8.5 Qtr capacity, but 7.5 Qtr for oil change?
#1 OFFLINE
Posted 03 September 2012 - 06:17 PM
Have 2013 w/ no track pack. Just oil to water standard cooler.
Drained oil, changed filter, then added 8.5 quarts of oil as indicated in manual. Did not drain oil from cooler - just removed drain plug on pan.
Oil appears a quart high now?
Is there another place that you are supposed to drain the oil from the cooler? Or does a quart of old oil stay in the system between changes?
Likely did something dumb. What did I miss?
#2 ONLINE
Posted 03 September 2012 - 06:45 PM
Oil capacity 8.5 quarts base, 9.5 quarts Track Pack, 5W-50 full synthetic
Edited by Snoopy49, 03 September 2012 - 07:14 PM.
#3 OFFLINE
Posted 03 September 2012 - 06:56 PM
#4 OFFLINE
Posted 04 September 2012 - 02:28 AM
#5 OFFLINE
Posted 04 September 2012 - 08:30 AM
2002 Saleen Extreme Coupe #59: (1 of 56) Mineral Grey
2003 "James Bond" T-Bird (1 of 700): Hard Top + Convertible Top. Coral with White (Hard Top) Black (Soft Top)
2005 Ranger Pick-up 4X4: Extended Cab, Black
2013 Sheby Gt500 Coupe: Black W/White Stripes, (SVTPP, Track Pack, Recaro's, Electronics Pack, Shaker Pro, Car Cover, Louvers & Scoops)
#6 OFFLINE
Posted 04 September 2012 - 12:54 PM
No problem w/o the track pack, but 10%+ used oil stays in track pack equipped GT500's. I wish there was some way to change all 9.5 qts w/TP!
#7 ONLINE
Posted 04 September 2012 - 01:19 PM
Edited by Snoopy49, 04 September 2012 - 02:01 PM.
#8 OFFLINE
Posted 04 September 2012 - 04:41 PM
Possible explanation - After the oil change, I checked for leaks, took it for a drive, then checked oil after a few minutes when the engine was hot....that is when I had the oil at the "overfill marks" on the dip stick. This morning, the oil was right at the upper hole.
Believe this is just the oil expansion causing the issue false reading.
Density Cold / Density Hot = Volume Hot / Volume Cold..., so for the oil from 20 deg. C to 100 deg. C the ration of the cold / hot densities is ~1.06.
Conclusion: for 8.5 Quarts of oil you could expect up to a 1/2 quart expansion.
Never had a car before with enough oil that this could really be observed.
#9 OFFLINE
Posted 04 September 2012 - 09:04 PM
This must be one reason never to overfill when changing or adding engine oil.
Does anyone have any info on what the range of temps that the engine oil experiences under different driving conditions & how much lower these temps are with the track pack?
#10 OFFLINE
Posted 08 December 2012 - 08:54 PM
I'm stumped as to why the plastic panel under the front of the car says "Remove for Oil Service"? I assumed that's where I'd find the filter, but no, it's further back. Can't find anything that looks like a drain plug under there.
Am I missing something, or is the only place I drain oil during an oil change at the pan?
1967 Mustang Convertible: Restomod (in progress)--347, TF heads and intake, World Class T5, 8.8 with 4:10s, Cobra 4 wheel disc brakes... Target completion May 2013.
#11 OFFLINE
Posted 08 December 2012 - 09:51 PM
This is only my second supercharged vehicle, but if it's anything like the other one, there IS supercharger oil to be changed, but it is totally separate from the engine oil. I haven't looked for it on the Shelby yet but, on my other vehicle, there's a plug on the nose drive through which the oil is extracted and replaced. Change interval for that vehicle's supercharger oil, depending on who you believe, varies between 30K and 100K miles. (Nothing like clear guidance...)
Edited by Norton, 08 December 2012 - 09:59 PM.
Built on 17 Oct, Delivered by Whitney's Value Ford in Elma, WA on 9 Nov
Mods: JLT CF Intake, Airaid SynthaMax Filter, Bob's Ultimate Oil Separator, Redline Tuning QuickLIFT Plus, FRPP Strut Tower Brace, Jaeger Bros Stone Guards, VLED 5K CREE Driving Lights, Clutch-Assist Spring Removed, Viper Ultra Tint, Rogue-Mounted Bel Vector 995, Lloyd Mats, Mobil 1 & Amsoil Lubricants
Originally ordered from Phil Long Ford Chapel Hills (CO) on 18 Jun, my order dropped from "#1 of 3" to "#3 of 2" on 19 Sep
Moral of the story: Do NOT shop Phil Long Ford Chapel Hills
#12 ONLINE
Posted 08 December 2012 - 09:56 PM
#13 OFFLINE
#14 ONLINE
Posted 08 December 2012 - 11:21 PM
#15 OFFLINE
Posted 08 December 2012 - 11:42 PM
#16 OFFLINE
Posted 08 December 2012 - 11:43 PM
#17 ONLINE
Posted 08 December 2012 - 11:59 PM
Husky44, on 08 December 2012 - 11:42 PM, said:
If the engine has to fill the oil filter before the engine sees any oil, wouldn't it be better to prevent this from happening by prefilling the filter? I would rather not take a chance.
#18 OFFLINE
Posted 09 December 2012 - 12:00 AM
Husky44, on 08 December 2012 - 11:43 PM, said:
I admit I didn't pay any attention to "Remove for Oil Service" verbiage when I was under the car, or I'd have probably suffered the same confusion you did. According to this thread in the SVT Performance forums, the plastic panel is shared among multiple Mustang variants and the 5.0 engine requires removal to access the oil filter.
Edited by Norton, 09 December 2012 - 12:01 AM.
#19 ONLINE
Posted 09 December 2012 - 12:01 AM
Is the filter located in a different position on an SVT TP equipped car?
#20 OFFLINE
Posted 09 December 2012 - 12:04 AM
Snoopy49, on 09 December 2012 - 12:01 AM, said:
No.
View Garage
