Rattling from Gear Shift
shelby shelby gt gear shift rattling
11 replies to this topic
#1 OFFLINE   wje1992
wje1992
  • Joined 11-December 12
Posted 11 December 2012 - 02:20 PM
I recently got a stock 2007 Shelby GT and I have noticed that under heavy acceleration (approx. greater than 4500) in second gear up to 6000 RPM that a rattling sound seems to be coming from the gear shift. I am not sure if this occurs in the top end of other gears as I usually go from 1st to 2nd to 5th. If someone could help me out and tell me if this is normal or abnormal I would really appreciate the help. If this question has already been asked I am sorry for the repeat. Again any help is appreciated.
Justin
Stock 2007 Shelby GT
#2 OFFLINE   2010KonaBlueGT
  • Banned
  • 7,766 posts
Posted 11 December 2012 - 02:47 PM
Justin
Is your hand on the shifter?
I found the same noise on my 2010 GT500 when I first bought it. I realized that I was holding onto the shifter and *slightly* holding back on it. Once I discovered that, I pulled my hand off and never had the sound again (It was ME, not the trans/shifter/car)!
I didn't even realize I had the habit of doing that....
#3 OFFLINE   wje1992
wje1992
Posted 11 December 2012 - 06:55 PM
No my hand has not been on the gear shift. Me and a friend but just happened to hear a slightly noticeable rattle. At first I was not sure where it was coming from but I soon figured out that it seemed to be coming from the gear shift and when I did place my hand on it, a slight vibration could be felt. Is this something that I should get checked out or should I just stay away from the top end of the gears?
Justin
#4 OFFLINE   ARMORINE
ARMORINE
  • 801 posts
  • Joined 19-February 09
Posted 11 December 2012 - 07:38 PM
check your e brake handle mine rattle alittle bit. if its not that then somethings loose. id get under the car and check the shifter mounts.. mine were loose when i got the car. didnt figure it out till i reached up past the tranny and started checking things before a race last year.
having a 9 second ricer is like coming out of the closet, at first you surprise every one but at the end of the day your still gay
man kind has earned the right to rule this planet by occasionally producing someone totally bats#$t insane
#5 OFFLINE   SGT3477
SGT3477
  • 306 posts
  • Joined 17-August 10
Posted 11 December 2012 - 08:09 PM
this has been mentioned before here. i can t remember where but, searching should bring it up. someone said something about some adjustment screws on the shifter i think.
mine does it. i can just touch it with my hand it and it stops. but i get it in all gears but only under load.
1 finger, slight pressure and it stops.
i did my aluminum driveshaft install and while i was under there i checked the bolts i could reach and all seemed snug. so i so guess i need to do some research as i dont remember the exact fix.
#6 OFFLINE   Bunky
Bunky
  • 161 posts
  • Joined 14-November 07
Posted 12 December 2012 - 05:49 PM
have you looked at TSB 08-3-4
SGT-C
08SGT0135
#7 OFFLINE   SGT3477
SGT3477
  • 306 posts
Posted 12 December 2012 - 07:41 PM
i just did.. do you really think i can just lightly touch the shifter ball and stop that from hapening all the way down there? seems to me like its more direclty related to the shifter since i really truly can just rest the weight of my finger on it and it stops.. thanks for that info though and i found a link that has the full text of that tsb ill try to get underneath this weekend and see if that could have anyhting to do with it.
thank you!
#8 OFFLINE   AndyGJ
AndyGJ
    SGT Owner
  • 1,121 posts
  • Joined 22-January 08
Posted 12 December 2012 - 08:06 PM
Mine has been doing it in 4th gear under load...about 3000 rpms and up. I had the TSB done for the syncros from 2nd to 3rd by the Ford Dealer under warranty and just after that is when mine started. Just by coincedense, I had them check it today when I was in for a couple of routine items & tires and they said they heard no rattle....looks like I'll have to take them for a ride to show them since I can get it to happen on command.
It is a definite vibration of some sort.
I'll have to check out that other TSB....not sure what that one is or if it is for my vehicle year, etc.
Andy.
Present Mustang:
2008 Shelby GT Convertible #1676
Mods Installed:
BF Goodrich g-Force Sport COMP-2 Tires (275/40/R18 Front & Rear)
CDC Sequential Tail Lights
FRPP GT500KR Axleback Mufflers
FRPP GT500KR 18" Rims
FRPP GT500 BREMBO Brake Upgrade (M2300-S)
FRPP 62mm Throttle Body
FRPP Stainless Steel Brakelines
Hawk HPS Brake Pads (front & rear)
JBA Tuned Length Ceramic Shorty Headers
LD's Performance Custom Tuning (91 & 93 Octane) w/SCT-X3 Tuner
Redline Hood Struts (w/update kit)
Royal Purple Synthetic Oil 5w20
Royal Purple Differential Gear Lub
Royal Purple Manual Transmission Fluid
Shelby Lower Radiator Grill Insert - Black
Shelby 4.6L Valve Covers
Shelby GT Berg Snake Faux Gas Cap
Shelby GT Berg Snake Front Floor Mats & Trunk Mat
Shelby Plain Rear Seat Floor Mats
Shelby Billet Engine Cap Set
Shelby Billet Fusebox Cover
Shelby Transmission Cooler Scoop
Shelby Front Brake Duct Cooling Kit
Shelby Fays2 Watts Link
Performance Brake Slotted & Cross Drilled Rotors (front & rear)
Ford Motorcraft DOT4 Brake Fluid
Steeda Aluminum 1-Piece Driveshaft
Steeda CAI Intake Elbow w/Black Tube
Steeda Motor Mounts (red inserts)
Steeda Under Drive Pulley
Prior Mustangs:
1968 Mustang Coupe - Midnight Blue
1966 Mustang Convertible 289v2 - Red w/black top & interior (still in the family)
1973 Mustang Convertible 351W - Poppy Red w/black top & interior - MCA Senior Division Grand National Retired Winner
1989 Mustang Hatchback 5.0 w/5spd - 25th Anniversary - Red w/red & black interior
#9 OFFLINE   JeffIsHereToo
JeffIsHereToo
    Jeff
  • 8,105 posts
Posted 27 December 2012 - 04:59 PM
Go to the Tech/Mod area and search for "shifter rattle" and you will find 5 years of issues and possible solutions.
There are more than a few causes for this and you'll need to figure out which one(s) apply to your car.
Good luck!
2013 Boss 302 (Grabber Blue) #2
2007 Shelby GT (White) #2621
2005 Mustang GT (Mineral Gray)
1989 Mustang GT (White)
1984 Mustang GT (Red)
1979 Mustang Cobra (Jade Green
Team Shelby State Director for AR
#10 OFFLINE   Lgs ShelbyGT
Lgs ShelbyGT
  • Pacific Northwest Region
  • 512 posts
  • Joined 19-September 08
  • Interests:cars, street bikes, sand dunes & ATVs, snow skiing & martial arts
Posted 27 December 2012 - 07:59 PM
The Hurst shifter linkage on the SGT has 3 o-rings on the shaft where the shifter connects to the linkage
Likely these are to dampen vibrations
Just wondering if the transmission was ever removed?
The o-rings can be challenging when you put everything back together and could be easily pinched & damaged if you're not not careful
I test drove a used SGT a couple of years ago, and the shifter not only vibrated it was sloppy loose
The used car salesman tried to tell me that was normal
He didn't know what to say when I told him not the case, because I owned one already
2007 Shelby GT Black 07SGT1717
E-force w/FRPP CAI (450 rwhp/443 rwt), McLeod RST, Brembos & SS lines, KR r axle reservoir, Steeda LCAs, Roush Off Road axle backs,UPR catch can, Fays2 Watts Link, Koni Sports, Vorshlag Caster Camber plates, BMR rear LCA relocation brackets+ other stuff
Still setting on the shelf to install: FRPP front brake cooling ducts, GT500 splitter
Ancient History:
1965 Mustang - 289 4brl, 4spd, Pony Pack, factory traction bars (1968-1971)
1968 Mustang California Special - 351W 4brl with Shaker hood 426HP
line lock, cool can, Shelby suspension upgrades, etc (1973)
#11 OFFLINE   ilmor
  • 12,917 posts
  • Interests:Shelby GT's (what else), Guitar, Camping in my RV, auto racing, autocross, car shows
Posted 28 December 2012 - 04:28 AM
HAHAHAAAAA
2007 Shelby GT CSM# 07SGT1917 - the "Garage Queen"Performance White, LIVE REAR AXLE Hurst 5-Speed, Premium Package
#12 OFFLINE   07SGT4578
07SGT4578
    2007-08 Shelby GT Registrar
  • 4,557 posts
  • Joined 29-October 07
  • Interests:nothing to see here........move along.
Posted 28 December 2012 - 05:27 AM
Mine used to do tho also. The rear shifter bolt was loose (only in a couple threads). Tightened it with some loctite, no more problems
Chris Carter
Shelby American Registrar --- 07-08 Shelby GT
Oklahoma Director --- Team Shelby Southern Plains Region
Email me
CLICK HERE TO REGISTER YOUR SHELBY
CLICK HERE TO BECOME A MEMBER OF TEAM SHELBY
Also tagged with one or more of these keywords: shelby, shelby gt, gear shift, rattling
