Clutch drag TSB 4th revision - $1,438.18 if you have to pay for it
209 replies to this topic
#181 OFFLINE   rosso400
rosso400
  • 17 posts
  • Joined 23-August 13
  • Region:European Union
  • Interests:Musclecars
Posted 13 September 2013 - 07:23 AM
Few minutes ago I have bought the new (second) Clutch Set for my Snake, now from TASCA PARTS - I´m  waiting now for arrival to AUSTRIA, hope I get it soon...
Edited by rosso400, 13 September 2013 - 07:26 AM.
#182 OFFLINE   rosso400
rosso400
  • 17 posts
Posted 14 September 2013 - 11:56 PM
This is the bent spring from the pressure plate...so it doesn´t declutch enough, because pressure plat doesn´t rest flat!!
#183 OFFLINE   rosso400
rosso400
  • 17 posts
Posted 29 September 2013 - 06:02 AM
Last Friday I got the new clutch set from TASCA Parts - tomorrow we´ll install - hope it works...
#184 OFFLINE   ingram4868
  • 6,363 posts
  • Interests:Love of God, Family and Great Cars
Posted 29 September 2013 - 10:59 AM
I am looking forward to your comparison between the old and new setup.
David Ingram
Sparks, NV.
Newest addition 1100 mile 2007 GT500
#185 OFFLINE   rosso400
rosso400
  • 17 posts
Posted 30 September 2013 - 03:46 AM
Unbelievable !!! - We installed the new Clutch set (pressure plate + discs) today but it´s the same problem again - I can´t shift into the 1. gear and reverse gear when engine is running!!
Flywheel - Pressure plate - Discs - Slave - Tube Line / everything is new and changed - it doesn´t work!!
The Slave cylinder press only 1 cm into the pressure plate - is this enought, or is this the problem? But why? Is there air in the system...? Anybody an idea, please help....
#186 OFFLINE   The Chairman
The Chairman
    The Chairman
  • 58 posts
  • Joined 08-March 10
Posted 09 October 2013 - 08:37 PM
Make sure you bleed the slave cylinder. There are instructions posted here somewhere. As I recall, you essentially grab the clutch pedal and pull it back towards the seat several times, then fully depress the pedal, repeat as necessary to pull all air out of the system.
#187 OFFLINE   rosso400
rosso400
  • 17 posts
Posted 10 October 2013 - 10:52 AM
Hello on everybody!
The problems are solved! Unbelievable what happened - this is a long story, but let me tell you:
After removing the gearbox for the third time we also removed the flywheel. Then we bolt the pressure plate on the flywheel and simulate the lift from the slave cylinder - we saw now that the first disc in the pressure plate goes free (declutch) but the second one on flywheel side not!! But why? We don´t know - there are 6 springs outside the pressure plate - three on the top and three on the bottom - this springs connect the two parts from the pressure plate (between them there is one disc) If this items work correct both discs are "free" during declutch...
So we bent (!!!!) this three springs on the bottom with a tire lever (!!!)  till such time we think it works...after this we installed all the parts again and unbelievable - it wooooooooooooooooooooooorks!!!
I have bought 2 brand new clutch kits and both are damaged?? Unbelievable - I am really amazed about the quality of the parts I have ordered from US. Two pressure plates and both doesn´t work - Certainly we have also adjusted the second pressure plate - so I have a second one in stock!
Thanks for all your help and tips - but the fault was only the quality from the (US) parts....unbelievable!!!
Best regards from AUSTRIA
Hannes
#188 OFFLINE   Grabber
  • 35,090 posts
Posted 10 October 2013 - 11:29 AM
Hannes,
I have been monitoring the clutch problems since 2007. I am on this site everyday for the last 6 years. I have never seen anyone have this problem. You are a very special instance and I do not believe you can judge USA parts from this one of a kind issue. If this was something that happened often....then you have every right to slam our USA parts.
My 2 cents.
#189 OFFLINE   Hans
Hans
  • 793 posts
  • Joined 02-April 06
Posted 10 October 2013 - 01:42 PM
I also have this thread tagged and read every post. I too have the 07 and have had an 08 clutch installed at eleven thousand miles along with transmission, now have 38,000 still no issues but very heavy clutch pedal as it was when new . I'll go with a after market parts when I need to have a new clutch. nothing worst than to be in a different country and have to order parts over seas and wait, only to find them to be defective. First time I have read about the Ford clutch being new in box defective :headscratch:
Glad it all good :kookie:
07 GT500 Shelby acquired Nov 21 2006
Exterior mods
Carbon fiber front splitter
Bi-exnon 6,000 Diamond white running and head lights
Mis Decals on car
Third break LED chrome stop light
Chrome rear tail light bezel trim
Satellite shark fin cover
9 inch antenna
MGW Cobra polished billet license anti-theft Cobra frame
Alcoa Shelby 20/10 rims with Shelby Cobra center caps
Steeda lock nuts
Nitto Invo  4   295/30/20
Cobra air caps all four
Roush rear window covers
Trunk LED light super bright
Web electronics sequential rear tail lights harness
LED license plate light
True forge Heat extractors billet hood vents
Carbon fiber KR Rocker panels by true fiber
Bangastang California side scoops
3M clear Bar Hood and roof and Front
Shelby Billet fuel door
Exterior mods cont.
Cobra rear break covers
Billet fender badges
Mustang Brake Duct Bezels
Carbon Fiber mirror covers Shelby
Engine mods
Morso billet brake Fluid cover
Shelby batteries hold down brackets
Ford racing damper
Revan racing over size C&R radiator and Shelby inter cooler dual high speed fan with matching anodized reservoirs coolant and power steering
VMP 2.4 TVS CNC port matched high flow inlet elbow, 2.6 pulley and 90mm idler pulley, colder plugs and thermostat with SCT tuner & two tunes, one 100 octane tune
Bangastang custom radiator cover to match car
Classic Hood strut lifts kit with Champion replacement 90 LB strut
Shock tower caps
C&L cold air tube and filter
JLT oil separator
Engine mods cont.
Shelby Drake Cobra billet engine cap set complete
Fuse box Chrome cover with old style Shelby cobra emblem
LED under hood engine Bay lights
Interior mods
Shelby Headrests
Areoforce CNF interceptor dual gauges and speed of sound gauge pillars
Mustang billet radio knob
GT500KR trunk liner
Trunk release in glove box
Chrome door lock knobs and pins
Billet cup holder trim
 LED Map light with Shelby Billet trims
Carbon fiber trims inside cabin accents
SVT LED door sills
LED foot well lights
Cobra stainless dead foot pedal rest
Shelby signature floor mats and trunk
MGW Billet deluxe power outlet Cobra
Pad for knee driver side
Organizer glove box
Custom Shelby trimmed Console cover by Gary Disney extra padded Cobra
Window tint all around with mole skins in front to protect film
 Carol Shelby signed dash plate
Ford racing short throw shifter
Grabber pony custom shift Handel and ball
Steeda Billet speaker cover
Four dual cone high performance speakers
Damplifier Prosound Interior insulation
Suspension Mods
Koni yellow strut and shocks
DBA Slotted rotes all four corners
Hawk yellow brake pads
Front Brake cooling hose kit with Billet inlets JLT
Steeda stainless braided break lines all four
Steeda Billet lower control arms
Steeda heavy duty upper control arm adjustable
Steeda blue lower springs all four corners
BMR adjustable panhard brace
BMR drive shaft safety loop
One piece aluminum Drive shaft
KR axel back muffler set
#190 OFFLINE   GT500THUNDER
GT500THUNDER
  • 41 posts
  • Joined 21-October 10
  • Interests:Cars , Road Racing, Hockey, golf
Posted 10 October 2013 - 03:00 PM
I had my clutch upgraded to the 2010 system. My 2008 has 14,000 miles(22900 Kms). I am happy with the results, here's what I have noticed so far:
- Softer peddle as everyone has indicated
- Easier starting, less drag
- Shifter is smoother
- Engine speed between shifts is lower, part of re-tune in TSB
- Smoother engage from take off
- No hiss from under car
All together I am pleased.
GT500THUNDER
 ShelbyatPeggysCoveLighthouse_zps81e5a425
#191 OFFLINE   rosso400
rosso400
  • 17 posts
Posted 12 October 2013 - 12:51 AM
Hello on everybody!
Please don´t misunderstand me - this is no attack to somebody, but I have wasted a lot money about this stupid fault! I have bought 2 clutch kits and both doesn´t work? So what would you say if this happens to you? We tried a lot of things (new hydraulic tube line, bleed for hours,....) but nothing helps!!
And after asking TASCA PARTS the only answer was that we have made a mistake during installation!! This isn´t a prudent answer - it makes me angry, because if you know how the parts are build then you also know that it isn´t possible to install them wrong!
But now it works and I´m happy - but afterwards again - I don´t understand why this happens....
Best regards from AUSTRIA!
Hannes
Thanks all again for help!!
@grabber: it is not really necessary to change the tube line, believe me - now I have a lot of experience .... ;)
I´m happy that my snake bites again.....
Edited by rosso400, 12 October 2013 - 12:53 AM.
#192 OFFLINE   SN8KB'T
SN8KB'T
  • Joined 12-December 12
  • Interests:All things Mustang!
Posted 07 April 2014 - 10:59 AM
Just wanted to let everyone know if you still need to do this upgrade. I just ordered my parts today through Tasca, (BTW thanks for this info!), my price shipped came out to $984.82. My local shop price would have been $1360.51 PLUS another $115 for taxes. Needless to say this is a HUGE savings! Plus the guy at Tasco already had the parts list in front of him because they get so many orders and knew what he was talking about. Also as a plus in case your interested, they take payments through Paypal which allows you to take advantage of 6 months no payments/no interest which gives you time to pay on it if you need to.
My 09 had a clutch upgrade done in May of 2011 by the previous owner but at that time the dealer was working off an older tech bulletin and used the original parts for the car and not the 2010 upgraded parts. The factory clutch went out at 20k miles and now this one that was installed back then is slipping out at 36k miles. Hopefully this one, now that it's the correct upgrade, will be much better!
#193 OFFLINE   Superchief
Superchief
  • 114 posts
  • Joined 28-May 07
Posted 06 May 2014 - 06:13 AM
I am assuming this is still the current fix ..*Clutch Drag TSB 10-3-8 (4th revision 2010 clutch set up)* -
Just took my '07 GT500 into shop 5/5/14 and told them to check for the TBS on the clutch. Told them I was experiencing clutch chatter when warm. Having to feather it with rpm's ...especially bad when pulling into driveway. Showed dealer my extended warranty. ..still in force till 6/14. I think they are going to replace under warranty. Fingers crossed!
#194 OFFLINE   Grabber
  • 35,090 posts
Posted 06 May 2014 - 06:05 PM
yes this is still the current fix and parts list.
#195 OFFLINE   Secondo
  • 5,167 posts
Posted 07 May 2014 - 02:06 PM
I just had this done to my car at our local Ford dealer in CT (Recently bought out by TASCA Ford!). The car feels more nimble and pleasant to drive. Much easier than before. Pedal effort is greatly reduced and there is no chatter. The clutch starts to grab lifting the pedal about 1/3 from the floor and engages very smoothly- and before you know it, the transmission is completely engaged to the engine without issue. My original clutch (build date 12/06) lasted 35K miles before it started slipping. Grabber, thank you for your research and posting the info and pics/videos, and thank you all for your contributions here. :yahoo:
#196 OFFLINE   ShelbyKR664
ShelbyKR664
    ShelbyKR664
  • 875 posts
  • Joined 13-June 11
  • Interests:Family, Shelby Mustangs, Restoring vintage Mustangs, Golf, Landscape Architecture , Fantasy Baseball
Posted 07 May 2014 - 03:42 PM
Grabber, thanks for all the information you have provided over the past few years on this subject. I have read many of the posts related to this TSB.. I own a 08 KR with only 800 miles. I don't have the clutch issues some of the other owners have. For now, I think I am OK, however, I probably will down the road. Based on your experience, should I pursue this before it is too late? If so, what approach would you recommend I take with my dealer? Thanks again.
CSM# 08KR0664 Silver/Blue 181 of 476 Purchased May 12,2013 Delivered June 3, 2013.Shaker 1000, LED interior lighting, KR Billet engine caps Moroso fuse box cover and aluminum radiator tank, Shelby GT500KR MC brake cover, 20" Alcoa "Shelby Forged" 20 x 9 x 4 GT500KR center caps Sumitomo HRTZ III 275/35/20! carbon fiberrear splash guards made by TruFiberShelby Redline Elites low pressure hood strutsStainless bolt kit engine bayShelby GT500KR trunk liner Shelby billet GT500KR fuel doorBillet shorty antenna Billet cup cover deleteSequential tail light kitFuture Mods:Functional: Shelby Watts link, Shelby 3 gauge dash pod, Brembo F&R 14" rotor upgrade, CF drive shaft, Shelby transmission coolerCosmetic: CF rockers, radiator cover, CF center console cover, Shelby rear trunk strut, transmission scoop cooler, KR shifter ball (Silver/blue,when available)
#197 OFFLINE   ViperNC
ViperNC
    Some say he roams around the woods at night foraging for wolves
  • 1,347 posts
  • Joined 23-December 11
  • Interests:Track days, Mountain bike riding/racing, motorcycle riding, cars, warbirds & chasing my kids, road course racing
Posted 07 May 2014 - 05:37 PM
Bill,
I inquired about this for my '09 and they quickly pointed out that I'm past my 5 year warranty.  I don't have the problem either, so I'm using the "If it ain't broke don't fix it" strategy.  Jer just released Shelby's new clutch assembly anyway and when my clutch finally gives up the ghost... I know what I'm getting to replace it.
2009 Shelby GT500 - Notable Upgrades:
  • True Forged Chicane Wheels w/ Michelin Pilot Super Sport Tires: 275/30/20 Front and 285/30/20 Rear
  • Shelby/Wilwood Front and Rear Racing Brakes
  • Shelby GT500 Brake Duct Bezels/Front Brake Duct Kit
  • Ford Racing Ceramic Coated Shorty Headers
  • Shelby Oil Separator
  • Shelby GT500 Engine Coil Covers
  • Metco 2.6 pulley/idler w/JLT Cold Air Kit and SCT Tune
  • Shelby Billet Aluminum Racing Oil Pan
  • Shelby Extreme Duty Heat Exchanger
  • PST Carbon Fiber Drive Shaft
  • Ford Racing Low Profile Differential Cover w/ over flow tank
  • Flowmaster Exhaust
  • Shelby Racing Front and Rear Sway Bars
  • Shelby Bumpsteer Tie Rod Adjuster
  • Shelby Sway Bar End Links
  • Shelby A Arms
  • Shelby K-Member, Radiator Support, Chassis Support, A Arm Support Brace
  • Shelby Billet Aluminum Watts Link
  • Metco Billet Aluminum Rear Lower Control Arms
  • Ford Racing Springs
  • Shelby Six Speed Shifter Lever w/ Shelby GT500 Shift Knob
  • Shelby GT500 Engine Billet Aluminum Cap Set
  • Shelby Billet Aluminum Racing Pedal and Dead Pedal Covers
  • Carbon fiber upgrades: Front Splitter, Rocker Panels, Rear Mud Guards, Rear Diffuser, Side View Mirror Inserts, Hood Vents, Door Sills, Speaker Rings, Center Console, Mirror Switch Covers, Door Lock Bezels
#198 OFFLINE   Grabber
  • 35,090 posts
Posted 07 May 2014 - 05:41 PM
Your 5 year warranty is up and since your miles are so low I would just drive the car and enjoy it. Once you start to experience any transmission syncro issues then you should do the TSB before any damage is done. If you feel your transmission slightly bumping the syncros in between gears then you know you have a issue. Or if you feel your clutch slipping, you have a issue.
Edited by Grabber, 07 May 2014 - 05:43 PM.
#199 OFFLINE   ShelbyKR664
ShelbyKR664
    ShelbyKR664
  • 875 posts
  • Joined 13-June 11
Posted 07 May 2014 - 05:58 PM
I will certainly enjoy driving it. I have several trips and shows planned this spring and summer. I also plan to put it on the track. I will certainly pay attention to the shifts and take your advice. Thanks
#200 OFFLINE   Superchief
Superchief
  • 114 posts
  • Joined 28-May 07
Posted 10 May 2014 - 06:32 PM
Update...to my clutch issue.  Dealer called and says my clutch needs to be replaced.  They said they need to pull the transmission etc... and have the insurance guy look to see if it's normal wear!!!???!!!   The dealer has asked for $400 to do this work.  If insurance covers clutch repair, I pay nothing but the deductible.  I have about 15,000 miles on my 07 GT600.   The dealers says clutchs only last about 20k miles on these cars???  Is that right??   So I find out next week who pays for this repair.
#201 OFFLINE   Grabber
  • 35,090 posts
Posted 10 May 2014 - 07:18 PM
The tranny always has to be removed to get to the clutch. The flywheel has caused excessive heat due to the fact that it is made out of a material that does not dissipate the heat transfer well at all. It then heats up the clutch and toasts it prematurely. The new flywheel in the TSB is made out of a better material to transfer the heat and the clutch pads are now made out of organic material which is more forgiving and can take the heat better. Some of the stock clutches last 35k and some 2k. Just depends on the driver.
#202 OFFLINE   ViperNC
ViperNC
  • 1,347 posts
Posted 11 May 2014 - 04:56 AM
18K+ and counting... No issues. Although I guess you could liken this to a ticking time bomb. I'm waiting for the slip which is going to happen at some point.
  • Shelby A Arms
#203 OFFLINE   Hans
Hans
  • 793 posts
Posted 11 May 2014 - 08:08 AM
I got a new clutch under warranty, with a new transmission (08) when my car had 11,000 miles. This has lasted me 8 years and twenty eight thousand miles with a dozen track days and some hard street driving. I'm going with the Mcleoyd RST street twin disk and all the other parts, lines and bearings. Going in the shop ASAP, AS the clutch is now slipping.
Exterior mods
Mis Decals on car
9 inch antenna
Steeda lock nuts
Exterior mods cont.
Engine mods
Ford racing damper
Shock tower caps
JLT oil separator
Engine mods cont.
Interior mods
Shelby Headrests
GT500KR trunk liner
SVT LED door sills
Organizer glove box
Suspension Mods
#204 OFFLINE   Superchief
Superchief
  • 114 posts
  • Joined 28-May 07
Posted 12 May 2014 - 07:59 PM
Last update...insurance will not cover. Clutch work to start this Thursday. Bummer. Car with under 15k miles, not covered. ..wow.
Now just want a good install.
#205 OFFLINE   wingsnut
wingsnut
  • 443 posts
  • Joined 21-June 08
Posted 13 May 2014 - 07:51 AM
Not surprised. They hooked you in. $400 to take it apart and see if it was covered? Now they have your car disassembled knowing you will probably cave and pay them to do the work. Pisses me off every time I hear this BS. Never, ever will I purchase another new Ford. Never.
Chip
Edited by wingsnut, 13 May 2014 - 07:51 AM.
2008 GT500 Performance White
Installed Mods
TVS, VMP Tune, Bob's Oil Separator, FR3 handling pack, Shelby Fays2 watts link, Baer Eradispeed front and rear brake kits with Hawk pads, BMR UCA and LCA's, LCA relocation brackets, J&M caster/camber plates, FRRP SVT axle assembly w/ 3:73 gears, MGW shifter, McLeod RXT clutch, Ford Racing SS clutch fluid line.
Mods still in boxes
Shelby extreme duty heat exchanger and radiator
#206 OFFLINE   SN8KB'T
SN8KB'T
Posted 13 May 2014 - 08:52 PM
I posted back on April 7th that I ordered my parts from Tasca. Thought I would give an update. If any of you guys are out of warranty DON'T get hoodwinked into thinking you have to have this work done by a Ford dealer service department! IF they are honest they will charge you the 5.1 book hours at $99 an hour which is a little over $500 just for the install. I had contacted two different dealer service departments in my area. Got the run around from one who said they couldn't tell me exactly how long the work would take so I wouldn't know about the charges until AFTER the work was complete. I'm not stupid, not doing that. The second tried telling me it would take 12 HOURS AT $1,200 FOR THE WORK! When I told them the Ford book and the TSB calls for 5.1 hours he lied to me and gave me some crap that there is different repair times for warranty work vs. non warranty work. Total BS! So I just went down to a local shop where I know the mechanic very well who works on race cars and owns several hot rods and asked him to do the work. Brought him the parts from Tasca and the TSB info. He said no problem, his computer told him it was a 5.1 hour job, and since it wasn't a dealer rapeing you on labor charges I ended up paying him a whopping $330 total for the install! And it runs top notch. Just like everyone described, softer feel, smoother engage, feels much more solid with all the HP it's holding. So my total for the repair with parts and labor was $1314. Not complaining about that.
#207 OFFLINE   Grabber
  • 35,090 posts
Posted 14 May 2014 - 04:17 AM
That is why I did this thread. To tell people what it should cost you. The TSB hours are only slightly different than the Ford book hours. Unfortunately the consumer needs to do his homework on this so they do not end up paying T & M (open checkbook).
#208 OFFLINE   SN8KB'T
SN8KB'T
Posted 18 May 2014 - 04:21 AM
And I have to give you a big thanks for posting this info! If you hadn't taken the time to make everyone aware of this I wouldn't have known better, and would have gotten sucked into a repair that would have cost easily 2 or 2 1/2 times as much. From pointing us to Tasca for the parts savings to the info on the repair costs and time you came through for several of us on here big time! If I ever end up in your direction, or meet at a Shelby event, cold beers are on me....
#209 OFFLINE   WV2008
WV2008
  • 15 posts
  • Joined 12-October 13
  • Interests:Mustangs & Corvettes
Posted 21 June 2014 - 07:03 AM
The transmission and old parts came out pretty quickly013-1.jpg014-1.jpg015-1.jpg016-1.jpg017-1.jpg018-1.jpg019-1.jpg020-1.jpg021-2.jpg022-2.jpg
Grabber,
Sorry for asking the same question as on another post, but do you recall how many miles you had on this clutch. I can see one of the clutch discs through the inspection port on the bell housing and it looks as if it has about the same thickness of material left. I am estimating its a tad less than 2/16 of an inch.
Dan
#210 OFFLINE   Grabber
  • 35,090 posts
Posted 21 June 2014 - 06:18 PM
Grabber,
Dan
3 or 4K miles if I recall.
