2007 GT500 15,000 miles. Car running cool. 140 degrees on interstate, and 160 after running car hard. I get a check engine light when driving extended interstate driving for cold running engine. Car has reischt 170 thermostat.(previous thermostat was stock, same issues) Steeda 91 octane tune via Predator. Checked thermostat using separate thermometer and opens at 170 degrees. Checked primary temp gauge and it is reading true. Checked fan temps and they are set correctly per instructions that came with thermostsat.
The only other thing that I think it could be is coolant mixture? Am I on the right track? Other possibilty is temp sensor?
cold running engine
Started by
hunters1
, Nov 26 2012 06:52 AM
1 reply to this topic
Posted 26 November 2012 - 06:52 AM
