Team Shelby: REVAN RACING HEAT EXCHANGER INSTALLATION - Team Shelby
Discussion Forum For This Event
Genuine Shelby Parts For Your Shelby
Brakes | Clutch | Engine | Exterior | Exhaust | Interior | Shifters | Sound System | Suspension | Wheels
702.405.3500
  • (4 Pages) +
  • 1
  • 2
  • 3
  • Last »
REVAN RACING HEAT EXCHANGER INSTALLATION With PIC's and descriptions
#1 User is offline   Revan Racing
  • Apex before NASCAR Turn 1 Daytona
  • Group: Authorized Advertiser
  • Interests:Road Racing
  • State or Province:FL
Post icon  Posted 29 March 2009 - 05:45 PM
This is going to take some time so stay with me as I load this stuff up.
Image One
The Heat Exchanger is HUGE!!!!!!!!! LOL
Image Two
Remove the Radiator Cover
Image Three
Remove 5 front inner fender well phillips head screws
Image Four
Remove Lower Air Dam and Belly Pan
Image Five
Remove inner fender well plastic phillips head release rivets. After inner fender well is removed disconnect all lighting connections
Image Six
More Phillips Rivets in fender well
Image Seven
Belly Pan 7/32 screws
Image Eight
Belly pan and front splitter removed
Image Nine
Remove upper bumper mounting screws
Missing Image
On each side after you remove the inner fender well there are two 10 MM screws that hold the bumper in place. Remove both on each side of the inner fender well. Lightly pull down and then lift and pull the front bumper clip off. It's amazing how easily this thing actually comes off.
Image Ten
Remove clamp at bottom of heat exchanger and loosen supercharger reservoir cap and place bucket underneath to capture fluid
Image Eleven
Disconnect electrical connection to water pump
Image Twelve
Disconnect inlet from Supercharger Reservoir to water pump
Missing Images. Remove water pump from current heat exchanger and install onto back of new C&R Heat Exchanger with 5 washers on each stud to space up the heat exchanger. Included in kit is new hose with 90 degree bend, the shorter one. Install onto water pump and connect to dual pass inlet on back of heat exchanger. Cut hose to fit and use provided stainless steel hose clamps to mount.
Image Thirteen
Remove Stock Bumper Bolts for replacement with new provided Bolts in kit for hanging Heat Exchanger
Image Fourteen
Install Heat Exchanger with new bolts and NYLOC nuts to hold in place. Take your time, this can be time consuming.
Image Fifteen
Heat Exchanger is hanging and in place. Tighten NYLOC hex nuts into place.
Image Sixteen
Time for COLD BEER
Image Seventeen
Wiring Harnesses and Relays. One relay is missing form the picture. Eddie G isn't the best photographer. LOL
Image Eighteen
Drill Holes for Relay Mounts and and grounding. You can find separate relay mounts of your choosing as well as grounding locations without drilling. Eddie G consider's his car that much closer to race ready for the road course so he doesn't really care about the holes. There are plenty of locations to pick up mounting locations and grounding locations.
Image Nineteen
First Relay is haning. Next relay will be located directly next to it. Then let the wiring begin.
Continue to Next Page..........My wife is starting to look at me like what the ..........are you doing over there? LOL
Attached File(s)
2007 Shelby GT500 Alloy Metallic # 357 NASA Time Trial Unlimited Competition Vehicle
WWW.REVANRACING.COM
2007 Shelby GT500 Alloy Metallic Coupe
Purchased October 30, 2006
Shelby Registry Documented as GT500 cooling system development car
Modifications:
Revan Racing/Shelby Original Prototype Radiator, Revan Racing/Shelby Original Prototype Heat Exchanger, Revan Racing/Shelby Reservoir Kit
Griggs Racing Products GR40 ST Suspension with Watts Link and Full Front SLA, Dynotech 1-Piece Aluminum Drive Shaft, dba Slotted Rotors, Hawk DTC 70 Race Pads, Brembo LCF 600 Plus Brake Fluid, Forgeline ZX3R's Matte Black with Titanium Fasteners and Hoosier R6 315's on all 4 corners
Kenne Bell 3.6LC Polished Competition Supercharger with 3.75 Upper, Kenne Bell Competition Boost-A-Pump, 2008 Lower Pulley, HPX MAF Sensor, Jon Lund Tuned and Calibrated (at least 100 times), Borla XR-1 Racing Long Tube Headers, Catless X-Pipe, Borla XR-1 Mufflers, Ford Racing Sparco Race Seat, Shelby Shifter, Silver Horse Racing Side Window Louvers, Agent 47 Retro Mirrors, Proglass Retro Ram Air Hood with Run Cool Hood Louvers, Agent 47 Brake Ducts, Schroth Racing harnesses, AEM Wide Band
Stock Motor Died on track at Daytona International Speedway December 2009 at 190+ MPH
New Motor Born February 2010
Custom Diamond/L&M Race Pistons 9.5:1 Compression, Oliver Rods with ARP 2000 Rod Bolts, Manley Titanium Valve Spring Retainers, Ferrea Super Alloy Exhaust and Intake Valves, AP Rings, Speed Pro Main and Rod Bearings, Ford GT Cams, Canton Road Race Oil Pan, Complete ARP 2000 Bolts throughout
Sponsored by: L&M Engines, www.lmengines.com C&R Racing, www.crracing.com Kenne Bell Superchargers, www.kennebell.net Lund Racing, www.lundracing.com SPEC Clutches, www.specclutch.com Griggs Racing www.griggsracing.com & Borla Racing Exhaust Systems www.borla.com
#2 User is offline   Revan Racing
Posted 29 March 2009 - 06:03 PM
Image Twenty
After wiring (see wiring diagram) in next post. Take provided in line fuses which are provided closed loop cut to need. Crimp round eyelet connector to both in line fuses and attach at fuse box location
Image Twenty One
Inline Fuses and Relay Triggers
Image Twenty Two
Fuse Position 47. We are doing an installation with the Add-A-Fuse product. A lot of you wanted to see it this way versus a crimp connector.
Image Twenty Three
Add-A-Fuse from Advance Auto Parts
Image Twenty Four
Twist the two wires from the relay (triggers) and crimp into place with the aforementioned Add-A-Fuse but splice.
Image Twenty Five
Image is not very good. Installed the 15 AMP mini fuse that was removed from Position 47 and installed 10 AMP mini fuse for Relay Trigger. This will trigger the relays and fans at Ignition or Key On.
Image Twenty Six
Add A Fuse installed.
Installation complete. Reverse installation and re-install bumper clip etc.
Attached File(s)
WWW.REVANRACING.COM
Modifications:
#3 User is offline   Revan Racing
Posted 29 March 2009 - 06:07 PM
Wiring Diagram. I know it's not exactly great but it's basic. I am having it drawn into CAD.
Attached File(s)
WWW.REVANRACING.COM
Modifications:
#4 User is offline   Revan Racing
Posted 29 March 2009 - 06:09 PM
Heat Exchanger Install Instructions as provided in Heat Exchanger Kit
Attached File(s)
WWW.REVANRACING.COM
Modifications:
#5 User is offline   LEESTOYSTANG
  • Team Shelby Member
  • State or Province:fl
Posted 29 March 2009 - 06:31 PM
Great write up and pics Van and Ed...
2008 GT500 RED/WHITE
I got a few mods.....
BAD ASS BOYS DRIVE BAD ASS TOYS
#6 User is offline   enormous
  • Team Shelby New Member
  • State or Province:On
Posted 29 March 2009 - 06:33 PM
Thanks Van, I have read everything twice. Now, I will probably be doing this in my dreams tonight :dreamy: :blink:
#7 User is offline   Revan Racing
Posted 29 March 2009 - 06:34 PM
Very Soon Norm. Very Soon.
WWW.REVANRACING.COM
Modifications:
#8 User is offline   srk1959
  • Interests:My 07 Shelby GT500's, 600 cubic inch Hemi Mopars,Dirt Bikes and ATV's, and finally working alot to afford these hobbies.
  • State or Province:wi
Posted 29 March 2009 - 06:35 PM
Yes, Thanks for taking the time with the pic's, it's always easier to see it along with having the drawings and instructions. I can't wait to get my Revan Racing stuff installed.......all of it!
This post has been edited by srk1959: 29 March 2009 - 06:36 PM
http://thedynoworks.com/index.html
2007 GT500 Convertible Ebony/White side stripe, L & M throttle body & plenum, C & L c.a.i.,
Driveshaft loop,2.6" upper,10% I.W. lower, Evolution tune,Shelby brake ducts, 11.41@124.24
2007 GT500 Coupe Torch Red/White Stripes,3.73's, Steeda rear U.C.A. and L.C.A.'s
Revan Racing H/E, coolant tank, intercooler tank, Techo watts link, Sequential rear signals,Dynotech driveshaft,BMR loop,Granatelli line lock,Tokico D spec shocks, AR headers, off road H-pipe, 08 Bullitt Mufflers, 3 point Torque box brace, Billet motor mounts, Whipple 2.9, 2.85" upper, Evo Fuel Rails, L & M tb, Ford GT pumps, 72# Injectors,10% I.W. Lower, Delta Force Tuning software and adjustments made by Black Shelby.
[/color]Evo stage 4 Tvs 10.788@132.99 http://www.midwestmu...s-gregs-cobra-/
I need slicks for next year!
http://www.midwestmu...-gt500-take-ii/
#9 User is offline   Revan Racing
Posted 29 March 2009 - 07:12 PM
And you've got PLENTY!!! LOL Thanks SRK
WWW.REVANRACING.COM
Modifications:
#10 User is offline   BEEKAY GT500
Posted 30 March 2009 - 08:35 AM
Image One
Image Two
Image Three
Image Four
Image Five
Image Six
Image Seven
Image Eight
Image Nine
Missing Image
Image Ten
Image Eleven
Image Twelve
Image Thirteen
Image Fourteen
Image Fifteen
Image Sixteen
Time for COLD BEER
Image Seventeen
Image Eighteen
Image Nineteen
this will really help out. good job putting it together. a few things i would add.
1. when putlling off the foam piece behind the bumper cover make sure you note the orientation. there is a top and bottom and it will go on both ways but you wnt be able to get the bumper cover back on. i have read about more than a few guys putting it on the wrong way and spending time trying to figure this out.
2. there are two pieces of plastic guides (one for each side at the bottom of the h/e) that will be left over from the stock he. i spent some time trying to figure out where these came from since i didnt take pictures along the way. because the revan racing/c&r he is taller these guides are no longer used. i cant remember if these even need to come off but i took them off and wasted time trying to figure it out.
3. make sure you mock up the wiring a few times to make sure. i didnt cut until everything was wired through the location i wanted to follow.
Engine
FRPP TVS 2.3L Super Charger (M-6066-SGT)
L&M 66mm TB
L&M Inlet Elbow
2.6" Stock look Pulley
FRPP 113mm Cold Air Kit (M-9603-SVT07)
Steeda Belt Tensioner (555-3343)
2008 GT500 Harmonic Balancer (M-6312-SVT)
Jon Lund Tune
Cooling
Revan Racing-C&R Dual Pass/Dual Puller Fan Heat Exchanger
Drivetrain
FRPP Shifter (M-7210-B)
FRPP White Shift Knob and Handle (M-7213-K)
Dynotech 3.5" Aluminum 1-Piece Driveshaft
BMR Front Driveshaft Safety Loop (DSL-010)
Exhaust
Corsa Axle-Backs (14311)
Styling
American Muscle Shorty Antenna (99007)
Steeda Billet Hood Struts (555-0651)
Ford Mustang All Weather Floor Mats (6R3Z-6313300-A)
Suspension
FRPP Strut Brace (M-20201-C)
FRPP Dampers (M-18000-C)
FRPP Springs (M-5300-L)
Steeda Heavy Duty Upper Strut Mounts (555-8120)
FRPP Anti-Roll Bars (M-5490-B)
Steeda Adjustable Street Upper Control Arm (555-4105)
Steeda Rear Lower Control Arms (555-4405-F)
BMR LCA Relocation Brackets (CAB005)
Steeda Adjustable Street Panhard Bar (555-2551)
Steeda Heavy Duty Panhard Bar Brace (555-2555)
Wheels
Stock GT500 Wheels F:18x9.5 & R:18x11.0
Tires
F:Goodyear F1 Supercar 285.40.18 & R:Toyo Proxes TQ 315.35.18 Drag Radials
Dyno
Stock = 445 rwhp & 457 rwtq (SAE)
Stage 1 = 505 rwhp & 490 rwtq (SAE)
TVS 2.3L Stage 2 = 615 rwhp & 632 rwtq (SAE)
TVS 2.3L Stage 3 = To Come
TVS 2.3L Dyno Comparison Thread
#11 User is offline   gr8snkbite
Posted 30 March 2009 - 09:05 AM
nice write up Van...... :hysterical:
guess you need a book now...techy posting for dumbies...... :hysterical:
do like the new orientation for fan wires though..... :doh:
#7 of xxxx Kona Blue Vert / SD / SVT
www-store-bvmperformance-com
#12 User is offline   Eddie G
  • Interests:Medicine, Reading, My GT 500
Posted 30 March 2009 - 03:23 PM
Hey guys...
There are a couple of more pics I'm going to add, this is just pretty stuff . I took wire loom , and covered all the wires coming right into the fuse box. Unfortunately , it will be a few days since my baby is a getting a new tranny as per the phone call from my mechanic today.
Ed
#13 User is offline   LEESTOYSTANG
Posted 30 March 2009 - 04:06 PM
View PostEddie G, on Mar 30 2009, 07:23 PM, said:
Hey guys...
Ed
Ed,
Glad to hear they're going to take care of it .... Did they give you any problems about the KB ??
This post has been edited by LEESTOYSTANG: 30 March 2009 - 04:06 PM
#14 User is offline   Revan Racing
Posted 31 March 2009 - 03:45 AM
BK
The lower fins you speak about can be installed. Unfortunately every install I have done we didn't have them because they were not in place. (replacing a Steeda or an AFCO). It can be difficult but what I did was use the flange clip and slid the clip in between the bumper plastic and the lip of the lower grill. Next time I take my lower belly pan off or do an install where the fins are still in place I will show how I installed them.
VC
WWW.REVANRACING.COM
Modifications:
#15 User is offline   BEEKAY GT500
Posted 31 March 2009 - 07:51 AM
View Postdactyl, on Mar 31 2009, 04:45 AM, said:
BK
VC
van, thanks for clarifying. i should have taken more detailed pictures during the install. i thought a portion of the fin went below the he thus not allowing it to fit due to the extended height. i'll have to see how it looks once you have it on.
Engine
L&M 66mm TB
L&M Inlet Elbow
Jon Lund Tune
Cooling
Drivetrain
Exhaust
Styling
Suspension
Wheels
Tires
Dyno
#16 User is offline   Revan Racing
Posted 31 March 2009 - 03:18 PM
Or the next time I do an install!
WWW.REVANRACING.COM
Modifications:
#17 User is offline   Secondo
  • Living one of my dreams: Owning and enjoying a Shelby!
  • State or Province:CT
Posted 31 March 2009 - 03:32 PM
Van if I may add to this:
Per Van each fan uses about 7 amps at start-up and run at 6 amps. The relays I'm assuming are 30 amp rated because they each come with a 30 amp fuse and the wires are 10-gauge. It is possible to use only one relay if I am correct. You'll have to solder each fan's red wire to the power wire coming from the relay. Use heat shrink tubing on the connection.
Also, for those who don't want to splice into the car's wiring harness or run the add-a-circuit through your fuse box, you can connect the trigger wire (the orange wire from the relay(s)) directly to the terminal with the white w/red stripe wire that goes to the heat exchanger control relay that is bolted to the passenger-side shock tower next to the fuse box.
This is what I have done on my car and it works great.
This post has been edited by secondo: 31 March 2009 - 03:50 PM
#18 User is offline   Revan Racing
Posted 31 March 2009 - 04:14 PM
The fans are low profile and you should use 15 AMP Blade fuses and not the 30 AMP fuses provided. If you look at the wiring diagram that I sent it says that at the top. No big deal, just switch them out when you get a chance.
You can run one 30 AMP in line fuse if you so choose however it is not recommended. Also, since there is so little draw by the fans if something were to fail in one fan or relay that might trigger a fuse to blow tracking the problem might be more difficult and you could potentially damage something else because of the high ampacity of the 30 AMP blade fuse.
I strongly recommend that you use both in line fuses as provided in the kits along with 15 amp blade fuses.
I have also connected to the trigger underneath the fuse box with a solder connection and it works nicely. My car is so track prepared though I need to be able to get at connections quickly so I try to make it easy on myself for that purpose. Good suggestion.
VC
WWW.REVANRACING.COM
Modifications:
#19 User is offline   Secondo
Posted 31 March 2009 - 06:54 PM
Thanks Van, I have the 15 amp fuse but forgot to swap it for the 30 in all my excitement of finishing the install!! :happy feet:
#20 User is offline   magilla12
  • State or Province:OK
Posted 18 December 2009 - 06:13 AM
bump for later, thanks good info.
2006 Mustang GT Screaming Yellow
K&N CAI
2009 Ford F150 Blue flame metalic
2010 Shelby GT500 Torch Red W/White Stripes
Evo Stage Zero Kit
JLT Carbon Fiber intake tube
Redline Tuning Hood lifters
C&R Heat Exchanger W/fans
  • (4 Pages) +
  • 1
  • 2
  • 3
  • Last »
2 User(s) are reading this topic
1 members, 1 guests, 0 anonymous users
  1. FormerGmc
