Was hoping to verify the stock GT500 spring rates, I have been told the fronts were in the 350lb range, which just seems too soft to me.
Was hoping someone could verify both front and rear rates as they come from the factory.
Thanks in advance,
Regards,
Philip
Stock GT500 Spring Rates Anyone know what rates come from Factory
Posted 25 August 2008 - 07:05 PM
Spring Rates For Coupes it's
Front - 34.1 N/mm per inch
Rear - 29.2 N/mm per inch
Coupe Sway Bars are
Front - 34mm x 5.8 mm tubular
Rear - 24mm Solid
Spring Rates For convertibles it's
Front - 31.0 N/mm per inch
Rear - 23.0 N/mm per inch
Convertible Sway Bars are
Front - 34mm x 5.1 mm tubular
Rear - 20mm Solid
Coupe Sway Bars are
Rear - 24mm Solid
Rear - 20mm Solid
This post has been edited by ColdwaterHotrod: 25 August 2008 - 07:06 PM
Posted 27 August 2008 - 11:08 AM
Coldwater,
Finally Found the conversion for N/mm to Lbs per inch,
For the Coupe that Works out to:
200lb / inch front
166 lb / inch rear
Thanks a ton for the help!k
Regards,
FP
200lb / inch front
166 lb / inch rear
Regards,
FP
Posted 27 August 2008 - 12:09 PM
Sorry I wasn't able to answer your PM very quickly, I got distracted & forgot about looking that up for ya, glad you got that figured out.
