8.5 Qtr capacity, but 7.5 Qtr for oil change?
59 replies to this topic
#31 OFFLINE   IngotSilverSnake
IngotSilverSnake
    IngotSilverSnake
  • 622 posts
  • Joined 29-April 12
Posted 09 December 2012 - 05:20 PM
Here is a photo of my assistant helping me to change the oil. She says always pre-fill your oil filter. So, are you going to believe these naysayers or my assistant?
Edited by IngotSilverSnake, 09 December 2012 - 05:32 PM.
2012 GT500 Coupe With SVTPP, Ingot Silver, Bone Stock (More Than Enough Power for Me)
2014 Ram SLT 1500, 395 HP 5.7L Hemi, ZF-8HP 8 Speed Automatic Transmission, Big Horn Package
2006 HD 35th Anniversary Dyna Super Glide (High Flow Air Filter, Stage 1 Kit, Race Tuner, Screamin Eagle II Slip Ons)
2011 BMW 328i (Wife's Dream Car)
#32 OFFLINE   bergenfelter
bergenfelter
  • 460 posts
  • Joined 07-April 12
Posted 09 December 2012 - 06:01 PM
You definitely needed to remove the "remove for oil service" panel. Hope nothing gets stuck.
#33 OFFLINE   Snoopy49
Snoopy49
  • 1,342 posts
  • Joined 18-May 12
Posted 09 December 2012 - 06:06 PM
I thought that only happens to dogs and shopping carts? B)
Edited by Snoopy49, 09 December 2012 - 09:21 PM.
2013 GT500 Coupe - HPW with Black Stripes - SVT PP - SVT TP - Redline Hood Struts - Jaeger Brothers Front Splash Guards - Bob's Oil Separator - AirAid Blue Non-Oiled Air Filter - CarboTech 1521 Ceramic Brake Pads - Resonator Eliminator Kit - WeatherTech Floor Mats - Craig’s No Drill License Plate Bracket - MGW2 Shifter - BMR Panhard Bar and Brace
Car Ordered 5-27-2012 - Build Date 1-14-2013 - Delivered 1-26-2013
#34 OFFLINE   BCPD199
BCPD199
  • 384 posts
  • Joined 13-July 07
Posted 10 December 2012 - 12:01 PM
I alway prefill also when I can, its all in the details and the little things that help.
Ever since back in the day when I had a couple of Turbo Gran Nationals, I always pre-filled the oil filters. Same with the Detroit Diesels in my boat. It's probably not as important on our cars; but, on the turbo's, they run dry for a second or two before the oil pressure comes up. If memory serves me right, the Buick's turbo oil feed came right after the filter. And as fast as a turbo spins, you definitely don't want them spinning dry. Habit now; but, I prefill the filter on everything I own. Except my Mercury 4 stroke outboard, the damn thing is installed upside down! Good luck pre-filling that!
#35 OFFLINE   IngotSilverSnake
IngotSilverSnake
    IngotSilverSnake
  • 622 posts
Posted 10 December 2012 - 12:44 PM
Gentlemen: Since you all probably don't believe my assistant knows much about filters, consider this when deciding whether or not to pre-fill your oil filters. The purpose of the anti-drain back valves that are on most oil filters today is as follows:
"Anti-Drainback Valve. Some oil filter mountings may allow oil to drain out of the filter through the oil pump when the engine is stopped. When the engine is next started, oil must refill the filter before full oil pressure reaches the engine. The anti-drainback valve, included in the filter when required, prevents oil from draining out of the filter. This anti-drainback valve is actually a rubber flap that covers the inside of the inlet holes of the filter. When the oil pump starts pumping oil, the pressure will unseat the flap. The purpose of this valve is to keep the oil filter filed at all times, so when the engine is started there will be an almost instantaneous supply of oil to the engine." (Quote is from this link: http://www.theautoch...ut/filters.html
Another quote from the same article: "Note On Dry Starts: If a vehicle has not been operated for several days or after oil and filter change, some oil may have drained from the filter in spite of the special valves. This is why it is always a good idea to start the engine slowly, letting it run on idle for 30-60 seconds so the lubrication system will be fully charged with oil before a heavy load is placed on the engine."
The filter on late model Shelby's is installed vertically so, the drain back valve makes no difference after the filter is filled. However, the point is that the device is designed to provide an immediate oil supply to the engine to prevent pre-mature wear of some components. I recall an example of the difference it makes on an old Blazer I had years ago. I was getting some engine noise (clatter) at start up that went away after a few seconds. I switched from the standard filter (no anti-drain back valve) to a newer filter with an anti-drain back valve at my dealerships suggestion. Cured the problem instantly. No clatter on start up.
Edited by IngotSilverSnake, 10 December 2012 - 12:45 PM.
#36 OFFLINE   mullens
mullens
  • 1,307 posts
  • Joined 11-July 08
  • Interests:Fast cars and smart women
Posted 10 December 2012 - 12:50 PM
Looks like your assistant needs higher ramps.
2013 GT500 DIB/White
FRPP Resonator Delete
JLT Oil Separator
Redline Hood Struts
#37 OFFLINE   IngotSilverSnake
IngotSilverSnake
    IngotSilverSnake
  • 622 posts
Posted 10 December 2012 - 12:54 PM
Yeah. Well at least she can hand me tools when I need them.
#38 OFFLINE   Snoopy49
Snoopy49
  • 1,342 posts
  • Joined 18-May 12
Posted 10 December 2012 - 02:23 PM
IngotSilverSnake
Do the filters for our car even have a "Anti-Drainback Valve"?
Edited by Snoopy49, 10 December 2012 - 02:24 PM.
#39 OFFLINE   IngotSilverSnake
IngotSilverSnake
    IngotSilverSnake
  • 622 posts
Posted 10 December 2012 - 02:55 PM
IngotSilverSnake
Yes -- If you buy the Motorcraft FL-820S Filter specified by Ford for our cars (See description at this link: http://www.autozone....entifier=140249) Most aftermarket filters also have them. However, since the filters install vertically, the only time you have to worry about starting on a dry filter is after an oil and filter change. You can fix that problem by pre-filling the oil filter before installation.
Edited by IngotSilverSnake, 10 December 2012 - 02:57 PM.
#40 OFFLINE   Snoopy49
Snoopy49
  • 1,342 posts
  • Joined 18-May 12
Posted 10 December 2012 - 03:23 PM
Thanks for the link and the post.
Edited by Snoopy49, 11 December 2012 - 12:12 AM.
#41 OFFLINE   Squirrel 007
Squirrel 007
    Ford Retiree
  • 168 posts
  • Joined 04-September 12
Posted 11 December 2012 - 06:43 AM
So that would be the wait for the hydraulic lifters to pump up and in the seconds you wait for that to happen the push rods are clanging against the rocker arms? That would be a little noisy and nerve-racking. Of course solid lifters would prevent that problem I believe.
1997 "Eddie Bauer" Explorer 4X4: White
2002 Saleen Extreme Coupe #59: (1 of 56) Mineral Grey
2003 "James Bond" T-Bird (1 of 700): Hard Top + Convertible Top. Coral with White (Hard Top) Black (Soft Top)
2005 Ranger Pick-up 4X4: Extended Cab, Black
2013 Sheby Gt500 Coupe: Black W/White Stripes, (SVTPP, Track Pack, Recaro's, Electronics Pack, Shaker Pro, Car Cover, Louvers & Scoops)
#42 OFFLINE   tomford
tomford
  • 12 posts
  • Joined 25-April 06
Posted 13 December 2012 - 05:23 AM
I solved this with SVT recently. The track pack's oil cooler & lines hold & keeps 1 used qt that does not drain when draining the pan, so an oil refill takes 8.5 qts with or w/o the track pack.
No problem w/o the track pack, but 10%+ used oil stays in track pack equipped GT500's. I wish there was some way to change all 9.5 qts w/TP!
The way to get that excess oil out with the track pack is to drain the oil and with the plug out run the engine for 5-10 minutes to purge the cooler and lines. This ought to empty the entire system.
2013 Shelby GT500
2012 Raptor
2006 Saleen Extreme
Owner of DiBlasi Ford
#43 OFFLINE   Squirrel 007
Squirrel 007
    Ford Retiree
  • 168 posts
Posted 13 December 2012 - 06:39 AM
Hold on there....these guys are worried about running their engines for the two seconds it takes to fill the oil filter up after an oil change when you start the engine. They would rather shoot themselves in the head before allowing the engine to run dry for 10 minutes. That would surely screw up something. :banghead: :finger: :slapfight: :club: :fan: :boxing: :hammer_self:
#44 OFFLINE   Farmer-Ted
Farmer-Ted
  • Mountain Region
  • 56 posts
  • Joined 04-October 12
Posted 13 December 2012 - 08:39 AM
Careful, someone will take this seriously. Just change the oil as normal.
2013 GT500 - Black, black and black.
1992 GT - Termifoxinator 92/03 hybrid
#45 OFFLINE   Snoopy49
Snoopy49
  • 1,342 posts
  • Joined 18-May 12
Posted 13 December 2012 - 08:46 AM
Does anyone have diagram that shows the oil flow through the engine?
Edited by Snoopy49, 13 December 2012 - 08:47 AM.
#46 OFFLINE   IngotSilverSnake
IngotSilverSnake
    IngotSilverSnake
  • 622 posts
Posted 13 December 2012 - 09:49 AM
I see you are the owner of DiBlasi Ford. I think I would pass on having your service department change the oil in my car.
#47 ONLINE   svtkeith
svtkeith
    svtkeith
  • 50,975 posts
  • Joined 25-March 06
Posted 13 December 2012 - 10:01 AM
I hope this is a joke..a poor one but a JOKE!!
2010 Red ZR1 Corvette
1966 AC Cobra Replica
#48 OFFLINE   jnf
jnf
  • Mountain Region
  • 1,030 posts
Posted 13 December 2012 - 05:07 PM
Hell no !!! :redcard:
Is this a procedure recommended by FORD??
If so, I would like to see it in the tech manual.
07 GT 500 Coupe
White w/ Vista Blue stripes
SLP Loud mouth exhaust
Ford Racing Short Throw with Shelby Ball
Custom CS 69 Special Edition 20" wheels
BMR Upper and lower control arms and brackets
BMR panhard bar, brace and relocation bracket
Eibach Pro lowering springs struts and shocks with front and rear sway bars
Shelby adjustable front end links
VMP 2.59 pulley and tune
JLT Big Air carbon fiber CAI
McLeod RXT twin disc clutch
#49 OFFLINE   mullens
mullens
  • 1,307 posts
  • Joined 11-July 08
Posted 14 December 2012 - 01:58 PM
There's a troll in the house!!
JLT Oil Separator
Redline Hood Struts
#50 OFFLINE   jnf
jnf
  • Mountain Region
  • 1,030 posts
Posted 14 December 2012 - 03:14 PM
Are you referring to me? Or the guy running his engine dry to drain his oil. B)
Edited by jnf, 14 December 2012 - 03:14 PM.
07 GT 500 Coupe
#51 OFFLINE   bergenfelter
bergenfelter
  • 460 posts
Posted 14 December 2012 - 03:34 PM
Oh, yeah, and don't forget to fill the crankcase with 8.5 quarts of turpentine and run 'er for about 100 miles just to be extra sure you got all the goo out before refilling with the factory spec oil.
:barf:
#52 OFFLINE   IngotSilverSnake
IngotSilverSnake
    IngotSilverSnake
  • 622 posts
Posted 14 December 2012 - 07:03 PM
You are right and the troll might actually own a Ford Dealership: http://diblasiford.com/staff.html You guys in New York need to take notice.
#53 OFFLINE   mullens
mullens
  • 1,307 posts
  • Joined 11-July 08
Posted 14 December 2012 - 08:40 PM
Not you the idiot who made that dumb suggestion.
Edited by mullens, 14 December 2012 - 08:42 PM.
JLT Oil Separator
Redline Hood Struts
#54 OFFLINE   440sprint
440sprint
  • 97 posts
  • Joined 29-August 12
  • Interests:technology, muscle cars
Posted 14 December 2012 - 11:46 PM
This would cause way more problems than to just leave the used qt in the TP! I stopped thinking about this concern after talking to SVT about it. I recommend that anyone still concerned to call SVT or to just get over it like I did. All things will be imperfect on some level!
#55 OFFLINE   jnf
jnf
  • Mountain Region
  • 1,030 posts
Posted 15 December 2012 - 08:07 AM
Thats what I thought.
What part of town are you at??
Haven't seen your car around, but I haven't been out much with the car.
07 GT 500 Coupe
#56 OFFLINE   mullens
mullens
  • 1,307 posts
  • Joined 11-July 08
Posted 16 December 2012 - 08:08 AM
I'm in Henderson near Boulder City. They have a cars and coffee Sat morning on Eastern. I go there sometimes.
JLT Oil Separator
Redline Hood Struts
#57 OFFLINE   jnf
jnf
  • Mountain Region
  • 1,030 posts
Posted 16 December 2012 - 02:46 PM
I usually go to that one almost every week.
Haven't had either car out in 6 weeks.
Still have left arm in a sling due to surgery.
Anything happening in Boulder City car wise??
07 GT 500 Coupe
#58 OFFLINE   mullens
mullens
  • 1,307 posts
  • Joined 11-July 08
Posted 16 December 2012 - 07:25 PM
Not that I know of. This time of year they don't have much..
JLT Oil Separator
Redline Hood Struts
#59 OFFLINE   Mike gatt
Mike gatt
  • Joined 27-October 13
  • Interests:Enjoying my cars with my family, car shows, cars and coffee,
Posted 23 August 2014 - 11:00 PM
Thanks all you out there, I spent 1 1/2 hours waiting to get my oil change done at my local ford dealer before finding out the parts dept was open, bought the correct oil and filter. I found some valuable info out there. Going to tackle it sunday. Thanks again mike. Race Red GT 500. (PS any body out there lowered the rear of the 500 )
#60 OFFLINE   Secondo
  • 8,171 posts
Posted 25 August 2014 - 11:03 AM
2 or more seconds of no oil pressure to a high HP precision engine started cold at high rpm X how many times you change your oil with out filling the filter. I've been filling mine since my first change at 16. Seems like a no-brainer to me. You don't mind running your engine without oil pressure for the minimal effort of pouring oil into the filter?? Remind me not to ever buy one of your used cars.
