PLEASE HELP! Problems with new Whipple SC and Procal tuner
#1 OFFLINE
Posted 08 June 2012 - 05:52 PM
I purchased a new part # M-6066-M11P7, which is a Ford Racing Whipple Supercharger with 550 HP for a manual transmission for my 07 SGT. This was installed my mechanic at Huber performance who specialize in performance race mustangs. Everything went great with the install for the manual is straight forward and everything is plug and play for the most part. I used my voucher that came with my kit to order the ProCal tuner and chip.
To regress slightly, a few weeks before Huber installed 4:10 gears in place of my stock 3:55's. I ordered a tool from Ford Racing to calibrate my speedo then sent the tool back to Ford. All is good car ran great!
The new ProCal tuner and chip arrived and my mechanic tried to install but the tuner would not work. Ford then next dayed my a new tuner and chip to go with it. Huber then tried install the new tune and the tool worked but the chip would not? I called Ford Racing an they forgot to put the tune on the chip and they next dayed me a new chip. Huber installed the tune and all was good I thought...
I was so excited that my car was finally finished after waiting 6 weeks for the SC and which seemed forever for the car to get completed. I did not let Huber test drive the car. I took off and that is when all the problems started:
1. My airbag light came on.
2. I had no power in the car and it was like I did not even have a SC.
3. Engine light came on but went off in a minute.
I babied the car home and called Huber. He told me to hook up my Procal tuner and send Ford racing the codes that came up in my tuner:
PCM 07E0
TCM 07E1
ICM 0720
ABS 0760
SJB 0726
4x4 0761
USR 0700
Ford Racing was very confused and said these codes were codes for an automatic transmission and a 4x4? They thought it may be a voltage problem.
I had Huber come to my house and use their computer and these are the codes and items that came up:
14.3 volts
Misfire in cylinders #1, #4, and #8
Codes:
P0300
P0301
P0304
P0308
B2292
These codes were continuous and came up with the key in the on position and when the car was running.
The volts obviousily are great. I pulled the plug in cylinder #1 and it was fine. The car smells like it is running lean?! We cleared the codes and took it for a very short controled drive then hooked it back up to the computer and both sets of the same codes came up again? I checked all the wires on the install and everything is in check? Does anyone any clue why these codes are coming up? Ford Racing engineers are dumb founded and do not have any answers for me? I told them I thought the problem was in the tuner or chip but these said it was not? Is there something that could damage these chips in transit? Static or a magnet? PLEASE HELP! DO I have my PCM cleared andd start over; would that help!? Any Ideas!
Thanks in advance
Chris
FRPP Whipple 550 supercharger kit with 11 psi boost
Carroll Shelby autographed airbag cover
GT500 alloy wheels that were powder coated with high gloss black
Goodyear Eagle F1 tires 255/45/18
305/40/10 Nitto NT555R drag radials
Berg snake center caps
Berg snake steering wheels cap
Berg snake faux gas cap
Berg snake headrest covers
Berg snake arm rest cover
Berg snake dead pedal
Shelby SC Gauge pod
whipple fuel relocation kit
GT500 front Brembo Brakes
shorty antenna
Raxiom black tail lights
Raxiom Black retro headlights
Drake sequential tail lights
MMD Black mirror covers
MMD GT350 black window cover
Lower billet grill
Dupli-color rear brake caliper paint
3:73 FRPP gears
Borla extreme axle back exhaust
new hood scoop
Shelby one piece driveshaft
BMR lower control arms
Shelby adjustable panhard bar and brace
Shelby Artehouse Shelby GT Carroll Shelby signed print with my CSM # and COA
#2 OFFLINE
Posted 09 June 2012 - 05:57 AM
#3 OFFLINE
Posted 09 June 2012 - 02:32 PM
Very Frustrated as my SGT sits when we have beautiful weather and I missing a Mustang show at our mueseum of transportation
Shelby SC Gauge pod
shorty antenna
Lower billet grill
3:73 FRPP gears
new hood scoop
#4 OFFLINE
Posted 09 June 2012 - 09:01 PM
Good luck.
#5 OFFLINE
Posted 10 June 2012 - 08:59 AM
Shelby SC Gauge pod
shorty antenna
Lower billet grill
3:73 FRPP gears
new hood scoop
#6 OFFLINE
Posted 10 June 2012 - 09:32 AM
TNTchris, on 10 June 2012 - 08:59 AM, said:
Oh shit! That's not good. That was going to be my next bit of advice. Load the OE tune, disconnect the batt, reconnect and go through the idle learn process, then try loading the FRPP tune.
Do you still have the first Procal and SD card? Your OE tune should be on the first SD card but you'll need to use the first Pro-cal that was married to your VIN to upload it with.
This has GOT to be frustrating.
How about going to a Ford Dealer and having the OE tune reflashed?
EDIT: Also check all of yoru wiring, connections and wiring routing. I've seen misrouted wires cause really strange problems like this. Be ABSOLUTELY sure that all sensors are connected too. When I first started my GT500 w/FRPP Whipple 2.9L tune it ran like crap, punched a bunch of codes, etc. I left the MAF sensor unplugged by mistake. Connected it and cleared the codes with the procal and it was perfect after that (except for ONE time under high RPM decell when it set a code and MIL).
Edited by 2010KonaBlueGT, 10 June 2012 - 09:35 AM.
CURRENT MODS: FRPP: Whipple 2.9L Polished Superchager w/Crusher Inlet & Cobra Jet dual 65mm Throttle Body - Ceramic Coated Shorty Headers - Ford Blue Cam Covers - Polished Billet COP & Oil filler Cap Covers - FR3 Handling Pack w/Tokico Struts/Shocks & Eibach Swaybars - Jounce Bumpers - 8.8" Low Profile Axle Girdle - 3" Front Brake Cooling Ducts - Vacuum/Boost Gauge~ MGW: Short Throw Shifter - White w/Blue Stripes Shifter Knob - Radiator and Intercooler Degas Bottle Caps - Seat Recliner Lever Covers - Parking Brake Handle Cover - Coat Hanger Hooks~ PST: 1-piece Carbon Fiber Driveshaft~ Revan Racing: C&R Radiator and Intercooler~ ROUSH: 3x Intercooler Degas Bottle - Side Splitters - Extreme Off-road Exhaust - Adjustable Trailing Arms (LCA) - Adjustable 3rd Link (UCA) - Adjustable 3rd Link Bracket - AC Vent Pod Vac/Boost Gauge Mount~ SHELBY: SC Aux. Idler Pulley - Oil Dipstick Handle, MC, PS & WS Washer Reservoir Caps - 8-qt. Oil Pan - Subframe K-member - Tubular Front A-arms - 6S Extreme Front Brakes - KR Style Front Brake Duct Bezels - Anti Bump-stear Tie-rod Ends - Race Style Swaybar Links - Adjustable Caster/Camber Plates - Adjustable Panhard Bar - Panhard Bar/Body Brace - KR Rear Axle Reservoir - Eradispeed Rear Brake Rotors & Caliper Relocation Brackets - Shelby/BMR Lower Control Arm Relocation Brackets -18" GT500KR Alcoa Dura-Bright Wheels & Goodyear KR Winged Boot F1 Supercar tires~
PURCHASED AND AWAITING INSTALLATION: Shelby/Baer Extreme Rear Brakes; Shelby/Metco Fuel Rails, Shelby Alcoa 20" Dura-Bright Super Snake style wheels; NMB2 2-Stage WOT Box, Granatelli Motors Tire Fryer Line-lock, Raptor shift light, ZEX N2O kit, Ford Racing Lighted Sill Plates w/Ford Racing logo.
#7 OFFLINE
Posted 10 June 2012 - 03:13 PM
Shelby SC Gauge pod
shorty antenna
Lower billet grill
3:73 FRPP gears
new hood scoop
#8 OFFLINE
Posted 21 June 2012 - 06:42 PM
The one issue that I still have outstanding is that my airbag light is still on? Anyone have any idea what this could be?
Chris
Shelby SC Gauge pod
shorty antenna
Lower billet grill
3:73 FRPP gears
new hood scoop
#9 OFFLINE
Posted 23 June 2012 - 04:19 AM
Andrew
#10 OFFLINE
Posted 23 June 2012 - 06:42 PM
#11 OFFLINE
Posted 23 June 2012 - 07:39 PM
Chris
Try this link
AIR BAG WARNING LAMP ON—DTC 2295 IN RESTRAINTS CONTROL MODULE AND LAMP FLASH CODE 22—BUILT 3/1/2007- 4/15/2007
07_10_03.pdf 190.26K 99 downloads
Shelby GT/SC=(good times/special car)
#12 OFFLINE
Posted 24 June 2012 - 05:41 PM
It happened to me!
Sam
In Memory Of Willy T
#13 OFFLINE
Posted 24 June 2012 - 07:08 PM
Sam, I did not get the gauge pod yet. That is on my wish list! Did you install yourself? Along with the oil pressure line? How long did it take? When ordering thru Shelby those are the only two parts I need to order for the SC version correct?
Chris
Shelby SC Gauge pod
shorty antenna
Lower billet grill
3:73 FRPP gears
new hood scoop
#14 OFFLINE
Posted 26 June 2012 - 05:01 AM
Yes, I did the install myself, (that's how I found out about the numerous ways to screw up!
I ordered the complete pod, (pre-installed gauges and pre-wired), along with the S/C version of the oil pressure adaptor. That should be all you need to order from SSP.
Install was straight forward (except for my bad eyes with the wiring) and took approximately 2-3 hours.
Sam
#15 OFFLINE
Posted 26 June 2012 - 08:20 PM
Wow, more to a reset than I thought.
View Garage
