Torque Specs for Alcoa 20's?
5 replies to this topic
#1 OFFLINE   frank bullitt
frank bullitt
  • 299 posts
  • Joined 28-February 09
  • Interests:Hockey, Health, Mustangs
Posted 09 April 2013 - 07:41 AM
Anyone know the torque specs for 20 Alcoa Wheels? I ran a search and found a comment on 18' KR Alcoa Wheels needing higher torque than what is normally called for. Not sure about Alcoa 20's though.
Frank Bullitt
#2 OFFLINE   2010KonaBlueGT
  • Banned
  • 7,766 posts
Posted 09 April 2013 - 09:19 AM
I assume you're asking about the lug nut torque....
The torque on a fastener is determined by the diameter of the threads and somewhat by the material you're bolting into, if into something other than a nut.
Unless you put a lager dia. stud on it, the torque should be the same regardless of what wheel you're using.
You should be able to find a chart on the Internet that tells you the max torque for each diameter of bolt/stud you have. I think I have one in my machinist tool box but we're in the middle of a blizzard right now so I won't be checking anytime soon!
#3 OFFLINE   aclass
aclass
  • 122 posts
  • Joined 18-May 12
Posted 09 April 2013 - 12:35 PM
Not sure of the official value, but I torque mine to 85ft/lb
#4 OFFLINE   MY500SS
  • 23,548 posts
Posted 09 April 2013 - 01:42 PM
Let me check my SS manual to see.....oh wait, we still don't have a manual do we. :hysterical2:
All kidding aside, I have my Alcoas torqued to 100 ft/lbs.
Edited by MY500SS, 09 April 2013 - 01:45 PM.
2007 GT500SS CSM 07SS0134.
2007 GT50040th CSM 07XL0273.
1965 Mustang Coupe K Code.
1964 289 FIA Cobra CSX 7076.
#5 OFFLINE   shelby001
  • 19,384 posts
Posted 09 April 2013 - 01:49 PM
I would think they are to Fords spec which is 100 ft/lbs as Dan stated.
When you are torque them put a drop of light oil on the bolt threads to obtain & accurate reading of 100 ft/lbs
#6 OFFLINE   glroy
glroy
  • 1,520 posts
  • Joined 05-February 08
  • Interests:Road trips
    car shows
Give them some time; we aren't even into the next generation of mustangs yet.
Vehicle
Last Updated Apr 09 2013 12:37 PM
Vehicle
1993 Mustang GT
Last Updated Apr 09 2013 12:36 PM
Vehicle
2013 Shelby GT500
Mods by
Mackenzie's Mustang Supply
It's worth the trip
  • Metco 2.80" Upper Pulley
  • MAC Custom axle back mufflers W/4"tips
  • Steeda Extreme Duty Billitt Lower Control Arms
  • Adjustable Upper Rear Control Arm
  • Maximum Motorsports Adjustable Pan Hard Bar
  • H&R Rear Lowering Springs
  • Painted Rear End
  • SPEC Twin SS Clutch and Flywheel
  • KR Axle Reservoir
  • Shelby/Baer Racing Black 6 Piston brakes, Slotted and Drilled 14" Front and 13" Rear Baer Rotors
  • Innovators West 10% Overdrive Balancer
  • Shelby Shifter Warranty; no more rattle in 2nd (having the first is not always the best)
  • Dynotech 1 Piece Driveshaft
  • Maximum Motorsports/Shelby Camber/Caster Plates W/ Spherical Bearing
  • H&R Front & Rear Sway Bars W/ Billet End Links
  • Tokico D-Spec 16 way Adjustable Shocks & Struts
  • Dynotech racing stainless long tube headers, X pipe, 200 cell high flow cats
  • Steeda lower control arm relocation brackets (welded)
  • JLT oil separator
  • hood struts
Mods by
ME
  • Steeda HE
  • JLT Carbon Fiber Intake and Mass Air Meter
  • Carbon Fiber KR Mirror Covers
  • Install and mod the Shelby dead pedal (it now stays in place)
  • GT500 sill plates and dash plaque
Mods by
others
  • Shelby interior upgrade
  • 373's
  • Detroit Truetrac
  • Build Date 02-22-07
