Of course the car has the rare 2.2L 16V Turbo III engine with the Lotus designed 16V head. I’ve owned the car for almost 10 years in which time i’ve put hours upon hours of work and $1000s into. There’s 102,417 miles on the odometer with a little over 5000 miles since the complete engine build-up in 2002. The car has not seen a winter since 1998. The car is located in LaSalle, Ontario (just across the river from Detroit, Mi) and was originally a US spec vehicle that I imported to Canada back in 1998. For any US buyer who is interested I also have both forms (EPA #3520-1 and NHTSA #HS-7) required for importation back to the US ready and waiting so there will be no issue importing as it has all EPA/NHTSA(DOT) labels on the car.
The price is $8700 Firm.
Exterior: The car was completely stripped and re-painted base-clear in 2004. OEM decals and emblems were re-installed. The rims were re-finished also and hand polished. Aside from some few nicks and scratches the car is in excellent condition with no rust.
Here’s a list of the performance goodies in the car that helped it dyno 320whp in August of 2007 on only 15psi of boost. With the right 3-bar calibration this engine will easily make 400whp and handle it.
T3 Engine Completely Rebuilt in 2002 (5000miles since)
2.2L Common Block Bored to +0.020"
Forged Venolia Pistons (+0.050mm) w/ Larger 0.912 wrist pins
New main bearings, rod bearings, and rod bolts installed
New oil pump installed
Full set of new lifters from FWD performance
New valve seals
Turbonetics T3/T4 50 Trim Hybrid Turbo w/ 0.63A/R & Stage III Turbine Wheel
ATP Turbo 3" Swing Valve (V-Band)
ATP Turbo 3" Downpipe w/ Dual O2 Bungs for Wideband O2
CATCO 3" High Flow catalytic converter (E-tests req'd in Ontario)
Turbos Unleashed 3" CAT-Back Exhaust with No Muffler
SRT-4 FMIC w/ Custom 2.5" Inlet
2.5" aluminum mandrel bent IC plumbing
1G DSM 1" Blow Off Valve
3" CAI tube w/ Cone Filter
Magnecor 8.5mm Race Wires
+20% 42lb/hr Injectors
Accufab Adjustable Fuel Pressure Regulator
Custom 15psi calibration w/ No Overboost & 7000 RPM rev limit
Custom made alcohol injection kit (uses same hardware as "Devil's Own" alcohol kit at 1/2 the price)
Koni Adjustable Shocks on the rear
Front Strut Tower Brace
Stock A568 transmission with urethane "booger" shifter bushings
Tires are Dunlop Sport SP5000 in very good shape
Interior: Modification include 30psi boost gauge and electric fuel pressure gauge in a-pillar pod and a 3-bar racing air-fuel meter. There is also a control panel for the alcohol injection kit in the center console and a lebaron traveler unit. A Chrysler remote keyless entry system is installed as well (From a Chrysler B-Van).
Couple minor issues with the car include the ABS light is on due to a problem with the pump (per DRB-II). Also the A/C was converted over to R134A a couple years ago but could probably use a charge (I don’t use A/C). There is also one small dent on the drivers front fender from leaning over the car one day... this may be fixed in the next few days. Other than that the car is in great shape for 16 years old as you can see in the pics. If there are any other specific pics you would like please let me know and I’ll take more.
Please PM me, email me at agvs24@cogeco.ca or call me before 10pm at 519-818-8740.
Thanks for looking. Chris
