, Silver Tribal. Signed by Carroll Shelby
2011 Shelby Felt Bicycle - #SF134 (1 of 500) - White, Blue Stripes
I'm not going to take this defeatist attitude and listen to all this crap any more from all these people who have nothing except doomsday to predict. Carroll Shelby
#404 OFFLINE   Haynico
Haynico
  • Joined 08-March 13
Posted 08 March 2013 - 06:03 PM
Nice! '13 grilles really add to the already awesome front end. How diificult was installation for both top and bottom?
#405 OFFLINE   WJinLV
WJinLV
    WJ in Vegas
  • 904 posts
  • Joined 15-June 12
  • Interests:.
Posted 08 March 2013 - 07:22 PM
Did you consider putting on screens to protect the radiator and HE now that they are wide open to the road and elements? Here is mine.
Edited by WJinLV, 08 March 2013 - 07:22 PM.
#406 OFFLINE   Tight lines
Tight lines
  • 56 posts
  • Joined 30-November 12
  • Interests:Rc cars & Fishing
Posted 14 March 2015 - 11:18 AM
I know this is kind of old but figured I'd ask here to keep all the info in one place. Has anybody come to a conclusion on the Ram Air Deflector, wether to keep or remove.
CC292A28-7A5C-4A79-9035-BEA354690534_zps
2011 Shelby GT500 Race Red - SVTPP package.
