Install number 2 for the SPEC Super twin SS trim clutch
4 replies to this topic
#1 OFFLINE   E.Marquez
E.Marquez
    GearHead
  • 165 posts
  • Joined 10-February 12
  • Interests:Motorcycles, off road, on road, track. If it has a motor, and performs well in both left and right turns, I’m interested.
Posted 29 June 2012 - 06:42 PM
This is install number 2 for the SPEC Super twin SS trim clutch  and #3 SPEC clutch install over all in as many months. ( all different cars not re-dos )
It was finally time to install this one as the clutch had started to slip under boost in 6th.
Started at 1830 with pulling on to the lift. 1:45 later the nasty mess is out.
As you can see lots of clutch meterial.
Flywheel showed no signs of warp or hot spots.
Disk pads were worn down almost to the rivets though.
Release bearing and bell housing is just covered in dust.
All for now will go back to the shop in the morning and start cleaning then install a nice new pilot bearing, clutch release bearing and of course a SPEC Super Twin Clutch and flywheel with ARP Fasteners
Lateral G-forces make me smile.
#2 OFFLINE   E.Marquez
E.Marquez
    GearHead
  • 165 posts
Posted 30 June 2012 - 01:19 PM
SPEC clutch job #3 compleat, just as the other two went, this one went smoothly as well.
No issues or surprises at install or initial run in.
Full pedal from the first few pumps after bleeding IAW the service manual procedure...
Clutch is smooth and not grabby at all.. NO chatter. Pedal is moderate in feel, not heavy at all.
Another SPEC win.
#3 OFFLINE   wingsnut
wingsnut
  • 371 posts
  • Joined 21-June 08
Posted 01 July 2012 - 05:22 AM
Good work, glad to hear you are having good luck with these clutches as I have had an SS trim sitting in my garage for a few years. I'm just waiting for the stock clutch to take a dump. Over 20,000 miles on it and it's still hanging in there. Told myself broke or not, it's getting replaced this fall.
How long does this job take? I have a lift and a tranny jack but most likely will be working alone.
Chip
2008 GT500 Performance White
Installed Mods
TVS, VMP Tune, JLT Oil Separators, FR3 handling pack, Shelby Fays2 watts link, Baer Eradispeed front and rear brake kits with Hawk pads, BMR UCA and LCA's, LCA relocation brackets, J&M caster/camber plates,  FRRP SVT axle assembly w/ 3:73 gears, MGW shifter.
Mods still in boxes
Spec SS super twin clutch, SS clutch fluid line, Shelby extreme duty heat exchanger and radiator
#4 OFFLINE   E.Marquez
E.Marquez
    GearHead
  • 165 posts
Posted 01 July 2012 - 08:34 AM
Chip
I have done two GT500 SPEC installs now, both with full lift, tranny jack and shop support. The first one took me 6.5 hours with a helper for the actual remove and install of the transmission and that included removing wheels and cutting rotors while I had it on the lift.. (done along with the other work, so it only added maybe 30 min to the whole job.
The SPEC super Twin install I did yesterday was 4.5 hours rolling on the lift to test drive. That was by myself, no assist.
There are a few things I found that save time.. like you only need to loosen the axle back sections and remove from the H or y pipe. And removing all but two bolts from the K member and dropping it and the motor down 1.5 inches.. The transmission comes right out that way,  I know the right combination of tools, extensions to get to each bolt for fastest removal, have air tools for quicker fastener removal, ect.., Getting to the right upper OX sensor plug is tricky, but if you loosen the manifold to pipe first on both sides, let it drop down, remove the starter, you can reach up, feel for the plug, depress the retainer and undo it.....and other little non short cut, but time saving things .
In my opinion, for a reasonable experienced home wrench, with proper tools and a lift.. this is an easy 1 working day job.
Book time is like 5.5 hours
#5 OFFLINE   wingsnut
wingsnut
  • 371 posts
  • Joined 21-June 08
Posted 02 July 2012 - 05:45 AM
Thanks for the tips! Although I won't be in any hurry to get the job done, I was just curious what to expect. I am going to install my shorty headers when I have the tranny out as well, not sure, but it seems like it may be easier to get them in there without it in the way.
I'm in the middle of pulling the turbo, down pipe and up pipes off of my 7.3 diesel Excursion now, can't imagine that the clutch job on the Shelby could be
any where near as difficult. Spent the better part of the day yesterday dealing with a bunch of heavily rusted nuts and bolts, Shelby has never been in the rain
and everything is like new underneath.
Chip
Installed Mods
Mods still in boxes
