NEED NEW TIRES ON MY 2010..SUGGESTIONS ?
#1 OFFLINE
Posted 28 June 2012 - 04:23 PM
These F1's in Canada are $1,500.00 to $2,000.00 per set which is crazy to spend on a car with 20,000 km.
I need to find out what happened as suspension wise the car is bone stock and I never do burn outs etc. but it seems many people are experiencing this problem.
Ford tells you to go shit in a hat but I can't afford this every few years.
Any suggestions on replacements for these F1's ?
#2 OFFLINE
Posted 02 July 2012 - 01:05 PM
#3 OFFLINE
Posted 02 July 2012 - 01:44 PM
blk12svt, on 02 July 2012 - 01:05 PM, said:
Thanks !
#4 OFFLINE
Posted 02 July 2012 - 02:09 PM
Michelin's are great tires, but also really expensive! You might also want to take a look at some Hankook Ventus V12 Evo K110s if you are looking for a good bank for your (Canadian) buck.
Mark
Born: 6/15/2009 #558 and 1 of 74 Coupes built with Performance White/Red Stripe combo
#49 of 382 in Performance White
#5 OFFLINE
Posted 02 July 2012 - 03:14 PM
Extreme Performance Survey - Tire Rack
http://www.tirerack....lay.jsp?type=EP
Edited by IA Shelby, 02 July 2012 - 03:16 PM.
#6 OFFLINE
Posted 02 July 2012 - 09:32 PM
#7 OFFLINE
Posted 03 July 2012 - 02:49 PM
#8 OFFLINE
Posted 03 July 2012 - 05:14 PM
2010 GT500. Black on Black. VMP TVS and Tune, FRPP 65mm CJ TB, Kenne Bell BAP, AFCO Dual Fan HE, IW10%, 72lb IDT Injectors, Dynotech Aluminum Drive Shaft, J&M LCA's, Roush Wheel Hop Reduction Kit, FRPP Strut Brace, FRPP Lowering Springs, Tokico D-Spec Struts/Shocks, FRPP Anti-Roll Bar Kit, Shelby Camber Plates, BMR Lowering Brackets, BRM Adjustable Panhard Bar, Lethal OR-H, Roush Extreme Exhaust mid pipes w/ stock mufflers, WOTBox, Bridgestone RE-11's, Lethal Line Lock, FRPP Side Scoops, Dynojet Wide Band, SOS Pillar Pod, signed by Carroll Shelby.
#9 OFFLINE
Posted 03 July 2012 - 06:21 PM
BlakSnake, on 03 July 2012 - 05:14 PM, said:
How is the noise level?
#10 OFFLINE
Posted 04 July 2012 - 05:44 AM
#11 OFFLINE
Posted 04 July 2012 - 10:31 AM
#12 OFFLINE
Posted 05 July 2012 - 10:39 AM
CANADA GUY, on 04 July 2012 - 05:44 AM, said:
BlakSnake, on 04 July 2012 - 10:31 AM, said:
I can second both of these. Not only that, but they ride SO MUCH better that the F1s.
Mark
#13 OFFLINE
Posted 05 July 2012 - 03:06 PM
mark.barton, on 05 July 2012 - 10:39 AM, said:
Mark
That's a good looking tire...nice to see it performs as well..I also like the look of the Hankook V12 and it's getting high marks as well....
BTW...are others having this issue with inner tire wear on the Goodyears ?
#14 OFFLINE
Posted 05 July 2012 - 03:16 PM
I can't speak for the others, but all I had on the car, Goodyear wise, were on the rear when I bought it. The inner didn't look any worse than the rest of the tire. Both rears were down to 5/32 and I replaced them shortly thereafter with the Bridgestone RE-11s.
Mark
#15 OFFLINE
Posted 05 July 2012 - 03:19 PM
mark.barton, on 05 July 2012 - 03:16 PM, said:
Mark
I have the fronts wearing on the inside and the rears wearing on the outside...pressure is at 32 psi...no crazy driving...but I see lots of other sites even with gt and v6 cars experiencing similar tire wear..
#16 OFFLINE
Posted 06 July 2012 - 04:58 AM
SHELBYCS6, on 05 July 2012 - 03:19 PM, said:
On the 2010 500s, the recommended tire pressure is 35 psi front and rear. Could it be that the pressure is to low?
Mark
#17 OFFLINE
Posted 07 July 2012 - 06:04 AM
Edited by BLUE 2010 SHELBY GT 500, 07 July 2012 - 06:16 AM.
#18 OFFLINE
Posted 07 July 2012 - 02:36 PM
mark.barton, on 06 July 2012 - 04:58 AM, said:
Mark
The big issue is the thumping when slowing down...a couple of psi shouldn't create these issues....many have tires set at 30 psi or lower without this thumping sound or odd tire wear...I'm thinking the rubber strut mounts have caused the front wear and a belt may now have shifted in the tire
#19 OFFLINE
Posted 09 July 2012 - 05:37 AM
SHELBYCS6, on 07 July 2012 - 02:36 PM, said:
Very odd. The only time it thumps is when you are slowing down? I would think that if a belt has shifted or if the tire was starting to separate it would thump most of the time or you would feel a vibration. I guess if it was my car, I would have the suspension and alignment checked and then replace the tires like you are planning on.
Mark
#20 OFFLINE
Posted 24 July 2012 - 08:02 PM
I cannot believe the astronomical difference. Hooks up like a champ. My Super Snake with the Pilot Sports has better traction that my old GT500s did with their stock tires.
