Road racing - wheels and tire setup
45 replies to this topic
#1 ONLINE   NMAv
NMAv
  • 589 posts
  • Joined 10-January 11
Posted 17 December 2012 - 03:49 PM
I've done all sorts of mods to my car but have never gotten it out to the track, well come the Shelby Bash 2013 I have two days of track time scheduled.  I've got the SVT 20 - 19 combo setup that I normally run.  Everything I have read says that 20 wheels for road racing is not a good thing.  So my question is, what is recommended of this application?
Edited by NMAv, 17 December 2012 - 05:39 PM.
~ NMAv
2011 Shelby GT500 with SVTPP (Kona Blue)
Modifications in order of occurance:  Escort 9500ix * Clearbra * Lund Tune * zPod with Areoforce gauges * Hood Lift Supports * 15% IW * J&M LCA * Shelby Watts link * JLT Oil Seperator * Revan H/E * ARH long tube/high flow cats w/H pipe * billet motor mounts * Evo 3 Point Frame Rail & Torque Box Brace * Boss 302 guage cluster * Boss 302 front brake ducts * OEM look Intercooler Reservoir 3x Capacity * HID Guy fog lights * Bosch 72 lb injectors * Driveshaft Co aluminum driveshaft * BMR LCA relocation brackets * Dynomax bullet mufflers * Kenne Bell 3.6 LC with 3.75 pulley * BMR UCA * Tow hook * Trufiber Black Momba hood * C&R radiator * Thump Racing tensioner - 5" KB high flow air intake *  2013 Upper front grille * 2013 splitter * Shelby transmission cooler scoop * Steeda SS brake lines * Shelby K Member support plates * NavTV reverse camera
Waiting to be installed:  bump stop relocation bracket,3 pod gauge cluster - door, Shelby starter button, rear sway bar relocation bracket.
Currently researching:  1.  Brake modifications - Front - Hawk street/performance pads with DBA 4000/5000 slotted rotors, Goodridge SS brake lines. Rear - Eradispeed 14" rotors (Maybe) and Hawk street/performance pads, Reverse camera by NAV TV.
Currently at 803 rwhp/717 torque with KB 3.6 LC, 3.75 inch upper on juiced gas, 15% IW lower and Jun Lund tune.  Ultimate goal: Surpassed
#2 OFFLINE   clark17357
clark17357
    Member Terlingua Racing Team, Team Shelby Member #499
  • 3,701 posts
  • Joined 20-August 07
Posted 17 December 2012 - 04:06 PM
You will get various responses.  If you run street tires, it will be challenging under any circumstances.  I have never run anything other than 18" wheels on the track.  That provides a fair amount of side wall.  I have raced a Boss 302 and he had street tires and 19" wheels and he did pretty well.  Mostly, be careful until you are familiar with how your car handles at speed.  Your car is wicked fast for the straight away but physics still apply in the corners.  Add street tires to all your power and things in the corners can get real interesting real fast.  Have a great time at the Bash.
Posted Image Posted Image Posted Image Posted Image Posted Image
2008 Shelby GT Mustang, Vista Blue with Silver Stripes, 5-Speed, Coupe, CSM Number 08SGT0282. Shelby Las Vegas Mod Shop additions:  Center gauge cluster, Kenne Bell polished supercharger, Lower grille with front and rear brake ducts w/o driving lights, Sequential directional lights.  Installed post Mod Shop:  AP Racing brakes (6-piston front, 4-piston rear), Fays2 Watts Link, GT500KR wheels and Goodyear F1 Supercar tires, Compass/temp/homelink rear view mirror, IUP gauges retrofit, Roger's IUP steering wheel, Metco upper and lower control arms, BBR 3.5" aluminum drive shaft, BMR front drive shaft safety loop; Autopower four point roll bar, Autopower five point racing harnesses (both sides), camber/caster plates, JBA shorty headers, QTP exhaust cutouts, Safecraft fire suppression system, Shelby/Revan Racing radiator, heat exchanger, and Shelby/Revan Racing black anodized underhood tanks, and Ford Racing power steering cooler. Dyno results: 453 rear wheel torque, 447 rear wheel horse power @ 67 degrees F, 75% humidity @ sea level.
#3 OFFLINE   TrakRat
TrakRat
  • 349 posts
  • Joined 29-December 10
Posted 17 December 2012 - 04:40 PM
The SVTPP is a competent package as it is for someone that hasn't been the track before.  You have a boat load of power so you may end up BBQing your brakes if it is hot out.
<p>'11 SVTPP Griggs GT500, '67 Coupe, '00 Explorer Limited, '96 Griggs Cobra *sold*
#4 OFFLINE   Secondo
  • 4,717 posts
Posted 19 December 2012 - 07:27 AM
Your stock wheels/tires should be good enough for your first time. You will be surprised how far you can push it. Also, for yours and everyone's safety, including the cars, don't forget the brakes. Please change your brake fluid to a high-performance fluid that won't boil and fail during track braking.
Edited by Secondo, 19 December 2012 - 07:29 AM.
#5 OFFLINE   ilmor
  • 10,910 posts
Posted 19 December 2012 - 08:22 AM
I agree - brakes are more critical.
On my SGT I ran on my stock 18's and all weather original BFG tires...sliding was fun....
#6 OFFLINE   mark.barton
mark.barton
  • 144 posts
  • Joined 01-December 11
  • Interests:Cars, Golf, Racing
Posted 19 December 2012 - 08:24 AM
+1 on all of this. Street tires and brake fluid.The other thing you will need is a good air pressure gauge regardless of the tires you are running. When you get to the track talk to other drivers and see what they are running for pressures. I will not only help save your tires a bit, but it will help the car handle more predictably.
Oh, and welcome to the track addict world. If you are not one now, you will be.............
Mark
2010 GT500 Performance White with Red Stripes
Born: 6/15/2009 #558 and 1 of 74 Coupes built with Performance White/Red Stripe combo
#49 of 382 in Performance White
#7 ONLINE   Albino500
Albino500
  • 905 posts
  • Joined 19-March 12
  • Interests:Open track and WOT
Posted 19 December 2012 - 08:32 AM
After reading your description of mods on your 2011 GT500 and noting your level of experience I would suggest going with a set of 19x9.5 RTR wheels and putting on a set of Kumho Ecsta XS 285/35-19 tires on all four corners . JMO P.S. - these tires are "legal " for ST class cars running in SCCA.
2007 GT500 Built on 7/27/2006
CSM#07SGT4755
#8 ONLINE   NMAv
NMAv
  • 589 posts
Posted 19 December 2012 - 06:34 PM
What brand brake fluid would you recommend?
And thank you!
Edited by NMAv, 19 December 2012 - 06:34 PM.
~ NMAv
#9 ONLINE   Albino500
Albino500
  • 905 posts
Posted 19 December 2012 - 06:59 PM
You can go with either the Ford High Performance brake fluid , Castrol Dot 4 ( formally known as LMA ) , or Motul RBF600 . As far as brake pads go -if you want something for street performance/limited track use go with Hawk HPS pads front and rear (better than stock and NO SQUEAL). True track pads will squeal . If you're considering performance rotors - go with slotted only ( crossdrilled are for looks and when the edge of a counter/radius hole wears it becomes a heat sink point and creates/ forms cracks on the rotor surface) 2 piece (floater) fronts because of the fixed front calipers . (I.E. = DBA5000)  JMO P.S. - If you are going to put on SS braided hoses make sure that they are DOT approved .
Edited by Albino500, 19 December 2012 - 07:01 PM.
CSM#07SGT4755
#10 OFFLINE   andrewnagle1964
andrewnagle1964
  • 1,316 posts
  • Joined 21-February 08
Posted 26 December 2012 - 06:20 PM
This ^^^^^
Have fun !
The Black 07SGT4986 (RIP April14, 2010) to the White 07SGT4623......thanks for the grace of God no one died.
#11 OFFLINE   jmn444
  • 2,762 posts
Posted 26 December 2012 - 07:46 PM
I run the Kuhmo ecsta xs tires on my '68 and really like them, they are a damn good value IMO.
519 RWHP / 484 TQ  Taking bets on when the bottom end will die....
#12 OFFLINE   3ponies
3ponies
  • Joined 01-July 07
Posted 27 December 2012 - 05:07 AM
I average doing 4 track events a year for the last 5 years. I am very happy with Cooper S3s that Jack Roush worked with Cooper on and 18 inch wheels. I use Hawk Pads and Dot 4 Fluid. It is a great hobby. Be safe and have fun  young Jedi! There are some real good track folks on here to coach you.
Edited by 3ponies, 27 December 2012 - 05:08 AM.
Posted ImageRick
08 GT500 Red Stripe Edition Vert:
FRPP 373s, CAI, Chrome Valve Covers, Mufflers, KR Strut Tower Brace
09 Roush #37 Black Jack
65 Restro Mod Fast Back in progress
#13 OFFLINE   03 DSG Snake
03 DSG Snake
  • 2,458 posts
  • Joined 11-May 06
Posted 27 December 2012 - 08:38 AM
I wouldn't mind a set of these for track duty http://fordracingpar...tKeyField=13505
:rockon:
2003 Dark Shadow Grey Cobra Coupe
Pulley, intake, long tubes, MM coil overs, tubular A arms, etc.
484rwhp/479rwtq
2007 Tungsten Grey Shelby GT500
KR mufflers, Intake, Handling Pack, DSS Driveshaft, Steeda LCAs, Maximum Motorsports C/C Plates and Panhard Bar, '08 Crank Pulley, HRE wheels, Custom Tune
545rwhp/530rwtq
#14 OFFLINE   Secondo
  • 4,717 posts
Posted 27 December 2012 - 08:51 AM
Which tire sizes do you put on your car since they don't have the Ford specified sizes for our GT500? Thanks.
Edited by Secondo, 27 December 2012 - 08:52 AM.
#15 OFFLINE   3ponies
3ponies
  • Joined 01-July 07
Posted 27 December 2012 - 09:36 AM
I use my Roush Stage 3 on the Track the Coopers are 275/40R18. The Stage 3 is more like a Sheby Super Charged GT than a GT500. The best price you will get on these tires is via Roush Performance. No Tax, No shipping. I just bought my 3rd set from them. My wheels are 18X10. All wheels and tires are the same size.
Posted ImageRick
#16 OFFLINE   Roush GR40
Roush GR40
  • 311 posts
  • Joined 20-February 08
Posted 27 December 2012 - 09:42 AM
Stock tires are a bit pricey for open track duty IMHO.  I prefer to run 18 x 9.5 wheels (less rotating mass = better braking) all the way around so they can be cross rotated to prolong life.  For tires...a Nitto NT-01, Toyo RA-1 Proxy or a Hoosier R6 for more agressive driving.  I have a complete setup for sale on ebay if you are looking...they only have about 100 miles/3 heat cycles on them...basically brand new. http://www.ebay.com/...984.m1558.l2649  Please PM me if interested.
#17 OFFLINE   Roush GR40
Roush GR40
  • 311 posts
Posted 27 December 2012 - 09:46 AM
:rockon:
This is the ultimate set of open track wheels...I think they are only about 17 or 18 pounds each.  Here they are on my '12 GT500 with Hoosier R6's (275/35x18)
#18 ONLINE   NMAv
NMAv
  • 589 posts
Posted 27 December 2012 - 09:53 AM
Thanks. NC is a long way from CO.  I was looking at a set of 18s from American Racing with new Nittos mounted etc delvered for ~ 1800.  Spoke with Jer @ SPP and he said they will be coming out with some sort of track wheel in the near future so I'm gonig to hold off for now.  Not sure if it would be a wheel/tire combo or what but I can afford to wait a month or so as I won't be tracking the car until the bash in March.
~ NMAv
#19 OFFLINE   Secondo
  • 4,717 posts
Posted 27 December 2012 - 03:17 PM
Ok, got it. Thanks for the info and advice, 3Ponies!! A friend of mine is a Cooper dealer, I'll ask him to get me a price.
Ever since the Ponies In The Poconos event I attended I've been bitten by the track racing bug! This is all great wheel/tire track advice in here! Thanks all!
Edited by Secondo, 27 December 2012 - 03:19 PM.
#20 OFFLINE   3ponies
3ponies
  • Joined 01-July 07
Posted 03 January 2013 - 12:34 PM
I believe that HOD is planning an event this year at Pocono. A lot of my Roush friends are looking forward to an event there.
Posted ImageRick
