Reminder - Drain your oil catch can!
check it regularly!
13 replies to this topic
#1 OFFLINE   2007_Shelby_GT
2007_Shelby_GT
    Certified Shelby Nut
  • 1,317 posts
  • Joined 18-January 08
  • Interests:Planes, cars, good times, good friends!
Posted 21 September 2012 - 03:30 AM
A reminder to everyone - don't forget to drain the oil out of your "catch can" if you have it installed!  I don't know how much oil would be captured in a normally aspirated engine, but wow, I drained about a cup of oil out of that thing yesterday!  I'm going to write down my mileage so I can get a good handle on how often I need to check that thing!
Makes me wonder if I need to go ahead and get a second can for the passenger side!?
Sam
AKA:
In Memory Of Willy T
#2 OFFLINE   Z-man
Z-man
  • 808 posts
Posted 22 September 2012 - 05:14 AM
On the GT500's, the PASSENGER side is the worse side in terms of oil. It was reccomended to me to put them on both sides, but I currently only have a single one on the passender side.
If the same statement is true for the supercharged SGT's, I'd get one on the passenger side right away...especially since there was so much oil in the one you have.
(Off to the garage now to see how much oil is in mine-------Thanks for the reminder to check it.)
Edited by Z-man, 22 September 2012 - 05:18 AM.
2008 GT500 - Vista Blue w/ Performance White Stripes
Orange FAI Stripes across front fenders and hood
Signed Shelby Dash Plaque_______________Shelby Automobiles GT500 License Plate Frame
Satin Finish Quarter Window Trim__________ Satin Finish Tail-light Bezels
Sequential Tail-lights (CDC)_______________ White Face Gage Cluster (US Speedo)
Flowmaster Axel-back Exhaust____________GT500 Embroidered Floor Mats & Trunk Mat (Lloyd)
"Shorty" Antenna________________________Front Brake Bezels (JLT)
Hood Lifter Kit (CDC)_____________________KR Strut Tower Brace (Painted to match car)
Radiator Cover (Bangastang)_______________Cervini Lower Quarter Side Scoops
Custom Painted Coil Covers_______________Billet Engine Cap Set
JLT Carbon Fiber CAI_____________________Carbon Fiber CAI Heat Shield
Painted Rear Axle / Differential_____________Lower Rear Control Arms (UMI)
Lowering Springs (Eibach)________________ Adj. Upper Rear Control Arm (UMI)
Struts / Shocks (Eibach)__________________Upper Rear Control Arm Mount (UMI)
Sway Bars (Eibach)______________________Adj. Panhard Bar (UMI)
Urethane Bushings (Eibach)_______________Camber Cam Bolts (BRM)
Oil Separator (JLT)_______________________Ford Racing Short Throw Shifter
2.60" Metco Super charger Pulley____________Metco/Shelby 90mm Aux Idler Pulley & Bracket
SCT Tuner with BAMA Tunes
Clutch TSB Performed 7/2/12 - 7/5/12 by Fred Beans Ford of Boyertown, PA
#3 OFFLINE   Lgs ShelbyGT
Lgs ShelbyGT
  • 465 posts
  • Joined 19-September 08
  • Interests:cars, street bikes, sand dunes & ATVs, snow skiing & martial arts
Posted 22 September 2012 - 10:55 PM
Sam,
Do you have some pictures of how you mounted it?
What did you use for hoses?
I've had a UPR catch can waiting to be installed for too long but still haven't figured out a good mounting point on hte driver's side
Once figure out the mounting, then I would like to have hoses made with OEM fittings
Larry
2007 Shelby GT Black 07SGT1717
E-force w/FRPP CAI (450 rwhp/443 rwt), McLeod RST, FRPP radiator, Brembos & SS lines, KR r axle reservoir, Steeda LCAs, Roush Off Road axle backs + other stuff
Hot on the shelf to install: Fays2 Watts Link, FRPP front brake cooling ducts, GT500 splitter, UPR catch can (how to mount it...)
Ancient History:
1965 Mustang - 289 4brl, 4spd, Pony Pack, factory traction bars (1968-1971)
1968 Mustang California Special - 351W 4brl with Shaker hood 426HP
line lock, cool can, Shelby suspension upgrades, etc (1973)
#4 OFFLINE   2007_Shelby_GT
2007_Shelby_GT
  • 1,317 posts
Posted 24 September 2012 - 05:33 PM
Larry,
I bought the Moroso catch can. Here is a pic of it installed with arrows showing direction of air flow:
http://www.teamshelb...led/#shareLinks
It came with the hoses you see along with instructions on how to cut and re-use factory ends, so no additional fittings to purchase!
Sam
Edited by 2007_Shelby_GT, 24 September 2012 - 05:38 PM.
AKA:
#5 OFFLINE   Lgs ShelbyGT
Lgs ShelbyGT
  • 465 posts
Posted 25 September 2012 - 08:27 PM
Sam
Wow, that looks great!
Surprised that there were enough threads to mount it under your strut tower brace
I was thinking that the outboard strut bolts would need to be used to mount a catch can, which is why I'm having challenges figuring out the mounting
The UPR catch can mount doesn't play well with the available space. Guess I may need to look at your choice instead
Where did you purchase the Moroso catch can?
Larry
Ancient History:
#6 OFFLINE   2007_Shelby_GT
2007_Shelby_GT
  • 1,317 posts
Posted 26 September 2012 - 04:47 AM
Larry,
I got it through American Muscle, but you can get them just about anywhere - mine is Moroso model 85477.
Mounting it on the strut tower was easiest, but if I get one for the passenger side, I'll have to figure out something different - there's just not enough "thread space" over there with the intercooler tank and other stuff!
Sam
AKA:
#7 OFFLINE   2007_Shelby_GT
2007_Shelby_GT
  • 1,317 posts
Posted 22 October 2012 - 05:06 AM
For peace of mind, I just ordered a second catch can for the passenger side!
After 250 miles, I emptied the driver's side can and removed about a tablespoon of oil, (there was actually a bit more, but I know you can't drain all of it unless you let the drain valve sit open for a while), so this indicates there's quite a bit of oil moving through the PCV!
For those without the catch can, (N/A or otherwise), this might explain the standard "puff of blue smoke" on start up, but who knows!?
Sam
AKA:
#8 OFFLINE   springer
Posted 22 October 2012 - 06:25 PM
Sam, it is not necessary for the passenger side.  That topic has been discussed here before.  On the SGT's, it needs to be on the driver's side.
#9 OFFLINE   2007_Shelby_GT
2007_Shelby_GT
  • 1,317 posts
Posted 23 October 2012 - 03:27 AM
The one I already have on the driver's side is definitely catching oil!  Perhaps it's not necessary on the passenger side, but if you're ventilating the crankcase from both sides, to me it would be reasonable to assume you're going to catch some oil from both sides.
No argument, just peace of mind for me!
Sam
AKA:
#10 OFFLINE   msmap
msmap
    proud mom of a Wounded Warrior
  • 5,197 posts
  • Joined 26-March 07
  • Interests:my family, my friends, my Shelby
Posted 23 October 2012 - 06:13 AM
I usually check/empty mine at fill ups.  There was quite a lot of oil in the beginning but now about about a teaspoon or so each time.
Sherri
2007 Shelby GT500 40th Anniversary
CSM 07XL0417 as of 04/2010 (Bud's last)
#2215 of 2695 verts
#266 of 325 Performance White verts
ordered 3/27/07
built 4/17/07
home 4/27/2007
Mods courtesy of Darrell McBryde, Alex MacKenzie and his mechanic, Garrett :)
Other stablemates include:
#1143 of 6381 01 SVT Lightnings
Oxford White
Born on 2/21/01
#939 of 1000 1994 Cobra Indy Pace cars
Saddle on Red
Born on 4/15/94
1969 Mach 1
Indian Fire
Born on 1/20/69
If you don't stand behind our troops,
please feel free to stand in front of them.
#11 OFFLINE   2007_Shelby_GT
2007_Shelby_GT
  • 1,317 posts
Posted 05 December 2012 - 06:06 AM
Sherri,
You are absolutely correct, and while you're under the hood, check your oil and other fluid levels as well!  This USED to be standard procedure at every fill up, but most of us have gotten a bit spoiled by these new cars and their "maintenance free" drivability!
I say, check everything at least every other fill up for peace of mind AND when you raise the hood, it usually draws a crowd, so you can show off while you're at it!
Sam
AKA:
#12 OFFLINE   slbgtsc
slbgtsc
    SLBGTSC
  • 807 posts
  • Joined 05-November 09
  • Interests:Love being outside, hanging with the family. Driving the Shelby is a great way to unwind.
Posted 11 December 2012 - 08:32 PM
I've ran several different setups on my SGT, started off with Breathers on both sides and on the oil fill but the passenger side breather left the valve cover coated lightly with oil, so I went with JLT catch cans on both sides and went back to the shelby oil fill cap. The JLT catch cans let oil into the intake from the drivers side. So third and final setup has been a breather on the drivers side a moroso catch can with breather on it on the passenger side, result is zero oil getting to the intake and zero oil coating the engine bay. I'm using one like this which I got from JEGS http://www.ebay.com/...ca3368e&vxp=mtr
"Halle"
2007 Shelby GT #3184, Saleen SC Stage 3 with 3.2 or 3.0 pulley (street/strip),Mosaleen tensioner system, Moroso Coolant tank, Moroso Intercooler tank,Shelby Engine Cap set, UCA,LCA,BMR A arm Brace, GT4 Wheels, Nitto NT555's, Brembo GT 500 Front Calipers Hawk pads, Brembo Slotted Rear Rotors Hawk Pads, Goodrich Stainless lines, MGW shifter, Pypes LT headers w/off road X pipe,Borla Touring Mufflers, FRP 3.73's, BMR adjustable Panhard Bar/brace , Steeda shaft loop, JLT 110mm CAI, FRP valve Covers, Brenspeed tuned. 12.425 @ 114.63 4800 feet on Nitto 555's, 492 RWP, 469 TQ.
#13 OFFLINE   jmn444
  • 2,766 posts
Posted 12 December 2012 - 04:24 AM
Sam
If running pcv, the pass side is sucking air, so the can wont catch anything unless you have an oil source in your intake tube!
519 RWHP / 484 TQ  Taking bets on when the bottom end will die....
#14 OFFLINE   Tight lines
Tight lines
  • 54 posts
  • Joined 30-November 12
  • Interests:Rc cars & Fishing
Posted 12 December 2012 - 05:52 AM
I have a reminder on my phone to go off once a month to remind me to empty catch can. I need all the help I can get remembering stuff. Lol
2011 Shelby GT500 Race Red - SVTPP package.
