I am installing the upgraded Shelby Rotors on the Front and Rear of my car along with Ceramic Hawk pads. In reading the information with the rotors it states that I need to "season" the rotors. Do I need to do this before changing out the pads?
In reading the information it appears that I need to season the new rotors, and once that is done then istall and break-in the pads. Is this the normal method for the best brake effectiveness and longivity?
Installing New Rotors and Pads
Started by
klastinger
, Jul 13 2012 07:30 PM
5 replies to this topic
#1 OFFLINE
Posted 13 July 2012 - 07:30 PM
2012 Shelby GT500 - White, Stripe Delete. Recaros, and Navigation. Koni Sports, Steeda Springs, Mounts, and Swaybars. Corsa Exhaust, JLT Intake, JLT Oil Catch Cans, AirRaid Filter. Steeda Pulley and Tunes. MGW Shifter, and Driveshaft Shop Carbon Fiber driveshaft. Shelby Brake upgrades. Shelby/Alcoa rims, and Michelin Pilot Super Sports.
#2 OFFLINE
Posted 14 July 2012 - 04:55 AM
Cleaning them oil and grease free before, then again after install is important..
Then,
Here is STOPTECH's take on it
http://www.stoptech....-and-procedures
Though I call it bedding.. not seasoning.. If you choose to season yours.. I'd suggest a dry rub......
Then,
Edited by E.Marquez, 15 July 2012 - 04:52 AM.
Lateral G-forces make me smile.
#3 OFFLINE
Posted 14 July 2012 - 07:03 PM
Thanks for the help. BAER calls for seasoning the rotors by progressive heating and cooling.
E.Marquez, on 14 July 2012 - 04:55 AM, said:
Cleaning then oil and grease free before, then again after install is important..
Then,
Then,
#4 OFFLINE
Posted 15 July 2012 - 05:43 AM
Called Burnishing and is an important method of seating or mating the brake parts, it involves as stated to rapidly heating the parts (medium braking) in successive braking sessions, many methods are published but all do the same thing, build heat and seat the brakes.
I like to perform it by accelerating to 30 mph and medium brake to 0 or 5 mph waiting 30 seconds and repeat for at least 10-15 times, the last should be at a higher speed 40 mph and to a full stop, I then go for a cruise to cool the brakes.
2007 Vista Blue coupe, white stripes tinted windows -Shaker 1000 ,Steeda CAI-SH 2.6 pulley Metco tensioner-SCT live wire tune Eibach Pro kit -Polished Steeda LCA's-Steeda UCA and bracket, 3.73 gears,,2008 mods Kooks headers catted X-pipe and Magnaflow stainless exhaust Innovators west Aluminum OD balancer, DSS driveshaft 160mm T-body Cross drilled Slotted rotors Steeda Adj panhard bar, FMS rear end cover , 2008 ET 10.93 @ 126.55 mph and Dyno #'s 625 RWHP 599 RWTQ on ET Streets, 2012 mods, Shelby heat exchanger, Reservoirs, Vortex series 4 pads, Steeda 20x11 /20x10 Spyder rims with Nitto 315/35/20 - 275/45/20, 6 piston brembos with 15"rotors, rear brake upgrade, stainless brake lines
2013 TVS blower, KB Dual Boost-a-pump now making in Sept 2012 - 755 RWHP & 687 RWTQ
#5 OFFLINE
Posted 15 July 2012 - 06:33 AM
THIS ^
The only thing I'd add is, do not come to a compleat stop while the brakes are hot.. Uneven Pad materiel transfer or overheating of the pad / rotor can happen with the new pad stationary on a hot rotor.... Same thing with the parking brake. don't set it with new pads and HOT rotors... after a cool down drive, all will be fine.
#6 OFFLINE
Posted 15 July 2012 - 08:00 AM
Sounds great guys. Thanks for the help. It does seem most that I read was consisitent. Take it easy initially and get progressively more breaking, but to heat and cool the rotors, while bedding the pads. All did stress the importance of not coming to a complete stopping and making sure not to have the pad still on the rotor. Seems like it is very important to control the heating during the break in to prevent rotor warp.
