TSB 12-8-24 (2011-2013 Mustang) GRUNT/CREAK/CHIRP/SQUEAK NOISE FROM THE FRONT LOWER CONTROL ARM OVER BUMPS
3 replies to this topic
#1 OFFLINE   Grabber
  • 34,325 posts
Posted 31 August 2012 - 07:29 AM
Attached File  tsb12-08-24 2011 - 2013 Grunt creak chirp squeak noise from front LCAs.pdf   47.27K   29 downloads
/pubs/auxf/~WT/USENIE/1527/adobe.gif Printable View (48 KB)
TSB
12-8-24
  • GRUNT/CREAK/CHIRP/SQUEAK NOISE FROM THE FRONT LOWER CONTROL ARM OVER BUMPS
Publication Date: August 30, 2012
FORD: 2011-2013 Mustang
The article supersedes TSB 11-10-17 to remove the production fix date, update the model years, Service Labor Time Standards and Part List.
ISSUE:
Some 2011-2013 Mustangs vehicles may exhibit a grunt/creak/chirp/squeak noise from the front lower control arm hydro bushing. These noises may occur over large vertical bumps like speed bumps, pot holes, rough roads and driveway approaches.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
  • Use chassis ears on the lower control arm hydro bushing bracket tabs to verify noise is coming from the hydro bushing. The hydro bushing is the large diameter bushing at the rear of the control arm.
    • If the noise is not confirmed as coming from the hydro bushing, do not continue with this article. Refer to Workshop Manual, Section 204-00 for normal diagnostics.
    • If the noise is confirmed as coming from the hydro bushing, replace the lower control arm that is making the noise. Refer to WSM, Section 204-01.
PART NUMBER PART NAME CR3Z-3079-C Arm Assy - Left Front W709865-S439 Lower Arm Front Bolt W711123-S439 Ball Joint Bolt W520214-S440 Ball Joint Nut W713882-S437 Rack Nut
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool. OPERATION DESCRIPTION TIME 120824A 2011-2013 Mustang: Replace One (1) Front Lower Control Arm, Includes Time To Diagnose 1.8 Hrs. 120824B 2011-2013 Mustang: Replace Two (2) Front Lower Control Arms, Includes Time To Diagnose 2.1 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE 3078 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2012 Ford Motor Company
#2 OFFLINE   2011SHELBYGT500CONV
2011SHELBYGT500CONV
  • 155 posts
  • Joined 11-April 11
Posted 11 October 2012 - 06:32 PM
Has anyone had there dealer complete this on their car? I hate to bring it in and have the car road tested....
http://autos.yahoo.c...-152707580.html
Vehicle Information:
~ 2011 SHELBY GT500 Convertible SVTPP/EP (STRIPE DELETE)
~ Born on 03-29-10 #42 of 950 Convertibles
    #6 of 61 in Ingot Silver Metallic
~ Carroll Shelby (Authenticate) Signed Dash Plaque
~ Carroll Shelby (Authenticate) Signed Dash/Airbag Cover
~ Carroll Shelby (Authenticate) Signed Vehicle Certificate
Modifications:
~ Shelby GT500 Air Filter (Oiled)
~ FRPP Resonator Delete
~ Tinted Windows
#3 ONLINE   07gt500conv
  • 4,439 posts
Posted 12 October 2012 - 03:11 AM
The mechanic I use at the Stealership I know takes care of my GT and Shelby.  He used to own a few and he knows how I take care of the cars.
No worries here.
#4 OFFLINE   RUFDRAFT
RUFDRAFT
    RUFDRAFT
  • 57,688 posts
  • Joined 04-May 06
  • Interests:Yes.
Posted 12 October 2012 - 12:37 PM
View PostGrabber, on 31 August 2012 - 07:29 AM, said:
Attachment tsb12-08-24 2011 - 2013 Grunt creak chirp squeak noise from front LCAs.pdf
TSB
12-8-24
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
Like driving with the hammer cocked!  2013 GT - Stock! (mostly)  off-road pipe -- Flowmasters --Bama Cam tuned - Eibachs -- Nitto NTO5's -- BBK - CAI -- MMD 1/4 Window covers -- 2006 Tacoma Pickup - 119 rwhp! -- Previous Mustangs - 2007 Mustang GT - 474 RWHP - SAE Corrected - : 1985 Black Hatch GT - 1989 Red LX 5.0 Vert - 1991 Grey LX 5.0 Sedan - 2001 White V6 - 2003 Zinc Yellow Mach 1. -
