RPM Roll Bar help!?
Started by
bpodner
, Mar 08 2013 12:12 PM
#1 OFFLINE
Posted 08 March 2013 - 12:12 PM
Just received my roll bar. Going through the instructions on the CD, I noticed that the provided template is for a coupe. Does anyone have the template for a 2011 vert?
TIA!!!
TIA!!!
Lethal 2.9L Whipple, 72lb injectors, 65mm CJ throttle body, 123mm JLT intake,
CHE upper & lower control arms & relocation brackets, Shelby watts link,
Dynotech driveshaft, BMR driveshaft loop, JLT oil separators, C&R heat exchanger,
Roush coolant tank, RPM (Van) 6 point roll bar, Magnaflow competition exhaust with
Tob modified Boss quad exhaust, Jon Lund tune, big ass smile!
644rwhp/557torque for now...
#2 OFFLINE
Posted 08 March 2013 - 12:55 PM
TIA!!!
TIA!!!
Uhhhhhh, I thought they were different Roll Bars!
Did you double check? I know MM has instructions and pics on their site, maybe that'd help (because they look like they might be the SAME item).
CURRENT MODS: FRPP: Whipple 2.9L Polished Superchager w/Crusher Inlet & Cobra Jet dual 65mm Throttle Body - Ceramic Coated Shorty Headers - Ford Blue Cam Covers - Polished Billet COP & Oil filler cap covers - FR3 Handling Pack w/Tokico Struts/Shocks & Eibach Swaybars - Jounce Bumpers - 8.8" Low Profile Axle Girdle - 3" Front Brake Cooling Ducts - Vacuum/Boost Gauge~ MGW:Short Throw Shifter~ PST: 1-piece Carbon Fiber Driveshaft~ Revan Racing: C&R Radiator and Intercooler~ ROUSH: 3x Intercooler degas bottle - Side Splitters - Extreme Off-road exhaust - Adjustable Trailing Arms (LCA) - Adjustable 3rd Link (UCA) - Adjustable 3rd Link Bracket - AC Vent Pod Vac/Boost Gauge Mount~ SHELBY: SC Aux. Idler pulley - Oil Dipstick handle, MC, PS & WS Washer reservoir caps - 8-qt. Oil Pan - Subframe K-member - Tubular Front A-arms - 6S Extreme Front Brakes - KR Style Front Brake Duct Bezels - Anti bump-stear tie-rod ends - Race Style Swaybar Links - Adjustable Caster/Camber Plates - Adjustable Panhard Bar - Panhard Bar/Body Brace - KR Rear Axle Reservoir - Eradispeed Rear Brake Rotors & Caliper Relocation Brackets - 18" GT500KR Alcoa Dura-Bright Wheels & Goodyear KR Winged Boot F1 Supercar tires~
#3 OFFLINE
Posted 08 March 2013 - 01:35 PM
Gotta hold of RPM finally, they're going to email me the template
#4 OFFLINE
Posted 09 March 2013 - 01:55 PM
It would be nice to see some pics if you get a chance to take a few during the install.
#5 OFFLINE
Posted 09 March 2013 - 04:57 PM
Sorry, 90% in, just gotta finish the door bars. If I had to do it again I would probably pay to have someone install it, only because I have a bad back. VERY HAPPY with it though!!!
#6 OFFLINE
Posted 09 March 2013 - 06:07 PM
Anyone have the template for a 2011 vert they could send me?
#7 OFFLINE
Posted 13 March 2013 - 06:12 AM
They are different. Remember my car is a convertible!
The RPM main hoop mounts to the floor behind the front seats, the MM main hoop mounts down through the top cap panels and to the B pillar.
The RPM rear legs mount about 2/3rds of the way up the wheel well (it is still rising above the mount point), the MM rear legs appear to mount near the top of the wheel well.
The RPM requires that you remove the convertible top pivot brace, the MM doesn't.
The RPM bar has 1/4 steel mounting pads and backing plates, don't know about the MMs.
The RPM bar has a non removable horizontal bar, the MM design doesn't allow it.
The RPM bar comes as a 5 point (6 point optional), the MM bar design doesn't allow door bars.
The RPM comes fully welded, the MM bar requires welding after installation.
I chose RPM after a lot of research of what was available for convertibles.
Forgot to add, the RPM roll bar is legal with most sanctioning bodies for racing.
Edited by bpodner, 13 March 2013 - 06:36 AM.
