9" Axle Assembly from Shelby Performance Parts?
#1 OFFLINE
Posted 01 December 2012 - 10:48 AM
#2 OFFLINE
Posted 01 December 2012 - 12:10 PM
__________________________________________________
Register your Shelby at: Shelby American Registry
Order your SAI Registry Certificate at: Shelby Store
PM's turned OFF. Email me at: StevenT@ShelbyAmerican.com
#3 ONLINE
Posted 01 December 2012 - 05:06 PM
Vice President, Shelby Performance Parts
JerG@ShelbyAmerican.com
2007 SGT/SC # 446 - White, 5spd, Whipple 550 HO with Shelby/ReVan Racing/C&R radiator and heat exchanger upgrade, Lethal Performance intercooler tank, Shelby tensioner support brace, Ford Racing laser-etched blue cam covers, Dark Charcoal Gray Interior and dash (signed by Carroll), IUP, Active Anti-Theft, Pioneer AVIC-Z130BT with XM Radio, NAV, HD Radio, DVD video touchscreen, Bluetooth, rearview camera, etc... Infinity Reference speakers, Shelby Kicker door subwoofers, trunk sub, and 4.1 amp, Chrome 20X9 Shelby-logoed Razors (ET24) with Nitto 555s (255 front, 275 rear), Baer Extreme+ 6 piston brakes all around, A'te Super Blue brake fluid, Goodridge s/s brakelines, SLP Loudmouths, Aeroforce Terminator gauge, Shelby gauge pod, CS Supercharged faux gas cap logo, billet lower grille, updated 2008-style front grille mount, grille, Shelby billet hood pin kit and pony emblem, the latest hood scoop & stripes, Shelby floormats and trunk mat, CG-Lock seatbelts, Shelby GT engine cap set and period-correct "Shelby Automobiles" license plate frames, Moroso tanks, brake fluid reservoir, and fusebox cover, shorty antenna, Shelby billet fuel fill door, 3/4 window louvers, Shelby upper control arm and mount and lower control arms, CHE K-member brace w/ torque limiters, sequential taillights, Shelby billet Watt's link, Ford Racing 3.73:1 gearset, Shelby GT500KR diff cover, de-rusted and painted rear axle housing, Eaton True Trac limited-slip differential, Moser axles, Strange Engineering axle studs, full of Mobil 1 with Ford Racing filter. H3R HalGuard fire extinguisher with Shelby and Brey-Krause mounting. Of course I have lots and lots of Shelby doodads, knicknacks, merch, apparel, bling, and bric-a-brac. Many Shelby certificates and Monroney sticker shiny and intact. Fender SGT guitar. Tolerant wife.
Shelby Vegas Bash 2011 and 2012 Show Winner. No longer eligible for judging.
Biggest UPDATE of ALL: Left Guitar Center and joined SA as Vice President, Shelby Performance Parts, August 2012.
#4 OFFLINE
Posted 01 December 2012 - 06:59 PM
#5 ONLINE
Posted 02 December 2012 - 10:28 PM
So I KNOW how convenient it would be to have a finished rear diff setup available. I'll get on it.
#6 OFFLINE
Posted 03 December 2012 - 07:20 PM
#7 ONLINE
Posted 03 December 2012 - 07:32 PM
#8 ONLINE
Posted 04 December 2012 - 09:22 PM
Everyone, chime in on what you'd like to see offered...
#9 OFFLINE
Posted 04 December 2012 - 11:22 PM
Must clear/fit with the Shelby Watts link (preferably both versions)
Must work with the Shelby Baer rear brakes (even if it's an option)
I'd like to see an option to use the standard driveshaft
I'd also like to see LCA relocation brackets built in
And (yes this is probably a bit in left field) I'd love to see a setup that incorporates a provision for a torque arm. Of course then you'd have to design a TA as well.
It is the Marines, Soldiers, Sailors and Airmen who salute the flag, who serve beneath the flag, and who's coffins are draped by the flag, that allow the protester to burn the flag.
I'm not a Shelby guy, I'm not a Mustang guy, I'm not a Camaro or Chevy guy, and I'm not a Dodge guy. I'm a car guy. I don't care what the fender says, if it looks cool, is fast and fun to drive, It can be called a Poo-master 1000 for all I care. I'll still like it.
http://www.facebook.com/BanTheFordMustang
#10 OFFLINE
Posted 05 December 2012 - 04:06 AM
What I would like to see is a Ford 9" (or beefed up 8.8") with a choice of gears and differentials. Make it bolt in either using factory components or components that are to factory specifications (UCA, LCA, panhard bar, etc.). have it painted and use an aluminum differential cover with drain and fill plugs for easy maintenance. I think offering a one piece driveshaft to match the axle would be a nice option as well. You could go crazy with disc brake offerings, but something that the factory units could be mounted to would really be nice to start.
It might be going too far, but I would like to see an offering that allows the axle to be shortened by about 1/2" on both sides to allow Shelby Alcoas to run wider tires. A 10" Alcoa could likely fit at least a 305mm tire, but with the offset of the rim and the overhang of the wider tire, it does not work well. However, if the entire rim and tire were moved inward by about 1/2" or so, it could llikely fit nicely. This might be a nice option to offer on the SuperSnake packages.
Thank you for looking into the possibilty of this for all of us. If it makes good financial sense and gets good responses, I hope it moves forward!
#11 OFFLINE
Posted 05 December 2012 - 05:07 AM
I also like the idea of options on upgrading the brakes incorporated into the pricing or no brakes to utilize the stock brakes
#12 ONLINE
Posted 05 December 2012 - 07:16 AM
Wilwood brakes pre-installed (optional)
Watts link clearance
Built-in LCA lowering brackets
Pre-painted, possible powdercoated housing
Choice of gear ratios and diff
Choice of axle studs
Bolt-in installation
(Just off the top of my head)
#13 ONLINE
Posted 05 December 2012 - 06:21 PM
shelbymotorsports, on 01 December 2012 - 12:10 PM, said:
Steve,
We started with a Currie, but changed direction... it's now a much more custom item...
#14 OFFLINE
Posted 05 December 2012 - 06:28 PM
Good to know. I've only been around our two P cars and haven't looked at the current production cars being built. Will add that to the "to do" list.
#15 OFFLINE
Posted 08 December 2012 - 06:15 AM
Edited by 1sgt, 08 December 2012 - 08:51 AM.
#16 ONLINE
Posted 08 December 2012 - 11:37 PM
1sgt, on 08 December 2012 - 06:15 AM, said:
We have a steel one (blue) and a billet aluminum one. The billet one is 2 pounds lighter, and looks a lot nicer, plus has an engraved Shelby logo. Otherwise, the same function - they work to control the roll center, and the car definitely feels the effect, it is an additional form of chassis bracing, and can reduce the amount the rear axle "steers" the car. I love mine, even just backing out of my driveway, the rear of the car feels stiffer, and more obedient to steering input. My third favorite and most effective mod ever (the blower and the brakes are #1 and #2). It is adjustable, so the car can be more "tail happy" for drifting, or more of a "snowplow", or just plain "neutral" in corners (my terms entirely, and mine is set up to be neutral).
Edited by Jer, 08 December 2012 - 11:37 PM.
#17 OFFLINE
Posted 10 December 2012 - 08:53 AM
Freak, on 04 December 2012 - 11:22 PM, said:
I've never seen a 9" offering for the S197 chassis that used a cup style pinion flange for the factory style CV joint. They usually have a flange for a U-joint. In addition, there'll be a problem for '13 owners that want to retain their CF driveshaft if the face of the pinion flange is in a different location (fore or aft) due to the length of the third member.
'07-'13 cup style pinion flange
Typical aftermarket (in this case, Currie) yoke
Jer, Shelby should have the resources to have a custom billet cup style flange made that would allow this. I have yet to see it done though. I'm also no fan of the 'Johnny Joint' atop the Currie housing. A simple factory style (custom durometer or not) bushing would suffice.
What I'd want in a 9" from Shelby...
- Move the lower shock bracket in slightly. Function of the shock would be the same but may possibly allow for more clearance to the shock body with custom meats. Shaft cover may still need removal or trimming though.
- Cup style pinion flange. Allows retention of factory '13 CF shaft as well as for '07-'12 owners that want to switch to the '13 shaft.
- Rear fill and drain plugs.
- stock width dimensions. Custom lengths only drive up cost.
- Multiple axle options (spline count, materials for drag or road race, etc).
- Bearing retainer plate/bracket that allows stock brakes to bolt on, whether the '07-'12 dimension or the '13 extended bracket for the larger diameter rotor.
- Optional fittings that allow '13 owners to bolt up their temp sensor as well as the for the cooler.
That's it!
Edited by Tob, 10 December 2012 - 08:54 AM.
#18 ONLINE
Posted 10 December 2012 - 09:14 AM
#19 OFFLINE
Posted 10 December 2012 - 03:46 PM
Yea, I know. I've never seen it either, that's why I mentioned it. The yoke itself shouldn't be a problem, and they could offer different styles depending on year. I'm not actually wanting to use the stock DS (really, what would be the point of a 9" if you aren't straining the stock driveshaft enough to break it?), but I'd prefer to use a bolt in one piece rather than a custom U-jointed one.
The flange location being different could be an issue, but it depends on how much different it is. I had a 9" in my '99 Camaro and used the stock DS with no problems. If I remember right it was only about 1/4 inch difference in length. I don't know how much play the CV joints give here though.
Anyway, it was just a list of "wants".
#20 ONLINE
Posted 10 December 2012 - 05:57 PM
This won't be an in-stock item (in most cases), it will be a made-to-order system that accomodates various driveshafts, brakes, axle stud lengths, etc...
I'm basing the options around what you all are requesting here, as much as possible.
P.S. It FIGURES, this program will start after I just dumped a few grand into my stock 8.8... LOL... You guys get all the luck.
