Stainless Steel brake lines
#1 ONLINE
Posted 27 September 2012 - 04:37 AM
2011 Shelby GT500 with SVTPP (Kona Blue)
Modifications in order of occurance: Escort 9500ix * Clearbra * Lund Tune * zPod with Areoforce gauges * Hood Lift Supports * 15% IW * J&M LCA * Shelby Watts link * JLT Oil Seperator * Revan H/E * ARH long tube/high flow cats w/H pipe * billet motor mounts * Evo 3 Point Frame Rail & Torque Box Brace * Boss 302 guage cluster * Boss 302 front brake ducts * OEM look Intercooler Reservoir 3x Capacity * HID Guy fog lights * Bosch 72 lb injectors * Driveshaft Co aluminum driveshaft * BMR LCA relocation brackets * Dynomax bullet mufflers * Kenne Bell 3.6 LC with 3.75 pulley * BMR UCA * Tow hook * Trufiber Black Momba hood * C&R radiator * Thump Racing tensioner - 5" KB high flow air intake * 2013 Upper front grille * 2013 splitter * Shelby transmission cooler scoop * Steeda SS brake lines * Shelby K Member support plates * NavTV reverse camera
Waiting to be installed: bump stop relocation bracket,3 pod gauge cluster - door, Shelby starter button, rear sway bar relocation bracket.
Currently researching: 1. Brake modifications - Front - Hawk street/performance pads with DBA 4000/5000 slotted rotors, Goodridge SS brake lines. Rear - Eradispeed 14" rotors (Maybe) and Hawk street/performance pads, Reverse camera by NAV TV.
Currently at 803 rwhp/717 torque with KB 3.6 LC, 3.75 inch upper on juiced gas, 15% IW lower and Jun Lund tune. Ultimate goal: Surpassed
#2 OFFLINE
Posted 27 September 2012 - 06:37 AM
35% window tint
nav-tv rear view camera
Red line hood struts
Front splitter curb alert system
Super snake carbon fiber splitter
APR Performance carbon fiber mirror assembly
JLT CF resonator delete w/blue airaid Filter
Shelby transmission cooler scoope
BMR UCA with Mount, BMR adjustable panhard bar
Bob's billet LCA and bob's oil separator
FRPP springs
HRE p40 w/Michelin Super sport tires
Future mods going on the car soon: Shelby floor and trunk mat, custom made EPCO shifter knob
Mods undecided about:
Boss x brace, MGW shifter, Boss side exhaust, Corsa black diamond axleback, Lithium battery
#3 OFFLINE
Posted 27 September 2012 - 06:25 PM
Black w/Red Interior
Options: GT500 Premium Trim, Shaker 1000, HID Headlamps, Ambient Lighting, Vehicle Cover (used occassionally in winter)
Awesome Engine Builders: Gretchen Allen and Jason Altidonna!!!
Dates: Ordered 3/31/08, Serialize/Segment 6/12/2008, Sequence 6/20/08, Blend 6/25/08, Produced 7/3/08, Released 7/10/08, Ship 7/16/08, Arrival 7/29/08, Home 7/29/08
Modifications: Alcoas (50th) w/Hankook Tires, Ford Racing KR Exhaust,Griggs GR40SS Suspension, Revan Racing Radiator and Heat Exchanger, Signed Dash Plaque, Red Stripe Floormats, Shelby GT500 Headrests/Console Cover, Project321 Coil Covers, Project321 Caps, True Forged Hood Vents, M-H Racing Intercooler/Reservoir Tank
Numbers: #271 of 3004 coupes (2009), #61 of 524 Torch Red (2009), 1 of 295 Red/Black Stripe coupe (2007-2009)
#4 ONLINE
Posted 27 September 2012 - 06:32 PM
#5 OFFLINE
Posted 27 September 2012 - 06:59 PM
#6 OFFLINE
#7 OFFLINE
Posted 28 September 2012 - 09:58 AM
35% window tint
FRPP springs
#8 OFFLINE
Edited by SSGT500, 28 September 2012 - 09:59 AM.
#9 OFFLINE
Posted 05 October 2012 - 05:21 AM
svt13, on 28 September 2012 - 09:58 AM, said:
I don't believe it has anything to do with overheating. With hydraulics it is all about pressure and where that force is applied. Rubber hoses expand under pressure , so when you press on the brake pedal part of the hydraulic pressure goes into expanding the rubber hoses (hence the squishy pedal). With stainless lines or reinforced low expansion rubber like the BOSS 302 brake line kit (which by the way sell for about $100 in the Shelby Parts Store) that force which normally would be expanding rubber brake lines is now being applied to the brake pistons resulting in a firmer pedal.
Mark
Oops, forgot to add that this will be one of my upgrades next time I flush the brake system. I'm looking at the BOSS 302 kit as a less expensive alternative to the $200+ stainless line kits.
Edited by mark.barton, 05 October 2012 - 05:29 AM.
Born: 6/15/2009 #558 and 1 of 74 Coupes built with Performance White/Red Stripe combo
#49 of 382 in Performance White
#10 OFFLINE
Posted 17 October 2012 - 12:16 PM
35% window tint
FRPP springs
#11 OFFLINE
Posted 17 October 2012 - 07:55 PM
89Saleen215, on 27 September 2012 - 10:47 PM, said:
+1 on the J & M pieces. I used them on a SGT and they are OEM fit and excellent quality.
I'm also happy with the Boss 302 lines that I put on my street driven GT500.
2008 Shelby GT500 Vapor/Black
#12 OFFLINE
Posted 12 November 2012 - 06:15 PM
http://www.tpsmotors...-wheel-abs.html
#13 OFFLINE
Posted 13 November 2012 - 08:05 AM
~JLT 123mm CF CAI~VMP 2.59 Pulley/90mm Idler~
~L&M 66m Throttle Body~Ported Stock s/c Elbow~
~Dynatech Headers~Borla Touring Axleback~Shelby Heat Exchanger~
~FRPP Shifter~Shelby Handling Kit~Eibach Pro Kit~
~BMR Rear Lower Control Arms~BMR Panhard Bar & Brace~
~SVTT 19"/20" Wheels~Nitto NT555R 315/35/20~
~2010+ Updated Trans~Shelby Hood Lift Kit~Shelby Supersnake Hood~
Pics
#14 OFFLINE
Posted 13 November 2012 - 08:31 AM
What was the difference in pedal feel with the boss 302 lines? It kinda feels with the pedal now you have to push it a bit to really engage the brakes. I was hoping that maybe changing the line would make it so that the moment I push it the brakes instantly or engage or do stainless steel and the boss 302 lines not do this? And when they say they make the pedal feel firmer do they mean then we have to push harder for our cars to brake the same amount as before?
35% window tint
FRPP springs
#15 OFFLINE
Posted 13 November 2012 - 09:14 AM
I was wondering about these also, anybody use them?
#16 OFFLINE
Posted 13 November 2012 - 09:56 AM
2003 Dark Shadow Grey Cobra Coupe
Pulley, intake, long tubes, MM coil overs, tubular A arms, etc.
484rwhp/479rwtq
2007 Tungsten Grey Shelby GT500
KR mufflers, Intake, Handling Pack, DSS Driveshaft, Steeda LCAs, Maximum Motorsports C/C Plates and Panhard Bar, '08 Crank Pulley, HRE wheels, Custom Tune
545rwhp/530rwtq
#17 OFFLINE
Posted 13 November 2012 - 08:50 PM
svt13, on 13 November 2012 - 08:31 AM, said:
I would say the Boss 302 brake lines provide a modest improvement over stock. They aren't expensive and they were relatively easy to install when I was flushing the brake fluid. I don't track my GT500 so I stayed with factory parts. In my experience the brake pads make more difference in pedal feel than the brake lines. Performance pads should have higher initial "bite" and greater friction so they change the pedal pressure required to slow the car.
Edited by ShelbyII, 13 November 2012 - 08:51 PM.
#18 OFFLINE
Posted 18 November 2012 - 02:39 PM
MODS
FRPP TVS/CAI, L&M TB/Plenum, Jim LaRocca porting, install & tune, KR Axle Back, 2010 wheels, UPR Pro Series Rear Suspension, Hawk HPS pads, C.S. Signed Visor & Dash Plaque, 20% tint
Bought my baby used in Spring 2012 w/1010 miles. Broke her in @ Team Shelby 50th @ Summit Pt., W.V.!
#19 ONLINE
Posted 27 January 2013 - 07:06 PM
#20 OFFLINE
Posted 20 April 2013 - 10:14 AM
