Sway Bar Relocation Bracket installation
3 replies to this topic
#1 OFFLINE   NMAv
NMAv
  • 592 posts
  • Joined 10-January 11
Posted 03 December 2012 - 05:15 PM
Does anyone have directions for this process.  I haven't looked at things but wanted to get some documentation before starting. Also, how long should it take?
~ NMAv
2011 Shelby GT500 with SVTPP (Kona Blue)
Modifications in order of occurance:  Escort 9500ix * Clearbra * Lund Tune * zPod with Areoforce gauges * Hood Lift Supports * 15% IW * J&M LCA * Shelby Watts link * JLT Oil Seperator * Revan H/E * ARH long tube/high flow cats w/H pipe * billet motor mounts * Evo 3 Point Frame Rail & Torque Box Brace * Boss 302 guage cluster * Boss 302 front brake ducts * OEM look Intercooler Reservoir 3x Capacity * HID Guy fog lights * Bosch 72 lb injectors * Driveshaft Co aluminum driveshaft * BMR LCA relocation brackets * Dynomax bullet mufflers * Kenne Bell 3.6 LC with 3.75 pulley * BMR UCA * Tow hook * Trufiber Black Momba hood * C&R radiator * Thump Racing tensioner - 5" KB high flow air intake *  2013 Upper front grille * 2013 splitter * Shelby transmission cooler scoop * Steeda SS brake lines * Shelby K Member support plates * NavTV reverse camera
Waiting to be installed:  bump stop relocation bracket,3 pod gauge cluster - door, Shelby starter button, rear sway bar relocation bracket.
Currently researching:  1.  Brake modifications - Front - Hawk street/performance pads with DBA 4000/5000 slotted rotors, Goodridge SS brake lines. Rear - Eradispeed 14" rotors (Maybe) and Hawk street/performance pads, Reverse camera by NAV TV.
Currently at 803 rwhp/717 torque with KB 3.6 LC, 3.75 inch upper on juiced gas, 15% IW lower and Jun Lund tune.  Ultimate goal: Surpassed
#2 OFFLINE   TAPD117
TAPD117
    GLENN (GG)
  • 1,094 posts
  • Joined 28-November 06
  • Interests:I dig Mustangs & Shelbys.
Posted 03 December 2012 - 05:43 PM
Drop Springer (John) a pm, he took his rear sway bar off to lube it several months ago.  GG
TAPD117 (My friends call me GG)
2008 Shelby GT/BJ Barrett Jackson Limited Edition Premium Convertible
Arizona Only Dealers Option Black With Red Stripes - 08SGT2290
1 of 100 SGT/BJ Limited Edition Mustangs (61 Coupes-39 Convertibles)
1 of 39 SGT/BJ Convertibles
1 of 11 SGT/BJ Convertible Automatics
1 of 5 SGT/BJ Convertible Automatics with Shaker 1000
Arkansas License Plate: SGT-BJ
SAI Transaction Notes & Results for 08SGT2290
AAI Build Date 11/26/2007
Dispatched for Shipping (Shipment NO. 2787) 01/31/2008
Marked as SHIPPED from Las Vegas SAI 02/06/2008
New Vehicle Purchase Date 08/25/2009
HID/IUP/AMB/ANTI-THEFT/SAT/6-Way Seat/Leather Interior/Barrett Jackson Headrest & Console Covers
CDC Sequential Tail Lights/Shaker 1000-Rather have NAV/Shelby Billet Engine Cap Set
Posted ImagePosted ImagePosted Image Posted ImagePosted ImagePosted ImagePosted Image
"Sometimes your the bug and sometimes your the windshield, here is the wisdom of life"
#3 OFFLINE   ingram4868
  • 6,095 posts
Posted 03 December 2012 - 08:27 PM
:lurk: Still have mine in the garage waiting on warmer weather for projects. :lurk:
David Ingram
Sparks, NV.
Newest addition 1100 mile 2007 GT500
#4 OFFLINE   msb64
msb64
  • 161 posts
  • Joined 23-December 08
Posted 05 December 2012 - 09:34 PM
Very simple mod, the hardest part is pretty much jacking the back end up to get at it.
Put the back end up on jack stands and then remove the rear wheels.
You need to unbolt the swaybar at the rear end, swing it up out of the way and tie it up with something, then trim off the lower parts of the mounts as per the instructions.
I took my time and did it by hand with a hacksaw, and then cleaned the edges up with a hand file.
I painted the newly exposed metal to match the rest of my painted rear end,  to keep things looking nice.
Bolt on the new relocation brackets, and then bolt the swaybar to the relocation brackets.
With hand tools in a home garage and painting, allow about 2 hours at a leasurely pace.
I used the BMR brackets to help fit 325/15 drag radials on the car.
In my case I also removed the body mounted bump stops, and installed zombeasts bumpstop relocation brackets.
Plenty of room back there now.
BMR installation instructions are available here:
www.cjponyparts.com/images/art/install_HW2352.pdf
