Help!
16 replies to this topic
#1 OFFLINE   Shelby N.Y.
Shelby N.Y.
  • 356 posts
  • Joined 09-January 08
Posted 27 September 2015 - 02:56 PM
Hello all, haven't been here for quite some time.Anyway here goes, I was driving the Gt/SC back from a car show today, and the check engine light started flashing, then I heard a very low drone noise for about 5 seconds, then the engine light came on steady. All gages read normal, no leakes, or smells, but the car does seem to have used an awful lot of fuel today. I am obviously taking it to the shop, just wonder if anyone had any thoughts on this?
20170628 201513
#2 OFFLINE   ViperNC
ViperNC
    Some say he roams around the woods at night foraging for wolves
  • 2,573 posts
  • Joined 23-December 11
  • Interests:Track days, Road course racing, Mountain bike riding/racing, motorcycle riding, cars, warbirds & chasing my kids
Posted 27 September 2015 - 03:26 PM
Hmmm.... Define "a lot of fuel today". How much more than normal? Any noticeable change in performance?
Edited by ViperNC, 27 September 2015 - 03:46 PM.
2009 Shelby GT500: 524.8 HP/549.9 Ft. Lb. Torque at the wheels on SuperFlow AutoDyn 880E AWD Chassis Dyno - https://www.youtube....h?v=f6lOjDH9eP0 True Forged Chicane Wheels w/ Michelin Pilot Super Sport Tires: 275/30/20 Front and 285/30/20 Rear - Shelby/Wilwood Front and Rear Racing Brakes - Shelby GT500 Brake Duct Bezels/Front Brake Duct Kit - Ford Racing Ceramic Coated Shorty Headers - Shelby Oil Separator - Shelby GT500 Engine Coil Covers - Metco 2.6 pulley/idler w/JLT Cold Air Kit and SCT Tune - Shelby Billet Aluminum Racing Oil Pan - Shelby Extreme Duty Heat Exchanger - McLeod RXT Performance Twin Disc Clutch - PST Carbon Fiber Drive Shaft - Ford Racing Low Profile Differential Cover w/ over flow tank - Flowmaster Exhaust - Shelby Racing Front and Rear Sway Bars - Shelby Bumpsteer Tie Rod Adjuster - Shelby Sway Bar End Links -  Shelby K-Member, Radiator Support, Chassis Support, A-Arms, A Arm Support Brace - Shelby Billet Aluminum Watts Link - Metco Billet Aluminum Rear Lower Control Arms - Ford Racing Springs - Shelby Six Speed Shifter Lever w/ Shelby GT500 Shift Knob - Shelby GT500 Engine Billet Aluminum Cap Set - Shelby Hood Lift Kit - Shelby Billet Aluminum Racing Pedal and Dead Pedal Covers - Carbon fiber upgrades: Front Splitter, Rocker Panels, Rear Mud Guards, Rear Diffuser, Side View Mirror Inserts, Hood Vents, Door Sills, Speaker Rings, Center Console, Mirror Switch Covers, Door Lock Bezels, Radiator Cover
#3 OFFLINE   Shelby N.Y.
Shelby N.Y.
  • 356 posts
Posted 27 September 2015 - 03:58 PM
Well I didn't get on it after it happened but it didn't seem to be down on power. It used a quarter of a tank in about 40-50 miles. That's WAY more than usual.
20170628 201513
#4 OFFLINE   Shelby N.Y.
Shelby N.Y.
  • 356 posts
Posted 27 September 2015 - 04:17 PM
20170628 201513
#5 OFFLINE   ViperNC
ViperNC
  • 2,573 posts
Posted 28 September 2015 - 04:25 AM
If you have a code reader, plug it in and see what code the computer is kicking out.  My guess is some type of fuel flow issue and maybe your fuel sending unit may have gone haywire.... But it is hard to say without the code.  Will be curious what the outcome is.
#6 OFFLINE   Doug_GT350
    aka... DICK!!!
  • PipPipPipPip
  • 16,056 posts
  • Interests:my grandchildren!
Posted 28 September 2015 - 08:45 AM
I'm curious myself..... beings how I have a GT/SC....
Whipple 10 Rib belt system, Lethal Ind. Poly motor mounts, Shelby Razors,
#7 OFFLINE   07-2937
07-2937
    Bill
  • 1,044 posts
  • Joined 21-February 08
  • Interests:Cars
Posted 29 September 2015 - 06:21 PM
so what is the issue??
Former SAI line Manager SGT,KR,50 SSnakes
07SGT2937, White, 5 speed,shkr1000, 2008 HID, GT500 Steering wheel
GT500 Brembo brakes, Metco uca, Whiteline subframe connectors/LCA's
CS hood,STR wheels/ 20"Razors,Gage pod, Secret stuff
http://s18.photobuck...ownhilbil/2937/
Gen 2 Whipple HO
Dyno tuned 512rwhp 471 trq @ 72degrees F @1524 feet alt
#8 OFFLINE   Shelby N.Y.
Shelby N.Y.
  • 356 posts
Posted 30 September 2015 - 12:26 PM
I don't have a code reader,she's going to the shop next Monday, I will let you all know what the problem is, and I too think it is some kind of fuel sensor I just hope it's not the pump.
20170628 201513
#9 OFFLINE   Shelby N.Y.
Shelby N.Y.
  • 356 posts
Posted 04 October 2015 - 10:57 PM
So, I borrowed a code reader from a friend and it turns out I get a misfire code for cylinders 4 and 7 which are paired. There is quite a few things that can cause this, so it's off to the shop sometime this coming week.
20170628 201513
#10 OFFLINE   CSSHELBYKID
CSSHELBYKID
  • 160 posts
  • Joined 12-May 12
  • Interests:Shelby's, cars, muscle cars, anything with cars.
Posted 07 October 2015 - 08:00 PM
I had a very similar problem with my SGT. Although mine is not a GT/SC, I had a very similar problem with a deeper, drone-like sound, but it was constant, and my code reader also said a mis-fire on cylinders 4 and 7. What my problem ended up being is that the variable-timing mechanism connected to the front of my cam became loose and bored out the slot that it slides in to on the cam. Fixed the problem buy putting in a new cam. Not too much of a big issue, but sure is a stressful one. This occurred back in 2012, and my SGT only had around 8k miles!
hope this helps a little :)
Best of luck with the fix.
CSSHELBYKID
Edited by CSSHELBYKID, 07 October 2015 - 08:01 PM.
2007 SHELBY GT-C
CSM 07SGT5186
(FIRST CAR!!)
"IF YOU AINT BREAKING STUFF, YOUR NOT DRIVING RIGHT" - CARROLL SHELBY
"IF YOUR IN CONTROL YOU'RE NOT DRIVING FAST ENOUGHT" - PARNELLI JONES
#11 OFFLINE   TheKurgan
TheKurgan
    Fast Member
  • 1,297 posts
  • Interests:Racing,Flyfishing,Kayaking
Posted 10 October 2015 - 03:19 AM
CSSHELBYKID
Interesting.  I've don't think I've heard of anyone else having that kind of issue.  I guess they must of not properly torqued the cam bolt.
Op do you have the BAP or GT500 fuel pumps ?  If you have the BAP, I would replace it with the GT500 pumps.  Could also maybe be the sending unit for the gauge.  Have you checked the mileage since you installed the SC ?  It does tend to go way down. :)
07 SGT - JDM302E, Paxton Novi 1500, Spec 3+, FRPP cams/intake/TB, Kooks, Tial 50mm BOV - 637 rwhp/547 rwtq - Tuned by VMP
#12 OFFLINE   Shelby N.Y.
Shelby N.Y.
  • 356 posts
Posted 30 September 2017 - 01:25 AM
Well, it has been 2 years now since this problem started with the Shelby, I have changed the plugs, battery, and tested all the coils, all working all correct. The car has been to Tasca and I thought they had solved the problem as it went away for several hundred miles but then it cam back, its the same code every time, multiple miss fire on cylinders 4 and 7.  The car is at a local ford specialist for the last two weeks , they tested the alternator, under load, its fine along with all the above items, going to change out the crank position sensor next because other 4.6 owners have stated similar problems to what i'm having and that's what solved it,frankly at this point no one has been able to figure out what is causing it. It does not seem to matter what temperature the car is at, or if i'm just cruising along or getting on the gas, it goes off at random times, and at this point its driving me crazy. I don't believe its anything mechanical nor does the mechanic as the car runs perfectly 95% of the time and the issue does not seem to be getting any worse, but it is extremely annoying. If anyone has any suggestions on what could be causing this I'm all ears.
20170628 201513
#13 OFFLINE   Shelby N.Y.
Shelby N.Y.
  • 356 posts
Posted 05 October 2017 - 06:40 PM
Picking up the Shelby tommorow, fingers crossed this fixes the problem.
20170628 201513
#14 OFFLINE   AndyGJ
AndyGJ
    SGT Owner
  • 1,124 posts
  • Joined 22-January 08
Posted 05 October 2017 - 07:03 PM
Good Luck!!!!
Present Mustang:
2008 Shelby GT Convertible #1676
Mods Installed:
BF Goodrich g-Force Sport COMP-2 Tires (275/40/R18 Front & Rear)
CDC Sequential Tail Lights
FRPP GT500KR Axleback Mufflers
FRPP GT500KR 18" Rims
FRPP GT500 BREMBO Brake Upgrade (M2300-S)
FRPP 62mm Throttle Body
FRPP Intake Manifold
FRPP Stainless Steel Brakelines
Hawk HPS Brake Pads (front & rear)
JBA Tuned Length Ceramic Shorty Headers
LD's Performance Custom Tuning (91 & 93 Octane) w/SCT-X3 Tuner
Redline Hood Struts (w/update kit)
Royal Purple Synthetic Oil 5w20
Royal Purple Differential Gear Lub
Royal Purple Manual Transmission Fluid
Motul 600 Hi Temp Brake Fluid
Shelby Lower Radiator Grill Insert - Black
Shelby 4.6L Valve Covers
Shelby GT Berg Snake Faux Gas Cap
Shelby GT Berg Snake Front Floor Mats & Trunk Mat
Shelby Plain Rear Seat Floor Mats
Shelby Billet Engine Cap Set
Shelby Billet Fusebox Cover
Shelby Transmission Cooler Scoop
Shelby Front Brake Duct Cooling Kit
Shelby Fays2 Watts Link
Performance Brake Slotted & Cross Drilled Rotors (front & rear)
Steeda Aluminum 1-Piece Driveshaft
Steeda CAI Intake Elbow w/Black Tube
Steeda Motor Mounts (red inserts)
Steeda Under Drive Pulley
Prior Mustangs:
1968 Mustang Coupe - Midnight Blue
1966 Mustang Convertible 289v2 - Red w/black top & interior (still in the family)
1973 Mustang Convertible 351W - Poppy Red w/black top & interior - MCA Senior Division Grand National Retired Winner
1989 Mustang Hatchback 5.0 w/5spd - 25th Anniversary - Red w/red & black interior
#15 OFFLINE   Shelby N.Y.
Shelby N.Y.
  • 356 posts
Posted 09 October 2017 - 07:34 PM
and....no go, after about 100 miles the engine code came back again. The crazy thing is it keeps giving the misfire code but almost every time now it comes up with a different cylinder number, so far 4, 7, 5, 2 . So I am not sure what to try next , was going to call ford performance and see if anyone there had an idea, i'm completely stumped.
20170628 201513
#16 OFFLINE   mfield2a
mfield2a
  • 64 posts
  • Joined 14-August 09
Posted 09 October 2017 - 07:47 PM
I assume it acted up when the code came up? I would take it back to the same shop, tell them you read one other instance where it was a cam related issue. If that's the case sounds like a perfectly legit reason for hot rod cams. I'm surprised to read that Tasca could not figure it out.
No Shelby in the barn yet, just a 0F02G, 979A, "W" Code, Z paint
#17 OFFLINE   Shelby N.Y.
Shelby N.Y.
  • 356 posts
Posted 11 October 2017 - 10:33 PM
I am bringing back to the shop on Monday,I am not sure how much Tasca really did to look for the problem, all they told me is they couldn't get it to come back while they had it, I thought the new plugs had solved the problem but it came back after about 300 miles. I had shown the local shop the post about the cam issue, they don't seem to think it's that but I will bring it up again.
Edited by Shelby N.Y., 11 October 2017 - 10:34 PM.
20170628 201513
