Team Shelby: TVS 2.3L Complied Dyno Results - Team Shelby
Shelby Racing Extras
Time Slip Central:
Add your Racing Results, Dyno Graphs, Time Slips and more here.
Shelby Garage:
Add your vehicle and list your modifications here.
  • (3 Pages) +
  • 1
  • 2
  • 3
TVS 2.3L Complied Dyno Results Comparitive results for those conisdering this blower upgrade
#1 User is offline   BEEKAY GT500
Posted 10 July 2008 - 08:26 PM
Thanks to srk1959 (steve) and idrathergolf (dana) for providing dyno sheets/run files from their tvs 2.3L dyno's. i have other tvs files that i want to add but i need to find out if the owners are fine with it. if you want yours added in please send me an SAE run file or dyno sheet. run file is prefered since it is more accurate.
Attached File  TVS_Comp_09.30.09.pdf (95.04K)
Attached File  TVS_Comp_06.09.09.pdf (170.42K)
Attached File  TVS_Comp_03.27.09.pdf (124.69K)
Attached File  TVS_Comp.pdf (97.62K)
This post has been edited by BEEKAY GT500: 30 September 2009 - 01:47 PM
#2 User is offline   srk1959
  • Interests:My 07 Shelby GT500's, 600 cubic inch Hemi Mopars,Dirt Bikes and ATV's, and finally working alot to afford these hobbies.
  • State or Province:wi
Posted 11 July 2008 - 03:10 AM
Attachment TVS_Comp2.pdf
Great job Brad, Hope others will join in with their sae results for the Tvs dyno runs. Runfiles are the nicest since you can see with a little more accuracy. That should help people to decide how much money they want to spend for how much hp! The more we have the more accurate it should become.
I will send any additional dyno runs to be added or updated.
#3 User is offline   idrathergolf
  • State or Province:ca
Posted 11 July 2008 - 05:48 AM
Thanks Brad for helping me out with this. I'll see if I can get my run file from Daniel. If not, I'll get on his dyno for another pull and this time run more than just one to get several reads. Now that I found a place in Sunol to get clean racing gas I'm interested to see if the A/F mixture stays at 11.5. The dyno results I gave you only had octane boost.
As Steve stated, hopefully we can get more run files of those who have installed the TVS.
#4 User is offline   ColdwaterHotrod
  • Team Shelby Member #6 is BACK!
  • View blog
  • State or Province:MI
Posted 11 July 2008 - 05:54 AM
What size upper pulley?
What size lower pulley?
Stock Drive shaft?
Stock Tires?
Rear gear?
What CAI?
What mufflers?
What temp, elevation, humidity?
the more info the better
#5 User is offline   srk1959
Posted 11 July 2008 - 05:59 AM
Stock Drive shaft?
Stock Tires?
Rear gear?
What CAI?
What mufflers?
Agreed, It's up to Brad how much info he wants to track? I will be more than happy to supply any info with no B/S.
#6 User is offline   Justin00Stang
  • Group: Authorized Advertiser
  • State or Province:FL
Posted 14 July 2008 - 07:23 AM
Here is my data:
http://vmptuning.com...TVSshorties.jpg
TVS with 2.65" upper and 10% od lower, vmp 66mm TB, frpp shorties, no cats, stock gears, stock driveshaft, 115mm vmp maf housing, store tires, 80ft above sea level with condition data printed on my dynograph
#7 User is offline   GT500Tow
Posted 14 July 2008 - 07:51 AM
WOW Justin, that's what i call spanking that A$$$$$$..... :drool:
#8 User is offline   OrthoDude
Posted 14 July 2008 - 08:47 AM
Now that's the combination I want! :drool:
#9 User is offline   srk1959
Posted 14 July 2008 - 09:12 AM
View PostJustin00Stang, on Jul 14 2008, 09:23 AM, said:
Here is my data:
Very nice! Thanks Justin for adding to Brads list. Are you considering trying any pulley work? I am waiting for some others to record results with my combo. Also did you install the larger injectors that you were thinking of 60#'s if I remember right?
This post has been edited by srk1959: 14 July 2008 - 09:16 AM
#10 User is offline   srk1959
Posted 14 July 2008 - 09:54 AM
One more question, I'm not asking to give up tuner secrets is map 1 the amount of spark advance? Your dyno sheets are a little different than the dynojet sheets I have. Also what is WB 2 =8.47 WB 2=13.55?
Sorry for the questions just trying to be able to understand the info. As you well know your numbers beat mine and that was with a 2.2, 2.4,and the 2.6 pulley's and I have long tubes. My a/f on my last was min 11.75 and max 12.13 and 684.5 sae was the best it got. I am running more spark advance than you if I am right about map 1?
I am concerned that maybe my dyno operators may be a factor, I sure don't want to be posting on the boards that 680's is topped out sae hp with all different pulley sizes if there is another 20 to 50 hp left in it. Because another 30 to 40 hp and you are in most KB owners sae corrected even if they are using the 10% lower? I have used the 2 different Dynojets in my area to try and confirm the data and both came up pretty darn close to the same. Both times on the last 2 dyno's we made sure intercooler fluid was cool and also allowed the engine to cool for approx 1/2 hour.
Anything I should be watching for or doing at the dyno?
Thanks Much
#11 User is offline   BEEKAY GT500
Posted 15 July 2008 - 10:43 AM
hi dana, no problem. if you go back let me know i'll see if i can make it this time.
Stock Drive shaft?
Stock Tires?
Rear gear?
What CAI?
What mufflers?
agreed, more information is desired here as well.
thanks for the latest feedback.
View PostJustin00Stang, on Jul 14 2008, 08:23 AM, said:
Here is my data:
thanks. you have top dog status now.
#12 User is offline   BEEKAY GT500
Posted 15 July 2008 - 10:44 AM
the first post will have the updated numbers.
#13 User is offline   srk1959
Posted 15 July 2008 - 01:58 PM
Very nice Brad, great job! :happy feet:
Now we just need to get you on the board soon! :yup:
#14 User is offline   Justin00Stang
Posted 18 July 2008 - 05:55 AM
Thanks Much
Hi, MAP=boost pressure. WB 2 = air/fuel ratio through a different channel on the dynojet, it was only used on one of the runs, and just defaulted to 8.xx on the other run where it was not used (channel air/fuel was used instead).
I will say that my runs were done in very ideal conditions with stock gears. There were times that the car would make less if poorer conditions.
I will be playing with some pulleys and other TVS mods in the future.
#15 User is offline   srk1959
Posted 19 July 2008 - 01:28 PM
Thanks Justin. Can't wait to see what you do with the Tvs for future mods!
#16 User is offline   cloud9
Posted 27 July 2008 - 09:54 AM
More TVS dyno numbers! We hit 649 rwhp and 609 rwtq with an 11.8 a/f across the board. This is on 91 pump gas! :happy feet: I wanted a safe tune that I can run on the road course for sustained time and speeds. I was hoping to top 640 rwhp on 91 octane so I am happy with this! :happy feet:
#17 User is offline   srk1959
Posted 27 July 2008 - 06:56 PM
Very nice Gary! Thanks for posting it.
Still thinking of going to Elkhart Lake? Should be interesting on the track with that HP!
As I posted in another thread, I was following a Z06 through a very smooth,very twisty road here. It was kind of spooky on stock tires because I would accelerate out of the curve and the back end would start to get loose. I need better tires....soon!
Be sure to pm me when and if you are for sure going and I will make it up there!
#18 User is offline   idrathergolf
Posted 27 July 2008 - 08:26 PM
Keep it safe. We all want to keep you and that hot car you have in one piece. I hope you were just messing around in a area where there was no traffic or trees.
By the way, were you able to keep up with Z06? With our cars it is hard to do unless you have a full Griggs racing system in the car ($12,000).
#19 User is offline   cloud9
Posted 28 July 2008 - 07:55 AM
Still planning to go the weekend after Labor Day! I'm all registered, paid and have hotel reservations. Just need to make some brake upgrades and I'll be set. It would be cool to see you! I'll PM with more info as we get closer. Yea, my biggest concern is still getting squirrelly accelerating out of those corners! Need race tires next year....wife's cut me off for the rest of this season after the brakes. :cry: Still debating on whether to run the Falken's up front and F1s in the rear or match them up. I'll bring both sets with me.
#20 User is offline   srk1959
Posted 28 July 2008 - 08:02 AM
Very safe, no traffic and just a fun run. The guy in the Z06 seemed pretty decent. He would pull me in the corners some and as soon as a straight came up I could catch right up. It wasn't a hard core race or anything and I don't think he was any kind of Pro driver either.
I saw him come up behind me and when I stopped at a stop sign he pulled up alongside me. He says nice 500 I know a stretch of rode thats pretty fun. I said I would follow him. Nice road, plenty of visibility. I am sure that a good driver in a Z06 could blow me away in the corners but we were keeping it at a comfortable level.
I have to say I would not want to push my coupe any harder without upgrades, the power is very hard to handle with my current setup as far as cornering goes. I would exit nice and easy but it was very hard to control when the boost would hit. So I played it as safe as I could and still make it fun.
I finally had an encounter with a Z06 so now my son can stop bugging me....I hope? Next time I give it a try will be at the drag strip with better tires on.
The road racing thing the way mine is currently setup is too spooky for me.
  • (3 Pages) +
  • 1
  • 2
  • 3
