Finally the took the stripes off.
22 replies to this topic
#1 OFFLINE   FordRocks1
FordRocks1
    CSM#0405
  • 3,005 posts
  • Joined 02-April 08
Posted 17 November 2012 - 04:24 AM
Well, the time has come that my stripes looked like total :censored:  so I finally took them off. They may stay off for some time until I order the deep draw /Terlingua hood. Took me about a day to completely take them off. These stripes were 5 years old and the FL sun has really gotten to them.
I have used this gel like substance that made the job a bit easier, this thing works wonders. It is graphix off. Just be careful on letting it sit too long on the bumpers, I have found out the hard way, it actually ate through my clear on one tiny spot not noticeable to but it happened (mind you this is on a repainted bumper so I think the clear just sucked anyway because the rear bumeper is perfect).
Anyway here are some pics/vids.
Roof Stripes
After 45 mins or so the gel will look like this and the stripes are ready to be removed...
Just click on the picture below and it will play a small video clip so you can see how easy these stripes come off.
Edited by FordRocks1, 17 November 2012 - 04:28 AM.
Our attitude toward life determines life's attitude towards us-Earl Nightingale
#2 OFFLINE   jmn444
  • 2,762 posts
Posted 17 November 2012 - 04:37 AM
Fun fun!  Gonna paint new ones or redo vinyl?
519 RWHP / 484 TQ  Taking bets on when the bottom end will die....
#3 OFFLINE   ilmor
  • 10,914 posts
Posted 17 November 2012 - 05:38 AM
Wow, that had to be scary to do....
#4 OFFLINE   FordRocks1
FordRocks1
    CSM#0405
  • 3,005 posts
Posted 17 November 2012 - 06:01 AM
No more vinyl, I'll keep it black until I can paint them on, the most tedious part of this was removing the glue residue.
#5 OFFLINE   clark17357
clark17357
    Member Terlingua Racing Team, Team Shelby Member #499
  • 3,701 posts
  • Joined 20-August 07
Posted 17 November 2012 - 06:53 AM
Just curious why you did not go with a heat gun for removal?  I have this feeling that all of us, sooner or later, will be in your shoes so I need to collect information about the best way to do it.  Although mine stays in a garage, I have noticed the beginnings of deterioration.
Posted Image Posted Image Posted Image Posted Image Posted Image
2008 Shelby GT Mustang, Vista Blue with Silver Stripes, 5-Speed, Coupe, CSM Number 08SGT0282. Shelby Las Vegas Mod Shop additions:  Center gauge cluster, Kenne Bell polished supercharger, Lower grille with front and rear brake ducts w/o driving lights, Sequential directional lights.  Installed post Mod Shop:  AP Racing brakes (6-piston front, 4-piston rear), Fays2 Watts Link, GT500KR wheels and Goodyear F1 Supercar tires, Compass/temp/homelink rear view mirror, IUP gauges retrofit, Roger's IUP steering wheel, Metco upper and lower control arms, BBR 3.5" aluminum drive shaft, BMR front drive shaft safety loop; Autopower four point roll bar, Autopower five point racing harnesses (both sides), camber/caster plates, JBA shorty headers, QTP exhaust cutouts, Safecraft fire suppression system, Shelby/Revan Racing radiator, heat exchanger, and Shelby/Revan Racing black anodized underhood tanks, and Ford Racing power steering cooler. Dyno results: 453 rear wheel torque, 447 rear wheel horse power @ 67 degrees F, 75% humidity @ sea level.
#6 OFFLINE   Rev Dennis
  • 628 posts
Posted 17 November 2012 - 07:47 AM
My SGT stays in a garage, but if mine go I will leave them off. I realize painting them on would have been cost prohibitive. I don't believe you can get them painted on the newer GT350s anymore either.
Edited by Rev Dennis, 17 November 2012 - 07:47 AM.
#7 OFFLINE   H0050
  • 3,399 posts
Posted 17 November 2012 - 08:59 AM
My body shop is using heat to remove mine.  Your method is almost like removing funiture stain or paint.
Edited by H0050, 17 November 2012 - 08:59 AM.
#8 OFFLINE   2007_Shelby_GT
2007_Shelby_GT
    Certified Shelby Nut
  • 1,317 posts
  • Joined 18-January 08
  • Interests:Planes, cars, good times, good friends!
Posted 17 November 2012 - 12:25 PM
So this stuff is good at removing the vinyl, but not the glue?  What did you use for that?
Also, what is the brand name - I did a search for "graphix off" and found nothing!
Eventually I'll need to replace mine, but rather than paint (unless I find a good deal) I might try "Flex Paint" that John Farmer mentioned.  Literally, paint on vinyl.
Sam
AKA:
In Memory Of Willy T
#9 OFFLINE   FordRocks1
FordRocks1
    CSM#0405
  • 3,005 posts
Posted 17 November 2012 - 03:09 PM
I was not able to use a heat gun on my stripes because the stripes were cracking in pieces already(except for the hood stripes), the roof and bumpers were actually shrinking if you look at the pics above you can see where they once were and how they got smaller in width. If your stripes are still in one piece you can go with the heat gun route but one they crack in into smaller pieces supposedly this is the only way to go according to a vinyl installer/removal. They charge $200 to remove stripes and to do a "mediocre" wax job. So I had to really pry out of the person what they use and the product is graphx off by auto trim design.
the website is
http://www.autotrimd...emover_GROG.asp
Sam
I used goof off carefully to remove the glue that was left and washed the car very well, clayed it, and waxed it. One thing that I will have to say is to do one piece at a time and remove the glue as soon as possible after removing the stripes(it makes the glue removal easier).
Edited by FordRocks1, 17 November 2012 - 03:10 PM.
#10 OFFLINE   jawa
jawa
  • 35 posts
  • Joined 17-July 11
Posted 19 November 2012 - 09:13 AM
I had my silver stripes repainted  at the beginning of the summer, it was not cheap, but well worth it in the end.  Best thing I have done to the car.  The silver paint really pops in the sunlight!
#11 OFFLINE   FordRocks1
FordRocks1
    CSM#0405
  • 3,005 posts
Posted 19 November 2012 - 07:12 PM
Jawa,
That's looks stunning. That's the route I am going to go with after buying the deep draw hood.
#12 OFFLINE   CSSHELBYKID
CSSHELBYKID
  • 74 posts
  • Joined 12-May 12
  • Interests:Shelby's, cars, muscle cars, anything with cars.
Posted 19 November 2012 - 09:49 PM
Fordrocks1, I tried to send you a pm but it wouldn't let me. So anyway.
Where did you get the graphix off sticker remover. I need to remove my stripes and that stuff would help a lot.
CSshelbykid
2007 SHELBY GT-C
CSM 07SGT5186
(FIRST CAR!!)
"IF YOU AINT BREAKING STUFF, YOUR NOT DRIVING RIGHT" - CARROLL SHELBY
"IF YOUR IN CONTROL YOUR NOT DRIVING FAST ENOUGHT" - PARNELLI JONES
#13 OFFLINE   FordRocks1
FordRocks1
    CSM#0405
  • 3,005 posts
Posted 21 November 2012 - 05:24 AM
CSshelbykid
Here ya go.
They also have a Facebook page where they will answer questions pretty fast. The 16 ounce bottle was enough to do the whole vehicle. Again, just be very careful on the bumper areas and do not let it sit too long, the minute you see the wrinkles it is ready to be taken off.
#14 OFFLINE   CSSHELBYKID
CSSHELBYKID
  • 74 posts
  • Joined 12-May 12
Posted 21 November 2012 - 11:21 AM
thanks.
csshelbykid
2007 SHELBY GT-C
CSM 07SGT5186
(FIRST CAR!!)
#15 OFFLINE   carnut12
  • 2,070 posts
Posted 21 November 2012 - 05:24 PM
That is the route I will take eventually, looks great.
Mind sharing how much it cost and did you do the side stripes also?
Thank you
07 Shelby GT # 5696 White, Charcoal Interior and Dash, 5-Speed, IUP, Anti-theft, Wheel Locks, Sirius, Shaker 1000, Heated Seats, Shelby Signature Mats, Shelby License Plate Holder, Lower Billet Grill, Silverhorse Cup Holder, Shifter Bezel, Climate Knobs, E-brake Handle, door handles, Mirror Control Knob, and Window Switch Plates, Clear Turn Signals
Shelby CS69 20" Staggered Wheels, Updated Hood Pins, Shelby Headrest Covers & Armrest Cover, Sequential Tail Lights
Back from Tasca on 03-25-09-550HP Whipple, Brake Upgrade, Shelby Gauges, Blue Ford Racing Valve Covers, Dynotech 1 Piece Driveshaft- 495 RWHP!!!!!!!!!!!!!! FR500S Exhaust
#16 OFFLINE   WillyT
WillyT
  • 41 posts
  • Joined 07-September 12
Posted 26 November 2012 - 09:30 PM
+1  cost?  side stripes?
#17 OFFLINE   gene64cobra
gene64cobra
    Team Shelby Member #133
  • 1,067 posts
Posted 27 November 2012 - 06:12 AM
jawa,
sweet..... love the darkside plate.....   vader rules...LOL
gene
03 Mach 1
06H0209
06H0235
07H0235
#18 OFFLINE   mywickedshelby
  • 34,728 posts
Posted 27 November 2012 - 08:58 AM
I had my stripes painted on when I added the deep draw hood too.
night and day difference...........wet sanded and buried in clear......totally seamless......
rain and water spots issues no longer of any concern.........oh what a relief it is!
#19 OFFLINE   jawa
jawa
  • 35 posts
  • Joined 17-July 11
Posted 28 November 2012 - 08:48 AM
Thanks for the compliments, much apprecaited.  The cost was about $2500 to paint the hood, roof, and trunk, along with both bumpers. I did not do the sides, as the vinyl still looks brand new, no issues at all.  In addtion, the cost to paint the sides is much higher, as you can imagine.  For this  price, the shop also fixed my hood scoop (which was starting to warp slightly), fixed the electolysis damage caused by the stupid stainless steel billet screws on the AL hood, as well as a few minor scratches elsewhere.
Now, the painted stripes have absolutely no ridge or bump relative to the black surfaces.   I wish I could remeber the type of clear coat that they used, but in any case it was a higher-end clear.   The shop said he would not even consider using the "everday" clear on this type of car.
Words cannot even describe how smooth the surfaces are now, not only the silver parts, but the black as well.  New cars off the showroom floor do not have surfaces as smoothe as this.  The car really looks brand new, better than new.   They guys did an unbelievable job, really exceeded my expectations.  The vinyl was a sour point for me since I bought the car in 2011, had rain spots on every horizontal surface.  I Tried many fixes like everybody else, but nothing worked good enough.
In any case, it's allot of $$ to do the work, but if you plan on keeping your car long-term, find a good higher-end shop and have the stripes painted.
#20 OFFLINE   SGT3477
SGT3477
  • 196 posts
  • Joined 17-August 10
Posted 11 December 2012 - 07:49 PM
i also paid a for dealer to paint my stripes on
2500 was the same thing i paid.
i had the stripes painted fromt to back, added the spoiler( they painted ) and they painted and installed the SHR quarter window inserts.
and had the "pit stripes" painted on both sides.
side stripes are still original.
best exterior mod EVER!
